Button Library - multiple instances of class
niky94547
Post by niky94547 »
We try to use library ZUNO_Button with multiple instances for buttons. Here is just a sample code with array of two instances...
#include <ZUNO_Buttons.h>
#define BTN_PIN1 4
#define BTN_PIN2 5
PinButton btn[2][2] = {
  {BTN_PIN1,true},
  {BTN_PIN2,true},
void setup() {
  Serial.begin(115200);
  pinMode(4, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
void loop() {
for( int i=0; i < sizeof 2; ++i ) {
  btn[i][i].update();
  btn[i][i].startDispatch();
  if(btn[i][i].isReleased()){
  if(btn[i][i].isSingleClick()){
  if(btn[i][i].isLongClick()){
  if(btn[i][i].isDoubleClick()){
  btn[i][i].endDispatch();
delay(20);
and gives us following error on compiler ....
C:\Users\USER\AppData\Local\Temp\arduino_build_438942\sketch_nov13a_sdcpp_.cpp:874:1:error: uCxx:Can't find method __cxx__PinButton__init00 for object btn of class PinButton
uCxx returned error code:-1
could you suggest any other approach or point our fault. We test same approach with original librarry on Arduino mega and it's ok.
Thanks a lot,
rkv
Re: Button Library - multiple instances of class
Post by rkv »
Thank you for your post. This is a bug and we will fix it soon.
niky94547
Post by niky94547 »
Thanks a lot for your reply and support. We look forward to implement library within our project. Just drop an notification once fixed.
Br,
