ZUNO2 system Handler(s)
yves
Post by yves »
I found another one, Maybe it is already in your //TODO list...
I am unable to attach an handler to CFGParam. ZUNO_SETUP_CFGPARAMETER_HANDLER() does not seem to work.
(Param are effectively changed, you see it after reboot but my config_parameter_changed() is never called.
Previously today I use also ZUNO_SETUP_SYSEVENT_HANDLER(sys_event); to detect potential bugs in my code and I was happy/proud to detect none. Now I am not so sure ….
One point: if you modify the defines (one at a time) in ZUNO_StaticData.h to add a bug:
Line 129:#define ZUNO_SETUP_CFGPARAMETER_HANDLER(H) \
      GENERIC_POINTER ___zunoCFGHandler = DUMMY ((void*)H)
OR
Line192:#define ZUNO_SETUP_CFGPARAMETER_HANDLER(H) DUMMY
The bug in the first definition does not prevent compilation but in line 192 it does!
Thanks for your work!
p0lyg0n1
Re: ZUNO2 system Handler(s)
Post by p0lyg0n1 »
It is not necessary to change this header, it is used by our preprocessor. How exactly the preprocessor converts the data can be seen in the build directory zunopreproc/ZUNO_AutoSetup.c. The handler specified by ZUNO_SETUP_CFGPARAMETER_HANDLER will work ONLY with static channel creation. When dynamically setting channels, use zunoAttachSysHandle.
Here are 2 examples.
1. Static definition:
ZUNO_ENABLE(LOGGING_DBG);
ZUNO_SETUP_CFGPARAMETER_HANDLER(onNewCfgParamValue);
void onNewCfgParamValue(byte param_number, dword value){
    Serial0.print("CFG Param#");
    Serial0.print(param_number);
    Serial0.print(" value:");
    Serial0.println(value);
void setup(){
    Serial0.begin(115200);
void loop(){
    Serial0.print("loop millis:");
    Serial0.println(millis());
    delay(10000);
2. Dynamic definition:
ZUNO_ENABLE(LOGGING_DBG  WITH_CC_CONFIGURATION);
void setup(){
    zunoAttachSysHandler(ZUNO_HANDLER_ZW_CFG, 0,  (void*)&onNewCfgParamValue);
void loop(){
    delay(10000);
It seems that you like to explore everything deeply. It's wonderful! You can try, as I already wrote, to enable logging on TX0 (see LOGGING_DBG, https://z-uno.z-wave.me/Reference/ZUNO_ENABLE/)-there you can see incoming packets and understand whether the parameter values are coming to the device.
I also advise you to try our Razberry board as a controller, you can even add it as a second controller to your existing network. It will give you much more information about what is happening on the Z-Wave network.
With respect,
Alex.
yves
Post by yves »
Hi Alex,
You were right (for sure), zunoAttachSysHandler works well (even without ENABLE(WITH_CC_CONFIGURATION) ?) Thanks!
But then there is something I am missing:
I had modified your header to try to understand where the preprocessor was fetching information. And, now, the answer is 'it depends on what you are talking about.
You say :
With my code(s) it seems that channel are inserted statically and that (sys) handler are attached dynamically.
It does not 'seem': it is! The code that 'validates' zunoAttachSysHandler includes channels statically and I have no znuoAttachChannelHandler.
Adding local bugs (after #ifdef) in ZUNO_StaticData.h shows that very well.
Questions are
  • what trigs dynamic/static inclusion?
  • is it normal that some parts are dynamic and other are not?
Best regards,
Yves
p0lyg0n1
Post by p0lyg0n1 »
Hi Yves,
I will try to explain as simply as possible. The preprocessor extracts code from top-level (global-level) macros. The preprocessor generates the code for you and it can be seen in the build directory (arduino_build_<number>/zuno_preproc/ZUNO_AutoSetup.c). If you start the device configuration yourself using zone zunoStartDeviceConfiguration(), then you should not use
device configuration macros such as ZUNO_SETUP_CHANNELS(), ZUNO_SETUP_CFGPARAMETER_HANDLER(), ZUNO_SETUP_S2 ACCESS(),
ZUNO_SETUP_SLEEPING_MODE()
For a deeper understanding, look at the zuno_preproc subdirectory in the build directory.
With respect,
Alex.
yves
Post by yves »
Hi p0lyg0n1,
Thank you for your answe. I just have to point 2 issues: (I did not had time to have a deep look in the zuno_preproc subdirectory )
* If you start the device configuration yourself using zone zunoStartDeviceConfiguration(), then you should not use
If I do so then I am not able to include something into my HC2 network (this was where I start from...)
* Today my channel are included Statically And I need to' include' 'handler dynamically wjich does not make sense
Regards,
Yves
helendam
Post by helendam »
p0lyg0n1 wrote:
23 Mar 2022 11:04
void setup(){
void loop(){
    delay(10000);
void setup(){
void loop(){
    delay(10000);
It seems that you like to explore everything deeply. It's wonderful! You can try, as I already wrote, to enable logging on TX0 (see LOGGING_DBG, https://z-uno.z-wave.me/Reference/ZUNO_ENABLE/squidward)-there you can see incoming packets and understand whether the parameter values are coming to the device.
With respect,
Alex.
thanks share
