Cannot find endpoint map to instance for Command Class COMMAND_CLASS_SWITCH_BINARY endpoint 0
nottix
Post by nottix » 19 Jan 2019 17:47
i'm having this error on openzwave with my 3 z-uno devices
2019-01-14 20:20:47.199 Error, Node017, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_SWITCH_BINARY endpoint 0
2019-01-14 20:20:47.704 Error, Node017, Cannot find endpoint map to instance for Command Class COMMAND_CLASS_SWITCH_BINARY endpoint 0
etc...
and this is a sample of my openzwave configuration file (where endpoint="0" is missing)
<CommandClass id="37" name="COMMAND_CLASS_SWITCH_BINARY" version="1" request_flags="5" innif="true">
	<Instance index="1" endpoint="1" />
	<Instance index="2" endpoint="2" />
	<Instance index="3" endpoint="3" />
	<Instance index="4" endpoint="4" />
	<Instance index="5" endpoint="5" />
	<Instance index="6" endpoint="6" />
	<Instance index="7" endpoint="7" />
	<Instance index="8" endpoint="8" />
</CommandClass>
I also found a similar problem with z-uno on this github issue https://github.com/OpenZWave/open-zwave/issues/966
Any ideas to fix this problem?
Thank you
