2.3.0 and Schlage Lock
CudaNet
Post by CudaNet »
@PoltoS,
Per your request, here is a log snippet of me manually locking and unlocking a Schlage lock. Z-way (Razberry v2) can control the lock as well as my Yale but I'm not seeing a state change in either Expert or Smarthome. I use Niffler for all my locks including all my GE binary/dimmer switches and this worked well in v2.2.3. To keep things simple, here are the logs for just a single lock. Please let me know if there is anything else I can provide or if I'm not capturing enough of the log.
Firmware
SDK Version: 6.51.06
Serial API Version: 05.04
Software Information
Version number: v2.3.0
Compile-ID: 910991fa4621bda7c7978d37cfe96364549f9c13
Compile-Date: 2017-01-27 20:35:38 +0300
UI
UI version 1.2.0
Built date 27-01-2017 17:46:19
[2017-01-31 07:52:25.166] [I] [zway] Node 3:0 CC Security: Received a secure message
[2017-01-31 07:52:25.167] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.firstPart = **********
[2017-01-31 07:52:25.167] [I] [zway] Node 3:0 CC Security: passing decrypted packet to application level: [ 71 05 15 01 00 ff 06 01 00 ]
[2017-01-31 07:52:25.167] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.V1event.alarmType = 21 (0x00000015)
[2017-01-31 07:52:25.167] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.V1event.level = 1 (0x00000001)
[2017-01-31 07:52:25.167] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.V1event = Empty
[2017-01-31 07:52:25.167] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2017-01-31 07:52:25.167] [D] [zway]   ( zero-length buffer )
[2017-01-31 07:52:25.167] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.6.event = 1 (0x00000001)
[2017-01-31 07:52:25.170] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.6.eventString = "Manual Lock Operation"
[2017-01-31 07:52:25.170] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2017-01-31 07:52:25.170] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.6 = Empty
[2017-01-31 07:52:25.175] [I] [core] Niffler doorlock alarm event
[2017-01-31 07:52:25.176] [I] [zway] Adding job: Door Lock Operation Get
[2017-01-31 07:52:25.186] [I] [zway] Node 3:0 CC Security: sending Nonce Get
[2017-01-31 07:52:25.186] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-01-31 07:52:25.186] [I] [zway] Adding job: Nonce Get
[2017-01-31 07:52:25.187] [D] [zway] SETDATA devices.3.data.lastNonceGet = 13672 (0x00003568)
[2017-01-31 07:52:25.197] [D] [zway] SENDING (cb 0x0b): ( 01 09 00 13 03 02 98 40 05 0B 32 )
[2017-01-31 07:52:25.199] [D] [zway] RECEIVED ACK
[2017-01-31 07:52:25.202] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-01-31 07:52:25.202] [D] [zway] SENT ACK
[2017-01-31 07:52:25.202] [D] [zway] Delivered to Z-Wave stack
[2017-01-31 07:52:26.481] [D] [zway] RECEIVED: ( 01 07 00 13 0B 00 00 80 60 )
[2017-01-31 07:52:26.481] [D] [zway] SENT ACK
[2017-01-31 07:52:26.481] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2017-01-31 07:52:26.481] [D] [zway] SendData Response with callback 0x0b received: received by recipient
[2017-01-31 07:52:26.481] [D] [zway] SETDATA devices.3.data.lastSend = 13800 (0x000035e8)
[2017-01-31 07:52:26.481] [D] [zway] Job 0x13 (Nonce Get): success
[2017-01-31 07:52:26.481] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-01-31 07:52:26.481] [D] [zway] SETDATA devices.3.data.lastNonceGet = 13800 (0x000035e8)
[2017-01-31 07:52:26.481] [I] [zway] Removing job: Nonce Get
[2017-01-31 07:52:26.501] [D] [zway] RECEIVED: ( 01 10 00 04 00 03 0A 98 80 4A A1 72 6C 22 5E 13 8B EB )
[2017-01-31 07:52:26.501] [D] [zway] SENT ACK
[2017-01-31 07:52:26.501] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:26.501] [I] [zway] Node 3:0 CC Security: received Nonce Report
[2017-01-31 07:52:26.501] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonce = **********
