WALLC (ZME_WCD2) - how to force factory reset?
Traskmannen
Post by Traskmannen » 26 Dec 2017 23:25
I got some 2nd hand Z-wave stuff for Christmas and I need some help getting it to work...
One of the devices is a z-wave.me wall controller WALLC, the label on the backside says "ZME-WCD2".
I am trying to include it in my VeraLIte but it won't work, I guess it was not excluded from its previous network. Does anyone have an idea about how I can factory reset it? I do not have access to the controller to which it previously was connected.
enbemokel
Re: WALLC (ZME_WCD2) - how to force factory reset?
Post by enbemokel » 27 Dec 2017 12:51
You don´t need the original controller, just exclude with your Vera. This should work.
Traskmannen
Post by Traskmannen » 27 Dec 2017 15:08
Thanks for the reply!
For some reason I am not able to neither include nor exclude it, I must be doing something wrong.
What I try (I have Ui7 on my Vera): Go to devices - add devices - choose generic z-wave device and click "retry" before the inclusion timer has finished. "Ready"-light on the VeraLite starts flashing quickly which I think shows it is in exclusion mode. I set the WALLC in management mode by pushing all four buttons for 5 seconds until the WALLC LED slowly flashes green. I then push button 3 (standard inclusion / exclusion) and the led flashes green twice and the red once. The LED on the Vera is now still flashing fast, no difference there. Now absolutely nothing happens, even if I wait for a while.
Clicking "Try adding it again" gets the Vera ready LED to flash slowly (inclusion mode, right?). I set the WALLC in management mode again and push button 3 again. Again two green and a red flash by the LED, further nothing.
What am I missing?
enbemokel
Post by enbemokel » 28 Dec 2017 13:22
Seems you are doing everything correct. How far are you away from the Vera? Maybe you should use Button 1 for NWI.
Also, what happens if you don´t do anything on the Vera and just use the include/exclude from the WallC? Same LED behaviour?
Maybe it´s broken, as you wrote from 2nd hand devices......
Traskmannen
Post by Traskmannen » 29 Dec 2017 21:33
Thanks for the support.
I finally started thinking, and now I solved the problem. The root cause is quite embarrassing. I just put in a fresh battery and now it works as it should... :oops:
Sorry for wasting your time!
enbemokel
Post by enbemokel » 02 Jan 2018 13:33
:-) no problem, it will help others who read this thread ;-)
