Z-Wave.me KEYFOB (ZME_KFOB_S): Cannot change wakeup interval
jacques
Post by jacques »
I recently successfully included a ZME_KFOB_S in my network.
But it seems that I cannot change the wake-up period which is stuck at 240 seconds even after setting a new value (e.g. 604560)
After issuing a set command for the wake-up period, I can check that the value stored in the device is correct, but it has no effect : the z-way-server log shows that a "Wakeup notification" is regularly received every 4 minutes.
I tried multiple exclusion/inclusion, even changed the battery, but it was useless.
Any idea or advice ?
Thanks.
[2015-03-06 16:12:15.123] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:12:15.124] [D] [zway] SENT ACK
[2015-03-06 16:12:15.125] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:12:15.125] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:12:15.125] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425654735 (0x54f9c3cf)
[2015-03-06 16:12:15.126] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:12:15.126] [D] [zway] SETDATA devices.9.data.lastSend = 2289300 (0x0022ee94)
[2015-03-06 16:12:15.127] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2288300 (0x0022eaac)
[2015-03-06 16:12:15.127] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:12:15.128] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425654735 (0x54f9c3cf)
[2015-03-06 16:12:15.129] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:12:15.129] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:12:15.188] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:12:15.188] [D] [zway] SENT ACK
[2015-03-06 16:12:15.189] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:12:15.190] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425654735 (0x54f9c3cf)
[2015-03-06 16:12:15.190] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:12:15.216] [I] [zway] Job 0x13 (Wakeup Sleep): Cancelling job: Wakeup Sleep
[2015-03-06 16:12:15.216] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:12:15.217] [I] [zway] Adding job: MultiCmd, Wakeup interval set, Wakeup Get
[2015-03-06 16:12:15.217] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425654735 (0x54f9c3cf)
[2015-03-06 16:12:15.218] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:12:15.218] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:12:15.219] [D] [zway] SENDING (cb 0x3f): ( 01 14 00 13 09 0D 8F 01 02 06 84 04 09 39 90 01 02 84 05 05 3F EE )
[2015-03-06 16:12:15.222] [D] [zway] RECEIVED ACK
[2015-03-06 16:12:15.226] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:12:15.226] [D] [zway] SENT ACK
[2015-03-06 16:12:15.227] [I] [zway] Job 0x13 (MultiCmd, Wakeup interval set, Wakeup Get): Response received - transfered to encapsulated jobs
[2015-03-06 16:12:15.227] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:12:15.228] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:12:15.247] [D] [zway] RECEIVED: ( 01 07 00 13 3F 00 00 02 D6 )
[2015-03-06 16:12:15.248] [D] [zway] SENT ACK
[2015-03-06 16:12:15.248] [I] [zway] Job 0x13 (MultiCmd, Wakeup interval set, Wakeup Get): Callback received - transfered to encapsulated jobs
[2015-03-06 16:12:15.249] [I] [zway] Job 0x13 (Wakeup interval set): Delivered
[2015-03-06 16:12:15.249] [D] [zway] SendData Response with callback 0x3f received: received by recipient
[2015-03-06 16:12:15.250] [D] [zway] Job 0x13 (Wakeup interval set): success
[2015-03-06 16:12:15.250] [I] [zway] Removing job: Wakeup interval set
[2015-03-06 16:12:15.250] [I] [zway] Job 0x13 (Wakeup Get): Delivered
[2015-03-06 16:12:15.251] [D] [zway] SendData Response with callback 0x3f received: received by recipient
[2015-03-06 16:12:15.251] [D] [zway] Job 0x13 (Wakeup Get): success
[2015-03-06 16:12:15.252] [I] [zway] Removing job: Wakeup Get
[2015-03-06 16:12:15.252] [I] [zway] Job 0x13 (MultiCmd, Wakeup interval set, Wakeup Get): Delivered
[2015-03-06 16:12:15.252] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:12:15.253] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 16 (0x00000010)
[2015-03-06 16:12:15.253] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 24 (0x00000018)
[2015-03-06 16:12:15.254] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:12:15.254] [D] [zway] SendData Response with callback 0x3f received: received by recipient
[2015-03-06 16:12:15.255] [D] [zway] SETDATA devices.9.data.lastSend = 2289308 (0x0022ee9c)
[2015-03-06 16:12:15.256] [D] [zway] Job 0x13 (MultiCmd, Wakeup interval set, Wakeup Get): success
[2015-03-06 16:12:15.256] [I] [zway] Removing job: MultiCmd, Wakeup interval set, Wakeup Get
[2015-03-06 16:12:15.284] [D] [zway] RECEIVED: ( 01 0C 00 04 00 09 06 84 06 09 39 90 01 DB )
[2015-03-06 16:12:15.284] [D] [zway] SENT ACK
[2015-03-06 16:12:15.285] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:12:15.285] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.interval = 604560 (0x00093990)
[2015-03-06 16:12:15.286] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.nodeId = 1 (0x00000001)
[2015-03-06 16:12:15.286] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data = Empty
