Zipato RFID-Pad App
Posted: 07 Sep 2023 20:02
by aLiEnHeAd
Hi!
I'm using the Zipato RFID-Pad for several years without any problems.
Now I added a new tag, which seemed to work (message "Tag added" in log), but if I use it, I always get the message "Wrong code entering"
I have no clue what could cause this issue. I tried different tags without success.
All tags that were added before work as expected, and adding a new code (instead of using a tag) also works.
Any ideas?
Z-Way version v4.1.2-wb1
Log using non-working tag:
[2023-09-07 18:51:22.510] [I] [zway] Adding job: Get background noise level
[2023-09-07 18:51:22.517] [D] [zway] SENDING: ( 01 03 00 3B C7 )
[2023-09-07 18:51:22.518] [D] [zway] RECEIVED ACK
[2023-09-07 18:51:22.519] [D] [zway] RECEIVED: ( 01 07 01 3B 9B 97 97 7F 26 )
[2023-09-07 18:51:22.520] [D] [zway] SENT ACK
[2023-09-07 18:51:22.520] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel1 = 155 (0x0000009b)
[2023-09-07 18:51:22.520] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel2 = 151 (0x00000097)
[2023-09-07 18:51:22.520] [D] [zway] SETDATA controller.data.statistics.backgroundRSSI.channel3 = 151 (0x00000097)
[2023-09-07 18:51:22.521] [I] [zway] Job 0x3b (Get background noise level): RSSI Ch#1: -101 dBm, Ch#2: -105 dBm, Ch#3: -105 dBm
[2023-09-07 18:51:22.521] [D] [zway] Job 0x3b (Get background noise level): success
[2023-09-07 18:51:22.521] [I] [zway] Removing job: Get background noise level
[2023-09-07 18:51:23.263] [D] [zway] RECEIVED: ( 01 17 00 04 00 11 0E 63 03 00 00 8F 92 81 F2 93 50 01 04 00 00 C0 00 00 FB )
[2023-09-07 18:51:23.263] [D] [zway] SENT ACK
[2023-09-07 18:51:23.264] [D] [zway] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2023-09-07 18:51:23.264] [D] [zway] SETDATA devices.17.instances.0.commandClasses.99.data.0.status = 0 (0x00000000)
[2023-09-07 18:51:23.264] [D] [zway] Invalid UTF8 string: ▒▒▒▒P
[2023-09-07 18:51:23.264] [E] [zway] Error returned from zdata_set_string(codeDH, buffer, TRUE): Bad arguments (-1)
[2023-09-07 18:51:23.265] [D] [zway] SETDATA devices.17.instances.0.commandClasses.99.data.0.hasCode = True
[2023-09-07 18:51:23.265] [D] [zway] SETDATA devices.17.instances.0.commandClasses.99.data.0 = Empty
[2023-09-07 18:51:23.275] [I] [core] Notification: notification (module): Wrong code entering
[2023-09-07 18:51:23.307] [D] [zway] RECEIVED: ( 01 0B 00 04 00 11 02 84 07 C0 00 00 A0 )
[2023-09-07 18:51:23.307] [D] [zway] SENT ACK
[2023-09-07 18:51:23.308] [D] [zway] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2023-09-07 18:51:23.308] [I] [zway] Node 17:0 CC Wakeup: Wakeup notification
[2023-09-07 18:51:23.308] [D] [zway] SETDATA devices.17.instances.0.commandClasses.132.data.lastWakeup = 1694105483 (0x64f9ff8b)
[2023-09-07 18:51:23.308] [D] [zway] SETDATA devices.17.data.isAwake = True
[2023-09-07 18:51:23.308] [D] [zway] SETDATA devices.17.data.lastSendInternal = **********
[2023-09-07 18:51:23.308] [D] [zway] SETDATA devices.17.data.lastNonceGet = 1937 (0x00000791)
[2023-09-07 18:51:23.308] [D] [zway] Running wakeup handler for node 17
[2023-09-07 18:51:23.308] [D] [zway] SETDATA devices.17.instances.0.commandClasses.132.data.lastSleep = 1694105483 (0x64f9ff8b)
[2023-09-07 18:51:23.308] [I] [zway] Node 17:0 CC Wakeup: Send node to sleep
