Z-uno and Arduino 1.6.7 troubles
velib
Post by velib »
Hi!
Cannot burn a bootloader. Error:
java.lang.NullPointerException
	at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:314)
	at processing.app.Editor.lambda$handleBurnBootloader$42(Editor.java:2754)
	at java.lang.Thread.run(Thread.java:745)
Error while burning bootloader.
Also cannot compile a example code:
exec: "C:\\Users\\Евгений\\AppData\\Local\\Arduino15\\packages\\Z-Uno\\tools\\zuno_toolchain\\00.02.10/zuno_toolchain/": file does not exist
Error compiling.
michap
Re: Z-uno and Arduino 1.6.7 troubles
Post by michap »
Please use Arduino 1.6.5
Michael
velib
Post by velib »
michap wrote:Please use Arduino 1.6.5
Michael
Hi Michael,
unfortunately I faced with troubles again.
Installed Arduino 1.6.5 with z-wave 0.6.3.
Bootloader not uploads. Errors:
	at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:306)
	at processing.app.Editor$59.run(Editor.java:2578)
	at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:709)
	at java.awt.EventQueue$3.run(EventQueue.java:703)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Uploading the sketch stops and stage of compilation:
usage: compiler.exe [-h] {size,build,prog,boot,erase,readnvm} ...
compiler.exe: error: unrecognized arguments: and Settings\Admin\Application Data\Arduino15\packages\Z-Uno\hardware\zw8051\0.6.3 and Settings\Admin\Application Data\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.02.10/zuno_toolchain/sdcc/bin/
C:\Documents возвратил 2
Ошибка компиляции.
michap
Post by michap »
send me please your sketch via PM - I will try it.
Michael
velib
Post by velib »
michap wrote:send me please your sketch via PM - I will try it.
I tried sketch from examples - multisensor.
Michael
