Aeon Labs Multisensor strange display
rabing
Post by rabing »
The Aeon Labs multisensor should show in "Device control" -> "Sensors"
4 values of the 4 sensors. After a few days it shows the 4 sensors plus
~30 lines of not existing sensors. e.g. "Solar Radiation" and "Rains State":
device [5] found
Vendor-Name : Aeon Labs
Vendor-ID : 134
Product-ID : 5
Product-Type : 2
Battery-Level: 100
Sensor-Binary: { "name": "level", "value": false, "type": "bool", "invalidateTime": 1376325450, "updateTime": 1377378621 }
Multilevel : 24.70
Multilevel : 24.70 °C Temperature
Multilevel : 42 Generic
Multilevel : 1 Lux Luminiscence
Multilevel : 39 % Humidity
Multilevel : 22.90 kPa Athmospheric Pressure
Multilevel : 79 Solar Radiation
Multilevel : 25.10 mm/h Rain Rate
Instances : 1
same with the "Wintop" sensor:
device [9] found
Vendor-Name : Wintop
Vendor-ID : 151
Product-ID : 17665
Product-Type : 4482
Battery-Level: 100
Sensor-Binary: { "name": "level", "value": true, "type": "bool", "invalidateTime": 1376325451, "updateTime": 1376325600 }
Multilevel : 22.92 °C Temperature
Multilevel : 324 Lux Luminiscence
Instances : 1
hekj
I also get extra rows, it
Post by hekj »
I also get extra rows, it seems like the software is performing some kind of cyclic re-interview... but I have not clicked on the re-interview button.... :-(
My devices shows "Device interview is not complete" status after a couple of days.
@rabing, don't expect to get a quick answer, it seems like PoltoS is only online for a couple of hours one day per week.
Coult you please turn on
Coult you please turn on debug logging (in config.xml put log-level 0) and provide us the log from the start till the time you see these wrong sensors. Also tell us z-way version and razberry/stick f/w version/
rabing
Multilevel strange valuses
Post by rabing »
Logging ist turned on in config.xml "0"
The z-way version is "v1.4-rc1" and razberry firmware is "4.54 pl1".
When I restart the Z-Way server the strange values are there already.
The values appeared some time after I upgraded to "v1.4-rc1" and in
the expert UI the number of sensor lines keep growing slowly. I think
I have more then 100 sensor values for the Aeon Labs sensor now. The
values are part of the JSON data tree and show up in the UI. I'll send the
LOG-File with an extra mail. The Aeon Labs sensor is device 5.
nicholas-s
I have the same problem. Reported it before, but was ignored.
Post by nicholas-s »
Device ID is 3. Has around 100 lines with sensors and growing. Is an Aeon Labs Multisensor.
Log:
[2013-08-26 09:17:20.834] SETDATA devices.3.data = Empty
[2013-08-26 09:17:20.835] SETDATA devices.3.instances.0.data = Empty
[2013-08-26 09:17:20.835] SETDATA devices.3.instances.0.data.dynamic = Empty
[2013-08-26 09:17:20.835] SETDATA devices.3.instances.0.data.dynamic = False
[2013-08-26 09:17:20.835] SETDATA devices.3.instances.0.data.genericType = Empty
[2013-08-26 09:17:20.835] SETDATA devices.3.instances.0.data.genericType = 0 (0x00000000)
[2013-08-26 09:17:20.836] SETDATA devices.3.instances.0.data.specificType = Empty
[2013-08-26 09:17:20.836] SETDATA devices.3.instances.0.data.specificType = 0 (0x00000000)
[2013-08-26 09:17:20.836] SETDATA devices.3.data.basicType = Empty
[2013-08-26 09:17:20.836] SETDATA devices.3.data.genericType = Empty
[2013-08-26 09:17:20.836] SETDATA devices.3.data.specificType = Empty
[2013-08-26 09:17:20.836] SETDATA devices.3.data.infoProtocolSpecific = Empty
[2013-08-26 09:17:20.837] SETDATA devices.3.data.deviceTypeString = Empty
[2013-08-26 09:17:20.837] SETDATA devices.3.data.isVirtual = Empty
[2013-08-26 09:17:20.837] SETDATA devices.3.data.isListening = Empty
[2013-08-26 09:17:20.837] SETDATA devices.3.data.isRouting = Empty
[2013-08-26 09:17:20.837] SETDATA devices.3.data.isAwake = Empty
[2013-08-26 09:17:20.837] SETDATA devices.3.data.optional = Empty
[2013-08-26 09:17:20.838] SETDATA devices.3.data.isFailed = Empty
[2013-08-26 09:17:20.838] SETDATA devices.3.data.beam = Empty
[2013-08-26 09:17:20.838] SETDATA devices.3.data.sensor250 = Empty
[2013-08-26 09:17:20.838] SETDATA devices.3.data.sensor1000 = Empty
[2013-08-26 09:17:20.838] SETDATA devices.3.data.neighbours = Empty
[2013-08-26 09:17:20.839] SETDATA devices.3.data.manufacturerId = Empty
[2013-08-26 09:17:20.839] SETDATA devices.3.data.vendorString = Empty
[2013-08-26 09:17:20.839] SETDATA devices.3.data.manufacturerProductType = Empty
[2013-08-26 09:17:20.839] SETDATA devices.3.data.manufacturerProductId = Empty
[2013-08-26 09:17:20.839] SETDATA devices.3.data.ZWLib = Empty
[2013-08-26 09:17:20.839] SETDATA devices.3.data.ZWProtocolMajor = Empty
[2013-08-26 09:17:20.840] SETDATA devices.3.data.ZWProtocolMinor = Empty
[2013-08-26 09:17:20.840] SETDATA devices.3.data.SDK = Empty
[2013-08-26 09:17:20.841] SETDATA devices.3.data.applicationMajor = Empty
[2013-08-26 09:17:20.842] SETDATA devices.3.data.applicationMinor = Empty
[2013-08-26 09:17:20.842] SETDATA devices.3.data.nodeInfoFrame = Empty
[2013-08-26 09:17:20.842] SETDATA devices.3.data.ZDDXMLFile = Empty
[2013-08-26 09:17:20.842] SETDATA devices.3.data.lastSend = Empty
[2013-08-26 09:17:20.843] SETDATA devices.3.data.lastNonceGet = Empty
[2013-08-26 09:17:20.844] SETDATA devices.3.data.lastReceived = Empty
[2013-08-26 09:17:20.844] SETDATA devices.3.data.failureCount = Empty
[2013-08-26 09:17:20.844] SETDATA devices.3.data.keepAwake = Empty
[2013-08-26 09:17:20.844] SETDATA devices.3.data.countSuccess = Empty
[2013-08-26 09:17:20.845] SETDATA devices.3.data.countFailed = Empty
[2013-08-26 09:17:20.845] SETDATA devices.3.data.queueLength = Empty
[2013-08-26 09:17:20.845] SETDATA devices.3.data.basicType = 0 (0x00000000)
[2013-08-26 09:17:20.845] SETDATA devices.3.data.genericType = 0 (0x00000000)
[2013-08-26 09:17:20.845] SETDATA devices.3.data.specificType = 0 (0x00000000)
[2013-08-26 09:17:20.846] SETDATA devices.3.data.infoProtocolSpecific = 0 (0x00000000)
[2013-08-26 09:17:20.846] SETDATA devices.3.data.deviceTypeString = ""
[2013-08-26 09:17:20.846] SETDATA devices.3.data.isVirtual = False
[2013-08-26 09:17:20.846] SETDATA devices.3.data.isListening = True
[2013-08-26 09:17:20.847] SETDATA devices.3.data.isRouting = False
[2013-08-26 09:17:20.847] SETDATA devices.3.data.isAwake = False
[2013-08-26 09:17:20.847] SETDATA devices.3.data.optional = False
[2013-08-26 09:17:20.847] SETDATA devices.3.data.isFailed = False
[2013-08-26 09:17:20.847] SETDATA devices.3.data.beam = False
[2013-08-26 09:17:20.850] SETDATA devices.3.data.sensor250 = False
[2013-08-26 09:17:20.850] SETDATA devices.3.data.sensor1000 = False
[2013-08-26 09:17:20.851] SETDATA devices.3.data.neighbours = Empty
[2013-08-26 09:17:20.851] SETDATA devices.3.data.manufacturerId = 0 (0x00000000)
[2013-08-26 09:17:20.851] SETDATA devices.3.data.manufacturerProductType = 0 (0x00000000)
[2013-08-26 09:17:20.851] SETDATA devices.3.data.manufacturerProductId = 0 (0x00000000)
[2013-08-26 09:17:20.851] SETDATA devices.3.data.applicationMajor = 0 (0x00000000)
[2013-08-26 09:17:20.852] SETDATA devices.3.data.applicationMinor = 0 (0x00000000)
[2013-08-26 09:17:20.852] SETDATA devices.3.data.ZWProtocolMajor = 0 (0x00000000)
[2013-08-26 09:17:20.852] SETDATA devices.3.data.ZWProtocolMinor = 0 (0x00000000)
[2013-08-26 09:17:20.852] SETDATA devices.3.data.ZWLib = 0 (0x00000000)
[2013-08-26 09:17:20.852] SETDATA devices.3.data.SDK = ""
[2013-08-26 09:17:20.853] SETDATA devices.3.data.vendorString = ""
[2013-08-26 09:17:20.853] SETDATA devices.3.data.nodeInfoFrame = Empty
[2013-08-26 09:17:20.853] SETDATA devices.3.data.ZDDXMLFile = ""
[2013-08-26 09:17:20.853] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:20.853] SETDATA devices.3.data.countSuccess = 0 (0x00000000)
[2013-08-26 09:17:20.856] SETDATA devices.3.data.countFailed = 0 (0x00000000)
[2013-08-26 09:17:20.857] SETDATA devices.3.data.queueLength = 0 (0x00000000)
[2013-08-26 09:17:20.857] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-26 09:17:20.858] SETDATA devices.3.data.lastSend = 0 (0x00000000)
[2013-08-26 09:17:20.858] SETDATA devices.3.data.failureCount = 0 (0x00000000)
[2013-08-26 09:17:22.660] SETDATA devices.3.data.basicType = 4 (0x00000004)
[2013-08-26 09:17:22.661] SETDATA devices.3.data.genericType = 32 (0x00000020)
[2013-08-26 09:17:22.661] SETDATA devices.3.instances.0.data.genericType = 32 (0x00000020)
[2013-08-26 09:17:22.661] SETDATA devices.3.data.specificType = 1 (0x00000001)
[2013-08-26 09:17:22.661] SETDATA devices.3.instances.0.data.specificType = 1 (0x00000001)
[2013-08-26 09:17:22.662] SETDATA devices.3.data.infoProtocolSpecific = 5413888 (0x00529c00)
[2013-08-26 09:17:22.662] SETDATA devices.3.data.deviceTypeString = "Routing Binary Sensor"
[2013-08-26 09:17:22.662] SETDATA devices.3.data.isVirtual = False
[2013-08-26 09:17:22.662] SETDATA devices.3.data.isListening = False
[2013-08-26 09:17:22.662] SETDATA devices.3.data.isRouting = True
[2013-08-26 09:17:22.663] SETDATA devices.3.data.isAwake = False
[2013-08-26 09:17:22.663] SETDATA devices.3.data.optional = True
[2013-08-26 09:17:22.663] SETDATA devices.3.data.isFailed = False
[2013-08-26 09:17:22.663] SETDATA devices.3.data.beam = False
[2013-08-26 09:17:22.663] SETDATA devices.3.data.sensor250 = False
[2013-08-26 09:17:22.664] SETDATA devices.3.data.sensor1000 = False
[2013-08-26 09:17:22.664] SETDATA devices.3.data.neighbours = byte[13]
[2013-08-26 09:17:22.665] SETDATA devices.3.data.manufacturerId = 134 (0x00000086)
[2013-08-26 09:17:22.665] SETDATA devices.3.data.vendorString = "Aeon Labs"
[2013-08-26 09:17:22.665] SETDATA devices.3.data.manufacturerProductType = 2 (0x00000002)
[2013-08-26 09:17:22.665] SETDATA devices.3.data.manufacturerProductId = 5 (0x00000005)
[2013-08-26 09:17:22.666] SETDATA devices.3.data.ZWLib = 6 (0x00000006)
[2013-08-26 09:17:22.667] SETDATA devices.3.data.ZWProtocolMajor = 3 (0x00000003)
[2013-08-26 09:17:22.667] SETDATA devices.3.data.ZWProtocolMinor = 28 (0x0000001c)
[2013-08-26 09:17:22.667] SETDATA devices.3.data.SDK = "5.03"
[2013-08-26 09:17:22.667] SETDATA devices.3.data.applicationMajor = 1 (0x00000001)
[2013-08-26 09:17:22.668] SETDATA devices.3.data.applicationMinor = 18 (0x00000012)
[2013-08-26 09:17:22.668] SETDATA devices.3.data.nodeInfoFrame = byte[8]
[2013-08-26 09:17:22.669] SETDATA devices.3.data.ZDDXMLFile = "407-0086-0002-0005-06-03-1c-01-12.xml"
[2013-08-26 09:17:22.669] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-26 09:17:22.669] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:22.669] SETDATA devices.3.data.countSuccess = 0 (0x00000000)
[2013-08-26 09:17:22.670] SETDATA devices.3.data.countFailed = 0 (0x00000000)
[2013-08-26 09:17:22.670] SETDATA devices.3.data.queueLength = 0 (0x00000000)
[2013-08-26 09:17:22.670] SETDATA devices.3.data.ZDDXML = Empty
[2013-08-26 09:17:22.671] SETDATA devices.3.data.ZDDXML = "
[2013-08-26 09:17:22.672] SETDATA devices.3.data.ZDDXMLLang = Empty
[2013-08-26 09:17:22.672] SETDATA devices.3.data.ZDDXMLLang = "
[2013-08-26 09:17:22.675] SETDATA devices.3.instances.0.data.dynamic = False
[2013-08-26 09:17:22.675] SETDATA devices.3.instances.0.data.genericType = 32 (0x00000020)
[2013-08-26 09:17:22.675] SETDATA devices.3.instances.0.data.specificType = 1 (0x00000001)
[2013-08-26 09:17:22.676] SETDATA devices.3.instances.0.commandClasses.32.data = Empty
[2013-08-26 09:17:22.676] SETDATA devices.3.instances.0.commandClasses.32.data.version = Empty
[2013-08-26 09:17:22.676] SETDATA devices.3.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2013-08-26 09:17:22.677] SETDATA devices.3.instances.0.commandClasses.32.data.security = Empty
[2013-08-26 09:17:22.677] SETDATA devices.3.instances.0.commandClasses.32.data.security = False
[2013-08-26 09:17:22.677] SETDATA devices.3.instances.0.commandClasses.32.data.interviewDone = Empty
[2013-08-26 09:17:22.677] SETDATA devices.3.instances.0.commandClasses.32.data.interviewCounter = Empty
[2013-08-26 09:17:22.677] SETDATA devices.3.instances.0.commandClasses.32.data.interviewDone = False
[2013-08-26 09:17:22.678] SETDATA devices.3.instances.0.commandClasses.32.data.interviewCounter = 10 (0x0000000a)
