The problem is in code for reading light level. It wasn't updated to match new Wire library. The fast fix is
https://github.com/Z-Wave-Me/Z-Uno-Core ... f2baf09535 inside BH1750 library.
You can do it manually:
1. Open folder with preferences.txt of ArduinoIDE (hyper link inside "preferences" dialog):
2. go to packages/Z-Uno/hardware/zw8051/2.0.8/libraries/ZUNO_BH1750/
3. replace ZUNO_BH1750.cpp with attached file
This is a library for the BH1750(FVI) light sensor
This sensor use I2C to communicate, 2 pins are required to
interface
Datasheet:
http://rohmfs.rohm.com/en/products/databook/datasheet/ic/sensor/light/bh1750fvi-e.pdf
Based on BH1750 lib written by Christopher Laws, March, 2013.
Adapted to ZUNO
#include "ZUNO_BH1750.h"
#include "Wire.h"
#define BH1750_DEBUG 0
BH1750::BH1750() {
void BH1750::begin(uint8_t mode, uint8_t addr) {
Wire.begin();
// initialization sensor
configure(mode, addr);
void BH1750::configure(uint8_t mode, uint8_t addr) {
Wire.beginTransmission(addr);
switch (mode) {
case BH1750_CONTINUOUS_HIGH_RES_MODE:
case BH1750_CONTINUOUS_HIGH_RES_MODE_2:
case BH1750_CONTINUOUS_LOW_RES_MODE:
case BH1750_ONE_TIME_HIGH_RES_MODE:
case BH1750_ONE_TIME_HIGH_RES_MODE_2:
case BH1750_ONE_TIME_LOW_RES_MODE:
// apply a valid mode change
Wire.write(mode);
delay(10);
break;
default:
// Invalid measurement mode
#if BH1750_DEBUG == 1
Serial.println("Invalid measurement mode");
#endif
break;
Wire.endTransmission();
void BH1750::powerOn(uint8_t addr) {
Wire.write(BH1750_POWER_ON);
void BH1750::powerDown(uint8_t addr) {
Wire.write(BH1750_POWER_DOWN);
void BH1750::reset(uint8_t addr) {
Wire.write(BH1750_RESET);
uint16_t BH1750::readLightLevel(uint8_t addr) {
uint16_t level;
Wire.requestFrom(addr, 2);
level = Wire.read();
level <<= 8;
level |= Wire.read();
Serial.print("Raw light level: ");
Serial.println(level);
#endif
//level = level/1.2; // convert to lux
level *= 6;
level /= 5;
Serial.print("Light level: ");
#endif
return level;
4. Rebuild & upload sketch