[2017-01-31 07:52:26.501] [I] [zway] Node 3:0 CC Security: Sending a secure message
[2017-01-31 07:52:26.501] [I] [zway] Node 3:0 CC Security: sending encrypted packet: Door Lock Operation Get
[2017-01-31 07:52:26.502] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.toFollow = False
[2017-01-31 07:52:26.502] [D] [zway] SETDATA devices.3.data.lastNonceGet = Empty
[2017-01-31 07:52:26.502] [I] [zway] Adding job: Security, Door Lock Operation Get
[2017-01-31 07:52:26.552] [D] [zway] SENDING (cb 0x0c): ( 01 1D 00 13 03 16 98 81 E8 06 89 6D C9 26 6E EA 94 1E 93 4A F5 B2 BB 37 C8 CC CB F8 05 0C 3A )
[2017-01-31 07:52:26.589] [D] [zway] RECEIVED ACK
[2017-01-31 07:52:26.593] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-01-31 07:52:26.593] [D] [zway] SENT ACK
[2017-01-31 07:52:26.594] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Response received - transfered to encapsulated jobs
[2017-01-31 07:52:26.594] [D] [zway] Delivered to Z-Wave stack
[2017-01-31 07:52:26.616] [D] [zway] RECEIVED: ( 01 07 00 13 0C 00 00 03 E4 )
[2017-01-31 07:52:26.616] [D] [zway] SENT ACK
[2017-01-31 07:52:26.616] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Callback received - transfered to encapsulated jobs
[2017-01-31 07:52:26.616] [I] [zway] Job 0x13 (Door Lock Operation Get): Delivered
[2017-01-31 07:52:26.616] [D] [zway] SendData Response with callback 0x0c received: received by recipient
[2017-01-31 07:52:26.617] [D] [zway] Job 0x13 (Door Lock Operation Get): success
[2017-01-31 07:52:26.617] [I] [zway] Removing job: Door Lock Operation Get
[2017-01-31 07:52:26.617] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Delivered
[2017-01-31 07:52:26.617] [D] [zway] SendData Response with callback 0x0c received: received by recipient
[2017-01-31 07:52:26.617] [D] [zway] SETDATA devices.3.data.lastSend = 13813 (0x000035f5)
[2017-01-31 07:52:26.617] [D] [zway] Job 0x13 (Security, Door Lock Operation Get): success
[2017-01-31 07:52:26.617] [I] [zway] Removing job: Security, Door Lock Operation Get
[2017-01-31 07:52:26.749] [D] [zway] RECEIVED: ( 01 08 00 04 00 03 02 98 40 2A )
[2017-01-31 07:52:26.750] [D] [zway] SENT ACK
[2017-01-31 07:52:26.750] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:26.750] [I] [zway] Node 3:0 CC Security: sending Nonce Report
[2017-01-31 07:52:26.750] [I] [zway] Adding job: Nonce Report
[2017-01-31 07:52:26.750] [D] [zway] SENDING (cb 0x0d): ( 01 11 00 13 03 0A 98 80 49 BF 64 5A 45 88 98 CC 05 0D B5 )
[2017-01-31 07:52:26.760] [D] [zway] RECEIVED ACK
[2017-01-31 07:52:26.760] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-01-31 07:52:26.760] [D] [zway] SENT ACK
[2017-01-31 07:52:26.760] [D] [zway] Delivered to Z-Wave stack
[2017-01-31 07:52:26.863] [D] [zway] RECEIVED: ( 01 07 00 13 0D 00 00 0A EC )
[2017-01-31 07:52:26.863] [D] [zway] SENT ACK
[2017-01-31 07:52:26.863] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-01-31 07:52:26.863] [D] [zway] SendData Response with callback 0x0d received: received by recipient
[2017-01-31 07:52:26.863] [D] [zway] SETDATA devices.3.data.lastSend = 13837 (0x0000360d)
[2017-01-31 07:52:26.863] [D] [zway] Job 0x13 (Nonce Report): success
[2017-01-31 07:52:26.863] [I] [zway] Removing job: Nonce Report
[2017-01-31 07:52:26.884] [D] [zway] RECEIVED: ( 01 21 00 04 00 03 1B 98 81 21 46 48 58 B2 ED 9C 45 F8 18 DB 0E 06 41 C9 3E 49 73 FE 64 FA 91 24 27 4F 28 )
[2017-01-31 07:52:26.884] [D] [zway] SENT ACK
[2017-01-31 07:52:26.885] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:26.885] [I] [zway] Node 3:0 CC Security: Received a secure message
[2017-01-31 07:52:26.885] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.firstPart = **********
