Sleep + DHT lib is not very stable.
Developers are checking this.
Even my workaround (above) is not working stable for a long time.
Michael
Z-Uno with battery
Re: Z-Uno with battery
When z-uno is sleeping no LED is on. Every 4 min green is on for about 4 seconds. I tried several settings. (wakeup was the first). I even make a soft configuration at HC2 which means the device is excluded, read parameters from the board following inclusion. The device id will stay.
The effect is that z-uno module disappear. But the impressive matter is that z-uno send date every 4 min as well.
There must be a value stored in z-uno forced the device to do so. ???? Such things have to be part of z-wave rules??
Reporting seems stable to me. Before softconfiguration i see values every 4 min in event-log. Live of battery is about the double.
(So z-uno was not in direct access of HC2 I try softconfig once more)
