Adding extra ir commands
MattyO
Post by MattyO »
Hi Guys. I am really new to arduino sketches and programming in general. I am trying to build a sketch that will send out multiple ir commands via IR. this example sketch is fantastic, But I cant work out how to add additional commands. Would anybody be able to give me a bit of a heads start as to which parts I need to add to.
Thanks in advance Matt
#include "IRController.h"
IRTransmitterParams ir_transmitter(byte(IR_TRANSMITTER_OUTPUT_PIN6),
IR_FLAGS_OUTPUT_HIGHDRIVE,
IR_MS_PRESCALLER_4MHZ,
IR_CARRIER_PRESCALLER_8MHZ);
#define SWITCH_ON 0xff
#define SWITCH_OFF 0
// Use IRScanner.ino as IR-sniffer
// This codes were shiffed from SONY TV IR remote control
word raw_command_on[] = {0x19, 0x990, 0x242, 0x26D, 0x243, 0x26C, 0x244, 0x26A, 0x246, 0x4C5, 0x243, 0x4BD, 0x24B, 0x4C0,
0x248, 0x267, 0x249, 0x4C2, 0x246, 0x269, 0x247, 0x267, 0x249, 0x265, 0x24B, 0x264};
word raw_command_off[] = {0x19, 0x987, 0x24B, 0x4C0, 0x248, 0x267, 0x249, 0x4C2, 0x247, 0x268, 0x248, 0x4C3, 0x245, 0x269.
0x246, 0x268, 0x248, 0x4C3, 0x245, 0x26A, 0x246, 0x269, 0x247, 0x267, 0x249, 0x266};
// Detected vendor
#define MY_IR_VENDOR IR_VENDOR_SONY // Use SONY protocol. See IRController.h for more details.
// Decoded commands
#define MY_IR_VENDOR_CMD_ON 0x290
#define MY_IR_VENDOR_CMD_OFF 0x290
#define DECODED_COMMAND_NBITS 12
// Last saved values on channels
byte currentCh1 = 0;
byte currentCh2 = 0;
// Command to send via IR
byte current_cmd = 0;
IRCommand_t vendor_cmd;
ZUNO_SETUP_CHANNELS(
ZUNO_SWITCH_BINARY(getter1, setter1),
ZUNO_SWITCH_BINARY(getter2, setter2)
void setup() {
// We have to setup IRLED pin as output
pinMode(6, OUTPUT);
digitalWrite(6, LOW);
// setting up IR-controller as IR-transmitter
ir_transmitter.setupVendor(MY_IR_VENDOR);
IR.begin(&ir_transmitter);
vendor_cmd.vendor = MY_IR_VENDOR;
vendor_cmd.n_bits = DECODED_COMMAND_NBITS;
void sendRAWCommand(WORD * raw16) {
// we have to repeat packet like another IR-controllers do
byte count = 7;
while(count--) {
IR.send_raw16(raw16);
delay(30);
void sendVendorCommand(unsigned long cmd) {
byte count = 7;
while(count--) {
vendor_cmd.data[0] = cmd;
IR.sendCommand(&vendor_cmd);
delay(30);
void loop() {
switch(current_cmd) {
case 1:
sendRAWCommand(raw_command_on);
break;
case 2:
sendRAWCommand(raw_command_off);
break;
case 3:
sendVendorCommand(MY_IR_VENDOR_CMD_ON);
break;
case 4:
sendVendorCommand(MY_IR_VENDOR_CMD_OFF);
break;
default:
// nothing to do
break;
current_cmd = 0;
delay(500);
void setter1(byte value) {
if (value != SWITCH_OFF) {
current_cmd = 1; // will be dispatched in the next loop
} else {
current_cmd = 2;
// let's save our value for the situation, when the controller will ask us about it
currentCh1 = value;
byte getter1() {
return currentCh1;
void setter2(byte value) {
current_cmd = 3;
} else {
current_cmd = 4;
currentCh2 = value;
byte getter2() {
return currentCh2;
Re: Adding extra ir commands
This scetch shows both raw commands and decoded. You can first of all check which type do you prefer. For this use IR learn scetch from examples.
The you can add more variables for each of your commands and add a corresponding sendVendorCommand or sendRAWCommand
MattyO
Post by MattyO »
Ok Cool I am using raw and have it working for the commands that are there. So to add more I jus need to add addition sendRAWCommand lines?
So if I add an new line and call it case 5: 6: 7: etc. Do I need to add anything else.
The definition of the command itself. Basically that's all you need.
