HC-SR04 and DS18B20 help?
Re: HC-SR04 and DS18B20 help?
You didn't put in:
zunoSendReport(1);
zunoSendReport(1);
Yep! Got it working now, only problem is, below 80% ( i set deviation to 10cm and tank height 110cm) in every 10cm which is also 10%, it goes off by 1%.
So in example if i set the object from the sensor to a distance of 30cm, it gives me the tank fillment of 80% which is correct, but if i set the object to a distance of 50cm which is 60%, i get a reading of 63%.
Also now that i got this part working, i need to combine the distance sensor with temperature sensors.
So this code
and this code
will need to work together. How do i do that? I combined two codes but cant seem to get them working properly. First i cant get the ultrasonic sensor reading and temp sensors show 0.91C. Also i have connected 2 temp sensord but the system shows me 3 temp sensors and same reading on all.
So this code
// HC-SR04 Ultrasonic Distance Sensor
ZUNO_SETUP_CHANNELS(
ZUNO_SENSOR_MULTILEVEL_GENERAL_PURPOSE(getter)
int readPin = 9;
int triggerPin = 10;
byte controlState = 0;
byte percentage;
void setup() {
Serial.begin();
pinMode(readPin, INPUT);
pinMode(triggerPin, OUTPUT);
digitalWrite(triggerPin, LOW);
void loop(){
byte distance, heightTank, deviation;
int duration;
//You'll probably want to change the next 2 lines.
// The first one is the max. level of the water.
// The next one is how high the sensor is above that max. level.
heightTank=110;
deviation=10;
delayMicroseconds(10);
digitalWrite(triggerPin, HIGH);
duration = pulseIn(readPin, HIGH, 100000);
distance = (duration/2)/29.1;
percentage = (byte)(100-(((distance-deviation)*100)/heightTank));
Serial.println(percentage);
zunoSendReport(1);
delay(1000);
byte getter() {
return percentage;
// Multiple temperature sensors DS18B20
#include "ZUNO_DS18B20.h"
#define DS18B20_BUS_PIN 11 // Pin to which 1-Wire bus is connected
#define MAX_SENSORS 10 // Number of DS18B20 sensors supported (equals to maximum number of channels for Z-Uno)
OneWire ow(DS18B20_BUS_PIN); // Software 1-Wire BUS
DS18B20Sensor ds18b20(&ow); // connect DS18B20 class to it
#define ADDR_SIZE 8 // Size of address of devices on 1-wire bus
byte addresses[ADDR_SIZE * MAX_SENSORS]; // Here we store all the scanned addresses
#define ADDR(i) (&addresses[i * ADDR_SIZE]) // Macro to simplify our life
byte number_of_sensors; // Number of sensors found
word temperature[MAX_SENSORS]; // Here we store temperatures
void setup() {
// Scanning sensors on the bus every time we starting a sketch
number_of_sensors = ds18b20.findAllSensors(addresses);
if(number_of_sensors > MAX_SENSORS)
number_of_sensors = MAX_SENSORS;
// Setting up Z-Uno channels
// We do id dynamically...
// You have to exclude/include your Z-Uno to this take effect on the controller side
ZUNO_START_CONFIG();
for (byte i = 0; i < number_of_sensors; i++) {
// Each channel is temperature sensor
// with 2 decimals precision (ex. 25.45C)
ZUNO_ADD_CHANNEL(ZUNO_SENSOR_MULTILEVEL_CHANNEL_NUMBER,
ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE,
SENSOR_MULTILEVEL_PROPERTIES_COMBINER(
SENSOR_MULTILEVEL_SCALE_CELSIUS,
SENSOR_MULTILEVEL_SIZE_TWO_BYTES,
SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS));
// Commit configuration that we made...
ZUNO_COMMIT_CONFIG();
void loop() {
// Read temperature
float ct = ds18b20.getTemperature(ADDR(i));
temperature[i] = ct * 100; // Convert temperature to fixed point (d)+.dd
// Sending report
zunoSendReport(i + 1); // Channels start from 1
// We have to wait 30 seconds
// It's a requirement of Z-Wave protocol
delay(30000);
// Universal handler for all the channels
void zunoCallback(void) {
// See callback_data variable
// We use word params for all
// We use zero based index of the channel instead of typical
// Getter/Setter index of Z-Uno.
// See enum ZUNO_CHANNEL*_GETTER/ZUNO_CHANNEL*_SETTER in ZUNO_Definitions.h
byte index = callback_data->type;
index >>= 1;
index --;
callback_data->param.wParam = temperature[index];
I have combined two codes like this at the moment
And Vera is showing temp values and distance, but.... distance is not changing, at all. It's the same value at all times. What am i missing here?