[2013-08-26 09:17:22.678] SETDATA devices.3.instances.0.commandClasses.32.data.level = Empty
[2013-08-26 09:17:22.678] SETDATA devices.3.instances.0.commandClasses.32.data.lastset = Empty
[2013-08-26 09:17:22.678] SETDATA devices.3.instances.0.commandClasses.32.data.mylevel = Empty
[2013-08-26 09:17:22.678] SETDATA devices.3.instances.0.commandClasses.32.data.mylevel = 0 (0x00000000)
[2013-08-26 09:17:22.679] SETDATA devices.3.instances.0.commandClasses.32.data.version = 1 (0x00000001)
[2013-08-26 09:17:22.679] SETDATA devices.3.instances.0.commandClasses.32.data.security = False
[2013-08-26 09:17:22.679] SETDATA devices.3.instances.0.commandClasses.32.data.interviewDone = True
[2013-08-26 09:17:22.680] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:22.681] SETDATA devices.3.instances.0.commandClasses.32.data.interviewCounter = 9 (0x00000009)
[2013-08-26 09:17:22.681] SETDATA devices.3.instances.0.commandClasses.32.data.level = 0 (0x00000000)
[2013-08-26 09:17:22.682] SETDATA devices.3.instances.0.commandClasses.32.data.mylevel = 0 (0x00000000)
[2013-08-26 09:17:22.683] SETDATA devices.3.instances.0.commandClasses.48.data = Empty
[2013-08-26 09:17:22.683] SETDATA devices.3.instances.0.commandClasses.48.data.version = Empty
[2013-08-26 09:17:22.683] SETDATA devices.3.instances.0.commandClasses.48.data.version = 1 (0x00000001)
[2013-08-26 09:17:22.684] SETDATA devices.3.instances.0.commandClasses.48.data.security = Empty
[2013-08-26 09:17:22.684] SETDATA devices.3.instances.0.commandClasses.48.data.security = False
[2013-08-26 09:17:22.685] SETDATA devices.3.instances.0.commandClasses.48.data.interviewDone = Empty
[2013-08-26 09:17:22.685] SETDATA devices.3.instances.0.commandClasses.48.data.interviewCounter = Empty
[2013-08-26 09:17:22.685] SETDATA devices.3.instances.0.commandClasses.48.data.interviewDone = False
[2013-08-26 09:17:22.685] SETDATA devices.3.instances.0.commandClasses.48.data.interviewCounter = 10 (0x0000000a)
[2013-08-26 09:17:22.689] SETDATA devices.3.instances.0.commandClasses.48.data.level = Empty
[2013-08-26 09:17:22.690] SETDATA devices.3.instances.0.commandClasses.48.data.version = 1 (0x00000001)
[2013-08-26 09:17:22.693] SETDATA devices.3.instances.0.commandClasses.48.data.security = False
[2013-08-26 09:17:22.693] SETDATA devices.3.instances.0.commandClasses.48.data.interviewDone = True
[2013-08-26 09:17:22.695] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:22.695] SETDATA devices.3.instances.0.commandClasses.48.data.interviewCounter = 9 (0x00000009)
[2013-08-26 09:17:22.695] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-26 09:17:22.695] SETDATA devices.3.instances.0.commandClasses.49.data = Empty
[2013-08-26 09:17:22.696] SETDATA devices.3.instances.0.commandClasses.49.data.version = Empty
[2013-08-26 09:17:22.696] SETDATA devices.3.instances.0.commandClasses.49.data.version = 1 (0x00000001)
[2013-08-26 09:17:22.696] SETDATA devices.3.instances.0.commandClasses.49.data.security = Empty
[2013-08-26 09:17:22.696] SETDATA devices.3.instances.0.commandClasses.49.data.security = False
[2013-08-26 09:17:22.696] SETDATA devices.3.instances.0.commandClasses.49.data.interviewDone = Empty
[2013-08-26 09:17:22.697] SETDATA devices.3.instances.0.commandClasses.49.data.interviewCounter = Empty
[2013-08-26 09:17:22.697] SETDATA devices.3.instances.0.commandClasses.49.data.interviewDone = False
[2013-08-26 09:17:22.697] SETDATA devices.3.instances.0.commandClasses.49.data.interviewCounter = 10 (0x0000000a)
[2013-08-26 09:17:22.697] SETDATA devices.3.instances.0.commandClasses.49.data.typemask = Empty
[2013-08-26 09:17:22.698] SETDATA devices.3.instances.0.commandClasses.49.data.version = 5 (0x00000005)
[2013-08-26 09:17:22.699] SETDATA devices.3.instances.0.commandClasses.49.data.security = False
[2013-08-26 09:17:22.699] SETDATA devices.3.instances.0.commandClasses.49.data.interviewDone = True
[2013-08-26 09:17:22.700] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:22.700] SETDATA devices.3.instances.0.commandClasses.49.data.interviewCounter = 9 (0x00000009)
[2013-08-26 09:17:22.701] SETDATA devices.3.instances.0.commandClasses.49.data.sensorType = Empty
[2013-08-26 09:17:22.701] SETDATA devices.3.instances.0.commandClasses.49.data.sensorType = 1 (0x00000001)
[2013-08-26 09:17:22.701] SETDATA devices.3.instances.0.commandClasses.49.data.sensorTypeString = Empty
[2013-08-26 09:17:22.701] SETDATA devices.3.instances.0.commandClasses.49.data.sensorTypeString = "Temperature"
[2013-08-26 09:17:22.701] SETDATA devices.3.instances.0.commandClasses.49.data.val = Empty
[2013-08-26 09:17:22.702] SETDATA devices.3.instances.0.commandClasses.49.data.val = 1.600000
[2013-08-26 09:17:22.702] SETDATA devices.3.instances.0.commandClasses.49.data.scale = Empty
[2013-08-26 09:17:22.702] SETDATA devices.3.instances.0.commandClasses.49.data.scale = 0 (0x00000000)
[2013-08-26 09:17:22.702] SETDATA devices.3.instances.0.commandClasses.49.data.scaleString = Empty
[2013-08-26 09:17:22.703] SETDATA devices.3.instances.0.commandClasses.49.data.scaleString = "%"
[2013-08-26 09:17:22.703] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-26 09:17:22.703] SETDATA devices.3.instances.0.commandClasses.49.data.3.sensorTypeString = Empty
[2013-08-26 09:17:22.703] SETDATA devices.3.instances.0.commandClasses.49.data.3.sensorTypeString = "Luminiscence"
[2013-08-26 09:17:22.703] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = Empty
[2013-08-26 09:17:22.704] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 3.000000
[2013-08-26 09:17:22.704] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = Empty
[2013-08-26 09:17:22.704] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.704] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = Empty
[2013-08-26 09:17:22.704] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-26 09:17:22.705] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = Empty
[2013-08-26 09:17:22.705] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-26 09:17:22.705] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-26 09:17:22.705] SETDATA devices.3.instances.0.commandClasses.49.data.5.sensorTypeString = Empty
[2013-08-26 09:17:22.705] SETDATA devices.3.instances.0.commandClasses.49.data.5.sensorTypeString = "Humidity"
[2013-08-26 09:17:22.706] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = Empty
[2013-08-26 09:17:22.706] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 74.000000
[2013-08-26 09:17:22.706] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = Empty
[2013-08-26 09:17:22.706] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.707] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = Empty
[2013-08-26 09:17:22.707] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-26 09:17:22.707] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = Empty
[2013-08-26 09:17:22.707] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-26 09:17:22.708] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-26 09:17:22.708] SETDATA devices.3.instances.0.commandClasses.49.data.1.sensorTypeString = Empty
[2013-08-26 09:17:22.708] SETDATA devices.3.instances.0.commandClasses.49.data.1.sensorTypeString = "Temperature"
[2013-08-26 09:17:22.708] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = Empty
[2013-08-26 09:17:22.708] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 13.200000
[2013-08-26 09:17:22.709] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = Empty
[2013-08-26 09:17:22.709] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.709] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = Empty
[2013-08-26 09:17:22.709] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-26 09:17:22.709] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = Empty
[2013-08-26 09:17:22.710] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-26 09:17:22.726] SETDATA devices.3.instances.0.commandClasses.49.data.17 = Empty
[2013-08-26 09:17:22.726] SETDATA devices.3.instances.0.commandClasses.49.data.17.sensorTypeString = Empty
[2013-08-26 09:17:22.726] SETDATA devices.3.instances.0.commandClasses.49.data.17.sensorTypeString = "CO2 Level"
[2013-08-26 09:17:22.727] SETDATA devices.3.instances.0.commandClasses.49.data.17.val = Empty
[2013-08-26 09:17:22.727] SETDATA devices.3.instances.0.commandClasses.49.data.17.val = 1.000000
[2013-08-26 09:17:22.727] SETDATA devices.3.instances.0.commandClasses.49.data.17.deviceScale = Empty
[2013-08-26 09:17:22.727] SETDATA devices.3.instances.0.commandClasses.49.data.17.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.728] SETDATA devices.3.instances.0.commandClasses.49.data.17.scale = Empty
[2013-08-26 09:17:22.728] SETDATA devices.3.instances.0.commandClasses.49.data.17.scale = 0 (0x00000000)
[2013-08-26 09:17:22.728] SETDATA devices.3.instances.0.commandClasses.49.data.17.scaleString = Empty
[2013-08-26 09:17:22.728] SETDATA devices.3.instances.0.commandClasses.49.data.17.scaleString = "ppm"
[2013-08-26 09:17:22.728] SETDATA devices.3.instances.0.commandClasses.49.data.7 = Empty
[2013-08-26 09:17:22.729] SETDATA devices.3.instances.0.commandClasses.49.data.7.sensorTypeString = Empty
[2013-08-26 09:17:22.729] SETDATA devices.3.instances.0.commandClasses.49.data.7.sensorTypeString = "Direction"
[2013-08-26 09:17:22.729] SETDATA devices.3.instances.0.commandClasses.49.data.7.val = Empty
[2013-08-26 09:17:22.730] SETDATA devices.3.instances.0.commandClasses.49.data.7.val = 81.000000
[2013-08-26 09:17:22.730] SETDATA devices.3.instances.0.commandClasses.49.data.7.deviceScale = Empty
[2013-08-26 09:17:22.731] SETDATA devices.3.instances.0.commandClasses.49.data.7.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.732] SETDATA devices.3.instances.0.commandClasses.49.data.7.scale = Empty
[2013-08-26 09:17:22.732] SETDATA devices.3.instances.0.commandClasses.49.data.7.scale = 0 (0x00000000)
[2013-08-26 09:17:22.732] SETDATA devices.3.instances.0.commandClasses.49.data.7.scaleString = Empty
[2013-08-26 09:17:22.732] SETDATA devices.3.instances.0.commandClasses.49.data.7.scaleString = "degree"
[2013-08-26 09:17:22.733] SETDATA devices.3.instances.0.commandClasses.49.data.9 = Empty
[2013-08-26 09:17:22.733] SETDATA devices.3.instances.0.commandClasses.49.data.9.sensorTypeString = Empty
[2013-08-26 09:17:22.733] SETDATA devices.3.instances.0.commandClasses.49.data.9.sensorTypeString = "Barometric Pressure"
[2013-08-26 09:17:22.733] SETDATA devices.3.instances.0.commandClasses.49.data.9.val = Empty
[2013-08-26 09:17:22.734] SETDATA devices.3.instances.0.commandClasses.49.data.9.val = 13.600000
[2013-08-26 09:17:22.734] SETDATA devices.3.instances.0.commandClasses.49.data.9.deviceScale = Empty
[2013-08-26 09:17:22.734] SETDATA devices.3.instances.0.commandClasses.49.data.9.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.734] SETDATA devices.3.instances.0.commandClasses.49.data.9.scale = Empty
[2013-08-26 09:17:22.735] SETDATA devices.3.instances.0.commandClasses.49.data.9.scale = 0 (0x00000000)
[2013-08-26 09:17:22.735] SETDATA devices.3.instances.0.commandClasses.49.data.9.scaleString = Empty
[2013-08-26 09:17:22.735] SETDATA devices.3.instances.0.commandClasses.49.data.9.scaleString = "kPa"
[2013-08-26 09:17:22.735] SETDATA devices.3.instances.0.commandClasses.49.data.180 = Empty
[2013-08-26 09:17:22.735] SETDATA devices.3.instances.0.commandClasses.49.data.180.sensorTypeString = Empty
[2013-08-26 09:17:22.736] SETDATA devices.3.instances.0.commandClasses.49.data.180.sensorTypeString = ""
[2013-08-26 09:17:22.736] SETDATA devices.3.instances.0.commandClasses.49.data.180.val = Empty
[2013-08-26 09:17:22.736] SETDATA devices.3.instances.0.commandClasses.49.data.180.val = 19.000000
[2013-08-26 09:17:22.737] SETDATA devices.3.instances.0.commandClasses.49.data.180.deviceScale = Empty
[2013-08-26 09:17:22.737] SETDATA devices.3.instances.0.commandClasses.49.data.180.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.737] SETDATA devices.3.instances.0.commandClasses.49.data.180.scale = Empty
[2013-08-26 09:17:22.738] SETDATA devices.3.instances.0.commandClasses.49.data.180.scale = 0 (0x00000000)
[2013-08-26 09:17:22.738] SETDATA devices.3.instances.0.commandClasses.49.data.180.scaleString = Empty
