I just discovered a strange behavior of the arduino environment. If the name of your sketch contains a dot a compiler error is thrown...
My sketch was named Multisensor_ah2, I made some modifications and wanted to save it as version 2.1 and named it Multisensor_ah2.1. The resulting error code is not very helpfull and it took me half an hour to figure out what was going on as I suspected my changes caused the error...
I don't know if the problem comes from the base arduino 1.65 environment or the Z-Uno add-on...
Regards,
Andreas.
Arduino: 1.6.5 (Windows 8.1), Platine: "Z-Wave>ME Z-Uno, Europe, Disabled, Disabled"
Verwende die Bibliothek ZUNO_DHTlib im Ordner: C:\Users\andre\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\2.0.6\libraries\ZUNO_DHTlib (legacy)
Verwende die Bibliothek ZUNO_BMP180 im Ordner: C:\Users\andre\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\2.0.6\libraries\ZUNO_BMP180 (legacy)
Verwende die Bibliothek ZUNO_DS18B20 im Ordner: C:\Users\andre\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\2.0.6\libraries\ZUNO_DS18B20 (legacy)
Verwende die Bibliothek ZUNO_OLED_I2C im Ordner: C:\Users\andre\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\2.0.6\libraries\ZUNO_OLED_I2C (legacy)
C:\Users\andre\AppData\Roaming\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.08.10/zuno_toolchain/compiler build C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp/Multisensor_ah2.1.cpp -r C:\Users\andre\AppData\Roaming\Arduino15\packages\Z-Uno\hardware\zw8051\2.0.6
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Print.cpp with SDCPP...
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Print_sdcpp_.cpp ...
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Stream.cpp with SDCPP...
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Stream_sdcpp_.cpp ...
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HardwareSerial.cpp with SDCPP...
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HardwareSerial_sdcpp_.cpp ...
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HLCore.cpp with SDCPP...
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HLCore_sdcpp_.cpp ...
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DHT.cpp with SDCPP...
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DHT_sdcpp_.cpp ...
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Wire.cpp with SDCPP...
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Wire_sdcpp_.cpp ...
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_BMP180.cpp with SDCPP...
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_BMP180_sdcpp_.cpp ...
ZUNO_BMP180_sdcpp_.cpp:516:1:warning:control may reach end of non-void function
ZUNO_BMP180_sdcpp_.cpp:519:16:warning:conversion from string literal to 'char *' is deprecated
ZUNO_BMP180_sdcpp_.cpp:520:16:warning:conversion from string literal to 'char *' is deprecated
ZUNO_BMP180_sdcpp_.cpp:521:16:warning:conversion from string literal to 'char *' is deprecated
ZUNO_BMP180_sdcpp_.cpp:522:16:warning:conversion from string literal to 'char *' is deprecated
ZUNO_BMP180_sdcpp_.cpp:523:16:warning:conversion from string literal to 'char *' is deprecated
ZUNO_BMP180_sdcpp_.cpp:524:16:warning:conversion from string literal to 'char *' is deprecated
ZUNO_BMP180_sdcpp_.cpp:526:16:warning:conversion from string literal to 'char *' is deprecated
ZUNO_BMP180_sdcpp_.cpp:527:16:warning:conversion from string literal to 'char *' is deprecated
ZUNO_BMP180_sdcpp_.cpp:529:16:warning:conversion from string literal to 'char *' is deprecated
ZUNO_BMP180_sdcpp_.cpp:531:16:warning:conversion from string literal to 'char *' is deprecated
ZUNO_BMP180_sdcpp_.cpp:532:16:warning:conversion from string literal to 'char *' is deprecated
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OneWire.cpp with SDCPP...
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OneWire_sdcpp_.cpp ...
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DS18B20.cpp with SDCPP...
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DS18B20_sdcpp_.cpp ...
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OLED_I2C.cpp with SDCPP...
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OLED_I2C_sdcpp_.cpp ...
Preprocessing file: C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\_Multisensor_ah2.1.cpp with SDCPP...
Multisensor_ah2.1.ino:33:1: warning: "SCL_PIN" redefined
In file included from Multisensor_ah2.1.ino:12:
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\/Wire.h:30:1: error: this is the location of the previous definition
Multisensor_ah2.1.ino:34:1: warning: "SDA_PIN" redefined
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\/Wire.h:31:1: error: this is the location of the previous definition
Compiling C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\_Multisensor_ah2.1_sdcpp_.cpp ...
Multisensor_ah2.1.ino:128:14:warning:conversion from string literal to 'char *' is deprecated
Multisensor_ah2.1.ino:132:14:warning:conversion from string literal to 'char *' is deprecated
Multisensor_ah2.1.ino:134:16:warning:conversion from string literal to 'char *' is deprecated
Multisensor_ah2.1.ino:136:14:warning:conversion from string literal to 'char *' is deprecated
Multisensor_ah2.1.ino:138:16:warning:conversion from string literal to 'char *' is deprecated
Multisensor_ah2.1.ino:138:16:warning:conversion from string literal to 'char *' is deprecatedCompiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\LLCore_arduino.c" by means of SDCC...
sdcc: Calling preprocessor...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\LLCore_arduino.c"
sdcc: Generating code...
sdcc: Calling assembler...