[2023-09-07 18:51:23.309] [I] [zway] Adding job: Wakeup Sleep to node 17
[2023-09-07 18:51:23.309] [D] [zway] SENDING (cb 0x14): ( 01 09 00 13 11 02 84 08 05 14 6B )
[2023-09-07 18:51:23.311] [D] [zway] RECEIVED ACK
[2023-09-07 18:51:23.312] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2023-09-07 18:51:23.313] [D] [zway] SENT ACK
[2023-09-07 18:51:23.313] [D] [zway] Delivered to Z-Wave stack
[2023-09-07 18:51:23.468] [D] [zway] RECEIVED: ( 01 1D 00 13 14 00 00 0F 01 C0 7F 7F 7F 7F 01 01 03 13 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 47 )
[2023-09-07 18:51:23.468] [D] [zway] SENT ACK
[2023-09-07 18:51:23.469] [I] [zway] Job 0x13 (Wakeup Sleep to node 17): Delivered
[2023-09-07 18:51:23.469] [D] [zway] SendData Response with callback 0x14 received: received by recipient
[2023-09-07 18:51:23.469] [D] [zway] SETDATA devices.17.data.lastSendInternal = **********
[2023-09-07 18:51:23.469] [D] [zway] SETDATA devices.17.data.lastSend = 2951 (0x00000b87)
[2023-09-07 18:51:23.469] [D] [zway] Job 0x13 (Wakeup Sleep to node 17): success
[2023-09-07 18:51:23.470] [D] [zway] SETDATA devices.17.data.isAwake = False
[2023-09-07 18:51:23.470] [D] [zway] Sending the queue for node 17 into sleep
[2023-09-07 18:51:23.470] [I] [zway] Removing job: Wakeup Sleep to node 17
Log of working tag:
[2023-09-07 18:52:42.830] [D] [zway] Job 0x3b: deleted from queue
[2023-09-07 18:52:46.196] [D] [zway] RECEIVED: ( 01 13 00 04 00 11 0A 71 05 00 FF 00 FF 06 05 01 03 BD 00 00 3B )
[2023-09-07 18:52:46.196] [D] [zway] SENT ACK
[2023-09-07 18:52:46.197] [D] [zway] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2023-09-07 18:52:46.197] [D] [zway] SETDATA devices.17.instances.0.commandClasses.113.data.6.5.status = True
[2023-09-07 18:52:46.197] [D] [zway] SETDATA devices.17.instances.0.commandClasses.113.data.6.5.parameters = byte[1]
[2023-09-07 18:52:46.197] [D] [zway]   ( 03 )
[2023-09-07 18:52:46.197] [D] [zway] SETDATA devices.17.instances.0.commandClasses.113.data.6.5 = Empty
[2023-09-07 18:52:46.198] [D] [zway] SETDATA devices.17.instances.0.commandClasses.113.data.6.status = True
[2023-09-07 18:52:46.198] [D] [zway] SETDATA devices.17.instances.0.commandClasses.113.data.6 = Empty
[2023-09-07 18:52:46.207] [I] [zway] Adding job: Configuration Set to node 17
[2023-09-07 18:52:46.207] [I] [zway] Adding job: Configuration Get to node 17
[2023-09-07 18:52:46.208] [I] [core] ---  ZWayVDev_zway_17-0-37 performCommand processing: {"0":"on"}
[2023-09-07 18:52:46.209] [I] [zway] Adding job: SwitchBinary Set to node 17
[2023-09-07 18:52:46.210] [I] [zway] Adding job: SwitchBinary Get to node 17
[2023-09-07 18:52:46.242] [D] [zway] RECEIVED: ( 01 0B 00 04 00 11 02 84 07 BD 00 00 DD )
[2023-09-07 18:52:46.242] [D] [zway] SENT ACK
[2023-09-07 18:52:46.243] [D] [zway] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2023-09-07 18:52:46.243] [I] [zway] Node 17:0 CC Wakeup: Wakeup notification
[2023-09-07 18:52:46.243] [D] [zway] SETDATA devices.17.instances.0.commandClasses.132.data.lastWakeup = 1694105566 (0x64f9ffde)
[2023-09-07 18:52:46.243] [D] [zway] SETDATA devices.17.data.isAwake = True
[2023-09-07 18:52:46.244] [D] [zway] SETDATA devices.17.data.lastSendInternal = **********
[2023-09-07 18:52:46.244] [D] [zway] SETDATA devices.17.data.lastNonceGet = 10044 (0x0000273c)