[2013-08-26 09:17:22.738] SETDATA devices.3.instances.0.commandClasses.49.data.180.scaleString = ""
[2013-08-26 09:17:22.739] SETDATA devices.3.instances.0.commandClasses.49.data.32 = Empty
[2013-08-26 09:17:22.739] SETDATA devices.3.instances.0.commandClasses.49.data.32.sensorTypeString = Empty
[2013-08-26 09:17:22.739] SETDATA devices.3.instances.0.commandClasses.49.data.32.sensorTypeString = ""
[2013-08-26 09:17:22.741] SETDATA devices.3.instances.0.commandClasses.49.data.32.val = Empty
[2013-08-26 09:17:22.742] SETDATA devices.3.instances.0.commandClasses.49.data.32.val = 62.000000
[2013-08-26 09:17:22.742] SETDATA devices.3.instances.0.commandClasses.49.data.32.deviceScale = Empty
[2013-08-26 09:17:22.742] SETDATA devices.3.instances.0.commandClasses.49.data.32.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.742] SETDATA devices.3.instances.0.commandClasses.49.data.32.scale = Empty
[2013-08-26 09:17:22.743] SETDATA devices.3.instances.0.commandClasses.49.data.32.scale = 0 (0x00000000)
[2013-08-26 09:17:22.743] SETDATA devices.3.instances.0.commandClasses.49.data.32.scaleString = Empty
[2013-08-26 09:17:22.743] SETDATA devices.3.instances.0.commandClasses.49.data.32.scaleString = ""
[2013-08-26 09:17:22.743] SETDATA devices.3.instances.0.commandClasses.49.data.164 = Empty
[2013-08-26 09:17:22.744] SETDATA devices.3.instances.0.commandClasses.49.data.164.sensorTypeString = Empty
[2013-08-26 09:17:22.744] SETDATA devices.3.instances.0.commandClasses.49.data.164.sensorTypeString = ""
[2013-08-26 09:17:22.744] SETDATA devices.3.instances.0.commandClasses.49.data.164.val = Empty
[2013-08-26 09:17:22.744] SETDATA devices.3.instances.0.commandClasses.49.data.164.val = 833.000000
[2013-08-26 09:17:22.745] SETDATA devices.3.instances.0.commandClasses.49.data.164.deviceScale = Empty
[2013-08-26 09:17:22.745] SETDATA devices.3.instances.0.commandClasses.49.data.164.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.748] SETDATA devices.3.instances.0.commandClasses.49.data.164.scale = Empty
[2013-08-26 09:17:22.748] SETDATA devices.3.instances.0.commandClasses.49.data.164.scale = 1 (0x00000001)
[2013-08-26 09:17:22.748] SETDATA devices.3.instances.0.commandClasses.49.data.164.scaleString = Empty
[2013-08-26 09:17:22.748] SETDATA devices.3.instances.0.commandClasses.49.data.164.scaleString = ""
[2013-08-26 09:17:22.749] SETDATA devices.3.instances.0.commandClasses.49.data.160 = Empty
[2013-08-26 09:17:22.749] SETDATA devices.3.instances.0.commandClasses.49.data.160.sensorTypeString = Empty
[2013-08-26 09:17:22.758] SETDATA devices.3.instances.0.commandClasses.49.data.160.sensorTypeString = ""
[2013-08-26 09:17:22.758] SETDATA devices.3.instances.0.commandClasses.49.data.160.val = Empty
[2013-08-26 09:17:22.758] SETDATA devices.3.instances.0.commandClasses.49.data.160.val = 28.200001
[2013-08-26 09:17:22.759] SETDATA devices.3.instances.0.commandClasses.49.data.160.deviceScale = Empty
[2013-08-26 09:17:22.759] SETDATA devices.3.instances.0.commandClasses.49.data.160.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.759] SETDATA devices.3.instances.0.commandClasses.49.data.160.scale = Empty
[2013-08-26 09:17:22.759] SETDATA devices.3.instances.0.commandClasses.49.data.160.scale = 0 (0x00000000)
[2013-08-26 09:17:22.759] SETDATA devices.3.instances.0.commandClasses.49.data.160.scaleString = Empty
[2013-08-26 09:17:22.760] SETDATA devices.3.instances.0.commandClasses.49.data.160.scaleString = ""
[2013-08-26 09:17:22.760] SETDATA devices.3.instances.0.commandClasses.49.data.24 = Empty
[2013-08-26 09:17:22.760] SETDATA devices.3.instances.0.commandClasses.49.data.24.sensorTypeString = Empty
[2013-08-26 09:17:22.760] SETDATA devices.3.instances.0.commandClasses.49.data.24.sensorTypeString = ""
[2013-08-26 09:17:22.761] SETDATA devices.3.instances.0.commandClasses.49.data.24.val = Empty
[2013-08-26 09:17:22.761] SETDATA devices.3.instances.0.commandClasses.49.data.24.val = 1000.000000
[2013-08-26 09:17:22.761] SETDATA devices.3.instances.0.commandClasses.49.data.24.deviceScale = Empty
[2013-08-26 09:17:22.761] SETDATA devices.3.instances.0.commandClasses.49.data.24.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.761] SETDATA devices.3.instances.0.commandClasses.49.data.24.scale = Empty
[2013-08-26 09:17:22.762] SETDATA devices.3.instances.0.commandClasses.49.data.24.scale = 1 (0x00000001)
[2013-08-26 09:17:22.762] SETDATA devices.3.instances.0.commandClasses.49.data.24.scaleString = Empty
[2013-08-26 09:17:22.762] SETDATA devices.3.instances.0.commandClasses.49.data.24.scaleString = ""
[2013-08-26 09:17:22.762] SETDATA devices.3.instances.0.commandClasses.49.data.252 = Empty
[2013-08-26 09:17:22.762] SETDATA devices.3.instances.0.commandClasses.49.data.252.sensorTypeString = Empty
[2013-08-26 09:17:22.763] SETDATA devices.3.instances.0.commandClasses.49.data.252.sensorTypeString = ""
[2013-08-26 09:17:22.763] SETDATA devices.3.instances.0.commandClasses.49.data.252.val = Empty
[2013-08-26 09:17:22.763] SETDATA devices.3.instances.0.commandClasses.49.data.252.val = 18.100000
[2013-08-26 09:17:22.763] SETDATA devices.3.instances.0.commandClasses.49.data.252.deviceScale = Empty
[2013-08-26 09:17:22.763] SETDATA devices.3.instances.0.commandClasses.49.data.252.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.764] SETDATA devices.3.instances.0.commandClasses.49.data.252.scale = Empty
[2013-08-26 09:17:22.764] SETDATA devices.3.instances.0.commandClasses.49.data.252.scale = 0 (0x00000000)
[2013-08-26 09:17:22.764] SETDATA devices.3.instances.0.commandClasses.49.data.252.scaleString = Empty
[2013-08-26 09:17:22.764] SETDATA devices.3.instances.0.commandClasses.49.data.252.scaleString = ""
[2013-08-26 09:17:22.765] SETDATA devices.3.instances.0.commandClasses.49.data.202 = Empty
[2013-08-26 09:17:22.765] SETDATA devices.3.instances.0.commandClasses.49.data.202.sensorTypeString = Empty
[2013-08-26 09:17:22.765] SETDATA devices.3.instances.0.commandClasses.49.data.202.sensorTypeString = ""
[2013-08-26 09:17:22.765] SETDATA devices.3.instances.0.commandClasses.49.data.202.val = Empty
[2013-08-26 09:17:22.765] SETDATA devices.3.instances.0.commandClasses.49.data.202.val = 954.000000
[2013-08-26 09:17:22.766] SETDATA devices.3.instances.0.commandClasses.49.data.202.deviceScale = Empty
[2013-08-26 09:17:22.766] SETDATA devices.3.instances.0.commandClasses.49.data.202.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.766] SETDATA devices.3.instances.0.commandClasses.49.data.202.scale = Empty
[2013-08-26 09:17:22.766] SETDATA devices.3.instances.0.commandClasses.49.data.202.scale = 1 (0x00000001)
[2013-08-26 09:17:22.767] SETDATA devices.3.instances.0.commandClasses.49.data.202.scaleString = Empty
[2013-08-26 09:17:22.767] SETDATA devices.3.instances.0.commandClasses.49.data.202.scaleString = ""
[2013-08-26 09:17:22.767] SETDATA devices.3.instances.0.commandClasses.49.data.204 = Empty
[2013-08-26 09:17:22.767] SETDATA devices.3.instances.0.commandClasses.49.data.204.sensorTypeString = Empty
[2013-08-26 09:17:22.767] SETDATA devices.3.instances.0.commandClasses.49.data.204.sensorTypeString = ""
[2013-08-26 09:17:22.773] SETDATA devices.3.instances.0.commandClasses.49.data.204.val = Empty
[2013-08-26 09:17:22.773] SETDATA devices.3.instances.0.commandClasses.49.data.204.val = 1000.000000
[2013-08-26 09:17:22.775] SETDATA devices.3.instances.0.commandClasses.49.data.204.deviceScale = Empty
[2013-08-26 09:17:22.775] SETDATA devices.3.instances.0.commandClasses.49.data.204.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.775] SETDATA devices.3.instances.0.commandClasses.49.data.204.scale = Empty
[2013-08-26 09:17:22.775] SETDATA devices.3.instances.0.commandClasses.49.data.204.scale = 1 (0x00000001)
[2013-08-26 09:17:22.776] SETDATA devices.3.instances.0.commandClasses.49.data.204.scaleString = Empty
[2013-08-26 09:17:22.776] SETDATA devices.3.instances.0.commandClasses.49.data.204.scaleString = ""
[2013-08-26 09:17:22.777] SETDATA devices.3.instances.0.commandClasses.49.data.182 = Empty
[2013-08-26 09:17:22.777] SETDATA devices.3.instances.0.commandClasses.49.data.182.sensorTypeString = Empty
[2013-08-26 09:17:22.778] SETDATA devices.3.instances.0.commandClasses.49.data.182.sensorTypeString = ""
[2013-08-26 09:17:22.778] SETDATA devices.3.instances.0.commandClasses.49.data.182.val = Empty
[2013-08-26 09:17:22.778] SETDATA devices.3.instances.0.commandClasses.49.data.182.val = 66.000000
[2013-08-26 09:17:22.779] SETDATA devices.3.instances.0.commandClasses.49.data.182.deviceScale = Empty
[2013-08-26 09:17:22.779] SETDATA devices.3.instances.0.commandClasses.49.data.182.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.780] SETDATA devices.3.instances.0.commandClasses.49.data.182.scale = Empty
[2013-08-26 09:17:22.780] SETDATA devices.3.instances.0.commandClasses.49.data.182.scale = 0 (0x00000000)
[2013-08-26 09:17:22.780] SETDATA devices.3.instances.0.commandClasses.49.data.182.scaleString = Empty
[2013-08-26 09:17:22.781] SETDATA devices.3.instances.0.commandClasses.49.data.182.scaleString = ""
[2013-08-26 09:17:22.781] SETDATA devices.3.instances.0.commandClasses.49.data.102 = Empty
[2013-08-26 09:17:22.781] SETDATA devices.3.instances.0.commandClasses.49.data.102.sensorTypeString = Empty
[2013-08-26 09:17:22.782] SETDATA devices.3.instances.0.commandClasses.49.data.102.sensorTypeString = ""
[2013-08-26 09:17:22.782] SETDATA devices.3.instances.0.commandClasses.49.data.102.val = Empty
[2013-08-26 09:17:22.783] SETDATA devices.3.instances.0.commandClasses.49.data.102.val = 13.400000
[2013-08-26 09:17:22.783] SETDATA devices.3.instances.0.commandClasses.49.data.102.deviceScale = Empty
[2013-08-26 09:17:22.783] SETDATA devices.3.instances.0.commandClasses.49.data.102.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.784] SETDATA devices.3.instances.0.commandClasses.49.data.102.scale = Empty
[2013-08-26 09:17:22.784] SETDATA devices.3.instances.0.commandClasses.49.data.102.scale = 0 (0x00000000)
[2013-08-26 09:17:22.785] SETDATA devices.3.instances.0.commandClasses.49.data.102.scaleString = Empty
[2013-08-26 09:17:22.785] SETDATA devices.3.instances.0.commandClasses.49.data.102.scaleString = ""
[2013-08-26 09:17:22.785] SETDATA devices.3.instances.0.commandClasses.49.data.184 = Empty
[2013-08-26 09:17:22.785] SETDATA devices.3.instances.0.commandClasses.49.data.184.sensorTypeString = Empty
[2013-08-26 09:17:22.787] SETDATA devices.3.instances.0.commandClasses.49.data.184.sensorTypeString = ""
[2013-08-26 09:17:22.787] SETDATA devices.3.instances.0.commandClasses.49.data.184.val = Empty
[2013-08-26 09:17:22.787] SETDATA devices.3.instances.0.commandClasses.49.data.184.val = 78.000000
[2013-08-26 09:17:22.788] SETDATA devices.3.instances.0.commandClasses.49.data.184.deviceScale = Empty
[2013-08-26 09:17:22.788] SETDATA devices.3.instances.0.commandClasses.49.data.184.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.788] SETDATA devices.3.instances.0.commandClasses.49.data.184.scale = Empty
[2013-08-26 09:17:22.788] SETDATA devices.3.instances.0.commandClasses.49.data.184.scale = 0 (0x00000000)
[2013-08-26 09:17:22.788] SETDATA devices.3.instances.0.commandClasses.49.data.184.scaleString = Empty
[2013-08-26 09:17:22.789] SETDATA devices.3.instances.0.commandClasses.49.data.184.scaleString = ""
[2013-08-26 09:17:22.789] SETDATA devices.3.instances.0.commandClasses.49.data.198 = Empty
[2013-08-26 09:17:22.790] SETDATA devices.3.instances.0.commandClasses.49.data.198.sensorTypeString = Empty
[2013-08-26 09:17:22.790] SETDATA devices.3.instances.0.commandClasses.49.data.198.sensorTypeString = ""
[2013-08-26 09:17:22.790] SETDATA devices.3.instances.0.commandClasses.49.data.198.val = Empty
[2013-08-26 09:17:22.790] SETDATA devices.3.instances.0.commandClasses.49.data.198.val = 1000.000000
[2013-08-26 09:17:22.791] SETDATA devices.3.instances.0.commandClasses.49.data.198.deviceScale = Empty
[2013-08-26 09:17:22.791] SETDATA devices.3.instances.0.commandClasses.49.data.198.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.791] SETDATA devices.3.instances.0.commandClasses.49.data.198.scale = Empty
