multiple sensors and vera
aivs
Re: multiple sensors and vera
Post by aivs » 01 Mar 2018 16:41
How to Vera + Z-Uno 5 Binary Sensors
Vera Secure - 1.7.3535
Z-Uno - 2.1.3
Sketch - 5 Motion Sensors
#define BINARY_PIN1 18
#define BINARY_PIN2 19
#define BINARY_PIN3 20
#define BINARY_PIN4 21
#define BINARY_PIN5 22
// Global variables to store data reported via getters// Global variables to store data reported via getters
byte lastBinaryValue1;
byte lastBinaryValue2;
byte lastBinaryValue3;
byte lastBinaryValue4;
byte lastBinaryValue5;
// Set up 5 channels
ZUNO_SETUP_CHANNELS(
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary1),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary2),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary3),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary4),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary5)
void setup() {
  pinMode(BINARY_PIN1, INPUT_PULLUP);
  pinMode(BINARY_PIN2, INPUT_PULLUP);
  pinMode(BINARY_PIN3, INPUT_PULLUP);
  pinMode(BINARY_PIN4, INPUT_PULLUP);
  pinMode(BINARY_PIN5, INPUT_PULLUP);
void loop() {
  byte currentBinaryValue1 = digitalRead(BINARY_PIN1);
  byte currentBinaryValue2 = digitalRead(BINARY_PIN2);
  byte currentBinaryValue3 = digitalRead(BINARY_PIN3);
  byte currentBinaryValue4 = digitalRead(BINARY_PIN4);
  byte currentBinaryValue5 = digitalRead(BINARY_PIN5);
  if (currentBinaryValue1 != lastBinaryValue1) {
    lastBinaryValue1 = currentBinaryValue1;
    zunoSendReport(1);
  if (currentBinaryValue2 != lastBinaryValue2) {
    lastBinaryValue2 = currentBinaryValue2;
    zunoSendReport(2);
  if (currentBinaryValue3 != lastBinaryValue3) {
    lastBinaryValue3 = currentBinaryValue3;
    zunoSendReport(3);
  if (currentBinaryValue4 != lastBinaryValue4) {
    lastBinaryValue4 = currentBinaryValue4;
    zunoSendReport(4);
  if (currentBinaryValue5 != lastBinaryValue5) {
    lastBinaryValue5 = currentBinaryValue5;
    zunoSendReport(5);
byte getterBinary1() {
    return (lastBinaryValue1 == 0) ? 0 : 255;
byte getterBinary2() {
    return (lastBinaryValue2 == 0) ? 0 : 255;
byte getterBinary3() {
    return (lastBinaryValue3 == 0) ? 0 : 255;
byte getterBinary4() {
    return (lastBinaryValue4 == 0) ? 0 : 255;
byte getterBinary5() {
    return (lastBinaryValue5 == 0) ? 0 : 255;
Z-Uno sends reports from the channels using multichannel association to Lifeline, but by default Vera sets basic association. So at first need to add Vera into Z-Uno multichannel association.
Choose general widget --> Device Options --> 1 Add Group --> Set to: Z-Wave 0; _Scene Controller 0
After applying the Association settings should be like this
Now Z-Uno can send Sensor Binary and Alarm via multichannel association.
Need to set the widget type to D_MotionSensor1
In each widgets --> Advanced
device_type = urn:schemas-micasaverde-com:device:MotionSensor:1
device_file = D_MotionSensor1.xml
device_json = D_GenericIO1.json
Should be like this
petergebruers
Post by petergebruers » 01 Mar 2018 16:50
Ah! Finally some details about multichannel association on vera! I bet this is a very important point. It has been mentioned before... It is important on other controllers as well. I do not own a "vera" so I cannot test this.
Question... You say "Need to set the widget type to D_MotionSensor1". What happens if you do not do that? I am asking this, because I have mentioned that I think vera needs to have a device specific configuration file...
Tillsy
Post by Tillsy » 02 Mar 2018 00:15
OMFG!!! aivs sir, you are a LEGEND!!!
I simply added that association and, seconds later, everything lit up like a Christmas tree! Have also shorted the pins to ground and, instantly, each one caused the green LED to do a data transmission and the Vera updated the relevant sensor status.
This desperately needs adding to the Z-UNO site - as I'm not the only one to have spent an incredible amount of time on this issue.
Thank you :) :) :) :) :)
jim_meyer
Post by jim_meyer » 20 May 2018 23:16
I am experiencing the same original problem in this thread.... In my case I have 2: ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_DISTANCE...... ) Channels. Based on what I see in the Ardurino Serial Monitor my sketch is running correctly.
When I first pair the Z-Uno with my Vera Edge I get 4 devices... one with the name I assigned when I paired (the "parent") and the other 3 are called "_GET_LANG(generic_sensor,sensor) 1", "_GET_LANG(generic_sensor,sensor) 2", '_GET_LANG(generic_sensor,sensor) 3'.... which I find pretty weird.
