Hi all
I am runnig razberry firmware version v2.1.1 and I cannot get the device interview finished successfully, so I was wondering if this device is not fully supported or I am making something wrong. Attached some pictures.
Best regards
Fibaro Dimmer 2 (FDG)-212 Fully supported
- screenshot.13.jpg (174.96 KiB) Viewed 29121 times
- screenshot.12.jpg (254.24 KiB) Viewed 29121 times
Re: Fibaro Dimmer 2 (FDG)-212 Fully supported
The device just have a broken firmware. Having Version inside channels for example is just bad (means not allowed). The device announce it but do not answer, so interview will never finish
Many thanks for the info supplied.
I have the same problem.
Any one know if there a fix for this yet?
Hi, i have exacly same problem. 4 devices (all fibaro FDG 212) are telling me that interview is not complete. Is there some workaround to solve this? I thing association between these devices is not working also because of this issue.
I would provide the log where I stopped server, deleted logs, started server and clicked on Force Interview for one of problematic device, but i'm not allowed to post the log file here.
- screenshot.JPG (90.01 KiB) Viewed 28999 times
We need to get them in hands first. May be also bind Fibaro bout the issue. Devices have Firmware Upgrade capability, so you can push them to release an update.
Yes, you are right about firmware update. Non of my other zwave devices supports that function, so i totally forget about this possibility. However Fibaro does not have any update available on their support page, so i'm going to ask them via email.PoltoS wrote:We need to get them in hands first. May be also bind Fibaro bout the issue. Devices have Firmware Upgrade capability, so you can push them to release an update.
But, can you form for me what exactly is wrong with their dimmer? Jut write me what i should complain about
It is just not Z-Wave Plus compliant
Version inside channels, does not answer to most CCs under channels
@karel007 - did you get any answers from Fibaro?karel007 wrote: But, can you form for me what exactly is wrong with their dimmer? Jut write me what i should complain about
Cheers,
bo
Here is reply from Fibaro which i did not expect to be different
Krzysztof Gumny 20 Nov 15
At present it is not possible update firmware of the modules using other controllers and also Fibaro Home Centers.
Such functionality should be introduced in the future but we do not know yet when exactly.
Fibaro Dimmer 2 was checked via series of verification, also for compliance with the protocol of Z-Wave.
The most probably your issue is related with compatibility with your main controller, but about compatibility you should ask your main controller support team.
Best regards
Best regards
