Schlage lock and v2.3.8
Posted: 19 Nov 2018 22:01
I just installed v2.3.8 to try to solve a crash issue, but the new version doesn't work well with my Schlage BE469 locks. The main missing item is the reporting of the lock status when they are locked or unlocked at the keypad. Nothing is reported in the GUI or the history.
However, I can see that the lock is sending status in the logs so I know it is attempting to report something to the Z-way software. With version 2.3.6 I could use the Niffler and that worked well. However, Niffler seems to have been removed and/or doesn't work with v2.3.8.
Also, the v2.3.8 software sees this lock as a keypad, not as a lock. Could that be part of the problem? Regardless, it should report that the keypad lock and unlock happened even if it sees it as a keypad.
Any ideas on how to get this lock to work with v2.3.8? Is there a way to get Niffler to work with it?