sdcc: sdas8051.exe -plosgffw "LLCore_arduino.rel" "LLCore_arduino".asm
at 1: warning 119: don't know what to do with file ''. file extension unsupported
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\LLCore_arduino.c:25: warning 85: in function NOPS unreferenced function argument : 'i'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\LLCore_arduino.c:208: warning 85: in function delayMicroseconds unreferenced function argument : 'value'
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Print_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Print_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Print_ucxx.rel" "Print_ucxx".asm
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Print_ucxx.c:160: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Print_ucxx.c:161: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Print_ucxx.c:326: warning 85: in function __cxx__Print__method__write0105 unreferenced local variable : 'cxx_sloc'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Print_ucxx.c:392: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Print_ucxx.c:401: warning 93: type 'double' not supported assuming 'float'
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Stream_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Stream_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Stream_ucxx.rel" "Stream_ucxx".asm
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Stream_ucxx.c:160: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Stream_ucxx.c:161: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Stream_ucxx.c:242: warning 85: in function __cxx__Stream__method__read00 unreferenced local variable : 'cxx_sloc'
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HardwareSerial_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HardwareSerial_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HardwareSerial_ucxx.rel" "HardwareSerial_ucxx".asm
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HardwareSerial_ucxx.c:160: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HardwareSerial_ucxx.c:161: warning 93: type 'double' not supported assuming 'float'
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HLCore_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HLCore_ucxx.c"
sdcc: sdas8051.exe -plosgffw "HLCore_ucxx.rel" "HLCore_ucxx".asm
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HLCore_ucxx.c:173: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\HLCore_ucxx.c:174: warning 93: type 'double' not supported assuming 'float'
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DHT_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DHT_ucxx.c"
sdcc: sdas8051.exe -plosgffw "ZUNO_DHT_ucxx.rel" "ZUNO_DHT_ucxx".asm
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DHT_ucxx.c:173: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DHT_ucxx.c:174: warning 93: type 'double' not supported assuming 'float'
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Wire_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Wire_ucxx.c"
sdcc: sdas8051.exe -plosgffw "Wire_ucxx.rel" "Wire_ucxx".asm
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Wire_ucxx.c:173: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Wire_ucxx.c:174: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\Wire_ucxx.c:890: warning 85: in function __cxx__TwoWire__method__endTransmission0105 unreferenced function argument : 'stop'
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_BMP180_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_BMP180_ucxx.c"
sdcc: sdas8051.exe -plosgffw "ZUNO_BMP180_ucxx.rel" "ZUNO_BMP180_ucxx".asm
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_BMP180_ucxx.c:160: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_BMP180_ucxx.c:161: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_BMP180_ucxx.c:414: warning 59: function '__cxx__ZUNO_BMP180__method__begin0105' must return value
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OneWire_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OneWire_ucxx.c"
sdcc: sdas8051.exe -plosgffw "ZUNO_OneWire_ucxx.rel" "ZUNO_OneWire_ucxx".asm
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OneWire_ucxx.c:173: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OneWire_ucxx.c:174: warning 93: type 'double' not supported assuming 'float'
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DS18B20_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DS18B20_ucxx.c"
sdcc: sdas8051.exe -plosgffw "ZUNO_DS18B20_ucxx.rel" "ZUNO_DS18B20_ucxx".asm
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DS18B20_ucxx.c:160: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_DS18B20_ucxx.c:161: warning 93: type 'double' not supported assuming 'float'
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OLED_I2C_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OLED_I2C_ucxx.c"
sdcc: sdas8051.exe -plosgffw "ZUNO_OLED_I2C_ucxx.rel" "ZUNO_OLED_I2C_ucxx".asm
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OLED_I2C_ucxx.c:159: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\ZUNO_OLED_I2C_ucxx.c:160: warning 93: type 'double' not supported assuming 'float'
Compiling file "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\_Multisensor_ah2.1_ucxx.c" by means of SDCC...
sdcc: sdcpp.exe -nostdinc -Wall -obj-ext=.rel -D__SDCC_STACK_AUTO -D__SDCC_MODEL_LARGE -D__SDCC_INT_LONG_REENT -D__SDCC_FLOAT_REENT -D__SDCC=3_5_0 -DSDCC=350 -D__SDCC_REVISION=9253 -D__SDCC_mcs51 -D__STDC_NO_COMPLEX__ -D__STDC_NO_THREADS__ -D__STDC_NO_ATOMICS__ -D__STDC_NO_VLA__ -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include\mcs51" -isystem "C:\Users\andre\AppData\Roaming\ARDUIN~1\packages\Z-Uno\tools\ZUNO_T~1\0008~1.10\ZUNO_T~1/sdcc/\bin\..\include" "C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\_Multisensor_ah2.1_ucxx.c"
sdcpp.exe: fatal error: when writing output to : Broken pipe
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\_Multisensor_ah2.1_ucxx.c:159: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\_Multisensor_ah2.1_ucxx.c:160: warning 93: type 'double' not supported assuming 'float'
C:\Users\andre\AppData\Local\Temp\build3715662809022207532.tmp\_Multisensor_ah2.1_ucxx.c:515: syntax error: token -> '.1' ; column 38
Error. SDCC returned: 1
Fehler beim Kompilieren.