[2015-03-06 16:12:15.328] [D] [zway] SENDING (cb 0x40): ( 01 06 00 46 09 01 40 F7 )
[2015-03-06 16:12:15.330] [D] [zway] RECEIVED ACK
[2015-03-06 16:12:15.337] [D] [zway] RECEIVED: ( 01 04 01 46 01 BD )
[2015-03-06 16:12:15.337] [D] [zway] SENT ACK
[2015-03-06 16:12:15.338] [D] [zway] Delivered to Z-Wave stack: process started
[2015-03-06 16:12:15.744] [D] [zway] RECEIVED: ( 01 05 00 46 40 00 FC )
[2015-03-06 16:12:15.745] [D] [zway] SENT ACK
[2015-03-06 16:12:15.745] [D] [zway] AssignReturnRoute Response with callback 0x40 received: received by recipient
[2015-03-06 16:12:15.746] [D] [zway] Job 0x46 (Assign return route): success
[2015-03-06 16:12:15.746] [I] [zway] Removing job: Assign return route
[2015-03-06 16:12:15.757] [D] [zway] SENDING (cb 0x41): ( 01 09 00 13 09 02 84 08 05 41 26 )
[2015-03-06 16:12:15.759] [D] [zway] RECEIVED ACK
[2015-03-06 16:12:15.763] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:12:15.763] [D] [zway] SENT ACK
[2015-03-06 16:12:15.764] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:12:15.782] [D] [zway] RECEIVED: ( 01 07 00 13 41 00 00 02 A8 )
[2015-03-06 16:12:15.782] [D] [zway] SENT ACK
[2015-03-06 16:12:15.783] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:12:15.783] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:12:15.784] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:12:15.784] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2015-03-06 16:12:15.785] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:12:15.785] [D] [zway] SendData Response with callback 0x41 received: received by recipient
[2015-03-06 16:12:15.786] [D] [zway] SETDATA devices.9.data.lastSend = 2289357 (0x0022eecd)
[2015-03-06 16:12:15.787] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:12:15.787] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:12:15.787] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:12:15.788] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:12:35.383] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:12:35.394] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:12:35.405] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:12:35.865] [D] [zway] Job 0x46: deleted from queue
[2015-03-06 16:12:35.886] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:15:47.342] [I] [zway] Adding job: Wakeup Get
[2015-03-06 16:15:57.453] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:15:57.454] [D] [zway] SENT ACK
[2015-03-06 16:15:57.454] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:15:57.455] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:15:57.455] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425654957 (0x54f9c4ad)
[2015-03-06 16:15:57.455] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:15:57.456] [D] [zway] SETDATA devices.9.data.lastSend = 2311051 (0x0023438b)
[2015-03-06 16:15:57.456] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2310051 (0x00233fa3)
[2015-03-06 16:15:57.457] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:15:57.457] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425654957 (0x54f9c4ad)
[2015-03-06 16:15:57.458] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:15:57.458] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:15:57.517] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:15:57.518] [D] [zway] SENT ACK
[2015-03-06 16:15:57.518] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:15:57.519] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425654957 (0x54f9c4ad)
[2015-03-06 16:15:57.519] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:15:57.541] [I] [zway] Node 9:0 CC MultiCmd: Only one packet fits in MultiCmd - should rather be sent as plain
[2015-03-06 16:15:57.541] [D] [zway] SENDING (cb 0x42): ( 01 09 00 13 09 02 84 05 05 42 28 )
[2015-03-06 16:15:57.544] [D] [zway] RECEIVED ACK
[2015-03-06 16:15:57.548] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:15:57.548] [D] [zway] SENT ACK
[2015-03-06 16:15:57.549] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:15:57.567] [D] [zway] RECEIVED: ( 01 07 00 13 42 00 00 02 AB )
[2015-03-06 16:15:57.567] [D] [zway] SENT ACK
[2015-03-06 16:15:57.568] [I] [zway] Job 0x13 (Wakeup Get): Delivered
[2015-03-06 16:15:57.569] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:15:57.569] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:15:57.570] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2015-03-06 16:15:57.570] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:15:57.571] [D] [zway] SendData Response with callback 0x42 received: received by recipient
[2015-03-06 16:15:57.571] [D] [zway] SETDATA devices.9.data.lastSend = 2311059 (0x00234393)
[2015-03-06 16:15:57.572] [D] [zway] Job 0x13 (Wakeup Get): success
[2015-03-06 16:15:57.572] [I] [zway] Removing job: Wakeup Get
[2015-03-06 16:15:57.603] [D] [zway] RECEIVED: ( 01 0C 00 04 00 09 06 84 06 09 39 90 01 DB )
[2015-03-06 16:15:57.604] [D] [zway] SENT ACK
[2015-03-06 16:15:57.605] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:15:57.605] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.interval = 604560 (0x00093990)