[2023-09-07 18:52:46.244] [D] [zway] Running wakeup handler for node 17
[2023-09-07 18:52:46.244] [D] [zway] SETDATA devices.17.instances.0.commandClasses.132.data.lastSleep = 1694105566 (0x64f9ffde)
[2023-09-07 18:52:46.244] [I] [zway] Node 17:0 CC Wakeup: Send node to sleep
[2023-09-07 18:52:46.245] [I] [zway] Adding job: Wakeup Sleep to node 17
[2023-09-07 18:52:46.245] [D] [zway] SENDING (cb 0x1a): ( 01 0C 00 13 11 05 70 04 02 01 0F 05 1A 93 )
[2023-09-07 18:52:46.247] [D] [zway] RECEIVED ACK
[2023-09-07 18:52:46.249] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2023-09-07 18:52:46.249] [D] [zway] SENT ACK
[2023-09-07 18:52:46.249] [D] [zway] Delivered to Z-Wave stack
[2023-09-07 18:52:46.411] [D] [zway] RECEIVED: ( 01 1D 00 13 1A 00 00 0F 01 BD 7F 7F 7F 7F 01 01 03 13 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 34 )
[2023-09-07 18:52:46.411] [D] [zway] SENT ACK
[2023-09-07 18:52:46.412] [I] [zway] Job 0x13 (Configuration Set to node 17): Delivered
[2023-09-07 18:52:46.412] [D] [zway] SendData Response with callback 0x1a received: received by recipient
[2023-09-07 18:52:46.413] [D] [zway] SETDATA devices.17.data.lastSendInternal = **********
[2023-09-07 18:52:46.413] [D] [zway] SETDATA devices.17.data.lastSend = 11059 (0x00002b33)
[2023-09-07 18:52:46.413] [D] [zway] Job 0x13 (Configuration Set to node 17): success
[2023-09-07 18:52:46.413] [I] [zway] Removing job: Configuration Set to node 17
[2023-09-07 18:52:46.455] [D] [zway] SENDING (cb 0x1b): ( 01 0A 00 13 11 03 70 05 02 05 1B 9D )
[2023-09-07 18:52:46.457] [D] [zway] RECEIVED ACK
[2023-09-07 18:52:46.459] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2023-09-07 18:52:46.459] [D] [zway] SENT ACK
[2023-09-07 18:52:46.459] [D] [zway] Delivered to Z-Wave stack
[2023-09-07 18:52:46.500] [D] [zway] RECEIVED: ( 01 1D 00 13 1B 00 00 03 01 BD 7F 7F 7F 7F 01 01 03 13 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 39 )
[2023-09-07 18:52:46.501] [D] [zway] SENT ACK
[2023-09-07 18:52:46.501] [I] [zway] Job 0x13 (Configuration Get to node 17): Delivered
[2023-09-07 18:52:46.502] [D] [zway] SendData Response with callback 0x1b received: received by recipient
[2023-09-07 18:52:46.502] [D] [zway] SETDATA devices.17.data.lastSendInternal = **********
[2023-09-07 18:52:46.502] [D] [zway] SETDATA devices.17.data.lastSend = 11066 (0x00002b3a)
[2023-09-07 18:52:46.502] [D] [zway] Job 0x13 (Configuration Get to node 17): success
[2023-09-07 18:52:46.503] [I] [zway] Waiting for job reply: Configuration Get from node 17
[2023-09-07 18:52:46.547] [D] [zway] RECEIVED: ( 01 0E 00 04 00 11 05 70 06 02 01 0F BD 00 00 26 )
[2023-09-07 18:52:46.548] [D] [zway] SENT ACK
[2023-09-07 18:52:46.548] [D] [zway] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2023-09-07 18:52:46.548] [D] [zway] Received reply on job (Configuration Get to node 17)
[2023-09-07 18:52:46.549] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.2.size = 1 (0x00000001)
[2023-09-07 18:52:46.549] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.2.val = 15 (0x0000000f)
[2023-09-07 18:52:46.549] [D] [zway] SETDATA devices.17.instances.0.commandClasses.112.data.2 = Empty
[2023-09-07 18:52:46.549] [I] [zway] Node 17:0 CC Configuration: Parameter 0x0002 = 15 (size = 1)
[2023-09-07 18:52:46.550] [D] [zway] SENDING (cb 0x1c): ( 01 0A 00 13 11 03 25 01 FF 05 1C 36 )