[2013-08-26 09:17:22.791] SETDATA devices.3.instances.0.commandClasses.49.data.198.scale = 1 (0x00000001)
[2013-08-26 09:17:22.792] SETDATA devices.3.instances.0.commandClasses.49.data.198.scaleString = Empty
[2013-08-26 09:17:22.792] SETDATA devices.3.instances.0.commandClasses.49.data.198.scaleString = ""
[2013-08-26 09:17:22.792] SETDATA devices.3.instances.0.commandClasses.49.data.22 = Empty
[2013-08-26 09:17:22.792] SETDATA devices.3.instances.0.commandClasses.49.data.22.sensorTypeString = Empty
[2013-08-26 09:17:22.793] SETDATA devices.3.instances.0.commandClasses.49.data.22.sensorTypeString = ""
[2013-08-26 09:17:22.793] SETDATA devices.3.instances.0.commandClasses.49.data.22.val = Empty
[2013-08-26 09:17:22.793] SETDATA devices.3.instances.0.commandClasses.49.data.22.val = 12.600000
[2013-08-26 09:17:22.794] SETDATA devices.3.instances.0.commandClasses.49.data.22.deviceScale = Empty
[2013-08-26 09:17:22.794] SETDATA devices.3.instances.0.commandClasses.49.data.22.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.794] SETDATA devices.3.instances.0.commandClasses.49.data.22.scale = Empty
[2013-08-26 09:17:22.794] SETDATA devices.3.instances.0.commandClasses.49.data.22.scale = 0 (0x00000000)
[2013-08-26 09:17:22.794] SETDATA devices.3.instances.0.commandClasses.49.data.22.scaleString = Empty
[2013-08-26 09:17:22.795] SETDATA devices.3.instances.0.commandClasses.49.data.22.scaleString = ""
[2013-08-26 09:17:22.795] SETDATA devices.3.instances.0.commandClasses.49.data.190 = Empty
[2013-08-26 09:17:22.795] SETDATA devices.3.instances.0.commandClasses.49.data.190.sensorTypeString = Empty
[2013-08-26 09:17:22.795] SETDATA devices.3.instances.0.commandClasses.49.data.190.sensorTypeString = ""
[2013-08-26 09:17:22.796] SETDATA devices.3.instances.0.commandClasses.49.data.190.val = Empty
[2013-08-26 09:17:22.796] SETDATA devices.3.instances.0.commandClasses.49.data.190.val = 22.500000
[2013-08-26 09:17:22.797] SETDATA devices.3.instances.0.commandClasses.49.data.190.deviceScale = Empty
[2013-08-26 09:17:22.797] SETDATA devices.3.instances.0.commandClasses.49.data.190.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.799] SETDATA devices.3.instances.0.commandClasses.49.data.190.scale = Empty
[2013-08-26 09:17:22.799] SETDATA devices.3.instances.0.commandClasses.49.data.190.scale = 0 (0x00000000)
[2013-08-26 09:17:22.799] SETDATA devices.3.instances.0.commandClasses.49.data.190.scaleString = Empty
[2013-08-26 09:17:22.800] SETDATA devices.3.instances.0.commandClasses.49.data.190.scaleString = ""
[2013-08-26 09:17:22.800] SETDATA devices.3.instances.0.commandClasses.49.data.38 = Empty
[2013-08-26 09:17:22.801] SETDATA devices.3.instances.0.commandClasses.49.data.38.sensorTypeString = Empty
[2013-08-26 09:17:22.801] SETDATA devices.3.instances.0.commandClasses.49.data.38.sensorTypeString = ""
[2013-08-26 09:17:22.801] SETDATA devices.3.instances.0.commandClasses.49.data.38.val = Empty
[2013-08-26 09:17:22.802] SETDATA devices.3.instances.0.commandClasses.49.data.38.val = 622.000000
[2013-08-26 09:17:22.802] SETDATA devices.3.instances.0.commandClasses.49.data.38.deviceScale = Empty
[2013-08-26 09:17:22.802] SETDATA devices.3.instances.0.commandClasses.49.data.38.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.803] SETDATA devices.3.instances.0.commandClasses.49.data.38.scale = Empty
[2013-08-26 09:17:22.803] SETDATA devices.3.instances.0.commandClasses.49.data.38.scale = 1 (0x00000001)
[2013-08-26 09:17:22.804] SETDATA devices.3.instances.0.commandClasses.49.data.38.scaleString = Empty
[2013-08-26 09:17:22.804] SETDATA devices.3.instances.0.commandClasses.49.data.38.scaleString = ""
[2013-08-26 09:17:22.805] SETDATA devices.3.instances.0.commandClasses.49.data.194 = Empty
[2013-08-26 09:17:22.805] SETDATA devices.3.instances.0.commandClasses.49.data.194.sensorTypeString = Empty
[2013-08-26 09:17:22.805] SETDATA devices.3.instances.0.commandClasses.49.data.194.sensorTypeString = ""
[2013-08-26 09:17:22.805] SETDATA devices.3.instances.0.commandClasses.49.data.194.val = Empty
[2013-08-26 09:17:22.806] SETDATA devices.3.instances.0.commandClasses.49.data.194.val = 906.000000
[2013-08-26 09:17:22.806] SETDATA devices.3.instances.0.commandClasses.49.data.194.deviceScale = Empty
[2013-08-26 09:17:22.807] SETDATA devices.3.instances.0.commandClasses.49.data.194.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.807] SETDATA devices.3.instances.0.commandClasses.49.data.194.scale = Empty
[2013-08-26 09:17:22.808] SETDATA devices.3.instances.0.commandClasses.49.data.194.scale = 1 (0x00000001)
[2013-08-26 09:17:22.808] SETDATA devices.3.instances.0.commandClasses.49.data.194.scaleString = Empty
[2013-08-26 09:17:22.809] SETDATA devices.3.instances.0.commandClasses.49.data.194.scaleString = ""
[2013-08-26 09:17:22.809] SETDATA devices.3.instances.0.commandClasses.49.data.196 = Empty
[2013-08-26 09:17:22.809] SETDATA devices.3.instances.0.commandClasses.49.data.196.sensorTypeString = Empty
[2013-08-26 09:17:22.810] SETDATA devices.3.instances.0.commandClasses.49.data.196.sensorTypeString = ""
[2013-08-26 09:17:22.810] SETDATA devices.3.instances.0.commandClasses.49.data.196.val = Empty
[2013-08-26 09:17:22.810] SETDATA devices.3.instances.0.commandClasses.49.data.196.val = 68.000000
[2013-08-26 09:17:22.811] SETDATA devices.3.instances.0.commandClasses.49.data.196.deviceScale = Empty
[2013-08-26 09:17:22.811] SETDATA devices.3.instances.0.commandClasses.49.data.196.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.812] SETDATA devices.3.instances.0.commandClasses.49.data.196.scale = Empty
[2013-08-26 09:17:22.813] SETDATA devices.3.instances.0.commandClasses.49.data.196.scale = 0 (0x00000000)
[2013-08-26 09:17:22.813] SETDATA devices.3.instances.0.commandClasses.49.data.196.scaleString = Empty
[2013-08-26 09:17:22.813] SETDATA devices.3.instances.0.commandClasses.49.data.196.scaleString = ""
[2013-08-26 09:17:22.820] SETDATA devices.3.instances.0.commandClasses.49.data.168 = Empty
[2013-08-26 09:17:22.821] SETDATA devices.3.instances.0.commandClasses.49.data.168.sensorTypeString = Empty
[2013-08-26 09:17:22.821] SETDATA devices.3.instances.0.commandClasses.49.data.168.sensorTypeString = ""
[2013-08-26 09:17:22.821] SETDATA devices.3.instances.0.commandClasses.49.data.168.val = Empty
[2013-08-26 09:17:22.821] SETDATA devices.3.instances.0.commandClasses.49.data.168.val = 72.000000
[2013-08-26 09:17:22.821] SETDATA devices.3.instances.0.commandClasses.49.data.168.deviceScale = Empty
[2013-08-26 09:17:22.822] SETDATA devices.3.instances.0.commandClasses.49.data.168.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.822] SETDATA devices.3.instances.0.commandClasses.49.data.168.scale = Empty
[2013-08-26 09:17:22.822] SETDATA devices.3.instances.0.commandClasses.49.data.168.scale = 0 (0x00000000)
[2013-08-26 09:17:22.822] SETDATA devices.3.instances.0.commandClasses.49.data.168.scaleString = Empty
[2013-08-26 09:17:22.823] SETDATA devices.3.instances.0.commandClasses.49.data.168.scaleString = ""
[2013-08-26 09:17:22.823] SETDATA devices.3.instances.0.commandClasses.49.data.128 = Empty
[2013-08-26 09:17:22.823] SETDATA devices.3.instances.0.commandClasses.49.data.128.sensorTypeString = Empty
[2013-08-26 09:17:22.823] SETDATA devices.3.instances.0.commandClasses.49.data.128.sensorTypeString = ""
[2013-08-26 09:17:22.824] SETDATA devices.3.instances.0.commandClasses.49.data.128.val = Empty
[2013-08-26 09:17:22.824] SETDATA devices.3.instances.0.commandClasses.49.data.128.val = 59.000000
[2013-08-26 09:17:22.824] SETDATA devices.3.instances.0.commandClasses.49.data.128.deviceScale = Empty
[2013-08-26 09:17:22.824] SETDATA devices.3.instances.0.commandClasses.49.data.128.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.825] SETDATA devices.3.instances.0.commandClasses.49.data.128.scale = Empty
[2013-08-26 09:17:22.825] SETDATA devices.3.instances.0.commandClasses.49.data.128.scale = 0 (0x00000000)
[2013-08-26 09:17:22.825] SETDATA devices.3.instances.0.commandClasses.49.data.128.scaleString = Empty
[2013-08-26 09:17:22.825] SETDATA devices.3.instances.0.commandClasses.49.data.128.scaleString = ""
[2013-08-26 09:17:22.825] SETDATA devices.3.instances.0.commandClasses.49.data.16 = Empty
[2013-08-26 09:17:22.826] SETDATA devices.3.instances.0.commandClasses.49.data.16.sensorTypeString = Empty
[2013-08-26 09:17:22.826] SETDATA devices.3.instances.0.commandClasses.49.data.16.sensorTypeString = "Current"
[2013-08-26 09:17:22.826] SETDATA devices.3.instances.0.commandClasses.49.data.16.val = Empty
[2013-08-26 09:17:22.826] SETDATA devices.3.instances.0.commandClasses.49.data.16.val = 946.000000
[2013-08-26 09:17:22.827] SETDATA devices.3.instances.0.commandClasses.49.data.16.deviceScale = Empty
[2013-08-26 09:17:22.827] SETDATA devices.3.instances.0.commandClasses.49.data.16.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.827] SETDATA devices.3.instances.0.commandClasses.49.data.16.scale = Empty
[2013-08-26 09:17:22.827] SETDATA devices.3.instances.0.commandClasses.49.data.16.scale = 1 (0x00000001)
[2013-08-26 09:17:22.827] SETDATA devices.3.instances.0.commandClasses.49.data.16.scaleString = Empty
[2013-08-26 09:17:22.828] SETDATA devices.3.instances.0.commandClasses.49.data.16.scaleString = "mA"
[2013-08-26 09:17:22.828] SETDATA devices.3.instances.0.commandClasses.49.data.88 = Empty
[2013-08-26 09:17:22.828] SETDATA devices.3.instances.0.commandClasses.49.data.88.sensorTypeString = Empty
[2013-08-26 09:17:22.828] SETDATA devices.3.instances.0.commandClasses.49.data.88.sensorTypeString = ""
[2013-08-26 09:17:22.828] SETDATA devices.3.instances.0.commandClasses.49.data.88.val = Empty
[2013-08-26 09:17:22.829] SETDATA devices.3.instances.0.commandClasses.49.data.88.val = 0.000000
[2013-08-26 09:17:22.829] SETDATA devices.3.instances.0.commandClasses.49.data.88.deviceScale = Empty
[2013-08-26 09:17:22.829] SETDATA devices.3.instances.0.commandClasses.49.data.88.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.829] SETDATA devices.3.instances.0.commandClasses.49.data.88.scale = Empty
[2013-08-26 09:17:22.829] SETDATA devices.3.instances.0.commandClasses.49.data.88.scale = 1 (0x00000001)
[2013-08-26 09:17:22.830] SETDATA devices.3.instances.0.commandClasses.49.data.88.scaleString = Empty
[2013-08-26 09:17:22.830] SETDATA devices.3.instances.0.commandClasses.49.data.88.scaleString = ""
[2013-08-26 09:17:22.838] SETDATA devices.3.instances.0.commandClasses.49.data.26 = Empty
[2013-08-26 09:17:22.839] SETDATA devices.3.instances.0.commandClasses.49.data.26.sensorTypeString = Empty
[2013-08-26 09:17:22.839] SETDATA devices.3.instances.0.commandClasses.49.data.26.sensorTypeString = ""
[2013-08-26 09:17:22.839] SETDATA devices.3.instances.0.commandClasses.49.data.26.val = Empty
[2013-08-26 09:17:22.839] SETDATA devices.3.instances.0.commandClasses.49.data.26.val = 0.000000
[2013-08-26 09:17:22.840] SETDATA devices.3.instances.0.commandClasses.49.data.26.deviceScale = Empty
[2013-08-26 09:17:22.840] SETDATA devices.3.instances.0.commandClasses.49.data.26.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.840] SETDATA devices.3.instances.0.commandClasses.49.data.26.scale = Empty
[2013-08-26 09:17:22.840] SETDATA devices.3.instances.0.commandClasses.49.data.26.scale = 1 (0x00000001)
[2013-08-26 09:17:22.841] SETDATA devices.3.instances.0.commandClasses.49.data.26.scaleString = Empty
[2013-08-26 09:17:22.841] SETDATA devices.3.instances.0.commandClasses.49.data.26.scaleString = ""
[2013-08-26 09:17:22.841] SETDATA devices.3.instances.0.commandClasses.49.data.34 = Empty
[2013-08-26 09:17:22.841] SETDATA devices.3.instances.0.commandClasses.49.data.34.sensorTypeString = Empty
[2013-08-26 09:17:22.841] SETDATA devices.3.instances.0.commandClasses.49.data.34.sensorTypeString = ""
[2013-08-26 09:17:22.842] SETDATA devices.3.instances.0.commandClasses.49.data.34.val = Empty
[2013-08-26 09:17:22.842] SETDATA devices.3.instances.0.commandClasses.49.data.34.val = 14.200000
[2013-08-26 09:17:22.842] SETDATA devices.3.instances.0.commandClasses.49.data.34.deviceScale = Empty
