Issue with triggers from multiple inputs
rpalmer68
Post by rpalmer68 » 22 Jul 2019 14:50
I have written the sketch below from examples I found here, but I'm very new to this so think I have made a mistake as it not quite working as I expected and just can't work out why!
I have 8 relays connected to my alarm system that mirror the 8 PIRs in my house that I want to trigger lights from, each relay is connected to an input pin on the Z-Uno (pins 24, 25, and 3 - 8).
I have the relays connected to the Z-Uno ground line, so when they close the input pin on the Z-Uno gets taken to ground, the relays stay closed for 30 seconds when triggered.
All seems to be basically working, except for some reason when Relay 1 closes (connected to pin 24) I get motion notifications in Homeseer for Relay 1 AND Relay 6 (connected to pin 6), but if Relays 2 through to 8 close I only get a motion notification for the single relay, which is what I was expecting.
I have tested the wiring and also the relays and can confirm there are no shorts between the inputs and the relays are operating as expected, so I have to assume it's something I have got wrong in my code.
Here is an example for my Homeseer logs:
This is when the PIR in the hallway is triggered (relay 1) as you can see relay 6 (in another unoccupied room also triggers),
Jul-22 9:40:00 PM Event Event Trigger "Floor Lights Motion Detected - Study"
Jul-22 9:40:00 PM Z-Wave Device: Node 32 Z-Wave Relay 6 - Study Sensor Set to On/Open/Motion
Jul-22 9:40:00 PM Event Event Trigger "Floor Lights Motion Detected - Hallway"
Jul-22 9:40:00 PM Z-Wave Device: Node 32 Z-Wave Relay 1 - Upstairs Hallway Sensor Set to On/Open/Motion
This is when other PIRs in different locations are triggered, as you can see they only trigger the one event:
Jul-22 9:21:03 PM Event Event Trigger "Floor Lights Motion Detected - Lounge"
Jul-22 9:21:03 PM Z-Wave Device: Node 32 Z-Wave Relay 3 - Lounge Sensor Set to On/Open/Motion
Jul-22 9:20:56 PM Event Event Trigger "Floor Lights Motion Detected - Kitchen"
Jul-22 9:20:56 PM Z-Wave Device: Node 32 Z-Wave Relay 4 - Kitchen Sensor Set to On/Open/Motion
So could somebody please have a look at the code below and tell me if I have done something wrong??
Many many thanks
Richard
// Pin definitions
#define LED_PIN 13
#define MotionInput_1 24
#define MotionInput_2 25
#define MotionInput_3 3
#define MotionInput_4 4
#define MotionInput_5 5
#define MotionInput_6 6
#define MotionInput_7 7
#define MotionInput_8 8
#define RelaxMotionTime 3000  //  ~3 sec relax time
#define SWITCH_ON 0xff
#define SWITCH_OFF 0
// Global variables
byte lastMotionValue_1 = 0;
byte lastMotionValue_2 = 0;
byte lastMotionValue_3 = 0;
byte lastMotionValue_4 = 0;
byte lastMotionValue_5 = 0;
byte lastMotionValue_6 = 0;
byte lastMotionValue_7 = 0;
byte lastMotionValue_8 = 0;
word relaxMotion_1 = 0;
word relaxMotion_2 = 0;
word relaxMotion_3 = 0;
word relaxMotion_4 = 0;
word relaxMotion_5 = 0;
word relaxMotion_6 = 0;
word relaxMotion_7 = 0;
word relaxMotion_8 = 0;
// Z-Wave channels
ZUNO_SETUP_CHANNELS(
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterMotion_1),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterMotion_2),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterMotion_3),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterMotion_4),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterMotion_5),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterMotion_6),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterMotion_7),
  ZUNO_SENSOR_BINARY(ZUNO_SENSOR_BINARY_TYPE_MOTION, getterMotion_8)
void setup() {
  // set up I/O pins.
