SSD1306 library/OLED screen
sitevnic
Post by sitevnic » 15 Apr 2018 19:54
Hi
I've connected OLED 0,96" screen to my Z-Uno device. It is working well with ZUNO_OLED_I2C library. However I would like to make some trend line of pressure and temperature from BMP180 sensor. I couldn't find any information how to set pixel on my OLED screen using OLED_I2C library. When I tried to use Adafruit_SSD1306 library, during verification I'm getting error compiling for board Z-Wave>ME Z-Uno.
So how can I make trend line of something, or actually just set pixel, draw line on that OLED screen?
perjar
Re: SSD1306 library/OLED screen
Post by perjar » 27 Sep 2018 20:52
Hi, I don't have a solution to your problem, but looking at the functions available it does not seem to pe possible. The z-uno version of the library is not at all as complete as the standrard Arduino library.
I have a question back though: I can't get my oled to work. When running the example code I can see the screen flashing for a microsecond when the sketch starts, but after that is is completely black.
How have you wired yours and have you made any alterations compared to the example code to make it work?
Post by PoltoS » 29 Sep 2018 10:36
michap
Contact:
Post by michap » 03 Oct 2018 14:33
perjar wrote:
27 Sep 2018 20:52
It should work - without problem. You are sure that you have SSD1306 controller on display?
Some boards are working with SH1106 chip. I have got the same "wrong"...
If SH1106 - checkk my lib, it is working but need 1024bytes of RAM (because needed buffer usage)
Wired - check here: http://z-uno.z-wave.me/examples/bmp180-oled/
Michael
perjar
Post by perjar » 03 Oct 2018 23:29
Thanks for your tips.
Yes I have the SSD1306 controller and it works fine when connected to an Adafruit Trinket. The wires are correctly connected, same as in the bmp180 project.
I looked into another project too, to see if I could borrow some working code: https://z-uno.z-wave.me/projects/Mercury206/
Some code snippets from the project:
#include <ZUNO_OLED_FONT_NUMB16.h>
// You can use another builtin fonts for numbers..._NUMB24, _NUMB40
#include <ZUNO_OLED_FONT_RUS8.h> // Russian font
#include <ZUNO_OLED_IMG_LOGO.h> // Z-Uno logo
oled.gotoXY(24, 0);
oled.setFont(zuno_font_rus8);
oled.print("Ntvgthfnehf");   //
oled.gotoXY(0, 1);
oled.setFont(zuno_font_numbers16);
oled.fixPrint(inst_meters[INS_METER_INDEX0(CHANNEL_THERMOIN1_MSENSOR)],1);
Where are all these ZUNO_OLED_FONT_*.h files located? How do I even know which ones exist? I can't find them at all on my computer but the compiler processes all this without complaints so apparently they do exist and so do their .cpp files.
There seems to be a lot more definitions than what can be seen in the ZUNO_OLED_IC2.h file, like setFont and fixPrint for instance. What else is there? It would be great with a consolidated documentation of the OLED library.
perjar
Post by perjar » 04 Oct 2018 23:13
Problem solved. I am even too embarrased to tell what it was. :oops:
The question about the OLED libraries still stand howiever. Where are these .h files located?
michap
Contact:
Post by michap » 05 Oct 2018 19:41
perjar wrote:
04 Oct 2018 23:13
located in the lib directory - as sample at Windows:
C:\Users\[user name]\AppData\Local\Arduino15\packages\Z-Uno\hardware\zw8051\2.1.5\libraries\ZUNO_OLED_I2C\
Michael
perjar
Post by perjar » 05 Oct 2018 21:29
Brilliant! Thanks a million!
