Release candidate for Z-Uno software version 2.0.7
Post by PoltoS » 06 Dec 2016 23:55
Dear advanced users!
We have released test version 2.0.7 for Z-Uno. To test it please follow this instruction: Change package source URL to http://z-uno.z-wave.me/files/z-uno/test ... index.json. Remove current Z-Uno file (better on the filesystem). Install 2.0.7 from Board Manager.
New features in 2.0.7:
  • IR controller
    - Learn IR commands into mark/space sequence
    - Send IR commands from mark/space sequence
    - Comparison of mark/space sequences
    - Coding/decoding for popular IR protocols: SONY/NEC/LG/RC5/RC6/SAMSUNG/PANASONIC
    - 3 ready to go sketches in examples: IRScanner/IR2ZWave/ZWave2IR
  • Meter Command Class
    - COMMAND_CLASS_METER version 4 support
    - Example for two channels (hot/cold) water meter: WaterMeter
  • Libraries:
    - New library ZUNO_MCP4725 for I2C DAC MCP4725. Community contribution by @michap.
    - New library ZUNO_BH1750 for light sensor BH1750. Community contribution by @A.Harrenberg
    - ZUNO_ONEWIRE lib can now scan the bus.
    - ZUNO_DS18B20 lib can search for all DS18B20 on the OneWire bus. Added example: DS18B20Sacnner.
    - ZMEKeypad new function isIdled() added to the lib to check if buttons are active or idle (to go to sleep only on idle).
  • Compatibility:
    - New parameter #12 added for correct work of Sensor Binary/Notification channels in Fibaro Home Center 2/Lite.
Fixes:
  • uCxx Compiler:
    - Multidimensional arrays definition fixed.
    - Dots in file names now work.
    - // comments in ZUNO_* macro work.
    - Warinings on local char * supressed.
    - Optimized pointer to this to minimize stack usage.
    - Optimized pointers parameters in function calls to minimize stack usage. All but char are now passed via XDATA instead of generic pointers.
    - Changed flags to SDCC to minimize stack usage (removed SLOCs).
    - Keypad restart after sleep fixed.
    - delayMicroseconds() precision up to 1 microsecond.
  • Libraries:
    - Wire. Bug with two bytes locations. Affected 16-bit registers in BMP180.
    - ZUNO_BMP180. Fixed inaccurate rounding of pressure.
    - ZUNO_ONEWIRE. Fixed intervals in OneWire bus handling with accurate delayMicroseconds.
    - ZUNO_DS18B20. Fixed timings depending on sensor resolution. Fixed problem with negative values. Thanks to @michap for contribution.
michap
Re: Release candidate for Z-Uno software version 2.0.7
Post by michap » 07 Dec 2016 12:10
I have different problems with 2.07 compairing with 2.06
Some calculations get wrong and some calls do not work more inside my libs (I had to make these calls more correct)
So a good testing would be fine (not sure, I'm the only one with problems ;) ....)
(Working) sketchs seems to be smaller after compiling.
Michael
A.Harrenberg
Post by A.Harrenberg » 07 Dec 2016 14:31
I updated yesterday night and did some very short testing this morning while eating my breakfast...
I also noted something strange... I am at work now, so I have to describe it based on my (limited) memory..
I have a byte declared in one function, let's say
byte bufferSize = sizeof(buffer_array);
, which is "2" as the array is defined with size 2. Then a pointer to that variable is passed to another function call. Like this:
testfunction( &bufferSize);
where testfunction is declared as "testfunction (byte *size)"
In "testfunction" the variable size is evaluated as "0" and not "2", so something seems to be wrong when passing arguments.
I don't know what this:
exactly means, but I guess it is connected to what I see here.
Regards,
Andreas.
p0lyg0n1
Post by p0lyg0n1 » 07 Dec 2016 16:45
Hi, Andreas.
Can you, please, check the same code with this:
static byte bufferSize;
This code will be 100% work if you create bufferSize in the global area.
A.Harrenberg
Post by A.Harrenberg » 07 Dec 2016 16:54
I can only try this earliest tomorrow evening and will give a feedback as soon as I have analyzed it.
Regards,
Andreas.
michap
Post by michap » 07 Dec 2016 17:36
Can you tell me why this is not working more?
(was working in 2.0.6)
long uP; //defined in .h file
char data[8]; //defined in .h file
in .cpp file:
uP = (data[0]*4096) + (data[1]*16) + (data[2]/16) ;
result will be wrong, like 79*4096+ 108*16 + 48/16 -> 4294963200
(printed out from debug print)
Already tried different things (with (long) inside ... etc.) , no idea.