[2017-01-31 07:52:26.885] [I] [zway] Node 3:0 CC Security: passing decrypted packet to application level: [ 62 03 ff 00 00 fe fe ]
[2017-01-31 07:52:26.885] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.mode = 255 (0x000000ff)
[2017-01-31 07:52:26.885] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.outsideMode = 0 (0x00000000)
[2017-01-31 07:52:26.885] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.insideMode = 0 (0x00000000)
[2017-01-31 07:52:26.885] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.condition = 0 (0x00000000)
[2017-01-31 07:52:26.885] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.lockMinutes = 254 (0x000000fe)
[2017-01-31 07:52:26.885] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.lockSeconds = 254 (0x000000fe)
[2017-01-31 07:52:26.924] [D] [zway] RECEIVED: ( 01 21 00 04 00 03 1B 98 81 57 1C C9 DC 5F 5A 88 61 5F F3 7D EE BE 92 FB DB 49 3C 98 21 B0 D8 A1 F5 74 DE )
[2017-01-31 07:52:26.924] [D] [zway] SENT ACK
[2017-01-31 07:52:26.925] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:26.925] [I] [zway] Node 3:0 CC Security: Received a secure message
[2017-01-31 07:52:26.925] [W] [zway] Node 3:0 CC Security: can not decrypt packet due to nonce lookup problem
[2017-01-31 07:52:27.138] [D] [zway] RECEIVED: ( 01 14 00 04 00 02 0E 32 02 21 44 00 00 09 C9 00 19 00 00 09 C9 AF )
[2017-01-31 07:52:27.139] [D] [zway] SENT ACK
[2017-01-31 07:52:27.139] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:27.139] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.0.val = 25.049999
[2017-01-31 07:52:27.139] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.0.delta = 25 (0x00000019)
[2017-01-31 07:52:27.139] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2017-01-31 07:52:27.139] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.0.previous = 25.049999
[2017-01-31 07:52:27.139] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.0 = Empty
[2017-01-31 07:52:27.821] [D] [zway] RECEIVED: ( 01 14 00 04 00 02 0E 32 02 21 54 00 00 19 DC 00 19 00 00 21 47 1C )
[2017-01-31 07:52:27.821] [D] [zway] SENT ACK
[2017-01-31 07:52:27.821] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:27.821] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.2.val = 66.199997
[2017-01-31 07:52:27.821] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.2.delta = 25 (0x00000019)
[2017-01-31 07:52:27.821] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2017-01-31 07:52:27.822] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.2.previous = 85.190002
[2017-01-31 07:52:27.822] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.2 = Empty
[2017-01-31 07:52:28.811] [D] [zway] RECEIVED: ( 01 10 00 04 00 02 0A 32 02 A1 42 30 E7 00 19 30 D7 19 )
[2017-01-31 07:52:28.811] [D] [zway] SENT ACK
[2017-01-31 07:52:28.811] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:28.812] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.4.val = 125.190002
[2017-01-31 07:52:28.812] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.4.delta = 25 (0x00000019)
[2017-01-31 07:52:28.812] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.4.ratetype = 1 (0x00000001)
[2017-01-31 07:52:28.812] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.4.previous = 125.029999
[2017-01-31 07:52:28.812] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.4 = Empty
[2017-01-31 07:52:29.810] [D] [zway] RECEIVED: ( 01 10 00 04 00 02 0A 32 02 A1 4A 00 37 00 19 00 46 50 )
[2017-01-31 07:52:29.810] [D] [zway] SENT ACK
[2017-01-31 07:52:29.810] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:29.810] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.5.val = 0.550000
[2017-01-31 07:52:29.811] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.5.delta = 25 (0x00000019)
[2017-01-31 07:52:29.811] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.5.ratetype = 1 (0x00000001)