  pinMode(LED_PIN, OUTPUT);
  pinMode(MotionInput_1, INPUT_PULLUP);
  pinMode(MotionInput_2, INPUT_PULLUP);
  pinMode(MotionInput_3, INPUT_PULLUP);
  pinMode(MotionInput_4, INPUT_PULLUP);
  pinMode(MotionInput_5, INPUT_PULLUP);
  pinMode(MotionInput_6, INPUT_PULLUP);
  pinMode(MotionInput_7, INPUT_PULLUP);
  pinMode(MotionInput_8, INPUT_PULLUP);
void loop() {
  byte currentMotionValue_1;
  byte currentMotionValue_2;
  byte currentMotionValue_3;
  byte currentMotionValue_4;
  byte currentMotionValue_5;
  byte currentMotionValue_6;
  byte currentMotionValue_7;
  byte currentMotionValue_8;
// Trigger motion and wait for relax before report idle
// Input 1
  currentMotionValue_1 = !digitalRead(MotionInput_1);
  if (currentMotionValue_1) {
    if (relaxMotion_1 == 0) {
      lastMotionValue_1 = 1;
      zunoSendReport(1);
      digitalWrite(LED_PIN, HIGH);        // turn LED on
    relaxMotion_1 = RelaxMotionTime;
  if (lastMotionValue_1 == 1 && relaxMotion_1 == 0) {
    zunoSendReport(1);
//Input 2
  currentMotionValue_2 = !digitalRead(MotionInput_2);
  if (currentMotionValue_2) {
    if (relaxMotion_2 == 0) {
      lastMotionValue_2 = 1;
      zunoSendReport(2);
    relaxMotion_2 = RelaxMotionTime;
  if (lastMotionValue_2 == 1 && relaxMotion_2 == 0) {
    zunoSendReport(2);
//Input 3
  currentMotionValue_3 = !digitalRead(MotionInput_3);
  if (currentMotionValue_3) {
    if (relaxMotion_3 == 0) {
      lastMotionValue_3 = 1;
      zunoSendReport(3);
    relaxMotion_3 = RelaxMotionTime;
  if (lastMotionValue_3 == 1 && relaxMotion_3 == 0) {
    zunoSendReport(3);
//Input 4
  currentMotionValue_4 = !digitalRead(MotionInput_4);
  if (currentMotionValue_4) {
    if (relaxMotion_4 == 0) {
      lastMotionValue_4 = 1;
      zunoSendReport(4);
    relaxMotion_4 = RelaxMotionTime;
  if (lastMotionValue_4 == 1 && relaxMotion_4 == 0) {
    zunoSendReport(4);
//Input 5
  currentMotionValue_5 = !digitalRead(MotionInput_5);
  if (currentMotionValue_5) {
    if (relaxMotion_5 == 0) {
      lastMotionValue_5 = 1;
      zunoSendReport(5);
    relaxMotion_5 = RelaxMotionTime;
  if (lastMotionValue_5 == 1 && relaxMotion_5 == 0) {
    zunoSendReport(5);
//Input 6
  currentMotionValue_6 = !digitalRead(MotionInput_6);
  if (currentMotionValue_6) {
    if (relaxMotion_6 == 0) {
      lastMotionValue_6 = 1;
      zunoSendReport(6);
    relaxMotion_6 = RelaxMotionTime;
  if (lastMotionValue_6 == 1 && relaxMotion_6 == 0) {
    zunoSendReport(6);
//Input 7
  currentMotionValue_7 = !digitalRead(MotionInput_7);
  if (currentMotionValue_7) {
    if (relaxMotion_7 == 0) {
      lastMotionValue_7 = 1;
      zunoSendReport(7);
    relaxMotion_7 = RelaxMotionTime;
  if (lastMotionValue_7 == 1 && relaxMotion_7 == 0) {
    zunoSendReport(7);
//Input 8
  currentMotionValue_8 = !digitalRead(MotionInput_8);
  if (currentMotionValue_8) {
    if (relaxMotion_8 == 0) {
      lastMotionValue_8 = 1;
      zunoSendReport(8);
    relaxMotion_8 = RelaxMotionTime;
  if (lastMotionValue_8 == 1 && relaxMotion_8 == 0) {
    zunoSendReport(8);
  if (relaxMotion_1) relaxMotion_1--;
  if (relaxMotion_2) relaxMotion_2--;
  if (relaxMotion_3) relaxMotion_3--;
  if (relaxMotion_4) relaxMotion_4--;
  if (relaxMotion_5) relaxMotion_5--;
  if (relaxMotion_6) relaxMotion_6--;
  if (relaxMotion_7) relaxMotion_7--;
  if (relaxMotion_8) relaxMotion_8--;
  if (lastMotionValue_1 == 0 && lastMotionValue_2 == 0 && lastMotionValue_3 == 0 && lastMotionValue_4 == 0 && lastMotionValue_5 == 0 && lastMotionValue_6 == 0 && lastMotionValue_7 == 0 && lastMotionValue_8 == 0) {
     digitalWrite(LED_PIN, LOW);         // turn LED off
// Getters and setters
byte getterMotion_1(void) {
  return lastMotionValue_1 ? 0xff : 0;
byte getterMotion_2(void) {
  return lastMotionValue_2 ? 0xff : 0;
byte getterMotion_3(void) {
  return lastMotionValue_3 ? 0xff : 0;
byte getterMotion_4(void) {
  return lastMotionValue_4 ? 0xff : 0;
byte getterMotion_5(void) {
  return lastMotionValue_5 ? 0xff : 0;
byte getterMotion_6(void) {
  return lastMotionValue_6 ? 0xff : 0;
byte getterMotion_7(void) {
  return lastMotionValue_7 ? 0xff : 0;
byte getterMotion_8(void) {
  return lastMotionValue_8 ? 0xff : 0;
Re: Issue with triggers from multiple inputs
Post by PoltoS » 22 Jul 2019 17:39
Hi!
We have heard about such problems with HomeSeer. Please write to their support - it is on their side and they claim to fix it a year ago.
HS support do have a Z-Uno to make tests. You can keep us in CC so we can assist.
