[HowTo] Installation on HummingBoard i2eX
Mirar
Re: HummingBoard i2eX
Post by Mirar »
Tell how it went. How much faster is the HummingBoard?
Chopper_Rob
Post by Chopper_Rob »
After changing the setting in the gui it worked immediately.
I have now moved my domoticz installation to the hummingboard and it seems to be much quicker. Still have to do some additional testing but everything seems to be working correct.
A small issue is the heatsink on the hummingboard. The heatsink is next to the IO pins and is also heigher then the pins. So the razberry does not fit by default. For the time being i put a couple of wires between the pins on the hummingboard and the razberry module, but i will replace them for something better.
Nice work. Could one of you make a step by step description in the Recipes subforum
thanks, moderator
Chopper_Rob
sure, i was already thinking about doing a new install just to see what the exact changes are that needs to be done. But it might take a while because of the lack of time. :P
Nadhyr
Post by Nadhyr »
@Chopper_Rob
I followed your tutorial to install domoticz on hummingboard i2ex.
I try to install razberry, but i can't installé correctly it.
Did you have another tutorial about this razberry gpio.
I hope you will help me. Thanks un advance.
Nadhyr
Post by Nadhyr »
zoic22 wrote:I find how to solve that :
- systemctl mask serial-getty@ttymxc0.servic
- edit /boot/uEnv.txt and remove reference to ttymxc0 (console=ttymxc0,xxxx)
Hi can you explain me how to make your solution ??
Thanks in advance
Nadhyr
Post by Nadhyr »
Hello everyone. I found a solution to my problem, after a week of crazy research. Many readers but few contributors.
So I wanted to share the solution I found.
My goal is to build a home automation box.
Moderator note: The actual instruction has been moved from here as final solution to the first post of this topic
Re: HummingBoard i2eX [Solved, see p2]
Made the topic sticky and updated the title to let other people easily find the recipe. Thanks for sharing this
Moderator note: This topic has been moved to the Recipes section