[2013-08-26 09:17:22.842] SETDATA devices.3.instances.0.commandClasses.49.data.34.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.842] SETDATA devices.3.instances.0.commandClasses.49.data.34.scale = Empty
[2013-08-26 09:17:22.843] SETDATA devices.3.instances.0.commandClasses.49.data.34.scale = 0 (0x00000000)
[2013-08-26 09:17:22.843] SETDATA devices.3.instances.0.commandClasses.49.data.34.scaleString = Empty
[2013-08-26 09:17:22.843] SETDATA devices.3.instances.0.commandClasses.49.data.34.scaleString = ""
[2013-08-26 09:17:22.843] SETDATA devices.3.instances.0.commandClasses.49.data.4 = Empty
[2013-08-26 09:17:22.844] SETDATA devices.3.instances.0.commandClasses.49.data.4.sensorTypeString = Empty
[2013-08-26 09:17:22.844] SETDATA devices.3.instances.0.commandClasses.49.data.4.sensorTypeString = "Power"
[2013-08-26 09:17:22.844] SETDATA devices.3.instances.0.commandClasses.49.data.4.val = Empty
[2013-08-26 09:17:22.844] SETDATA devices.3.instances.0.commandClasses.49.data.4.val = 2.000000
[2013-08-26 09:17:22.844] SETDATA devices.3.instances.0.commandClasses.49.data.4.deviceScale = Empty
[2013-08-26 09:17:22.845] SETDATA devices.3.instances.0.commandClasses.49.data.4.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.845] SETDATA devices.3.instances.0.commandClasses.49.data.4.scale = Empty
[2013-08-26 09:17:22.845] SETDATA devices.3.instances.0.commandClasses.49.data.4.scale = 1 (0x00000001)
[2013-08-26 09:17:22.845] SETDATA devices.3.instances.0.commandClasses.49.data.4.scaleString = Empty
[2013-08-26 09:17:22.845] SETDATA devices.3.instances.0.commandClasses.49.data.4.scaleString = "Btu/h"
[2013-08-26 09:17:22.846] SETDATA devices.3.instances.0.commandClasses.49.data.6 = Empty
[2013-08-26 09:17:22.846] SETDATA devices.3.instances.0.commandClasses.49.data.6.sensorTypeString = Empty
[2013-08-26 09:17:22.846] SETDATA devices.3.instances.0.commandClasses.49.data.6.sensorTypeString = "Velocity"
[2013-08-26 09:17:22.846] SETDATA devices.3.instances.0.commandClasses.49.data.6.val = Empty
[2013-08-26 09:17:22.846] SETDATA devices.3.instances.0.commandClasses.49.data.6.val = 72.000000
[2013-08-26 09:17:22.847] SETDATA devices.3.instances.0.commandClasses.49.data.6.deviceScale = Empty
[2013-08-26 09:17:22.847] SETDATA devices.3.instances.0.commandClasses.49.data.6.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.847] SETDATA devices.3.instances.0.commandClasses.49.data.6.scale = Empty
[2013-08-26 09:17:22.847] SETDATA devices.3.instances.0.commandClasses.49.data.6.scale = 0 (0x00000000)
[2013-08-26 09:17:22.848] SETDATA devices.3.instances.0.commandClasses.49.data.6.scaleString = Empty
[2013-08-26 09:17:22.848] SETDATA devices.3.instances.0.commandClasses.49.data.6.scaleString = "m/s"
[2013-08-26 09:17:22.872] SETDATA devices.3.instances.0.commandClasses.49.data.244 = Empty
[2013-08-26 09:17:22.872] SETDATA devices.3.instances.0.commandClasses.49.data.244.sensorTypeString = Empty
[2013-08-26 09:17:22.872] SETDATA devices.3.instances.0.commandClasses.49.data.244.sensorTypeString = ""
[2013-08-26 09:17:22.873] SETDATA devices.3.instances.0.commandClasses.49.data.244.val = Empty
[2013-08-26 09:17:22.873] SETDATA devices.3.instances.0.commandClasses.49.data.244.val = 14.600000
[2013-08-26 09:17:22.873] SETDATA devices.3.instances.0.commandClasses.49.data.244.deviceScale = Empty
[2013-08-26 09:17:22.873] SETDATA devices.3.instances.0.commandClasses.49.data.244.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.873] SETDATA devices.3.instances.0.commandClasses.49.data.244.scale = Empty
[2013-08-26 09:17:22.874] SETDATA devices.3.instances.0.commandClasses.49.data.244.scale = 0 (0x00000000)
[2013-08-26 09:17:22.874] SETDATA devices.3.instances.0.commandClasses.49.data.244.scaleString = Empty
[2013-08-26 09:17:22.874] SETDATA devices.3.instances.0.commandClasses.49.data.244.scaleString = ""
[2013-08-26 09:17:22.874] SETDATA devices.3.instances.0.commandClasses.49.data.210 = Empty
[2013-08-26 09:17:22.875] SETDATA devices.3.instances.0.commandClasses.49.data.210.sensorTypeString = Empty
[2013-08-26 09:17:22.875] SETDATA devices.3.instances.0.commandClasses.49.data.210.sensorTypeString = ""
[2013-08-26 09:17:22.875] SETDATA devices.3.instances.0.commandClasses.49.data.210.val = Empty
[2013-08-26 09:17:22.875] SETDATA devices.3.instances.0.commandClasses.49.data.210.val = 57.000000
[2013-08-26 09:17:22.875] SETDATA devices.3.instances.0.commandClasses.49.data.210.deviceScale = Empty
[2013-08-26 09:17:22.876] SETDATA devices.3.instances.0.commandClasses.49.data.210.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.876] SETDATA devices.3.instances.0.commandClasses.49.data.210.scale = Empty
[2013-08-26 09:17:22.876] SETDATA devices.3.instances.0.commandClasses.49.data.210.scale = 0 (0x00000000)
[2013-08-26 09:17:22.876] SETDATA devices.3.instances.0.commandClasses.49.data.210.scaleString = Empty
[2013-08-26 09:17:22.876] SETDATA devices.3.instances.0.commandClasses.49.data.210.scaleString = ""
[2013-08-26 09:17:22.877] SETDATA devices.3.instances.0.commandClasses.49.data.44 = Empty
[2013-08-26 09:17:22.877] SETDATA devices.3.instances.0.commandClasses.49.data.44.sensorTypeString = Empty
[2013-08-26 09:17:22.877] SETDATA devices.3.instances.0.commandClasses.49.data.44.sensorTypeString = ""
[2013-08-26 09:17:22.877] SETDATA devices.3.instances.0.commandClasses.49.data.44.val = Empty
[2013-08-26 09:17:22.877] SETDATA devices.3.instances.0.commandClasses.49.data.44.val = 189.000000
[2013-08-26 09:17:22.878] SETDATA devices.3.instances.0.commandClasses.49.data.44.deviceScale = Empty
[2013-08-26 09:17:22.878] SETDATA devices.3.instances.0.commandClasses.49.data.44.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.878] SETDATA devices.3.instances.0.commandClasses.49.data.44.scale = Empty
[2013-08-26 09:17:22.878] SETDATA devices.3.instances.0.commandClasses.49.data.44.scale = 1 (0x00000001)
[2013-08-26 09:17:22.879] SETDATA devices.3.instances.0.commandClasses.49.data.44.scaleString = Empty
[2013-08-26 09:17:22.879] SETDATA devices.3.instances.0.commandClasses.49.data.44.scaleString = ""
[2013-08-26 09:17:22.879] SETDATA devices.3.instances.0.commandClasses.49.data.56 = Empty
[2013-08-26 09:17:22.879] SETDATA devices.3.instances.0.commandClasses.49.data.56.sensorTypeString = Empty
[2013-08-26 09:17:22.879] SETDATA devices.3.instances.0.commandClasses.49.data.56.sensorTypeString = ""
[2013-08-26 09:17:22.880] SETDATA devices.3.instances.0.commandClasses.49.data.56.val = Empty
[2013-08-26 09:17:22.893] SETDATA devices.3.instances.0.commandClasses.49.data.56.val = 13.900000
[2013-08-26 09:17:22.894] SETDATA devices.3.instances.0.commandClasses.49.data.56.deviceScale = Empty
[2013-08-26 09:17:22.894] SETDATA devices.3.instances.0.commandClasses.49.data.56.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.894] SETDATA devices.3.instances.0.commandClasses.49.data.56.scale = Empty
[2013-08-26 09:17:22.894] SETDATA devices.3.instances.0.commandClasses.49.data.56.scale = 0 (0x00000000)
[2013-08-26 09:17:22.895] SETDATA devices.3.instances.0.commandClasses.49.data.56.scaleString = Empty
[2013-08-26 09:17:22.895] SETDATA devices.3.instances.0.commandClasses.49.data.56.scaleString = ""
[2013-08-26 09:17:22.895] SETDATA devices.3.instances.0.commandClasses.49.data.208 = Empty
[2013-08-26 09:17:22.895] SETDATA devices.3.instances.0.commandClasses.49.data.208.sensorTypeString = Empty
[2013-08-26 09:17:22.896] SETDATA devices.3.instances.0.commandClasses.49.data.208.sensorTypeString = ""
[2013-08-26 09:17:22.896] SETDATA devices.3.instances.0.commandClasses.49.data.208.val = Empty
[2013-08-26 09:17:22.896] SETDATA devices.3.instances.0.commandClasses.49.data.208.val = 75.000000
[2013-08-26 09:17:22.896] SETDATA devices.3.instances.0.commandClasses.49.data.208.deviceScale = Empty
[2013-08-26 09:17:22.896] SETDATA devices.3.instances.0.commandClasses.49.data.208.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.897] SETDATA devices.3.instances.0.commandClasses.49.data.208.scale = Empty
[2013-08-26 09:17:22.897] SETDATA devices.3.instances.0.commandClasses.49.data.208.scale = 0 (0x00000000)
[2013-08-26 09:17:22.897] SETDATA devices.3.instances.0.commandClasses.49.data.208.scaleString = Empty
[2013-08-26 09:17:22.897] SETDATA devices.3.instances.0.commandClasses.49.data.208.scaleString = ""
[2013-08-26 09:17:22.897] SETDATA devices.3.instances.0.commandClasses.49.data.62 = Empty
[2013-08-26 09:17:22.898] SETDATA devices.3.instances.0.commandClasses.49.data.62.sensorTypeString = Empty
[2013-08-26 09:17:22.898] SETDATA devices.3.instances.0.commandClasses.49.data.62.sensorTypeString = ""
[2013-08-26 09:17:22.898] SETDATA devices.3.instances.0.commandClasses.49.data.62.val = Empty
[2013-08-26 09:17:22.898] SETDATA devices.3.instances.0.commandClasses.49.data.62.val = 15.700000
[2013-08-26 09:17:22.899] SETDATA devices.3.instances.0.commandClasses.49.data.62.deviceScale = Empty
[2013-08-26 09:17:22.899] SETDATA devices.3.instances.0.commandClasses.49.data.62.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.899] SETDATA devices.3.instances.0.commandClasses.49.data.62.scale = Empty
[2013-08-26 09:17:22.899] SETDATA devices.3.instances.0.commandClasses.49.data.62.scale = 0 (0x00000000)
[2013-08-26 09:17:22.899] SETDATA devices.3.instances.0.commandClasses.49.data.62.scaleString = Empty
[2013-08-26 09:17:22.900] SETDATA devices.3.instances.0.commandClasses.49.data.62.scaleString = ""
[2013-08-26 09:17:22.900] SETDATA devices.3.instances.0.commandClasses.49.data.224 = Empty
[2013-08-26 09:17:22.911] SETDATA devices.3.instances.0.commandClasses.49.data.224.sensorTypeString = Empty
[2013-08-26 09:17:22.911] SETDATA devices.3.instances.0.commandClasses.49.data.224.sensorTypeString = ""
[2013-08-26 09:17:22.911] SETDATA devices.3.instances.0.commandClasses.49.data.224.val = Empty
[2013-08-26 09:17:22.911] SETDATA devices.3.instances.0.commandClasses.49.data.224.val = 17.799999
[2013-08-26 09:17:22.912] SETDATA devices.3.instances.0.commandClasses.49.data.224.deviceScale = Empty
[2013-08-26 09:17:22.912] SETDATA devices.3.instances.0.commandClasses.49.data.224.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.912] SETDATA devices.3.instances.0.commandClasses.49.data.224.scale = Empty
[2013-08-26 09:17:22.912] SETDATA devices.3.instances.0.commandClasses.49.data.224.scale = 0 (0x00000000)
[2013-08-26 09:17:22.912] SETDATA devices.3.instances.0.commandClasses.49.data.224.scaleString = Empty
[2013-08-26 09:17:22.913] SETDATA devices.3.instances.0.commandClasses.49.data.224.scaleString = ""
[2013-08-26 09:17:22.913] SETDATA devices.3.instances.0.commandClasses.49.data.220 = Empty
[2013-08-26 09:17:22.913] SETDATA devices.3.instances.0.commandClasses.49.data.220.sensorTypeString = Empty
[2013-08-26 09:17:22.913] SETDATA devices.3.instances.0.commandClasses.49.data.220.sensorTypeString = ""
[2013-08-26 09:17:22.914] SETDATA devices.3.instances.0.commandClasses.49.data.220.val = Empty
[2013-08-26 09:17:22.914] SETDATA devices.3.instances.0.commandClasses.49.data.220.val = 15.000000
[2013-08-26 09:17:22.914] SETDATA devices.3.instances.0.commandClasses.49.data.220.deviceScale = Empty
[2013-08-26 09:17:22.914] SETDATA devices.3.instances.0.commandClasses.49.data.220.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.914] SETDATA devices.3.instances.0.commandClasses.49.data.220.scale = Empty
[2013-08-26 09:17:22.915] SETDATA devices.3.instances.0.commandClasses.49.data.220.scale = 0 (0x00000000)
[2013-08-26 09:17:22.915] SETDATA devices.3.instances.0.commandClasses.49.data.220.scaleString = Empty
[2013-08-26 09:17:22.915] SETDATA devices.3.instances.0.commandClasses.49.data.220.scaleString = ""
[2013-08-26 09:17:22.915] SETDATA devices.3.instances.0.commandClasses.49.data.248 = Empty
[2013-08-26 09:17:22.916] SETDATA devices.3.instances.0.commandClasses.49.data.248.sensorTypeString = Empty
[2013-08-26 09:17:22.916] SETDATA devices.3.instances.0.commandClasses.49.data.248.sensorTypeString = ""
[2013-08-26 09:17:22.916] SETDATA devices.3.instances.0.commandClasses.49.data.248.val = Empty
