But immediately some questions popped up, which hopefully someone of the experts here can answer:
1. Is it possible, that the devices are not yet fully reflected in the device database?
I can not see detailed configuration options in the standard or the expert UI (configuration tab). Operating standard functions of the device and setting parameters via parameter-number and value work correctly.
2. There are 5 parameters listed in the manual to configure (5 different) alarm behaviour, for example:
Without being an expert, I don't understand the construction of the 4bytes value.31. Alarm configuration - 2nd slot
This parameter determines to which alarm frames and how the device should react. The parameters consist of 4 bytes, three most significant bytes are set according to the official Z-Wave protocol specification.
Parameter size: 4B
Default value: [0x05, 0xFF, 0x00, 0x00]
(Water Alarm, any notification, no action)
Available values:
1B [MSB] – Notification Type
2B – Notification Status
3B – Event/State Parameters
4B [LSB] – action:
0xX0 – no action on output,
0xX1 – turn ON, 0xX2 – turn OFF,
0xX3 – turn ON/OFF continuously,
0x0X – no action on LED frame,
0x1X – LED frame blinks red,
0x2X – LED frame blinks green,
0x4X – LED frame blinks blue,
0x8X – disable LED frame,
0xFX – LED frame LAPD signal (red-white-blue)
Can somebody explain, please?
How can I configure this via API-Call or expert command?
Thanks a lot.
Karsten