[2023-09-07 18:52:46.552] [D] [zway] RECEIVED ACK
[2023-09-07 18:52:46.553] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2023-09-07 18:52:46.553] [D] [zway] SENT ACK
[2023-09-07 18:52:46.553] [D] [zway] Delivered to Z-Wave stack
[2023-09-07 18:52:46.673] [D] [zway] RECEIVED: ( 01 1D 00 13 1C 00 00 0B 01 BE 7F 7F 7F 7F 01 01 03 13 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 35 )
[2023-09-07 18:52:46.674] [D] [zway] SENT ACK
[2023-09-07 18:52:46.674] [I] [zway] Job 0x13 (SwitchBinary Set to node 17): Delivered
[2023-09-07 18:52:46.675] [D] [zway] SendData Response with callback 0x1c received: received by recipient
[2023-09-07 18:52:46.675] [D] [zway] SETDATA devices.17.data.lastSendInternal = **********
[2023-09-07 18:52:46.675] [D] [zway] SETDATA devices.17.data.lastSend = 11081 (0x00002b49)
[2023-09-07 18:52:46.675] [D] [zway] Job 0x13 (SwitchBinary Set to node 17): success
[2023-09-07 18:52:46.676] [I] [zway] Removing job: SwitchBinary Set to node 17
[2023-09-07 18:52:46.717] [D] [zway] SENDING (cb 0x1d): ( 01 09 00 13 11 02 25 02 05 1D C9 )
[2023-09-07 18:52:46.719] [D] [zway] RECEIVED ACK
[2023-09-07 18:52:46.721] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2023-09-07 18:52:46.721] [D] [zway] SENT ACK
[2023-09-07 18:52:46.721] [D] [zway] Delivered to Z-Wave stack
[2023-09-07 18:52:46.764] [D] [zway] RECEIVED: ( 01 1D 00 13 1D 00 00 04 01 BE 7F 7F 7F 7F 01 01 03 13 00 00 00 02 01 00 00 7F 7F 7F 7F 7F 3B )
[2023-09-07 18:52:46.764] [D] [zway] SENT ACK
[2023-09-07 18:52:46.765] [I] [zway] Job 0x13 (SwitchBinary Get to node 17): Delivered
[2023-09-07 18:52:46.765] [D] [zway] SendData Response with callback 0x1d received: received by recipient
[2023-09-07 18:52:46.766] [D] [zway] SETDATA devices.17.data.lastSendInternal = **********
[2023-09-07 18:52:46.766] [D] [zway] SETDATA devices.17.data.lastSend = 11088 (0x00002b50)
[2023-09-07 18:52:46.766] [D] [zway] Job 0x13 (SwitchBinary Get to node 17): success
[2023-09-07 18:52:46.766] [I] [zway] Waiting for job reply: SwitchBinary Get from node 17
[2023-09-07 18:52:46.811] [D] [zway] RECEIVED: ( 01 0C 00 04 00 11 03 25 03 FF BE 00 00 82 )
[2023-09-07 18:52:46.811] [D] [zway] SENT ACK
[2023-09-07 18:52:46.812] [D] [zway] SETDATA devices.17.data.lastReceived = 0 (0x00000000)
[2023-09-07 18:52:46.812] [D] [zway] Received reply on job (SwitchBinary Get to node 17)
[2023-09-07 18:52:46.812] [D] [zway] SETDATA devices.17.instances.0.commandClasses.37.data.level = True
[2023-09-07 18:52:46.812] [D] [zway] SENDING (cb 0x1e): ( 01 09 00 13 11 02 84 08 05 1E 61 )
[2023-09-07 18:52:46.815] [D] [zway] RECEIVED ACK
[2023-09-07 18:52:46.816] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2023-09-07 18:52:46.816] [D] [zway] SENT ACK
[2023-09-07 18:52:46.816] [D] [zway] Delivered to Z-Wave stack
[2023-09-07 18:52:46.823] [I] [core] Notification: device-info (device-OnOff): {"dev":"Wintop Switch (#17)","l":"on","location":5}
Re: Zipato RFID-Pad App
Posted: 10 Sep 2023 13:57
by aLiEnHeAd
I finally succeeded by adding the tag via HTTP API:
http://<ip>:8083/ZWave.zway/Run/devices[17].instances[0].commandClasses[99].SetRaw(6,[0x8F,0x92,0x81,0xF2,0x93,0x50,0x01,0x04,0x00,0x00],1)
where "6" is the code id in the app
So it seems the adding of tags via the Zipato RFID Keypad App is broken
