have included the AEOTEC Multisensor unit to the network.
Checking the logs I can see that not every motion event will be logged - the assigned switch (Everspring Binary Power Switch) does work fine - it will switch on and off (after delay) if motion is detected.
In log I see sometimes only the switch off event - but not the switch on.
I have already moved the device near the RasZberry (some meters) - but no changes.
(BTW: the power switch is in more distance as the RaZberry...)
Any idea?
Thanks,
Michael
missing log entries
May be Multisensor does not
May be Multisensor does not send On event from time to time? It is very unlikely for RaZberry to miss it...
forget about it, after
forget about it, after reinstall device 2 times it is not reproduce more.
Thanks!
Thanks!
