Fibaro heat controller / thermostat FGT-001
Posted: 10 Feb 2018 13:18
by phigu
I'm new to this forum. I've been using RaZberry with Z-Wave for a couple of weeks now and it works great. So far this forum has provided all the answers I needed to get my problems solved. Unfortunately, I couldn't find any hints to my current problem.
I managed to include quite a few devices in my Network but now I'm struggling to get my new Fibaro Heat Controller FGT-001 working. The Interview always completes most of the command classes. Nevertheless, the CommandClass "Security" in instance 1 and 2 won't complete. Resetting the device to factory defaults didn't help. Does anyone have a solution to this issue?
Re: Fibaro heat controller / thermostat FGT-001
Posted: 10 Feb 2018 19:22
by phigu
The log says:
Node 30:1 CC Security: secure channel not established on root device - can not interview inside channel
Posted: 14 Feb 2018 03:31
by IgoriokLT
Try to make Insecure Inclusion. Works most of the times with Fibaro devices
Posted: 27 Feb 2018 00:23
by phigu
I've tried secure and insecure inclusion multiple times. Both didn't finish completely.
Posted: 21 Dec 2018 21:53
by pssara
I have the same problem. Anyone solved it?
Posted: 30 Jul 2019 10:53
by aivs
Try to update to 3.0.0.
After adding device wait for the window to appear. Enter pin code. Device should be added with security s2.
Posted: 09 Aug 2019 10:33
by Arek
try to be closer to razzbery (max 2m) with fibaro device during inclusion. In ma case it helps.