[2015-03-06 16:15:57.606] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.nodeId = 1 (0x00000001)
[2015-03-06 16:15:57.606] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data = Empty
[2015-03-06 16:15:57.647] [D] [zway] SENDING (cb 0x43): ( 01 09 00 13 09 02 84 08 05 43 24 )
[2015-03-06 16:15:57.649] [D] [zway] RECEIVED ACK
[2015-03-06 16:15:57.653] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:15:57.654] [D] [zway] SENT ACK
[2015-03-06 16:15:57.654] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:15:57.672] [D] [zway] RECEIVED: ( 01 07 00 13 43 00 00 03 AB )
[2015-03-06 16:15:57.673] [D] [zway] SENT ACK
[2015-03-06 16:15:57.673] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:15:57.674] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:15:57.674] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:15:57.675] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2015-03-06 16:15:57.675] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:15:57.676] [D] [zway] SendData Response with callback 0x43 received: received by recipient
[2015-03-06 16:15:57.676] [D] [zway] SETDATA devices.9.data.lastSend = 2311067 (0x0023439b)
[2015-03-06 16:15:57.677] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:15:57.677] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:15:57.678] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:15:57.678] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:16:17.708] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:16:17.780] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:19:38.755] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:19:38.756] [D] [zway] SENT ACK
[2015-03-06 16:19:38.756] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:19:38.757] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:19:38.757] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425655178 (0x54f9c58a)
[2015-03-06 16:19:38.758] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:19:38.758] [D] [zway] SETDATA devices.9.data.lastSend = 2332710 (0x00239826)
[2015-03-06 16:19:38.758] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2331710 (0x0023943e)
[2015-03-06 16:19:38.759] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:19:38.759] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425655178 (0x54f9c58a)
[2015-03-06 16:19:38.760] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:19:38.760] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:19:38.819] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:19:38.820] [D] [zway] SENT ACK
[2015-03-06 16:19:38.821] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:19:38.821] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425655178 (0x54f9c58a)
[2015-03-06 16:19:38.822] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:19:38.843] [D] [zway] SENDING (cb 0x44): ( 01 09 00 13 09 02 84 08 05 44 23 )
[2015-03-06 16:19:38.846] [D] [zway] RECEIVED ACK
[2015-03-06 16:19:38.850] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:19:38.851] [D] [zway] SENT ACK
[2015-03-06 16:19:38.851] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:19:38.869] [D] [zway] RECEIVED: ( 01 07 00 13 44 00 00 02 AD )
[2015-03-06 16:19:38.869] [D] [zway] SENT ACK
[2015-03-06 16:19:38.870] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:19:38.871] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:19:38.871] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:19:38.872] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2015-03-06 16:19:38.872] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:19:38.873] [D] [zway] SendData Response with callback 0x44 received: received by recipient
[2015-03-06 16:19:38.873] [D] [zway] SETDATA devices.9.data.lastSend = 2332718 (0x0023982e)
[2015-03-06 16:19:38.874] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:19:38.874] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:19:38.875] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:19:38.875] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:19:58.972] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:23:19.916] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:23:19.917] [D] [zway] SENT ACK
[2015-03-06 16:23:19.917] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:23:19.918] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:23:19.918] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425655399 (0x54f9c667)
[2015-03-06 16:23:19.919] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:23:19.919] [D] [zway] SETDATA devices.9.data.lastSend = 2354360 (0x0023ecb8)
[2015-03-06 16:23:19.920] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2353360 (0x0023e8d0)
[2015-03-06 16:23:19.920] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:23:19.921] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425655399 (0x54f9c667)
[2015-03-06 16:23:19.921] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:23:19.922] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:23:19.981] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:23:19.981] [D] [zway] SENT ACK