Michael
michap
Post by michap » 07 Dec 2016 22:47
Some more details:
Working only (in 2.0.7):
uT = (int32_t)(data[3])*4096 + (int32_t)(data[4])*16 + data[5]/16;
And Working:
  uT = (int32_t)data[3] << 16;
  uT |= (int32_t)data[4] << 8;
  uT |= data[5];
  uT = uT >> 4;
Michael
p0lyg0n1
Post by p0lyg0n1 » 08 Dec 2016 00:22
It have to fail on 2.0.6 too....
Just do it together step by step.
There are some very important moments for 8051 that we have to check and discuss.
1. Check the code. "The black box" method.
Just create a simple sketch with your code inside:
char data[8]={79,108,48,00,00,00,00,00}; //defined in .h file
void setup() {
  // put your setup code here, to run once:
  Serial.begin();
void loop() {
  // put your main code here, to run repeatedly:
  Serial.print("uP =");
  Serial.println(uP);
  delay(100);
Try to compile it with 2.0.6 first
and we have an output:
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
What!? We have to see 79*4096 + 108*16 + 48/16 = [where is my calc!?] = 325315
May be 2.0.7 will be ok?
...and we have
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
uP =-2365
What did happened?
The first problem there is an evident overflow:
(data[0]*4096)
the first operand is byte, the second is word (constant).The result have to be 323584. But, by default any compiler will try to use the size of the architecture accumulator. The size of this for 8051 is 8bits and it fails. This code will work normally on x86 because its accumulator register (EAX) is 32bit long.
try
#include <stdio.h>
char data[8]={79, 108,48,00,00,00,00,00}; //defined in .h file
void main()
        uP = (data[0]*4096); //+ (data[1]*16) + (data[2]/16) ;
        printf("uP = %d\n", uP);
gcc test.c
./a.out
You will see:
uP = 323584
Pretty cool.
We have to say on 8051 that he have to use 32bit result instead of 8-bit:
uP = ((unsigned long)data[0]*4096);
and it works right:
uP =323584
uP =323584
uP =323584
uP =323584
uP =323584
With the second part we have the same problem, cause you shift 180 4 bits left and have a byte overflow too. Just fix it like this:
uP = ((unsigned long)data[0]*4096) +  ((word)data[1]*16) + (data[2]/16);
Now we have
uP =325315
uP =325315
uP =325315
uP =325315
uP =325315
uP =325315
uP =325315
uP =325315
uP =325315
uP =325315
We can write the final statement another way (using shifts and bit operations):
uP = data[0];
uP <<= 8;
uP |= data[1];
uP <<= 4;
uP |= (data[2] >> 4);
and we have:
uP =325315
uP =325315
uP =325315
uP =325315
uP =325315
uP =325315
uP =325315
The final question why do we use signed values for data?
The range of char is [-127;128]. I think that we have to use byte instead of this. This prevent us from many strange errors in case if we use operators * and / instead of shifts and bit wise operations.
Use the last variant of code it will be optimal by speed and size and it's a "pro" style.
Hope this small post will help you with your code. ;-)
PS. I tested all code with 2.0.6 & 2.0.7. They have the same output. You can try it yourself.
Alex.
michap
Post by michap » 08 Dec 2016 01:04
thank you for explaining.
But it was not a dream ;) - The lib was working in "my" 2.06 before updating to 2.0.7.
I do not know why, but it was happen.
Can not demonstrate it more, because of the current 2.0.6 is an other as the old one.
Maybe it was updated in the meantime?
I had a working BMP280 and BME280 lib - some people here in office have it seen ;)
It's ok to do it right now, I was only really confused ;)
There is another change in 2.0.7:
I have a function:
char BMP280::readBytes(char address, char length)
data[x] = Wire.read();
return (1);
then I have used in other function the call
readBytes(0xE4,1);
instead of
result = readBytes(0xE4,1);
new compiler does not like if function will give return value - but you do not assign the return value to anything when calling function
(the return value is used for error detection)
This is of course not a compiler error - but was my mistake.
Thanks again!
Michael
michap
Post by michap » 08 Dec 2016 11:10
BTW: my 2.0.7 "issues" about the calculation tests happen because of a simple typo :-D
I used in my tests
test=(unsigned long)(1000*4096);
instead of
test=((unsigned long)1000*4096);
Then you will get such funny results :-D
But anyway my old sensor with BME280 is still working with old 2.0.6 code - not more compiling at 2.0.7
I think there are some declaration errors inside my code- and the previous compiler have skipped it and "corrected" it.
So it's a good idea to check this test code in detail (it was still not prepaired for "production") and make it right :)
Thank you again for your help!
Michael