Thomas Carew poems
#define DS18B20_BUS_PIN 11 // Pin to which DS18B20 bus is connected
#define N_SENSOR 2 // Number of DS18B20 sensors
// You need to adopt ZUNO_SETUP_CHANNELS and add more getters if tou need more sensors
byte addresses[ADDR_SIZE * N_SENSOR]; // Here we store all the scanned addresses
word temperature[N_SENSOR]; // Here we store temperatures
//ultrasonic sensor
int readPin = 9;
byte percentage;
//ultrasonic sensor
// Define Z-Wave channels. Add more if you need more sensors
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp1),
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp2),
//ultrasonic sensor
void setup() {
//ultrasonic sensor
Serial.begin();
//ultrasonic sensor
void loop() {
for (byte i = 0; i < number_of_sensors && i < N_SENSOR; i++) {
// Read temperature
temperature[i] = ds18b20.getTemperature(ADDR(i)) * 100;
// Sending report
zunoSendReport(i + 1); // Channels starts from 1
//ultrasonic sensor
int duration;
heightTank=110;
deviation=10;
zunoSendReport(1);
//ultrasonic sensor
delay(3000);
// Getters. Add more if you need more sensors
word getterTemp1() {
return temperature[1];
word getterTemp2() {
return temperature[2];
//ultrasonic sensor
byte getter() {
return percentage;
//ultrasonic sensor
Thomas Carew poems
Your just updating the temperature sensors in code:
and zunoSendReport(1);
You need to add:
zunoSendReport(3);
You need to add:
zunoSendReport(3);
Thanks, will try it out right now. Silly question but, does it matter where i put zunoSendReports?mdietinger@gmail.com wrote: ↑04 Jul 2018 11:09Your just updating the temperature sensors in code:
You need to add:
zunoSendReport(3);
One here
void loop() {
// Read temperature
// Sending report
//ultrasonic sensor
int duration;
heightTank=110;
deviation=10;
zunoSendReport(3);
//ultrasonic sensor
Doesn't matter where in the loop you put it, as long the value is calculated before the send report.
The above example will just work fine.
Cheers! Got it working now. Only thing is, i added 2 more temp sensors so now it's 4 temps sensors and one ultrasonic sensor.
In the code i wrote 4 temp sensors and added lines as needed, for ultrasonic i wrote zunoSendReport(5);
first 3 temp sensors work as they should, ultrasonic reads distance in percent as it should but the fourth temp is stuck on 0,09C.
I can't figure out whats the problem.
Here's the code
Here's the code
#define N_SENSOR 4 // Number of DS18B20 sensors
//ultrasonic sensor
int readPin = 9;
byte percentage;
//ultrasonic sensor
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp3),
ZUNO_SENSOR_MULTILEVEL(ZUNO_SENSOR_MULTILEVEL_TYPE_TEMPERATURE, SENSOR_MULTILEVEL_SCALE_CELSIUS, SENSOR_MULTILEVEL_SIZE_TWO_BYTES, SENSOR_MULTILEVEL_PRECISION_TWO_DECIMALS, getterTemp4),
//ultrasonic sensor
void setup() {
//ultrasonic sensor
Serial.begin();
//ultrasonic sensor
void loop() {
// Read temperature
// Sending report
//ultrasonic sensor
int duration;
heightTank=110;
deviation=10;
zunoSendReport(5);
//ultrasonic sensor
delay(3000);
word getterTemp3() {
return temperature[3];
word getterTemp4() {
return temperature[4];
//ultrasonic sensor
byte getter() {
return percentage;
//ultrasonic sensor
Sorry, my bad, got it working now. Got some numbers wrong in getter's
Changed that part and now its working!
return temperature[0];
try to use
instead of
Another good practice is to send reports at the and of all calculation just before the delay()
try this "loop" code instead (it's just an illustration, go give you an idea):
try to use
temperature[i] = ds18b20.getTempC100(ADDR(i));
void loop() {
// Read temperature
// It already encoded for format VVV.vv and doesn't use float
//ultrasonic sensor
int duration;
// WE HAVE TO DO IT JUST ONCE, NOT INSIDE DS18B20 LOOP^
heightTank=110;
deviation=10;
// this code loads the uC hard, so lets report all values after it ends
// This uses float thats not good for this uS, it eats lots of code
// distance = (duration/2)/29.1;
// percentage = (byte)(100-(((distance-deviation)*100)/heightTank));
// alternative will be: (RISC style)
duration >>= 1; // /2
duration *= 100;
duration /= 291;
duration -= deviation;
// To ensure there is no overflow
duration = max(duration, heightTank);
duration *= 100;
duration /= heightTank;
percentage = 100 - duration;
// Report all the sensors at the end of the loop
for(byte i=0;i<5;i++){
zunoSendReport(i+1);
// delay while the OS could do something with reports & radio
delay(3000);
