Hello
I wanted to query support for the above, appreciate it's a brand new sensor.
I had the sensor included via the Expert UI, showing as a "Routing Multilevel Sensor_7", although without a device description XML so not much in the way of configuration via the expert UI, however somehow managed to set it up in a rudimentary way to trigger a Fibaro dimmer. Rudimentary as it's doing it regardless of light level and needs the sensitivity lowering. I forget exactly how as I was tinkering quite a bit.
In the hope of finding better support I updated my Pi to the latest software, however the device is not listed in the new "Smart Home" interface.
I was wondering if increased support for this device is on the way, or if anyone has any advice at all on getting it configured. I found this XML, however while the various settings look about right I don't believe it's the correct format:
http://www.pepper1.net/zwavedb/device/7 ... -01-04.xml
Apologies for the fairly lost post, I'm fairly technically competent but getting a bit stuck.
Aeon Labs Multisensor 6 - Gen5
Re: Aeon Labs Multisensor 6 - Gen5
Maybe you need to update your local device descriptors (see this post) since it has been updated in the pepper1 database only a couple of days ago
Thanks for that, updating now.
Just wanted to say thanks again, only just had time to tinker but updating the XML and plugging it in to allow it to complete interview looks to have got it working, I can see motion, lux, temp, humidity etc in Smart Home. Good stuff.
Good to hear you got it working