All 4 devices have the following Advanced Params:
device_type: urn:schemas-micasaverde-com:device:GenericSensor:1
device_file: D_GenericSensor1.xml
device_json: D_GenericSensor1.json
The "parent" works OK... it updates its CurrentLevel variable on a regular basis.... But the 3 children are really slow to update.... seems like 10 minutes or more. "_GET_LANG(generic_sensor,sensor) 1" displays the same distance as the Parent but does not update as often. "_GET_LANG(generic_sensor,sensor) 3" displays my 2nd distance sensor... but again updates are real slow. "_GET_LANG(generic_sensor,sensor) 4" never updates.
I can go into the "parent" Device Options" and add the Associations as described above in this thread... But entering Device options for any of the children simple displays a "N/A"... so I can not assign Associations to those devices.
Also, there are a lot of Advanced->Variables that are present for the Parent (35 of them) that do not exist for the 3 Children.... which only has 5.
Can anyone shed some light on this and help me get to the point where my second distance sensor updates more often?
Thank you!
Post by PoltoS » 23 May 2018 00:10
You only need to set this Association to 1.0 (Multichannel Association) on the root device
jim_meyer
Post by jim_meyer » 28 Nov 2018 00:17
PoltoS wrote:
23 May 2018 00:10
Sorry, but I still cannot get this to work.... The "root/parent/1st channel" device value in Vera updates every time the Getter in my z-uno code gets called but the "child/2nd channel" device value only updates occasionally when its Getter is called... its value is often up to 15 minutes behind.
In the Vera UI I under the "Parent" device under "Device Options-> Associations" I have added a Group ID of 1 with ZWave and _Scene Controller checked.... so the Association "Set to" is "1,2".... but "Currently" just lists "2".
Any help on this is appreciated.
jim_meyer
Post by jim_meyer » 28 Nov 2018 23:13
Looks like I finally got this working.
My last problem was solved by not only checking but also entering a "0" in both the ZWave and _Scene Controller fields when setting those 2 associations for the "parent" device.
azvarga
Post by azvarga » 24 Dec 2018 22:17
Avis/all, I am able to get the inputs outputs working with VERA and then in a different sketch (thanks to Avis) I can get five inputs to work. Now I am struggling to get 3 outputs and 5 inputs working in the same sketch. Compiles fine and the outputs work but the inputs are behaving strange and very sluggish. Only the first input works but I have to take all five high to get it to turn on and then after taking all low it takes some time to turn off. Just programming I am sure.
The sketch is an integration of a 3 output sketch that works and a 5 input sketch that works. It is likely in the definition of the z-wave channel ? It is pasted in the post below
Any thoughts ?
azvarga
Post by azvarga » 24 Dec 2018 22:19
This sketch is used to interface the Genmon Raspberry Pi microprocessor to the Z-Uno Z-wave Arduino processor to provide a Z-wave interface between the generator and the VERA Plus home controller
		          		PI       Z-Uno
STATUS_READY		16	18
STATUS_ALARM		18	19
STATUS_SERVICE 		22	17
STATUS_RUNNING		26	20
STATUS_EXERCISING		24	21
STATUS_OFF			21	22
INPUT_STOP			11	9
INPUT_START			13	10
INPUT_TRANSFER		15	11
Off - LOW
On - HIGH
// Pins definitions
#define LedPin1 9
#define LedPin2 10
#define LedPin3 11
byte switchValue1 = 1;
byte switchValue2 = 1;
byte switchValue3 = 1;
// Set up 3 output channels and 5 input channels
  ZUNO_SWITCH_BINARY(getterSwitch1, setterSwitch1),
  ZUNO_SWITCH_BINARY(getterSwitch2, setterSwitch2),
  ZUNO_SWITCH_BINARY(getterSwitch3, setterSwitch3),
// set up I/O pins.
void setup() {
  pinMode(LedPin1, OUTPUT);
  pinMode(LedPin2, OUTPUT);
  pinMode(LedPin3, OUTPUT);
void loop() {
    zunoSendReport(1);
    zunoSendReport(2);
    zunoSendReport(3);
    zunoSendReport(4);
    zunoSendReport(5);
// Getters and setters
void setterSwitch1(byte value) {
  digitalWrite(LedPin1, (value > 0) ? HIGH : LOW);
  switchValue1 = value;
byte getterSwitch1(){
  return switchValue1;
 void setterSwitch2(byte value) {
  digitalWrite(LedPin2, (value > 0) ? HIGH : LOW);
  switchValue2 = value;
byte getterSwitch2(){
  return switchValue2;
void setterSwitch3(byte value) {
  digitalWrite(LedPin3, (value > 0) ? HIGH : LOW);
  switchValue3 = value;
byte getterSwitch3(){
  return switchValue3;