[2017-01-31 07:52:29.811] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.5.previous = 0.700000
[2017-01-31 07:52:29.811] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.5 = Empty
[2017-01-31 07:52:30.483] [D] [zway] RECEIVED: ( 01 0C 00 04 00 1D 06 31 05 02 0A 0B 2D F6 )
[2017-01-31 07:52:30.484] [D] [zway] SENT ACK
[2017-01-31 07:52:30.484] [D] [zway] SETDATA devices.29.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:30.484] [D] [zway] SETDATA devices.29.instances.0.commandClasses.49.data.2.deviceScale = 1 (0x00000001)
[2017-01-31 07:52:30.484] [D] [zway] SETDATA devices.29.instances.0.commandClasses.49.data.2.scale = 1 (0x00000001)
[2017-01-31 07:52:30.486] [D] [zway] SETDATA devices.29.instances.0.commandClasses.49.data.2.scaleString = ""
[2017-01-31 07:52:30.486] [D] [zway] SETDATA devices.29.instances.0.commandClasses.49.data.2.val = 2861.000000
[2017-01-31 07:52:30.486] [D] [zway] SETDATA devices.29.instances.0.commandClasses.49.data.2 = Empty
[2017-01-31 07:52:37.182] [D] [zway] RECEIVED: ( 01 08 00 04 00 03 02 98 40 2A )
[2017-01-31 07:52:37.185] [D] [zway] SENT ACK
[2017-01-31 07:52:37.185] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:37.185] [I] [zway] Node 3:0 CC Security: sending Nonce Report
[2017-01-31 07:52:37.186] [I] [zway] Adding job: Nonce Report
[2017-01-31 07:52:37.186] [D] [zway] SENDING (cb 0x0e): ( 01 11 00 13 03 0A 98 80 8B B4 C1 9C E2 2B 30 C3 05 0E BF )
[2017-01-31 07:52:37.192] [D] [zway] RECEIVED ACK
[2017-01-31 07:52:37.192] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-01-31 07:52:37.192] [D] [zway] SENT ACK
[2017-01-31 07:52:37.192] [D] [zway] Delivered to Z-Wave stack
[2017-01-31 07:52:37.212] [D] [zway] RECEIVED: ( 01 07 00 13 0E 00 00 02 E7 )
[2017-01-31 07:52:37.212] [D] [zway] SENT ACK
[2017-01-31 07:52:37.212] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-01-31 07:52:37.212] [D] [zway] SendData Response with callback 0x0e received: received by recipient
[2017-01-31 07:52:37.212] [D] [zway] SETDATA devices.3.data.lastSend = 14852 (0x00003a04)
[2017-01-31 07:52:37.212] [D] [zway] Job 0x13 (Nonce Report): success
[2017-01-31 07:52:37.212] [I] [zway] Removing job: Nonce Report
[2017-01-31 07:52:37.273] [D] [zway] RECEIVED: ( 01 23 00 04 00 03 1D 98 81 82 89 98 20 9B AF 96 9A D0 47 7E DD A9 FB 7A 16 A4 76 8B C3 62 FB DC 8F EA 7A F9 67 )
[2017-01-31 07:52:37.273] [D] [zway] SENT ACK
[2017-01-31 07:52:37.273] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:37.274] [I] [zway] Node 3:0 CC Security: Received a secure message
[2017-01-31 07:52:37.274] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.firstPart = **********
[2017-01-31 07:52:37.274] [I] [zway] Node 3:0 CC Security: passing decrypted packet to application level: [ 71 05 16 01 00 ff 06 02 00 ]
[2017-01-31 07:52:37.274] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.V1event.alarmType = 22 (0x00000016)
[2017-01-31 07:52:37.274] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.V1event.level = 1 (0x00000001)
[2017-01-31 07:52:37.274] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.V1event = Empty
[2017-01-31 07:52:37.274] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.6.eventParameters = byte[0]
[2017-01-31 07:52:37.274] [D] [zway]   ( zero-length buffer )
[2017-01-31 07:52:37.274] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.6.event = 2 (0x00000002)
[2017-01-31 07:52:37.275] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.6.eventString = "Manual Lock Open Operation"
[2017-01-31 07:52:37.275] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.6.status = 255 (0x000000ff)
[2017-01-31 07:52:37.275] [D] [zway] SETDATA devices.3.instances.0.commandClasses.113.data.6 = Empty
[2017-01-31 07:52:37.298] [I] [core] Niffler doorlock alarm event