[2015-03-06 16:23:19.982] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:23:19.982] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425655399 (0x54f9c667)
[2015-03-06 16:23:19.983] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:23:20.009] [D] [zway] SENDING (cb 0x45): ( 01 09 00 13 09 02 84 08 05 45 22 )
[2015-03-06 16:23:20.011] [D] [zway] RECEIVED ACK
[2015-03-06 16:23:20.015] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:23:20.016] [D] [zway] SENT ACK
[2015-03-06 16:23:20.016] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:23:20.034] [D] [zway] RECEIVED: ( 01 07 00 13 45 00 00 02 AC )
[2015-03-06 16:23:20.035] [D] [zway] SENT ACK
[2015-03-06 16:23:20.035] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:23:20.036] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:23:20.037] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:23:20.037] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2015-03-06 16:23:20.038] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:23:20.038] [D] [zway] SendData Response with callback 0x45 received: received by recipient
[2015-03-06 16:23:20.039] [D] [zway] SETDATA devices.9.data.lastSend = 2354368 (0x0023ecc0)
[2015-03-06 16:23:20.039] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:23:20.040] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:23:20.040] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:23:20.041] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:23:40.135] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:27:01.045] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:27:01.046] [D] [zway] SENT ACK
[2015-03-06 16:27:01.047] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:27:01.047] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:27:01.048] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425655621 (0x54f9c745)
[2015-03-06 16:27:01.048] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:27:01.049] [D] [zway] SETDATA devices.9.data.lastSend = 2375996 (0x0024413c)
[2015-03-06 16:27:01.049] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2374996 (0x00243d54)
[2015-03-06 16:27:01.050] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:27:01.050] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425655621 (0x54f9c745)
[2015-03-06 16:27:01.051] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:27:01.051] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:27:01.112] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:27:01.113] [D] [zway] SENT ACK
[2015-03-06 16:27:01.114] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:27:01.114] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425655621 (0x54f9c745)
[2015-03-06 16:27:01.114] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:27:01.139] [D] [zway] SENDING (cb 0x46): ( 01 09 00 13 09 02 84 08 05 46 21 )
[2015-03-06 16:27:01.141] [D] [zway] RECEIVED ACK
[2015-03-06 16:27:01.145] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:27:01.146] [D] [zway] SENT ACK
[2015-03-06 16:27:01.146] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:27:01.164] [D] [zway] RECEIVED: ( 01 07 00 13 46 00 00 02 AF )
[2015-03-06 16:27:01.165] [D] [zway] SENT ACK
[2015-03-06 16:27:01.166] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:27:01.166] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:27:01.166] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:27:01.167] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2015-03-06 16:27:01.168] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:27:01.168] [D] [zway] SendData Response with callback 0x46 received: received by recipient
[2015-03-06 16:27:01.169] [D] [zway] SETDATA devices.9.data.lastSend = 2376004 (0x00244144)
[2015-03-06 16:27:01.169] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:27:01.170] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:27:01.170] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:27:01.171] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:27:21.271] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:30:42.239] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:30:42.240] [D] [zway] SENT ACK
[2015-03-06 16:30:42.240] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:30:42.241] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:30:42.241] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425655842 (0x54f9c822)
[2015-03-06 16:30:42.242] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:30:42.242] [D] [zway] SETDATA devices.9.data.lastSend = 2397640 (0x002495c8)
[2015-03-06 16:30:42.242] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2396640 (0x002491e0)
[2015-03-06 16:30:42.243] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:30:42.243] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425655842 (0x54f9c822)
[2015-03-06 16:30:42.244] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:30:42.244] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:30:42.303] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:30:42.304] [D] [zway] SENT ACK
