z-uno 2 Sleep 5Sec and Transmit shortly
MMA
Post by MMA »
I want to send sensor data shortly and go to sleep after that for 5 sec. I want that the minimum of power is used. I thought the transmission time is just some milliseconds.
Unfortunately I measured that the z-uno 2 needs 1sec for transmission time and Z-Wave operation. Only 4 sec is the device in sleep mode.
The Z-Uno 2 is peered with an Z Wave Controller (Aeotec).
Attached you can see the timing diagram of the Z Uno 2 device current. It is measured with an oscilloscope and a 1Ohm resister.
That is the sketch:
byte counter = 1;
#define SLEEP_MODE SLEEP_MODE_EM4
#define WAKEUP_CUSTOM_INTERVAL 5 // Every 5 seconds
ZUNO_SETUP_SLEEPING_MODE(ZUNO_SLEEPING_MODE_SLEEPING) // It's sleeping device
ZUNO_SETUP_CHANNELS(ZUNO_SWITCH_BINARY(counter, NULL));
void setup()
void loop()
 if(zunoIsSleepLocked())
    zunoSendReport(1); // Report will block sleep anyway
    zunoSetCustomWUPTimer(WAKEUP_CUSTOM_INTERVAL);
    zunoSendDeviceToSleep(SLEEP_MODE); // This just says I am ready but it doesn't stop usercode momentally & completely
    // User sleep latch is opened
How can the transmission time and Z-Wave operating time reduced to about 50ms?
Sleep Current.png (85.15 KiB) Viewed 1719 times
Re: z-uno 2 Sleep 5Sec and Transmit shortly
I'm checking it with the R&D, but looks the doc is wrong. zunoIsSleepLocked should return true when it is not possible to sleep (before zunoSendDeviceToSleep was called).
MMA
Post by MMA »
Could you talk R&D, could they find out why the transmittion time / CPU active time so long is? Please let me know. Is there anyway to reduce power consumption? Thanks