[2017-01-31 07:52:37.299] [I] [zway] Adding job: Door Lock Operation Get
[2017-01-31 07:52:37.303] [I] [zway] Node 3:0 CC Security: sending Nonce Get
[2017-01-31 07:52:37.303] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-01-31 07:52:37.304] [I] [zway] Adding job: Nonce Get
[2017-01-31 07:52:37.304] [D] [zway] SETDATA devices.3.data.lastNonceGet = 14860 (0x00003a0c)
[2017-01-31 07:52:37.314] [D] [zway] SENDING (cb 0x0f): ( 01 09 00 13 03 02 98 40 05 0F 36 )
[2017-01-31 07:52:37.316] [D] [zway] RECEIVED ACK
[2017-01-31 07:52:37.319] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-01-31 07:52:37.319] [D] [zway] SENT ACK
[2017-01-31 07:52:37.319] [D] [zway] Delivered to Z-Wave stack
[2017-01-31 07:52:40.923] [D] [zway] RECEIVED: ( 01 07 00 13 0F 00 01 68 8D )
[2017-01-31 07:52:40.923] [D] [zway] SENT ACK
[2017-01-31 07:52:40.923] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2017-01-31 07:52:40.923] [D] [zway] SendData Response with callback 0x0f received: received by recipient
[2017-01-31 07:52:40.923] [D] [zway] SETDATA devices.3.data.lastSend = 15217 (0x00003b71)
[2017-01-31 07:52:40.923] [D] [zway] Job 0x13 (Nonce Get): success
[2017-01-31 07:52:40.923] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-01-31 07:52:40.923] [D] [zway] SETDATA devices.3.data.lastNonceGet = 15217 (0x00003b71)
[2017-01-31 07:52:40.923] [I] [zway] Removing job: Nonce Get
[2017-01-31 07:52:40.944] [D] [zway] RECEIVED: ( 01 10 00 04 00 03 0A 98 80 0E 43 44 74 B1 A9 FE B6 D7 )
[2017-01-31 07:52:40.944] [D] [zway] SENT ACK
[2017-01-31 07:52:40.945] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:40.945] [I] [zway] Node 3:0 CC Security: received Nonce Report
[2017-01-31 07:52:40.945] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.rNonce = **********
[2017-01-31 07:52:40.945] [I] [zway] Node 3:0 CC Security: Sending a secure message
[2017-01-31 07:52:40.945] [I] [zway] Node 3:0 CC Security: sending encrypted packet: Door Lock Operation Get
[2017-01-31 07:52:40.945] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.toFollow = False
[2017-01-31 07:52:40.945] [D] [zway] SETDATA devices.3.data.lastNonceGet = Empty
[2017-01-31 07:52:40.945] [I] [zway] Adding job: Security, Door Lock Operation Get
[2017-01-31 07:52:40.995] [D] [zway] SENDING (cb 0x10): ( 01 1D 00 13 03 16 98 81 04 4F A6 7A 33 C5 09 AD 6E B1 64 0E E6 8E C1 18 7B 13 E5 DA 05 10 7E )
[2017-01-31 07:52:40.999] [D] [zway] RECEIVED ACK
[2017-01-31 07:52:41.003] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-01-31 07:52:41.003] [D] [zway] SENT ACK
[2017-01-31 07:52:41.003] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Response received - transfered to encapsulated jobs
[2017-01-31 07:52:41.003] [D] [zway] Delivered to Z-Wave stack
[2017-01-31 07:52:41.027] [D] [zway] RECEIVED: ( 01 07 00 13 10 00 00 02 F9 )
[2017-01-31 07:52:41.028] [D] [zway] SENT ACK
[2017-01-31 07:52:41.028] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Callback received - transfered to encapsulated jobs
[2017-01-31 07:52:41.028] [I] [zway] Job 0x13 (Door Lock Operation Get): Delivered
[2017-01-31 07:52:41.028] [D] [zway] SendData Response with callback 0x10 received: received by recipient
[2017-01-31 07:52:41.028] [D] [zway] Job 0x13 (Door Lock Operation Get): success
[2017-01-31 07:52:41.028] [I] [zway] Removing job: Door Lock Operation Get
[2017-01-31 07:52:41.028] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Delivered
[2017-01-31 07:52:41.028] [D] [zway] SETDATA devices.3.data.lastSend = 15227 (0x00003b7b)
[2017-01-31 07:52:41.028] [D] [zway] Job 0x13 (Security, Door Lock Operation Get): success
[2017-01-31 07:52:41.028] [I] [zway] Removing job: Security, Door Lock Operation Get