[2015-03-06 16:30:42.304] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:30:42.305] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425655842 (0x54f9c822)
[2015-03-06 16:30:42.305] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:30:42.327] [D] [zway] SENDING (cb 0x47): ( 01 09 00 13 09 02 84 08 05 47 20 )
[2015-03-06 16:30:42.329] [D] [zway] RECEIVED ACK
[2015-03-06 16:30:42.333] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:30:42.334] [D] [zway] SENT ACK
[2015-03-06 16:30:42.334] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:30:42.353] [D] [zway] RECEIVED: ( 01 07 00 13 47 00 00 02 AE )
[2015-03-06 16:30:42.353] [D] [zway] SENT ACK
[2015-03-06 16:30:42.354] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:30:42.354] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:30:42.355] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:30:42.355] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 20 (0x00000014)
[2015-03-06 16:30:42.356] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:30:42.357] [D] [zway] SendData Response with callback 0x47 received: received by recipient
[2015-03-06 16:30:42.357] [D] [zway] SETDATA devices.9.data.lastSend = 2397648 (0x002495d0)
[2015-03-06 16:30:42.357] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:30:42.358] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:30:42.358] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:30:42.359] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:31:02.457] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:34:23.486] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:34:23.487] [D] [zway] SENT ACK
[2015-03-06 16:34:23.488] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:34:23.488] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:34:23.488] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425656063 (0x54f9c8ff)
[2015-03-06 16:34:23.489] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:34:23.489] [D] [zway] SETDATA devices.9.data.lastSend = 2419294 (0x0024ea5e)
[2015-03-06 16:34:23.490] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2418294 (0x0024e676)
[2015-03-06 16:34:23.490] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:34:23.491] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425656063 (0x54f9c8ff)
[2015-03-06 16:34:23.492] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:34:23.492] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:34:23.551] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:34:23.552] [D] [zway] SENT ACK
[2015-03-06 16:34:23.552] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:34:23.553] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425656063 (0x54f9c8ff)
[2015-03-06 16:34:23.553] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:34:23.579] [D] [zway] SENDING (cb 0x48): ( 01 09 00 13 09 02 84 08 05 48 2F )
[2015-03-06 16:34:23.581] [D] [zway] RECEIVED ACK
[2015-03-06 16:34:23.585] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:34:23.585] [D] [zway] SENT ACK
[2015-03-06 16:34:23.586] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:34:23.604] [D] [zway] RECEIVED: ( 01 07 00 13 48 00 00 02 A1 )
[2015-03-06 16:34:23.604] [D] [zway] SENT ACK
[2015-03-06 16:34:23.605] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:34:23.605] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:34:23.606] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:34:23.606] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2015-03-06 16:34:23.607] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:34:23.608] [D] [zway] SendData Response with callback 0x48 received: received by recipient
[2015-03-06 16:34:23.608] [D] [zway] SETDATA devices.9.data.lastSend = 2419302 (0x0024ea66)
[2015-03-06 16:34:23.609] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:34:23.609] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:34:23.609] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:34:23.610] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:34:43.708] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:38:04.728] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:38:04.729] [D] [zway] SENT ACK
[2015-03-06 16:38:04.730] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:38:04.731] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:38:04.731] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425656284 (0x54f9c9dc)
[2015-03-06 16:38:04.732] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:38:04.732] [D] [zway] SETDATA devices.9.data.lastSend = 2440947 (0x00253ef3)
[2015-03-06 16:38:04.732] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2439947 (0x00253b0b)
[2015-03-06 16:38:04.733] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:38:04.733] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425656284 (0x54f9c9dc)
[2015-03-06 16:38:04.734] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:38:04.735] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:38:04.793] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:38:04.794] [D] [zway] SENT ACK
