Config Parameters are note set/received
Posted: 07 Nov 2017 21:46
by DerLexus
Hi there,
I tried to extend my sketch for my weather sensor with 4 parameters for compensation of measured values. It seems to be really simple, but as always problems occurs :(
It seems that the configuration callback isn't called at all. At least my parameters are not changing. I tried to add a Serial.print to the function but I doesn't get anything (can it be that Serial isn't allowed in callbacks, I remember I've read somewhere about that).
Do you have any other tips to try?
I can post my sketch if this helps and I'm on 1.6.5.
Thank you, bye!
Re: Config Parameters are note set/received
Posted: 07 Nov 2017 21:48
Have you tried the example presented here: http://z-uno.z-wave.me/Reference/ZUNO_S ... R_HANDLER/ ?
Posted: 08 Nov 2017 00:13
by p0lyg0n1
Post your sketch here, or you can send me it by means of PM. Don't worry, we will help you. :-)
Posted: 08 Nov 2017 11:25
by DerLexus
No problem, there is no magic in it :)
I attached it because of the 2 needed local libs.
@Poltos: I copied the example more or less from the blinking sample and changed it a bit. Maybe it has todo with the zuno sleep but I tried it without that and the problem is the same.
Posted: 10 Dec 2017 19:30
by DerLexus
Does someone have a working example of user channels?
Posted: 13 Dec 2017 17:56
by p0lyg0n1
I am sorry. We have a lot of work with new release and have no time to reply fast.
So, I tried your code. It works with my Razberry controller fine (configuration parameters work, I don't have a sensors I just comment all the sensor code).
See the attached screenshot.
The code is
//#include "BH1750.h"
//#include "BME280.h"
#include <Wire.h>
//BME280 bme280; // Temp/Hum/Pressure Sensor BME280
//BH1750 bh1750; // Light Sensor BH1750
#define MAX_DWORD 4294967295
//#define DEBUG
#define MY_SERIAL Serial0
ZUNO_SETUP_DEBUG_MODE(DEBUG_ON);
// set up channel
ZUNO_SETUP_CHANNELS(
      // Temperature
      ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE,
                             SENSOR_MULTILEVEL_SCALE_CELSIUS,
                             SENSOR_MULTILEVEL_SIZE_TWO_BYTES,
                             SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS,
                             getterTemp),
      // Pressure
      ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_BAROMETRIC_PRESSURE ,
                             SENSOR_MULTILEVEL_SCALE_KILO_PASCAL,
                             SENSOR_MULTILEVEL_SIZE_FOUR_BYTES,
                             getterPressureKiloPascal),
      // Hum
      ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_RELATIVE_HUMIDITY ,
                             SENSOR_MULTILEVEL_SCALE_PERCENTAGE_VALUE ,
                             SENSOR_MULTILEVEL_SIZE_ONE_BYTE,
                             SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS,
                             getterHum),
      // Light
      ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_LUMINANCE,
                             SENSOR_MULTILEVEL_SCALE_LUX,
                             getterLight)
//ZUNO_SETUP_SLEEPING_MODE(ZUNO_SLEEPING_MODE_SLEEPING);
ZUNO_SETUP_BATTERY_LEVELS(2400,3000);
dword lightLuxComp = 0, tempDegreesComp = 0, pressureKiloPascalComp = 0,humPercentComp = 0;
long  lightLux = 0,lightLuxOld = 0;
word  tempDegrees = 0,tempDegreesOld = 0;
long  pressureKiloPascal = 0,pressureKiloPascalOld = 0;
byte  humPercent = 0,humPercentOld = 0;
void config_parameter_changed(byte param, dword * value)
    switch(param)
      case 64:  // Light
        lightLuxComp = *value;
        break;
      case 65:  // Temperature
        tempDegreesComp = *value;
        if (tempDegreesComp>10000) tempDegreesComp=10000;
        break;
      case 66:  // Pressure
        pressureKiloPascalComp = *value;
        if (pressureKiloPascalComp>10000) pressureKiloPascalComp=10000;
        break;
      case 67:  // Humidity
        humPercentComp = *value;
        if (humPercentComp>100) humPercentComp=100;
        break;
