Is Arduino Library compatible with ZUNO
jeffhumster
Post by jeffhumster »
I want to use a voice recognition software with Z-Uno, the software provides a Arduino Library. Since both programming languages are similar,I wonder if the arduino libraries works with Z-Uno compiler, if not ,will I be able to do minor modification to make it compatible? :D
Any opinion or suggestion is appreciated.
Re: Is Arduino Library compatible with ZUNO
If it has no assembler commands and no unusual C++ syntax, it should be portable.
But from voice recognition I would expect low level ASM commands