[2015-03-06 16:38:04.795] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:38:04.795] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425656284 (0x54f9c9dc)
[2015-03-06 16:38:04.796] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:38:04.821] [D] [zway] SENDING (cb 0x49): ( 01 09 00 13 09 02 84 08 05 49 2E )
[2015-03-06 16:38:04.823] [D] [zway] RECEIVED ACK
[2015-03-06 16:38:04.827] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:38:04.828] [D] [zway] SENT ACK
[2015-03-06 16:38:04.828] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:38:04.846] [D] [zway] RECEIVED: ( 01 07 00 13 49 00 00 02 A0 )
[2015-03-06 16:38:04.847] [D] [zway] SENT ACK
[2015-03-06 16:38:04.847] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:38:04.848] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:38:04.848] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:38:04.849] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2015-03-06 16:38:04.850] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:38:04.850] [D] [zway] SendData Response with callback 0x49 received: received by recipient
[2015-03-06 16:38:04.851] [D] [zway] SETDATA devices.9.data.lastSend = 2440955 (0x00253efb)
[2015-03-06 16:38:04.860] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:38:04.861] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:38:04.862] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:38:04.862] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:38:24.951] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:41:45.529] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:41:45.530] [D] [zway] SENT ACK
[2015-03-06 16:41:45.530] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:41:45.531] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:41:45.531] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425656505 (0x54f9cab9)
[2015-03-06 16:41:45.532] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:41:45.532] [D] [zway] SETDATA devices.9.data.lastSend = 2462558 (0x0025935e)
[2015-03-06 16:41:45.533] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2461558 (0x00258f76)
[2015-03-06 16:41:45.533] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:41:45.534] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425656505 (0x54f9cab9)
[2015-03-06 16:41:45.534] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:41:45.535] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:41:45.593] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:41:45.594] [D] [zway] SENT ACK
[2015-03-06 16:41:45.594] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:41:45.595] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425656505 (0x54f9cab9)
[2015-03-06 16:41:45.595] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:41:45.631] [D] [zway] SENDING (cb 0x4a): ( 01 09 00 13 09 02 84 08 05 4A 2D )
[2015-03-06 16:41:45.633] [D] [zway] RECEIVED ACK
[2015-03-06 16:41:45.637] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:41:45.637] [D] [zway] SENT ACK
[2015-03-06 16:41:45.638] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:41:45.656] [D] [zway] RECEIVED: ( 01 07 00 13 4A 00 00 02 A3 )
[2015-03-06 16:41:45.657] [D] [zway] SENT ACK
[2015-03-06 16:41:45.658] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:41:45.658] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:41:45.658] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:41:45.659] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2015-03-06 16:41:45.660] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:41:45.661] [D] [zway] SendData Response with callback 0x4a received: received by recipient
[2015-03-06 16:41:45.661] [D] [zway] SETDATA devices.9.data.lastSend = 2462567 (0x00259367)
[2015-03-06 16:41:45.662] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:41:45.662] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:41:45.662] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:41:45.663] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:42:05.759] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:45:26.852] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:45:26.853] [D] [zway] SENT ACK
[2015-03-06 16:45:26.853] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:45:26.854] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:45:26.854] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425656726 (0x54f9cb96)
[2015-03-06 16:45:26.855] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:45:26.855] [D] [zway] SETDATA devices.9.data.lastSend = 2484221 (0x0025e7fd)
[2015-03-06 16:45:26.855] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2483221 (0x0025e415)
[2015-03-06 16:45:26.856] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:45:26.857] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425656726 (0x54f9cb96)
[2015-03-06 16:45:26.857] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:45:26.858] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:45:26.916] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:45:26.917] [D] [zway] SENT ACK
