Beginners problem, cannot start RaZberry
Your RaZberry H/W is not
Post by PoltoS » 08 Mar 2013 02:26
Your RaZberry H/W is not responding. Please try to powercycle your Raspberry Pi (not just a reboot, but replug the power).
pbergman111
Power Cycle, same result
Post by pbergman111 » 08 Mar 2013 02:26
Still failed to discover the Razberry. Directly out of the box although it was packed badly in the box and did shake around a bit.
May be it is broken. You
May be it is broken. You might contact your local shop for an exchange. We aplogoize. We had only few h/w problems so far.
dthavot
the same for me after rpi-update
Post by dthavot » 08 Mar 2013 02:26
i just have updated my rasp by rpi-update command and i have now my uname -a give:
Linux xxxxxxx 3.10.19+ #600 PREEMPT Sat Nov 16 20:34:43 GMT 2013 armv6l GNU/Linux
my z-way before update was running very well but after update z-way process won't start...
i have reinstalled z-way with the same like above.
Do you accept Z-Wave.Me licence agreement?
Please read it on Z-Wave.Me web site: http://razberry.z-wave.me/docs/ZWAYEULA.pdf
yes/no: yes
Previous Z-Way installation found
Stoping Z-Way
Stopping Z-Way: start-stop-daemon: warning: failed to kill 1784: No such process
done.
Making backup of previous version of Z-Way in /opt/z-way-server_2013-12-02-01-05-25
Installing additional libraries
Lecture des listes de paquets...
Construction de l'arbre des dépendances...
Lecture des informations d'état...
libyajl2 est déjà la plus récente version disponible.
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
Getting Z-Way for Raspberry Pi
Copying settings
cp: impossible d'évaluer « /opt/z-way-server_2013-12-02-01-05-25/automation/.syscommand »: Aucun fichier ou dossier de ce type
Creating Z-Way startup script
Adding to autostart
update-rc.d: using dependency based boot sequencing
Starting Z-Way
Starting Z-Way: done.
is the update would broke z-way install?
the link to my log when i start my z-way:
pastelink.me/dl/8f10c4