[2013-08-26 09:17:22.916] SETDATA devices.3.instances.0.commandClasses.49.data.248.val = 3.000000
[2013-08-26 09:17:22.916] SETDATA devices.3.instances.0.commandClasses.49.data.248.deviceScale = Empty
[2013-08-26 09:17:22.917] SETDATA devices.3.instances.0.commandClasses.49.data.248.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.917] SETDATA devices.3.instances.0.commandClasses.49.data.248.scale = Empty
[2013-08-26 09:17:22.917] SETDATA devices.3.instances.0.commandClasses.49.data.248.scale = 1 (0x00000001)
[2013-08-26 09:17:22.917] SETDATA devices.3.instances.0.commandClasses.49.data.248.scaleString = Empty
[2013-08-26 09:17:22.917] SETDATA devices.3.instances.0.commandClasses.49.data.248.scaleString = ""
[2013-08-26 09:17:22.918] SETDATA devices.3.instances.0.commandClasses.49.data.114 = Empty
[2013-08-26 09:17:22.918] SETDATA devices.3.instances.0.commandClasses.49.data.114.sensorTypeString = Empty
[2013-08-26 09:17:22.918] SETDATA devices.3.instances.0.commandClasses.49.data.114.sensorTypeString = ""
[2013-08-26 09:17:22.918] SETDATA devices.3.instances.0.commandClasses.49.data.114.val = Empty
[2013-08-26 09:17:22.918] SETDATA devices.3.instances.0.commandClasses.49.data.114.val = 55.000000
[2013-08-26 09:17:22.919] SETDATA devices.3.instances.0.commandClasses.49.data.114.deviceScale = Empty
[2013-08-26 09:17:22.930] SETDATA devices.3.instances.0.commandClasses.49.data.114.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.930] SETDATA devices.3.instances.0.commandClasses.49.data.114.scale = Empty
[2013-08-26 09:17:22.931] SETDATA devices.3.instances.0.commandClasses.49.data.114.scale = 0 (0x00000000)
[2013-08-26 09:17:22.931] SETDATA devices.3.instances.0.commandClasses.49.data.114.scaleString = Empty
[2013-08-26 09:17:22.931] SETDATA devices.3.instances.0.commandClasses.49.data.114.scaleString = ""
[2013-08-26 09:17:22.931] SETDATA devices.3.instances.0.commandClasses.49.data.116 = Empty
[2013-08-26 09:17:22.931] SETDATA devices.3.instances.0.commandClasses.49.data.116.sensorTypeString = Empty
[2013-08-26 09:17:22.932] SETDATA devices.3.instances.0.commandClasses.49.data.116.sensorTypeString = ""
[2013-08-26 09:17:22.932] SETDATA devices.3.instances.0.commandClasses.49.data.116.val = Empty
[2013-08-26 09:17:22.932] SETDATA devices.3.instances.0.commandClasses.49.data.116.val = 58.000000
[2013-08-26 09:17:22.932] SETDATA devices.3.instances.0.commandClasses.49.data.116.deviceScale = Empty
[2013-08-26 09:17:22.933] SETDATA devices.3.instances.0.commandClasses.49.data.116.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.933] SETDATA devices.3.instances.0.commandClasses.49.data.116.scale = Empty
[2013-08-26 09:17:22.933] SETDATA devices.3.instances.0.commandClasses.49.data.116.scale = 0 (0x00000000)
[2013-08-26 09:17:22.933] SETDATA devices.3.instances.0.commandClasses.49.data.116.scaleString = Empty
[2013-08-26 09:17:22.934] SETDATA devices.3.instances.0.commandClasses.49.data.116.scaleString = ""
[2013-08-26 09:17:22.934] SETDATA devices.3.instances.0.commandClasses.49.data.186 = Empty
[2013-08-26 09:17:22.934] SETDATA devices.3.instances.0.commandClasses.49.data.186.sensorTypeString = Empty
[2013-08-26 09:17:22.934] SETDATA devices.3.instances.0.commandClasses.49.data.186.sensorTypeString = ""
[2013-08-26 09:17:22.935] SETDATA devices.3.instances.0.commandClasses.49.data.186.val = Empty
[2013-08-26 09:17:22.935] SETDATA devices.3.instances.0.commandClasses.49.data.186.val = 0.000000
[2013-08-26 09:17:22.935] SETDATA devices.3.instances.0.commandClasses.49.data.186.deviceScale = Empty
[2013-08-26 09:17:22.935] SETDATA devices.3.instances.0.commandClasses.49.data.186.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.936] SETDATA devices.3.instances.0.commandClasses.49.data.186.scale = Empty
[2013-08-26 09:17:22.936] SETDATA devices.3.instances.0.commandClasses.49.data.186.scale = 1 (0x00000001)
[2013-08-26 09:17:22.936] SETDATA devices.3.instances.0.commandClasses.49.data.186.scaleString = Empty
[2013-08-26 09:17:22.936] SETDATA devices.3.instances.0.commandClasses.49.data.186.scaleString = ""
[2013-08-26 09:17:22.936] SETDATA devices.3.instances.0.commandClasses.49.data.188 = Empty
[2013-08-26 09:17:22.937] SETDATA devices.3.instances.0.commandClasses.49.data.188.sensorTypeString = Empty
[2013-08-26 09:17:22.937] SETDATA devices.3.instances.0.commandClasses.49.data.188.sensorTypeString = ""
[2013-08-26 09:17:22.937] SETDATA devices.3.instances.0.commandClasses.49.data.188.val = Empty
[2013-08-26 09:17:22.937] SETDATA devices.3.instances.0.commandClasses.49.data.188.val = 23.700001
[2013-08-26 09:17:22.938] SETDATA devices.3.instances.0.commandClasses.49.data.188.deviceScale = Empty
[2013-08-26 09:17:22.938] SETDATA devices.3.instances.0.commandClasses.49.data.188.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.938] SETDATA devices.3.instances.0.commandClasses.49.data.188.scale = Empty
[2013-08-26 09:17:22.938] SETDATA devices.3.instances.0.commandClasses.49.data.188.scale = 0 (0x00000000)
[2013-08-26 09:17:22.938] SETDATA devices.3.instances.0.commandClasses.49.data.188.scaleString = Empty
[2013-08-26 09:17:22.939] SETDATA devices.3.instances.0.commandClasses.49.data.188.scaleString = ""
[2013-08-26 09:17:22.939] SETDATA devices.3.instances.0.commandClasses.49.data.36 = Empty
[2013-08-26 09:17:22.939] SETDATA devices.3.instances.0.commandClasses.49.data.36.sensorTypeString = Empty
[2013-08-26 09:17:22.939] SETDATA devices.3.instances.0.commandClasses.49.data.36.sensorTypeString = ""
[2013-08-26 09:17:22.939] SETDATA devices.3.instances.0.commandClasses.49.data.36.val = Empty
[2013-08-26 09:17:22.940] SETDATA devices.3.instances.0.commandClasses.49.data.36.val = 531.000000
[2013-08-26 09:17:22.949] SETDATA devices.3.instances.0.commandClasses.49.data.36.deviceScale = Empty
[2013-08-26 09:17:22.949] SETDATA devices.3.instances.0.commandClasses.49.data.36.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.950] SETDATA devices.3.instances.0.commandClasses.49.data.36.scale = Empty
[2013-08-26 09:17:22.950] SETDATA devices.3.instances.0.commandClasses.49.data.36.scale = 1 (0x00000001)
[2013-08-26 09:17:22.950] SETDATA devices.3.instances.0.commandClasses.49.data.36.scaleString = Empty
[2013-08-26 09:17:22.951] SETDATA devices.3.instances.0.commandClasses.49.data.36.scaleString = ""
[2013-08-26 09:17:22.951] SETDATA devices.3.instances.0.commandClasses.49.data.234 = Empty
[2013-08-26 09:17:22.951] SETDATA devices.3.instances.0.commandClasses.49.data.234.sensorTypeString = Empty
[2013-08-26 09:17:22.951] SETDATA devices.3.instances.0.commandClasses.49.data.234.sensorTypeString = ""
[2013-08-26 09:17:22.951] SETDATA devices.3.instances.0.commandClasses.49.data.234.val = Empty
[2013-08-26 09:17:22.952] SETDATA devices.3.instances.0.commandClasses.49.data.234.val = 13.600000
[2013-08-26 09:17:22.952] SETDATA devices.3.instances.0.commandClasses.49.data.234.deviceScale = Empty
[2013-08-26 09:17:22.952] SETDATA devices.3.instances.0.commandClasses.49.data.234.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.952] SETDATA devices.3.instances.0.commandClasses.49.data.234.scale = Empty
[2013-08-26 09:17:22.953] SETDATA devices.3.instances.0.commandClasses.49.data.234.scale = 0 (0x00000000)
[2013-08-26 09:17:22.953] SETDATA devices.3.instances.0.commandClasses.49.data.234.scaleString = Empty
[2013-08-26 09:17:22.953] SETDATA devices.3.instances.0.commandClasses.49.data.234.scaleString = ""
[2013-08-26 09:17:22.953] SETDATA devices.3.instances.0.commandClasses.49.data.230 = Empty
[2013-08-26 09:17:22.954] SETDATA devices.3.instances.0.commandClasses.49.data.230.sensorTypeString = Empty
[2013-08-26 09:17:22.954] SETDATA devices.3.instances.0.commandClasses.49.data.230.sensorTypeString = ""
[2013-08-26 09:17:22.954] SETDATA devices.3.instances.0.commandClasses.49.data.230.val = Empty
[2013-08-26 09:17:22.954] SETDATA devices.3.instances.0.commandClasses.49.data.230.val = 22.200001
[2013-08-26 09:17:22.954] SETDATA devices.3.instances.0.commandClasses.49.data.230.deviceScale = Empty
[2013-08-26 09:17:22.959] SETDATA devices.3.instances.0.commandClasses.49.data.230.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.960] SETDATA devices.3.instances.0.commandClasses.49.data.230.scale = Empty
[2013-08-26 09:17:22.960] SETDATA devices.3.instances.0.commandClasses.49.data.230.scale = 0 (0x00000000)
[2013-08-26 09:17:22.960] SETDATA devices.3.instances.0.commandClasses.49.data.230.scaleString = Empty
[2013-08-26 09:17:22.960] SETDATA devices.3.instances.0.commandClasses.49.data.230.scaleString = ""
[2013-08-26 09:17:22.961] SETDATA devices.3.instances.0.commandClasses.49.data.106 = Empty
[2013-08-26 09:17:22.961] SETDATA devices.3.instances.0.commandClasses.49.data.106.sensorTypeString = Empty
[2013-08-26 09:17:22.961] SETDATA devices.3.instances.0.commandClasses.49.data.106.sensorTypeString = ""
[2013-08-26 09:17:22.961] SETDATA devices.3.instances.0.commandClasses.49.data.106.val = Empty
[2013-08-26 09:17:22.962] SETDATA devices.3.instances.0.commandClasses.49.data.106.val = 51.000000
[2013-08-26 09:17:22.962] SETDATA devices.3.instances.0.commandClasses.49.data.106.deviceScale = Empty
[2013-08-26 09:17:22.962] SETDATA devices.3.instances.0.commandClasses.49.data.106.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.962] SETDATA devices.3.instances.0.commandClasses.49.data.106.scale = Empty
[2013-08-26 09:17:22.962] SETDATA devices.3.instances.0.commandClasses.49.data.106.scale = 0 (0x00000000)
[2013-08-26 09:17:22.963] SETDATA devices.3.instances.0.commandClasses.49.data.106.scaleString = Empty
[2013-08-26 09:17:22.963] SETDATA devices.3.instances.0.commandClasses.49.data.106.scaleString = ""
[2013-08-26 09:17:22.963] SETDATA devices.3.instances.0.commandClasses.49.data.214 = Empty
[2013-08-26 09:17:22.963] SETDATA devices.3.instances.0.commandClasses.49.data.214.sensorTypeString = Empty
[2013-08-26 09:17:22.963] SETDATA devices.3.instances.0.commandClasses.49.data.214.sensorTypeString = ""
[2013-08-26 09:17:22.964] SETDATA devices.3.instances.0.commandClasses.49.data.214.val = Empty
[2013-08-26 09:17:22.964] SETDATA devices.3.instances.0.commandClasses.49.data.214.val = 673.000000
[2013-08-26 09:17:22.964] SETDATA devices.3.instances.0.commandClasses.49.data.214.deviceScale = Empty
[2013-08-26 09:17:22.964] SETDATA devices.3.instances.0.commandClasses.49.data.214.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:22.965] SETDATA devices.3.instances.0.commandClasses.49.data.214.scale = Empty
[2013-08-26 09:17:22.965] SETDATA devices.3.instances.0.commandClasses.49.data.214.scale = 1 (0x00000001)
[2013-08-26 09:17:22.965] SETDATA devices.3.instances.0.commandClasses.49.data.214.scaleString = Empty
[2013-08-26 09:17:22.965] SETDATA devices.3.instances.0.commandClasses.49.data.214.scaleString = ""
[2013-08-26 09:17:22.965] SETDATA devices.3.instances.0.commandClasses.49.data.242 = Empty
[2013-08-26 09:17:22.966] SETDATA devices.3.instances.0.commandClasses.49.data.242.sensorTypeString = Empty
[2013-08-26 09:17:22.966] SETDATA devices.3.instances.0.commandClasses.49.data.242.sensorTypeString = ""
[2013-08-26 09:17:22.966] SETDATA devices.3.instances.0.commandClasses.49.data.242.val = Empty
[2013-08-26 09:17:22.966] SETDATA devices.3.instances.0.commandClasses.49.data.242.val = 69.000000
[2013-08-26 09:17:22.967] SETDATA devices.3.instances.0.commandClasses.49.data.242.deviceScale = Empty
[2013-08-26 09:17:22.967] SETDATA devices.3.instances.0.commandClasses.49.data.242.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.967] SETDATA devices.3.instances.0.commandClasses.49.data.242.scale = Empty
[2013-08-26 09:17:22.967] SETDATA devices.3.instances.0.commandClasses.49.data.242.scale = 0 (0x00000000)
[2013-08-26 09:17:22.967] SETDATA devices.3.instances.0.commandClasses.49.data.242.scaleString = Empty
[2013-08-26 09:17:22.968] SETDATA devices.3.instances.0.commandClasses.49.data.242.scaleString = ""
[2013-08-26 09:17:22.968] SETDATA devices.3.instances.0.commandClasses.49.data.132 = Empty
[2013-08-26 09:17:22.968] SETDATA devices.3.instances.0.commandClasses.49.data.132.sensorTypeString = Empty
