Can't PAIR with VERA
poordom
Post by poordom »
Good afternoon All,
I've been trying to Pair my Z-Uno, with VERA, without any success.
I've reset Z-Uno by pressing and holding the Service Button for 5 Sec. and rapidly pressing the service button 3 times, in order to un-pair, just in case.
I then followed the instructions to pair, by pressing the service button 3 times, all to no avail.
Please Help.
Dom
Re: Can't PAIR with VERA
Make sure the frequency matches!
poordom
Post by poordom »
Thanks PoltoS,
Yep! first thing I did, to no avail.
The thing I don't understand, when I first pair the unit with my Vera, the were no problem.
Then I had some unrelated issues with Vera, which were corrected, and when I finally got to try Z-Uno, nothing, so I'm not sure if what the Vera technician had me do, removed the Z-Uno. If I recall we had to dump the firmware and reload it.
So since I wasn't sure if Z-Uno was still paired with Vera but hidden, I tried to Unpaired the unit. So now I don't know if its paired or not?
Is there a way of showing all the hidden devices, or hidden Z-Uno.
Dom
Please try to remove it from Vera first (go in Add and find the Remove button nearby). Even if it is included, you can always remove it
poordom
Post by poordom »
Thanks PoltoS,
That's the problem, I don't see my Z-Uno on Vera anymore.
So I can't tell if its paired or not, or even just invisible.
I've tried several times to unpair by holding the service switch for 5 seconds and then pressing the service switch 3 times as indicated, again nothing.
Is there a way I can reset the Z-Uno to factory specs.
Is it possible that the recent firmware is not compatible with my Z-Uno, since my z-uno dates back to one of the original versions?
Thanks for your assistance.
Dom
Please check the factory reset and rescue mode on Z-Uno
poordom
Post by poordom »
PoltoS,
Thanks for your assistance, I finally got Z-Uno working.
I have uploaded a trial sketch, and modified some setting, and we are up and running.
I will be loading the 10 Channels sketch shortly, and I am petrified of screwing it up, but progress must go on.
Thanks Again
Dom