[2017-01-31 07:52:41.160] [D] [zway] RECEIVED: ( 01 08 00 04 00 03 02 98 40 2A )
[2017-01-31 07:52:41.160] [D] [zway] SENT ACK
[2017-01-31 07:52:41.161] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:41.161] [I] [zway] Node 3:0 CC Security: sending Nonce Report
[2017-01-31 07:52:41.161] [I] [zway] Adding job: Nonce Report
[2017-01-31 07:52:41.161] [D] [zway] SENDING (cb 0x11): ( 01 11 00 13 03 0A 98 80 CC 07 4E 26 26 21 D5 C3 05 11 4A )
[2017-01-31 07:52:41.171] [D] [zway] RECEIVED ACK
[2017-01-31 07:52:41.171] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-01-31 07:52:41.171] [D] [zway] SENT ACK
[2017-01-31 07:52:41.171] [D] [zway] Delivered to Z-Wave stack
[2017-01-31 07:52:41.191] [D] [zway] RECEIVED: ( 01 07 00 13 11 00 00 02 F8 )
[2017-01-31 07:52:41.191] [D] [zway] SENT ACK
[2017-01-31 07:52:41.191] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-01-31 07:52:41.191] [D] [zway] SendData Response with callback 0x11 received: received by recipient
[2017-01-31 07:52:41.191] [D] [zway] SETDATA devices.3.data.lastSend = 15243 (0x00003b8b)
[2017-01-31 07:52:41.191] [D] [zway] Job 0x13 (Nonce Report): success
[2017-01-31 07:52:41.191] [I] [zway] Removing job: Nonce Report
[2017-01-31 07:52:41.242] [D] [zway] RECEIVED: ( 01 21 00 04 00 03 1B 98 81 D2 93 79 FA A3 68 BD D3 78 9E 38 0A D4 2C 00 EA CC 56 E4 AA 57 62 9C A6 72 D3 )
[2017-01-31 07:52:41.242] [D] [zway] SENT ACK
[2017-01-31 07:52:41.243] [D] [zway] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:41.243] [I] [zway] Node 3:0 CC Security: Received a secure message
[2017-01-31 07:52:41.243] [D] [zway] SETDATA devices.3.instances.0.commandClasses.152.data.firstPart = **********
[2017-01-31 07:52:41.243] [I] [zway] Node 3:0 CC Security: passing decrypted packet to application level: [ 62 03 00 00 02 fe fe ]
[2017-01-31 07:52:41.243] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.mode = 0 (0x00000000)
[2017-01-31 07:52:41.243] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.outsideMode = 0 (0x00000000)
[2017-01-31 07:52:41.243] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.insideMode = 0 (0x00000000)
[2017-01-31 07:52:41.243] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.condition = 2 (0x00000002)
[2017-01-31 07:52:41.243] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.lockMinutes = 254 (0x000000fe)
[2017-01-31 07:52:41.243] [D] [zway] SETDATA devices.3.instances.0.commandClasses.98.data.lockSeconds = 254 (0x000000fe)
[2017-01-31 07:52:45.783] [D] [zway] Job 0x13: deleted from queue
[2017-01-31 07:52:47.120] [D] [zway] Job 0x13: deleted from queue
[2017-01-31 07:52:47.192] [D] [zway] Job 0x13: deleted from queue
[2017-01-31 07:52:47.202] [D] [zway] Job 0x13: deleted from queue
[2017-01-31 07:52:47.406] [D] [zway] Job 0x13: deleted from queue
[2017-01-31 07:52:51.112] [D] [zway] RECEIVED: ( 01 14 00 04 00 02 0E 32 02 21 44 00 00 09 C9 00 19 00 00 09 C9 AF )
[2017-01-31 07:52:51.112] [D] [zway] SENT ACK
[2017-01-31 07:52:51.112] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:51.112] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.0.val = 25.049999
[2017-01-31 07:52:51.112] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.0.delta = 25 (0x00000019)
[2017-01-31 07:52:51.112] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.0.ratetype = 1 (0x00000001)
[2017-01-31 07:52:51.113] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.0.previous = 25.049999
[2017-01-31 07:52:51.113] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.0 = Empty
[2017-01-31 07:52:51.368] [D] [zway] RECEIVED: ( 01 0C 00 04 00 25 06 31 05 02 0A 08 EA 0A )
[2017-01-31 07:52:51.368] [D] [zway] SENT ACK
[2017-01-31 07:52:51.369] [D] [zway] SETDATA devices.37.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:51.369] [D] [zway] SETDATA devices.37.instances.0.commandClasses.49.data.2.deviceScale = 1 (0x00000001)