[2013-08-26 09:17:22.968] SETDATA devices.3.instances.0.commandClasses.49.data.132.sensorTypeString = ""
[2013-08-26 09:17:22.968] SETDATA devices.3.instances.0.commandClasses.49.data.132.val = Empty
[2013-08-26 09:17:22.969] SETDATA devices.3.instances.0.commandClasses.49.data.132.val = 17.500000
[2013-08-26 09:17:22.969] SETDATA devices.3.instances.0.commandClasses.49.data.132.deviceScale = Empty
[2013-08-26 09:17:22.969] SETDATA devices.3.instances.0.commandClasses.49.data.132.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.980] SETDATA devices.3.instances.0.commandClasses.49.data.132.scale = Empty
[2013-08-26 09:17:22.981] SETDATA devices.3.instances.0.commandClasses.49.data.132.scale = 0 (0x00000000)
[2013-08-26 09:17:22.981] SETDATA devices.3.instances.0.commandClasses.49.data.132.scaleString = Empty
[2013-08-26 09:17:22.981] SETDATA devices.3.instances.0.commandClasses.49.data.132.scaleString = ""
[2013-08-26 09:17:22.981] SETDATA devices.3.instances.0.commandClasses.49.data.30 = Empty
[2013-08-26 09:17:22.982] SETDATA devices.3.instances.0.commandClasses.49.data.30.sensorTypeString = Empty
[2013-08-26 09:17:22.982] SETDATA devices.3.instances.0.commandClasses.49.data.30.sensorTypeString = ""
[2013-08-26 09:17:22.982] SETDATA devices.3.instances.0.commandClasses.49.data.30.val = Empty
[2013-08-26 09:17:22.982] SETDATA devices.3.instances.0.commandClasses.49.data.30.val = 23.000000
[2013-08-26 09:17:22.982] SETDATA devices.3.instances.0.commandClasses.49.data.30.deviceScale = Empty
[2013-08-26 09:17:22.983] SETDATA devices.3.instances.0.commandClasses.49.data.30.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.983] SETDATA devices.3.instances.0.commandClasses.49.data.30.scale = Empty
[2013-08-26 09:17:22.983] SETDATA devices.3.instances.0.commandClasses.49.data.30.scale = 0 (0x00000000)
[2013-08-26 09:17:22.983] SETDATA devices.3.instances.0.commandClasses.49.data.30.scaleString = Empty
[2013-08-26 09:17:22.983] SETDATA devices.3.instances.0.commandClasses.49.data.30.scaleString = ""
[2013-08-26 09:17:22.984] SETDATA devices.3.instances.0.commandClasses.49.data.232 = Empty
[2013-08-26 09:17:22.984] SETDATA devices.3.instances.0.commandClasses.49.data.232.sensorTypeString = Empty
[2013-08-26 09:17:22.984] SETDATA devices.3.instances.0.commandClasses.49.data.232.sensorTypeString = ""
[2013-08-26 09:17:22.984] SETDATA devices.3.instances.0.commandClasses.49.data.232.val = Empty
[2013-08-26 09:17:22.985] SETDATA devices.3.instances.0.commandClasses.49.data.232.val = 78.000000
[2013-08-26 09:17:22.985] SETDATA devices.3.instances.0.commandClasses.49.data.232.deviceScale = Empty
[2013-08-26 09:17:22.985] SETDATA devices.3.instances.0.commandClasses.49.data.232.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.985] SETDATA devices.3.instances.0.commandClasses.49.data.232.scale = Empty
[2013-08-26 09:17:22.985] SETDATA devices.3.instances.0.commandClasses.49.data.232.scale = 0 (0x00000000)
[2013-08-26 09:17:22.986] SETDATA devices.3.instances.0.commandClasses.49.data.232.scaleString = Empty
[2013-08-26 09:17:22.986] SETDATA devices.3.instances.0.commandClasses.49.data.232.scaleString = ""
[2013-08-26 09:17:22.986] SETDATA devices.3.instances.0.commandClasses.49.data.228 = Empty
[2013-08-26 09:17:22.986] SETDATA devices.3.instances.0.commandClasses.49.data.228.sensorTypeString = Empty
[2013-08-26 09:17:22.987] SETDATA devices.3.instances.0.commandClasses.49.data.228.sensorTypeString = ""
[2013-08-26 09:17:22.987] SETDATA devices.3.instances.0.commandClasses.49.data.228.val = Empty
[2013-08-26 09:17:22.987] SETDATA devices.3.instances.0.commandClasses.49.data.228.val = 78.000000
[2013-08-26 09:17:22.987] SETDATA devices.3.instances.0.commandClasses.49.data.228.deviceScale = Empty
[2013-08-26 09:17:22.987] SETDATA devices.3.instances.0.commandClasses.49.data.228.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:22.988] SETDATA devices.3.instances.0.commandClasses.49.data.228.scale = Empty
[2013-08-26 09:17:22.988] SETDATA devices.3.instances.0.commandClasses.49.data.228.scale = 0 (0x00000000)
[2013-08-26 09:17:22.988] SETDATA devices.3.instances.0.commandClasses.49.data.228.scaleString = Empty
[2013-08-26 09:17:22.988] SETDATA devices.3.instances.0.commandClasses.49.data.228.scaleString = ""
[2013-08-26 09:17:22.989] SETDATA devices.3.instances.0.commandClasses.49.data.68 = Empty
[2013-08-26 09:17:22.989] SETDATA devices.3.instances.0.commandClasses.49.data.68.sensorTypeString = Empty
[2013-08-26 09:17:22.989] SETDATA devices.3.instances.0.commandClasses.49.data.68.sensorTypeString = ""
[2013-08-26 09:17:22.989] SETDATA devices.3.instances.0.commandClasses.49.data.68.val = Empty
[2013-08-26 09:17:22.989] SETDATA devices.3.instances.0.commandClasses.49.data.68.val = 80.000000
[2013-08-26 09:17:22.990] SETDATA devices.3.instances.0.commandClasses.49.data.68.deviceScale = Empty
[2013-08-26 09:17:22.990] SETDATA devices.3.instances.0.commandClasses.49.data.68.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.000] SETDATA devices.3.instances.0.commandClasses.49.data.68.scale = Empty
[2013-08-26 09:17:23.001] SETDATA devices.3.instances.0.commandClasses.49.data.68.scale = 0 (0x00000000)
[2013-08-26 09:17:23.001] SETDATA devices.3.instances.0.commandClasses.49.data.68.scaleString = Empty
[2013-08-26 09:17:23.001] SETDATA devices.3.instances.0.commandClasses.49.data.68.scaleString = ""
[2013-08-26 09:17:23.001] SETDATA devices.3.instances.0.commandClasses.49.data.80 = Empty
[2013-08-26 09:17:23.002] SETDATA devices.3.instances.0.commandClasses.49.data.80.sensorTypeString = Empty
[2013-08-26 09:17:23.002] SETDATA devices.3.instances.0.commandClasses.49.data.80.sensorTypeString = ""
[2013-08-26 09:17:23.002] SETDATA devices.3.instances.0.commandClasses.49.data.80.val = Empty
[2013-08-26 09:17:23.002] SETDATA devices.3.instances.0.commandClasses.49.data.80.val = 178.000000
[2013-08-26 09:17:23.002] SETDATA devices.3.instances.0.commandClasses.49.data.80.deviceScale = Empty
[2013-08-26 09:17:23.003] SETDATA devices.3.instances.0.commandClasses.49.data.80.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:23.003] SETDATA devices.3.instances.0.commandClasses.49.data.80.scale = Empty
[2013-08-26 09:17:23.003] SETDATA devices.3.instances.0.commandClasses.49.data.80.scale = 1 (0x00000001)
[2013-08-26 09:17:23.003] SETDATA devices.3.instances.0.commandClasses.49.data.80.scaleString = Empty
[2013-08-26 09:17:23.003] SETDATA devices.3.instances.0.commandClasses.49.data.80.scaleString = ""
[2013-08-26 09:17:23.004] SETDATA devices.3.instances.0.commandClasses.49.data.226 = Empty
[2013-08-26 09:17:23.004] SETDATA devices.3.instances.0.commandClasses.49.data.226.sensorTypeString = Empty
[2013-08-26 09:17:23.004] SETDATA devices.3.instances.0.commandClasses.49.data.226.sensorTypeString = ""
[2013-08-26 09:17:23.004] SETDATA devices.3.instances.0.commandClasses.49.data.226.val = Empty
[2013-08-26 09:17:23.005] SETDATA devices.3.instances.0.commandClasses.49.data.226.val = 53.000000
[2013-08-26 09:17:23.005] SETDATA devices.3.instances.0.commandClasses.49.data.226.deviceScale = Empty
[2013-08-26 09:17:23.005] SETDATA devices.3.instances.0.commandClasses.49.data.226.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.005] SETDATA devices.3.instances.0.commandClasses.49.data.226.scale = Empty
[2013-08-26 09:17:23.006] SETDATA devices.3.instances.0.commandClasses.49.data.226.scale = 0 (0x00000000)
[2013-08-26 09:17:23.006] SETDATA devices.3.instances.0.commandClasses.49.data.226.scaleString = Empty
[2013-08-26 09:17:23.006] SETDATA devices.3.instances.0.commandClasses.49.data.226.scaleString = ""
[2013-08-26 09:17:23.006] SETDATA devices.3.instances.0.commandClasses.49.data.166 = Empty
[2013-08-26 09:17:23.007] SETDATA devices.3.instances.0.commandClasses.49.data.166.sensorTypeString = Empty
[2013-08-26 09:17:23.007] SETDATA devices.3.instances.0.commandClasses.49.data.166.sensorTypeString = ""
[2013-08-26 09:17:23.007] SETDATA devices.3.instances.0.commandClasses.49.data.166.val = Empty
[2013-08-26 09:17:23.007] SETDATA devices.3.instances.0.commandClasses.49.data.166.val = 67.000000
[2013-08-26 09:17:23.007] SETDATA devices.3.instances.0.commandClasses.49.data.166.deviceScale = Empty
[2013-08-26 09:17:23.008] SETDATA devices.3.instances.0.commandClasses.49.data.166.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.008] SETDATA devices.3.instances.0.commandClasses.49.data.166.scale = Empty
[2013-08-26 09:17:23.008] SETDATA devices.3.instances.0.commandClasses.49.data.166.scale = 0 (0x00000000)
[2013-08-26 09:17:23.008] SETDATA devices.3.instances.0.commandClasses.49.data.166.scaleString = Empty
[2013-08-26 09:17:23.008] SETDATA devices.3.instances.0.commandClasses.49.data.166.scaleString = ""
[2013-08-26 09:17:23.009] SETDATA devices.3.instances.0.commandClasses.49.data.174 = Empty
[2013-08-26 09:17:23.009] SETDATA devices.3.instances.0.commandClasses.49.data.174.sensorTypeString = Empty
[2013-08-26 09:17:23.009] SETDATA devices.3.instances.0.commandClasses.49.data.174.sensorTypeString = ""
[2013-08-26 09:17:23.009] SETDATA devices.3.instances.0.commandClasses.49.data.174.val = Empty
[2013-08-26 09:17:23.010] SETDATA devices.3.instances.0.commandClasses.49.data.174.val = 10.700000
[2013-08-26 09:17:23.010] SETDATA devices.3.instances.0.commandClasses.49.data.174.deviceScale = Empty
[2013-08-26 09:17:23.020] SETDATA devices.3.instances.0.commandClasses.49.data.174.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.021] SETDATA devices.3.instances.0.commandClasses.49.data.174.scale = Empty
[2013-08-26 09:17:23.021] SETDATA devices.3.instances.0.commandClasses.49.data.174.scale = 0 (0x00000000)
[2013-08-26 09:17:23.021] SETDATA devices.3.instances.0.commandClasses.49.data.174.scaleString = Empty
[2013-08-26 09:17:23.021] SETDATA devices.3.instances.0.commandClasses.49.data.174.scaleString = ""
[2013-08-26 09:17:23.022] SETDATA devices.3.instances.0.commandClasses.49.data.144 = Empty
[2013-08-26 09:17:23.022] SETDATA devices.3.instances.0.commandClasses.49.data.144.sensorTypeString = Empty
[2013-08-26 09:17:23.022] SETDATA devices.3.instances.0.commandClasses.49.data.144.sensorTypeString = ""
[2013-08-26 09:17:23.022] SETDATA devices.3.instances.0.commandClasses.49.data.144.val = Empty
[2013-08-26 09:17:23.022] SETDATA devices.3.instances.0.commandClasses.49.data.144.val = 10.200000
[2013-08-26 09:17:23.023] SETDATA devices.3.instances.0.commandClasses.49.data.144.deviceScale = Empty
[2013-08-26 09:17:23.023] SETDATA devices.3.instances.0.commandClasses.49.data.144.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.023] SETDATA devices.3.instances.0.commandClasses.49.data.144.scale = Empty
[2013-08-26 09:17:23.023] SETDATA devices.3.instances.0.commandClasses.49.data.144.scale = 0 (0x00000000)
[2013-08-26 09:17:23.024] SETDATA devices.3.instances.0.commandClasses.49.data.144.scaleString = Empty
[2013-08-26 09:17:23.024] SETDATA devices.3.instances.0.commandClasses.49.data.144.scaleString = ""
[2013-08-26 09:17:23.024] SETDATA devices.3.instances.0.commandClasses.49.data.154 = Empty
[2013-08-26 09:17:23.024] SETDATA devices.3.instances.0.commandClasses.49.data.154.sensorTypeString = Empty
[2013-08-26 09:17:23.024] SETDATA devices.3.instances.0.commandClasses.49.data.154.sensorTypeString = ""
[2013-08-26 09:17:23.025] SETDATA devices.3.instances.0.commandClasses.49.data.154.val = Empty
[2013-08-26 09:17:23.025] SETDATA devices.3.instances.0.commandClasses.49.data.154.val = 1000.000000
[2013-08-26 09:17:23.025] SETDATA devices.3.instances.0.commandClasses.49.data.154.deviceScale = Empty
[2013-08-26 09:17:23.025] SETDATA devices.3.instances.0.commandClasses.49.data.154.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:23.026] SETDATA devices.3.instances.0.commandClasses.49.data.154.scale = Empty
[2013-08-26 09:17:23.026] SETDATA devices.3.instances.0.commandClasses.49.data.154.scale = 1 (0x00000001)
[2013-08-26 09:17:23.026] SETDATA devices.3.instances.0.commandClasses.49.data.154.scaleString = Empty
[2013-08-26 09:17:23.026] SETDATA devices.3.instances.0.commandClasses.49.data.154.scaleString = ""
