Some duplicated channels
donic46
Post by donic46 » 12 Apr 2018 11:50
I have 12 channels in my Z-UNO, but in the z-way i have 4 channels duplicated.
https://ibb.co/cme4jx
ZUNO_SETUP_SLEEPING_MODE(ZUNO_SLEEPING_MODE_ALWAYS_AWAKE);  // Defines sleeping mode to always awake
ZUNO_SETUP_ISR_INT0(int0_handler);                          // Defines handler to be called on INT0
ZUNO_SETUP_ISR_INT1(int1_handler);                          // Defines handler to be called on INT1
ZUNO_SETUP_ISR_1MSTIMER(m1ms_handler);                      // Defines handler to be called on 1 millisecond software interrupt
ZUNO_SETUP_CFGPARAMETER_HANDLER(config_parameter_changed);  // Defines handler to be called on configuration parameter change
ZUNO_SETUP_ASSOCIATIONS(ZUNO_ASSOCIATION_GROUP_SET_VALUE);  // Send Basic Set to association group
ZUNO_SETUP_CHANNELS(
  ZUNO_SENSOR_MULTILEVEL_TEMPERATURE(getterTemperatureInside),                    // Instance 1 - Inside temperature
  ZUNO_SENSOR_MULTILEVEL_HUMIDITY(getterHumidityInside),                          // Instance 2 - Inside humidity
  ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_CO2_LEVEL, 0,                // Instance 3 - Inside CO2
      SENSOR_MULTILEVEL_SIZE_TWO_BYTES,
      SENSOR_MULTILEVEL_PRECISION_ZERO_DECIMALS,
      getterCO2Inside),
  ZUNO_SENSOR_MULTILEVEL(0x27, 0,                                                 // Instance 4 - Inside VOC
      getterVOCInside),
  ZUNO_SENSOR_MULTILEVEL_TEMPERATURE(getterTemperatureHeater),                    // Instance 5 - Heater chamber temperature
  ZUNO_SENSOR_MULTILEVEL_HUMIDITY(getterHumidityHeater),                          // Instance 6 - Heater chamber humidity
  ZUNO_SWITCH_MULTILEVEL(getterMotorPosition, setterMotorPosition),               // Instance 7 - Motor position
  ZUNO_BLINDS(getterBlindPosition, setterBlindPosition),                          // Instance 8 - Blind position
  ZUNO_SWITCH_MULTILEVEL(getterVentilationIntensity, setterVentilationIntensity), // Instance 9 - Ventilation intensity
  ZUNO_SWITCH_MULTILEVEL(getterLedIntensity, setterLedIntensity),                 // Instance 10 - Led strip intensity
  ZUNO_SENSOR_BINARY_DOOR_WINDOW(getterWindowPosition),                           // Instance 11 - Window position
  ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_GENERAL_PURPOSE_VALUE, 0,    // Instance 12 - Errors
      getterErrors)
What i am doing wrong? Any suggestion?
Re: Some duplicated channels
Post by PoltoS » 16 Apr 2018 01:33
This is by design. Please read this: http://z-uno.z-wave.me/Reference/Z-Wave/#Channels