ZUNO_SETUP_CFGPARAMETER_HANDLER(config_parameter_changed);
void setup()
  #ifdef DEBUG
  Serial.begin();
  #endif
  zunoLoadCFGParam(64,&lightLuxComp);
  lightLuxComp=(lightLuxComp==MAX_DWORD)?0:lightLuxComp;
  MY_SERIAL.println(lightLuxComp);
  zunoLoadCFGParam(65,&tempDegreesComp);
  tempDegreesComp=(tempDegreesComp==MAX_DWORD)?0:tempDegreesComp;
  zunoLoadCFGParam(66,&pressureKiloPascalComp);
  pressureKiloPascalComp=(pressureKiloPascalComp==MAX_DWORD)?0:pressureKiloPascalComp;
  zunoLoadCFGParam(67,&humPercentComp);
  humPercentComp=(humPercentComp==MAX_DWORD)?0:humPercentComp;
  //Wire.begin();
void readLightSensor()
 /* bh1750.begin(BH1750_ONE_TIME_HIGH_RES_MODE, BH1750_I2CADDR_LOW);
  delay(180); // delay for meassurement of bh1750
  bh1750.readLightLevel();
  lightLux = bh1750.lightLux + lightLuxComp;*/
void readTempSensor()
  bme280.begin();
  bme280.setOversampling(4);
  char result = bme280.startMeasurement();
  if (result == 0)
    #ifdef DEBUG
    Serial.println("BMx280: Initialisierungsfehler");
    #endif
    return;
  tempDegrees = bme280.getTemperature100() + tempDegreesComp;
  pressureKiloPascal = (bme280.getPressure100()/10.0) + pressureKiloPascalComp; // x/1000*100 = x/10
  humPercent = max(100,bme280.getHum() + humPercentComp);*/
void sendData()
  #ifdef DEBUG
    Serial.print("Params: ");
    Serial.print(lightLuxComp);
    Serial.print(", ");
    Serial.print(tempDegreesComp);
    Serial.print(", ");
    Serial.print(pressureKiloPascalComp);
    Serial.print(", ");
    Serial.println(humPercentComp);
  #endif
  #ifdef DEBUG
    Serial.print("Light       ");
    Serial.print(lightLux);
    Serial.println(" Lux");
    Serial.print("Temperature ");
    Serial.print(tempDegrees/100.0);
    Serial.println(" C");
    Serial.print("Pressure    ");
    Serial.print(pressureKiloPascal/10);
    Serial.println(" kPa");
    /*if(bme280.chip_id == 96)
      Serial.print("Humidity    ");
      Serial.print(humPercent);
      Serial.println(" %");
  #endif
  if (tempDegreesOld != tempDegrees)
    zunoSendReport(1);
    tempDegreesOld = tempDegrees;
  if (pressureKiloPascalOld != pressureKiloPascal)
    zunoSendReport(2);
    pressureKiloPascalOld = pressureKiloPascal;
  if (humPercent != humPercentOld)
    zunoSendReport(3);
    humPercentOld = humPercent;
  if (lightLux != lightLuxOld)
    zunoSendReport(4);
    lightLuxOld = lightLux;
word getterLight()
  return lightLux;
word getterTemp()
  return tempDegrees;
long getterPressureKiloPascal()
  return pressureKiloPascal;
byte getterHum()
  return humPercent;
void loop()
  #ifdef DEBUG
  delay(5000);  // time to open the serial console to view debug messages
  #endif
  readLightSensor();
  readTempSensor();
  sendData();
  zunoSendDeviceToSleep();
It looks like I know the reason why it's not working on your board. May be you use the prerelease version(2.1.1 from test-ucxx). Please try to reinstall the latest stable version from the main URL(http://rus.z-wave.me/files/z-uno/packag ... index.json). To reinstall Z-Uno packages you have to do this:
1. Remove Z-Uno package folder from Arduino (sometthing like <...>/Arduino15/packages/Z-Uno and <...>/Arduino15/packages/staging/Z-Uno - you will see it if you tap to "preferences.txt" link in preferences window of Arduino )
2. Check that you have the right URL in "Additionals Board Manager URLs".
3. Install Z-Uno board (release 2.1.1) using "Board manager".
Alex.
Posted: 13 Jan 2019 19:08
by nottix
i have the same problem. I have latest firmware version 2.1.4 and i unable to receive or set new configuration via Command class.
I'm using ZUNO_SETUP_CFGPARAMETER_HANDLER(config_parameter_changed) but the function "config_parameter_changed" was never called by the system.
I see on ZWave controller log that the config command was sent successfully. Any idea to resolve? thank you.
Posted: 13 Jan 2019 20:09
by nottix
i fixed the problem changing the option size from 4 to 2 bytes, according to latest 2.1.4 update. Please update the public documentation!
Thank you.
Posted: 16 Jan 2019 09:13
Well noted, we will fix the doc
