multiple sensors and vera
azvarga
Re: multiple sensors and vera
Post by azvarga » 25 Dec 2018 06:56
Okay, figured it out. It was a matter of order of the code
Now working with 3 digital outputs and 6 digital inputs. LOVE the Z-Uno board !
This sketch is used to interface the Genmon Raspberry Pi microprocessor to the Z-Uno Z-wave Arduino processor to provide a
Z-wave interface between the generator and the VERA Plus home controller
                  PI     Z-Uno
STATUS_READY      16      17
STATUS_ALARM      18      18
STATUS_SERVICE    22      19
STATUS_RUNNING    26      20
STATUS_EXERCISING 24      21
STATUS_OFF        21      22
INPUT_STOP        11      9
INPUT_START       13      10
INPUT_TRANSFER    15      11
Off - LOW
On - HIGH
// Pin definitions
#define BINARY_PIN1 17
#define BINARY_PIN2 18
#define BINARY_PIN3 19
#define BINARY_PIN4 20
#define BINARY_PIN5 21
#define BINARY_PIN6 22
#define LedPin1 9
#define LedPin2 10
#define LedPin3 11
// Global variables to store data reported via getters// Global variables to store data reported via getters
byte lastBinaryValue1;
byte lastBinaryValue2;
byte lastBinaryValue3;
byte lastBinaryValue4;
byte lastBinaryValue5;
byte lastBinaryValue6;
byte switchValue1 = 1;
byte switchValue2 = 1;
byte switchValue3 = 1;
// Send Basic Set to association group
// ZUNO_SETUP_ASSOCIATIONS(ZUNO_ASSOCIATION_GROUP_SET_VALUE);
// Set up 3 output channels and 5 input channels
ZUNO_SETUP_CHANNELS(
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary1),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary2),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary3),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary4),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary5),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterBinary6),
  ZUNO_SWITCH_BINARY(getterSwitch1, setterSwitch1),
  ZUNO_SWITCH_BINARY(getterSwitch2, setterSwitch2),
  ZUNO_SWITCH_BINARY(getterSwitch3, setterSwitch3)
// set up I/O pins.
void setup() {
  pinMode(BINARY_PIN1, INPUT_PULLUP);
  pinMode(BINARY_PIN2, INPUT_PULLUP);
  pinMode(BINARY_PIN3, INPUT_PULLUP);
  pinMode(BINARY_PIN4, INPUT_PULLUP);
  pinMode(BINARY_PIN5, INPUT_PULLUP);
  pinMode(BINARY_PIN6, INPUT_PULLUP);
  pinMode(LedPin1, OUTPUT);
  pinMode(LedPin2, OUTPUT);
  pinMode(LedPin3, OUTPUT);
void loop() {
  byte currentBinaryValue1 = digitalRead(BINARY_PIN1);
  byte currentBinaryValue2 = digitalRead(BINARY_PIN2);
  byte currentBinaryValue3 = digitalRead(BINARY_PIN3);
  byte currentBinaryValue4 = digitalRead(BINARY_PIN4);
  byte currentBinaryValue5 = digitalRead(BINARY_PIN5);
  byte currentBinaryValue6 = digitalRead(BINARY_PIN6);
  if (currentBinaryValue1 != lastBinaryValue1) {
    lastBinaryValue1 = currentBinaryValue1;
    zunoSendReport(1);
  if (currentBinaryValue2 != lastBinaryValue2) {
    lastBinaryValue2 = currentBinaryValue2;
    zunoSendReport(2);
  if (currentBinaryValue3 != lastBinaryValue3) {
    lastBinaryValue3 = currentBinaryValue3;
    zunoSendReport(3);
  if (currentBinaryValue4 != lastBinaryValue4) {
    lastBinaryValue4 = currentBinaryValue4;
    zunoSendReport(4);
  if (currentBinaryValue5 != lastBinaryValue5) {
    lastBinaryValue5 = currentBinaryValue5;
    zunoSendReport(5);
  if (currentBinaryValue6 != lastBinaryValue6) {
    lastBinaryValue6 = currentBinaryValue6;
    zunoSendReport(6);
// Getters
byte getterBinary1() {
    return (lastBinaryValue1 == 0) ? 0 : 255;
byte getterBinary2() {
    return (lastBinaryValue2 == 0) ? 0 : 255;
byte getterBinary3() {
    return (lastBinaryValue3 == 0) ? 0 : 255;
byte getterBinary4() {
    return (lastBinaryValue4 == 0) ? 0 : 255;
byte getterBinary5() {
    return (lastBinaryValue5 == 0) ? 0 : 255;
byte getterBinary6() {
    return (lastBinaryValue6 == 0) ? 0 : 255;
// Setters
void setterSwitch1(byte value) {
  digitalWrite(LedPin1, (value > 0) ? HIGH : LOW);
  switchValue1 = value;
byte getterSwitch1(){
  return switchValue1;
 void setterSwitch2(byte value) {
  digitalWrite(LedPin2, (value > 0) ? HIGH : LOW);
  switchValue2 = value;
byte getterSwitch2(){
  return switchValue2;
void setterSwitch3(byte value) {
  digitalWrite(LedPin3, (value > 0) ? HIGH : LOW);
  switchValue3 = value;
byte getterSwitch3(){
  return switchValue3;
