Adding extra ir commands
Posted: 03 Jun 2018 11:04
Hi Guys. I am really new to arduino sketches and programming in general. I am trying to build a sketch that will send out multiple ir commands via IR. this example sketch is fantastic, But I cant work out how to add additional commands. Would anybody be able to give me a bit of a heads start as to which parts I need to add to.
Thanks in advance Matt
#include "IRController.h"
IRTransmitterParams ir_transmitter(byte(IR_TRANSMITTER_OUTPUT_PIN6),
IR_FLAGS_OUTPUT_HIGHDRIVE,
IR_MS_PRESCALLER_4MHZ,
IR_CARRIER_PRESCALLER_8MHZ);
#define SWITCH_ON 0xff
#define SWITCH_OFF 0
// Use IRScanner.ino as IR-sniffer
// This codes were shiffed from SONY TV IR remote control
word raw_command_on[] = {0x19, 0x990, 0x242, 0x26D, 0x243, 0x26C, 0x244, 0x26A, 0x246, 0x4C5, 0x243, 0x4BD, 0x24B, 0x4C0,
0x248, 0x267, 0x249, 0x4C2, 0x246, 0x269, 0x247, 0x267, 0x249, 0x265, 0x24B, 0x264};
word raw_command_off[] = {0x19, 0x987, 0x24B, 0x4C0, 0x248, 0x267, 0x249, 0x4C2, 0x247, 0x268, 0x248, 0x4C3, 0x245, 0x269.
0x246, 0x268, 0x248, 0x4C3, 0x245, 0x26A, 0x246, 0x269, 0x247, 0x267, 0x249, 0x266};
// Detected vendor
#define MY_IR_VENDOR IR_VENDOR_SONY // Use SONY protocol. See IRController.h for more details.
// Decoded commands
#define MY_IR_VENDOR_CMD_ON 0x290
#define MY_IR_VENDOR_CMD_OFF 0x290
#define DECODED_COMMAND_NBITS 12
// Last saved values on channels
byte currentCh1 = 0;
byte currentCh2 = 0;
// Command to send via IR
byte current_cmd = 0;
IRCommand_t vendor_cmd;
ZUNO_SETUP_CHANNELS(
ZUNO_SWITCH_BINARY(getter1, setter1),
ZUNO_SWITCH_BINARY(getter2, setter2)
void setup() {
// We have to setup IRLED pin as output
pinMode(6, OUTPUT);
digitalWrite(6, LOW);
// setting up IR-controller as IR-transmitter
ir_transmitter.setupVendor(MY_IR_VENDOR);
IR.begin(&ir_transmitter);
vendor_cmd.vendor = MY_IR_VENDOR;
vendor_cmd.n_bits = DECODED_COMMAND_NBITS;
void sendRAWCommand(WORD * raw16) {
// we have to repeat packet like another IR-controllers do
byte count = 7;
while(count--) {
IR.send_raw16(raw16);
delay(30);
void sendVendorCommand(unsigned long cmd) {
byte count = 7;
while(count--) {
vendor_cmd.data[0] = cmd;
IR.sendCommand(&vendor_cmd);
delay(30);
void loop() {
switch(current_cmd) {
case 1:
sendRAWCommand(raw_command_on);
break;
case 2:
sendRAWCommand(raw_command_off);
break;
case 3:
sendVendorCommand(MY_IR_VENDOR_CMD_ON);
break;
case 4:
sendVendorCommand(MY_IR_VENDOR_CMD_OFF);
break;
default:
// nothing to do
break;
current_cmd = 0;
delay(500);
void setter1(byte value) {
if (value != SWITCH_OFF) {
current_cmd = 1; // will be dispatched in the next loop
} else {
current_cmd = 2;
// let's save our value for the situation, when the controller will ask us about it
currentCh1 = value;
byte getter1() {
return currentCh1;
void setter2(byte value) {
current_cmd = 3;
} else {
current_cmd = 4;
currentCh2 = value;
byte getter2() {
return currentCh2;
// Detected vendor
// Decoded commands
void setup() {
pinMode(6, OUTPUT);
byte count = 7;
while(count--) {
delay(30);
byte count = 7;
while(count--) {
delay(30);
void loop() {
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
default:
// nothing to do
break;
current_cmd = 0;
delay(500);
} else {
current_cmd = 2;
currentCh1 = value;
byte getter1() {
return currentCh1;
current_cmd = 3;
} else {
current_cmd = 4;
currentCh2 = value;
byte getter2() {
return currentCh2;