[2017-01-31 07:52:51.369] [D] [zway] SETDATA devices.37.instances.0.commandClasses.49.data.2.scale = 1 (0x00000001)
[2017-01-31 07:52:51.371] [D] [zway] SETDATA devices.37.instances.0.commandClasses.49.data.2.scaleString = ""
[2017-01-31 07:52:51.371] [D] [zway] SETDATA devices.37.instances.0.commandClasses.49.data.2.val = 2282.000000
[2017-01-31 07:52:51.371] [D] [zway] SETDATA devices.37.instances.0.commandClasses.49.data.2 = Empty
[2017-01-31 07:52:51.385] [I] [core] Notification: device-info (device-generic): {"dev":"Fortrezz Generic (37.0.49.2)","l":"2282.0 null"}
[2017-01-31 07:52:51.817] [D] [zway] RECEIVED: ( 01 14 00 04 00 02 0E 32 02 21 54 00 00 1A 37 00 19 00 00 19 DC 57 )
[2017-01-31 07:52:51.818] [D] [zway] SENT ACK
[2017-01-31 07:52:51.818] [D] [zway] SETDATA devices.2.data.lastReceived = 0 (0x00000000)
[2017-01-31 07:52:51.818] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.2.val = 67.110001
[2017-01-31 07:52:51.818] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.2.delta = 25 (0x00000019)
[2017-01-31 07:52:51.818] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.2.ratetype = 1 (0x00000001)
[2017-01-31 07:52:51.818] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.2.previous = 66.199997
[2017-01-31 07:52:51.818] [D] [zway] SETDATA devices.2.instances.0.commandClasses.50.data.2 = Empty
Re: 2.3.0 and Schlage Lock
Looks the device sends the Notification "Manual door lock/unlock" and then you trap it to make Get on DoorLock. Strange implementation... I would do it completelly different - send DoorLock Report explicitelly
CudaNet
Post by CudaNet »
Well I'll take that as you agree it's a problem. Next steps ?
PoltoS wrote:Looks the device sends the Notification "Manual door lock/unlock" and then you trap it to make Get on DoorLock. Strange implementation... I would do it completelly different - send DoorLock Report explicitelly
brun368
Post by brun368 »
I have the same problem with version 2.3. I can't see the state of my danalock125 in the ZWay UI. If I call http://myip:8083/ZAutomation/api/v1/devices I get an empty field for level of my doorlock:
...{"creationTime":1486663346,"creatorId":1,"customIcons":{},"deviceType":"doorlock","h":987675276,"hasHistory":false,"id":"ZWayVDev_zway_42-0-98","location":2,"metrics":{"level":"","icon":"door","title":..."
@brun368: Sure Danalock reports the state to Z-Way?
@CudaNet: I think this particular device requires a special "legacy" handling. May be special device specific App is required (like there are for some Vision Security devices). This is not on our short term roadmap yet. Apologize. But you can either do it yourself or make a small "fix" via Custom JS Code to bind on the Notification event and do DoorLock.Get()
CudaNet
Post by CudaNet »
SO, I now have an entire house of locks (Yale and Schlage) not reporting a status (rendering them useless)... I'm not a developer and to suggest I write/amend code to fix a problem introduced by Z-way is frustrating at best.
PoltoS wrote:@brun368: Sure Danalock reports the state to Z-Way?
brun368
Post by brun368 »
I downgraded the software to v2.2.5 and now the Danalock reports back again:
..."creationTime":1486808304,"creatorId":1,"deviceType":"doorlock","h":1016304427,"hasHistory":false,"id":"ZWayVDev_zway_42-0-98","location":2,"metrics":{"level":"open","icon":"door","title"...
@brun368
If Danalok is working on 2.2.5 and not in 2.3.0, can you provide us the log for both (same actions) so we can compare and find the problem?
@CudaNet: we will add in our roadmap such a fix.
https://github.com/Z-Wave-Me/home-automation/issues/422
CudaNet
Post by CudaNet »
@PoltoS
Thank you !
PoltoS wrote:@CudaNet: we will add in our roadmap such a fix.
