New 2.1.0 test build is ready!
Post by PoltoS » 29 Aug 2017 03:24
This build introduces many new features.
You can get it from http://z-uno.z-wave.me/files/z-uno/test ... index.json repo (note the test-ucxx in the middle!)
What's new:
Bug fixes
  • Fixed problem with extern
New features
  • New channel types:
    • Blinds (Same as Switch Multilevel, but most controllers will show blinds icon)
    • Flow Stop (Same as Switch Binary, but most controllers will show valve icon). This type is allowed to be FLiRS and run on batteries (yes, this is the way to officially do battery power relays ;)
    • Siren (Same as Switch Binary, but most controllers will show siren icon). This type is allowed to be FLiRS and run on batteries
  • Dynamic configuration channels and associations. Now you can define Z-Uno configuration during compilation or on Z-Uno boot. More flexibility!
Libraries New examples
Black Cat
Re: New 2.1.0 test build is ready!
Post by Black Cat » 02 Sep 2017 10:03
How do I install it?
Are there step by step instructions other than download it? (I have,but I am none the wiser).
Some help as to how or where to upload it would help.
Post by PoltoS » 02 Sep 2017 18:02
There is a release now. Please install it. If you have already installed the test one, you will need to clean packages/Z-Uno and staging/packages/zuno_*.
Black Cat
Post by Black Cat » 03 Sep 2017 00:27
I couldn't work out how to install the test one, that is why I asked how?
Post by PoltoS » 03 Sep 2017 00:29
We have released the normal one (not test), so install it.
Next time to install test follow the normal instructions, but use the link above (with test-ucxx in the middle) to get test build
Black Cat
Post by Black Cat » 03 Sep 2017 05:14
This is all still very confusing.
If I have uploaded V2.1.0 correctly, how can I verify it?
Post by PoltoS » 03 Sep 2017 16:29
You download it and go in Tool->Burn bootloader. Then it is in your board and you can upload your sketches