[2015-03-06 16:45:26.917] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:45:26.918] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425656726 (0x54f9cb96)
[2015-03-06 16:45:26.918] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:45:26.945] [D] [zway] SENDING (cb 0x4b): ( 01 09 00 13 09 02 84 08 05 4B 2C )
[2015-03-06 16:45:26.947] [D] [zway] RECEIVED ACK
[2015-03-06 16:45:26.951] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:45:26.951] [D] [zway] SENT ACK
[2015-03-06 16:45:26.952] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:45:26.970] [D] [zway] RECEIVED: ( 01 07 00 13 4B 00 00 02 A2 )
[2015-03-06 16:45:26.970] [D] [zway] SENT ACK
[2015-03-06 16:45:26.971] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:45:26.971] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:45:26.972] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:45:26.972] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 19 (0x00000013)
[2015-03-06 16:45:26.973] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:45:26.974] [D] [zway] SendData Response with callback 0x4b received: received by recipient
[2015-03-06 16:45:26.974] [D] [zway] SETDATA devices.9.data.lastSend = 2484229 (0x0025e805)
[2015-03-06 16:45:26.974] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:45:26.975] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:45:26.975] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:45:26.976] [I] [zway] Removing job: Wakeup Sleep
[2015-03-06 16:45:47.078] [D] [zway] Job 0x13: deleted from queue
[2015-03-06 16:49:08.126] [D] [zway] RECEIVED: ( 01 08 00 04 00 09 02 84 07 7B )
[2015-03-06 16:49:08.126] [D] [zway] SENT ACK
[2015-03-06 16:49:08.127] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:49:08.127] [I] [zway] Node 9:0 CC Wakeup: Wakeup notification
[2015-03-06 16:49:08.127] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastWakeup = 1425656948 (0x54f9cc74)
[2015-03-06 16:49:08.127] [D] [zway] SETDATA devices.9.data.isAwake = True
[2015-03-06 16:49:08.127] [D] [zway] SETDATA devices.9.data.lastSend = 2505877 (0x00263c95)
[2015-03-06 16:49:08.128] [D] [zway] SETDATA devices.9.data.lastNonceGet = 2504877 (0x002638ad)
[2015-03-06 16:49:08.128] [D] [zway] Running wakeup handler for node 9
[2015-03-06 16:49:08.128] [D] [zway] SETDATA devices.9.instances.0.commandClasses.132.data.lastSleep = 1425656948 (0x54f9cc74)
[2015-03-06 16:49:08.128] [I] [zway] Node 9:0 CC Wakeup: Send node to sleep
[2015-03-06 16:49:08.128] [I] [zway] Adding job: Wakeup Sleep
[2015-03-06 16:49:08.191] [D] [zway] RECEIVED: ( 01 09 00 04 00 09 03 80 03 60 1B )
[2015-03-06 16:49:08.191] [D] [zway] SENT ACK
[2015-03-06 16:49:08.191] [D] [zway] SETDATA devices.9.data.lastReceived = 0 (0x00000000)
[2015-03-06 16:49:08.192] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.history.96 = 1425656948 (0x54f9cc74)
[2015-03-06 16:49:08.192] [D] [zway] SETDATA devices.9.instances.0.commandClasses.128.data.last = 96 (0x00000060)
[2015-03-06 16:49:08.213] [D] [zway] SENDING (cb 0x4c): ( 01 09 00 13 09 02 84 08 05 4C 2B )
[2015-03-06 16:49:08.215] [D] [zway] RECEIVED ACK
[2015-03-06 16:49:08.219] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2015-03-06 16:49:08.220] [D] [zway] SENT ACK
[2015-03-06 16:49:08.226] [D] [zway] Delivered to Z-Wave stack
[2015-03-06 16:49:08.239] [D] [zway] RECEIVED: ( 01 07 00 13 4C 00 00 03 A4 )
[2015-03-06 16:49:08.240] [D] [zway] SENT ACK
[2015-03-06 16:49:08.240] [I] [zway] Job 0x13 (Wakeup Sleep): Delivered
[2015-03-06 16:49:08.240] [D] [zway] SETDATA devices.9.data.lastPacketInfo.delivered = True
[2015-03-06 16:49:08.241] [D] [zway] SETDATA devices.9.data.lastPacketInfo.packetLength = 5 (0x00000005)
[2015-03-06 16:49:08.241] [D] [zway] SETDATA devices.9.data.lastPacketInfo.deliveryTime = 13 (0x0000000d)
[2015-03-06 16:49:08.241] [D] [zway] SETDATA devices.9.data.lastPacketInfo = **********
[2015-03-06 16:49:08.242] [D] [zway] SendData Response with callback 0x4c received: received by recipient
[2015-03-06 16:49:08.242] [D] [zway] SETDATA devices.9.data.lastSend = 2505886 (0x00263c9e)
[2015-03-06 16:49:08.242] [D] [zway] Job 0x13 (Wakeup Sleep): success
[2015-03-06 16:49:08.242] [D] [zway] SETDATA devices.9.data.isAwake = False
[2015-03-06 16:49:08.242] [D] [zway] Sending the queue for node 9 into sleep
[2015-03-06 16:49:08.243] [I] [zway] Removing job: Wakeup Sleep
[edit] 2015/03/14 :
After hours of efforts trying to change wakeup interval parameter without any visible results, I changed my mind and decided to modify configuration parameter number 25 and set its value to 0 (= wakeup is blocked"). Now, when I need to trigger a wakeup notification to the controller , I can still manualy switch the device into management mode and press button 2...
Re: Z-Wave.me KEYFOB (ZME_KFOB_S): Cannot change wakeup inte
This is a known problem. We found it last month. The only way is to send it us for reflashing or use the workaround you found (which is even better since saves battery). We apologize.