[2013-08-26 09:17:23.026] SETDATA devices.3.instances.0.commandClasses.49.data.158 = Empty
[2013-08-26 09:17:23.027] SETDATA devices.3.instances.0.commandClasses.49.data.158.sensorTypeString = Empty
[2013-08-26 09:17:23.027] SETDATA devices.3.instances.0.commandClasses.49.data.158.sensorTypeString = ""
[2013-08-26 09:17:23.027] SETDATA devices.3.instances.0.commandClasses.49.data.158.val = Empty
[2013-08-26 09:17:23.027] SETDATA devices.3.instances.0.commandClasses.49.data.158.val = 15.400000
[2013-08-26 09:17:23.028] SETDATA devices.3.instances.0.commandClasses.49.data.158.deviceScale = Empty
[2013-08-26 09:17:23.028] SETDATA devices.3.instances.0.commandClasses.49.data.158.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.028] SETDATA devices.3.instances.0.commandClasses.49.data.158.scale = Empty
[2013-08-26 09:17:23.028] SETDATA devices.3.instances.0.commandClasses.49.data.158.scale = 0 (0x00000000)
[2013-08-26 09:17:23.028] SETDATA devices.3.instances.0.commandClasses.49.data.158.scaleString = Empty
[2013-08-26 09:17:23.029] SETDATA devices.3.instances.0.commandClasses.49.data.158.scaleString = ""
[2013-08-26 09:17:23.029] SETDATA devices.3.instances.0.commandClasses.49.data.72 = Empty
[2013-08-26 09:17:23.029] SETDATA devices.3.instances.0.commandClasses.49.data.72.sensorTypeString = Empty
[2013-08-26 09:17:23.029] SETDATA devices.3.instances.0.commandClasses.49.data.72.sensorTypeString = ""
[2013-08-26 09:17:23.029] SETDATA devices.3.instances.0.commandClasses.49.data.72.val = Empty
[2013-08-26 09:17:23.030] SETDATA devices.3.instances.0.commandClasses.49.data.72.val = 81.000000
[2013-08-26 09:17:23.040] SETDATA devices.3.instances.0.commandClasses.49.data.72.deviceScale = Empty
[2013-08-26 09:17:23.041] SETDATA devices.3.instances.0.commandClasses.49.data.72.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.041] SETDATA devices.3.instances.0.commandClasses.49.data.72.scale = Empty
[2013-08-26 09:17:23.041] SETDATA devices.3.instances.0.commandClasses.49.data.72.scale = 0 (0x00000000)
[2013-08-26 09:17:23.041] SETDATA devices.3.instances.0.commandClasses.49.data.72.scaleString = Empty
[2013-08-26 09:17:23.041] SETDATA devices.3.instances.0.commandClasses.49.data.72.scaleString = ""
[2013-08-26 09:17:23.042] SETDATA devices.3.instances.0.commandClasses.49.data.74 = Empty
[2013-08-26 09:17:23.042] SETDATA devices.3.instances.0.commandClasses.49.data.74.sensorTypeString = Empty
[2013-08-26 09:17:23.042] SETDATA devices.3.instances.0.commandClasses.49.data.74.sensorTypeString = ""
[2013-08-26 09:17:23.042] SETDATA devices.3.instances.0.commandClasses.49.data.74.val = Empty
[2013-08-26 09:17:23.042] SETDATA devices.3.instances.0.commandClasses.49.data.74.val = 50.000000
[2013-08-26 09:17:23.043] SETDATA devices.3.instances.0.commandClasses.49.data.74.deviceScale = Empty
[2013-08-26 09:17:23.043] SETDATA devices.3.instances.0.commandClasses.49.data.74.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.043] SETDATA devices.3.instances.0.commandClasses.49.data.74.scale = Empty
[2013-08-26 09:17:23.043] SETDATA devices.3.instances.0.commandClasses.49.data.74.scale = 0 (0x00000000)
[2013-08-26 09:17:23.044] SETDATA devices.3.instances.0.commandClasses.49.data.74.scaleString = Empty
[2013-08-26 09:17:23.044] SETDATA devices.3.instances.0.commandClasses.49.data.74.scaleString = ""
[2013-08-26 09:17:23.044] SETDATA devices.3.instances.0.commandClasses.49.data.58 = Empty
[2013-08-26 09:17:23.044] SETDATA devices.3.instances.0.commandClasses.49.data.58.sensorTypeString = Empty
[2013-08-26 09:17:23.045] SETDATA devices.3.instances.0.commandClasses.49.data.58.sensorTypeString = ""
[2013-08-26 09:17:23.045] SETDATA devices.3.instances.0.commandClasses.49.data.58.val = Empty
[2013-08-26 09:17:23.045] SETDATA devices.3.instances.0.commandClasses.49.data.58.val = 20.799999
[2013-08-26 09:17:23.045] SETDATA devices.3.instances.0.commandClasses.49.data.58.deviceScale = Empty
[2013-08-26 09:17:23.045] SETDATA devices.3.instances.0.commandClasses.49.data.58.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.046] SETDATA devices.3.instances.0.commandClasses.49.data.58.scale = Empty
[2013-08-26 09:17:23.046] SETDATA devices.3.instances.0.commandClasses.49.data.58.scale = 0 (0x00000000)
[2013-08-26 09:17:23.046] SETDATA devices.3.instances.0.commandClasses.49.data.58.scaleString = Empty
[2013-08-26 09:17:23.046] SETDATA devices.3.instances.0.commandClasses.49.data.58.scaleString = ""
[2013-08-26 09:17:23.047] SETDATA devices.3.instances.0.commandClasses.49.data.110 = Empty
[2013-08-26 09:17:23.047] SETDATA devices.3.instances.0.commandClasses.49.data.110.sensorTypeString = Empty
[2013-08-26 09:17:23.047] SETDATA devices.3.instances.0.commandClasses.49.data.110.sensorTypeString = ""
[2013-08-26 09:17:23.047] SETDATA devices.3.instances.0.commandClasses.49.data.110.val = Empty
[2013-08-26 09:17:23.047] SETDATA devices.3.instances.0.commandClasses.49.data.110.val = 23.200001
[2013-08-26 09:17:23.048] SETDATA devices.3.instances.0.commandClasses.49.data.110.deviceScale = Empty
[2013-08-26 09:17:23.048] SETDATA devices.3.instances.0.commandClasses.49.data.110.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.048] SETDATA devices.3.instances.0.commandClasses.49.data.110.scale = Empty
[2013-08-26 09:17:23.048] SETDATA devices.3.instances.0.commandClasses.49.data.110.scale = 0 (0x00000000)
[2013-08-26 09:17:23.048] SETDATA devices.3.instances.0.commandClasses.49.data.110.scaleString = Empty
[2013-08-26 09:17:23.049] SETDATA devices.3.instances.0.commandClasses.49.data.110.scaleString = ""
[2013-08-26 09:17:23.049] SETDATA devices.3.instances.0.commandClasses.49.data.86 = Empty
[2013-08-26 09:17:23.049] SETDATA devices.3.instances.0.commandClasses.49.data.86.sensorTypeString = Empty
[2013-08-26 09:17:23.049] SETDATA devices.3.instances.0.commandClasses.49.data.86.sensorTypeString = ""
[2013-08-26 09:17:23.050] SETDATA devices.3.instances.0.commandClasses.49.data.86.val = Empty
[2013-08-26 09:17:23.050] SETDATA devices.3.instances.0.commandClasses.49.data.86.val = 13.500000
[2013-08-26 09:17:23.060] SETDATA devices.3.instances.0.commandClasses.49.data.86.deviceScale = Empty
[2013-08-26 09:17:23.061] SETDATA devices.3.instances.0.commandClasses.49.data.86.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.061] SETDATA devices.3.instances.0.commandClasses.49.data.86.scale = Empty
[2013-08-26 09:17:23.061] SETDATA devices.3.instances.0.commandClasses.49.data.86.scale = 0 (0x00000000)
[2013-08-26 09:17:23.061] SETDATA devices.3.instances.0.commandClasses.49.data.86.scaleString = Empty
[2013-08-26 09:17:23.061] SETDATA devices.3.instances.0.commandClasses.49.data.86.scaleString = ""
[2013-08-26 09:17:23.062] SETDATA devices.3.instances.0.commandClasses.49.data.42 = Empty
[2013-08-26 09:17:23.062] SETDATA devices.3.instances.0.commandClasses.49.data.42.sensorTypeString = Empty
[2013-08-26 09:17:23.062] SETDATA devices.3.instances.0.commandClasses.49.data.42.sensorTypeString = ""
[2013-08-26 09:17:23.062] SETDATA devices.3.instances.0.commandClasses.49.data.42.val = Empty
[2013-08-26 09:17:23.063] SETDATA devices.3.instances.0.commandClasses.49.data.42.val = 79.000000
[2013-08-26 09:17:23.063] SETDATA devices.3.instances.0.commandClasses.49.data.42.deviceScale = Empty
[2013-08-26 09:17:23.063] SETDATA devices.3.instances.0.commandClasses.49.data.42.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.063] SETDATA devices.3.instances.0.commandClasses.49.data.42.scale = Empty
[2013-08-26 09:17:23.064] SETDATA devices.3.instances.0.commandClasses.49.data.42.scale = 0 (0x00000000)
[2013-08-26 09:17:23.064] SETDATA devices.3.instances.0.commandClasses.49.data.42.scaleString = Empty
[2013-08-26 09:17:23.064] SETDATA devices.3.instances.0.commandClasses.49.data.42.scaleString = ""
[2013-08-26 09:17:23.064] SETDATA devices.3.instances.0.commandClasses.49.data.8 = Empty
[2013-08-26 09:17:23.064] SETDATA devices.3.instances.0.commandClasses.49.data.8.sensorTypeString = Empty
[2013-08-26 09:17:23.065] SETDATA devices.3.instances.0.commandClasses.49.data.8.sensorTypeString = "Athmospheric Pressure"
[2013-08-26 09:17:23.065] SETDATA devices.3.instances.0.commandClasses.49.data.8.val = Empty
[2013-08-26 09:17:23.065] SETDATA devices.3.instances.0.commandClasses.49.data.8.val = 73.000000
[2013-08-26 09:17:23.065] SETDATA devices.3.instances.0.commandClasses.49.data.8.deviceScale = Empty
[2013-08-26 09:17:23.066] SETDATA devices.3.instances.0.commandClasses.49.data.8.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.066] SETDATA devices.3.instances.0.commandClasses.49.data.8.scale = Empty
[2013-08-26 09:17:23.066] SETDATA devices.3.instances.0.commandClasses.49.data.8.scale = 0 (0x00000000)
[2013-08-26 09:17:23.066] SETDATA devices.3.instances.0.commandClasses.49.data.8.scaleString = Empty
[2013-08-26 09:17:23.066] SETDATA devices.3.instances.0.commandClasses.49.data.8.scaleString = "kPa"
[2013-08-26 09:17:23.067] SETDATA devices.3.instances.0.commandClasses.49.data.66 = Empty
[2013-08-26 09:17:23.067] SETDATA devices.3.instances.0.commandClasses.49.data.66.sensorTypeString = Empty
[2013-08-26 09:17:23.067] SETDATA devices.3.instances.0.commandClasses.49.data.66.sensorTypeString = ""
[2013-08-26 09:17:23.067] SETDATA devices.3.instances.0.commandClasses.49.data.66.val = Empty
[2013-08-26 09:17:23.067] SETDATA devices.3.instances.0.commandClasses.49.data.66.val = 495.000000
[2013-08-26 09:17:23.068] SETDATA devices.3.instances.0.commandClasses.49.data.66.deviceScale = Empty
[2013-08-26 09:17:23.068] SETDATA devices.3.instances.0.commandClasses.49.data.66.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:23.068] SETDATA devices.3.instances.0.commandClasses.49.data.66.scale = Empty
[2013-08-26 09:17:23.068] SETDATA devices.3.instances.0.commandClasses.49.data.66.scale = 1 (0x00000001)
[2013-08-26 09:17:23.069] SETDATA devices.3.instances.0.commandClasses.49.data.66.scaleString = Empty
[2013-08-26 09:17:23.069] SETDATA devices.3.instances.0.commandClasses.49.data.66.scaleString = ""
[2013-08-26 09:17:23.069] SETDATA devices.3.instances.0.commandClasses.49.data.126 = Empty
[2013-08-26 09:17:23.069] SETDATA devices.3.instances.0.commandClasses.49.data.126.sensorTypeString = Empty
[2013-08-26 09:17:23.069] SETDATA devices.3.instances.0.commandClasses.49.data.126.sensorTypeString = ""
[2013-08-26 09:17:23.070] SETDATA devices.3.instances.0.commandClasses.49.data.126.val = Empty
[2013-08-26 09:17:23.070] SETDATA devices.3.instances.0.commandClasses.49.data.126.val = 93.000000
[2013-08-26 09:17:23.080] SETDATA devices.3.instances.0.commandClasses.49.data.126.deviceScale = Empty
[2013-08-26 09:17:23.081] SETDATA devices.3.instances.0.commandClasses.49.data.126.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:23.081] SETDATA devices.3.instances.0.commandClasses.49.data.126.scale = Empty
[2013-08-26 09:17:23.081] SETDATA devices.3.instances.0.commandClasses.49.data.126.scale = 1 (0x00000001)
[2013-08-26 09:17:23.081] SETDATA devices.3.instances.0.commandClasses.49.data.126.scaleString = Empty
[2013-08-26 09:17:23.081] SETDATA devices.3.instances.0.commandClasses.49.data.126.scaleString = ""
[2013-08-26 09:17:23.082] SETDATA devices.3.instances.0.commandClasses.49.data.150 = Empty
[2013-08-26 09:17:23.082] SETDATA devices.3.instances.0.commandClasses.49.data.150.sensorTypeString = Empty
[2013-08-26 09:17:23.082] SETDATA devices.3.instances.0.commandClasses.49.data.150.sensorTypeString = ""
[2013-08-26 09:17:23.082] SETDATA devices.3.instances.0.commandClasses.49.data.150.val = Empty
[2013-08-26 09:17:23.083] SETDATA devices.3.instances.0.commandClasses.49.data.150.val = 77.000000
[2013-08-26 09:17:23.083] SETDATA devices.3.instances.0.commandClasses.49.data.150.deviceScale = Empty
[2013-08-26 09:17:23.083] SETDATA devices.3.instances.0.commandClasses.49.data.150.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.083] SETDATA devices.3.instances.0.commandClasses.49.data.150.scale = Empty
[2013-08-26 09:17:23.084] SETDATA devices.3.instances.0.commandClasses.49.data.150.scale = 0 (0x00000000)
[2013-08-26 09:17:23.084] SETDATA devices.3.instances.0.commandClasses.49.data.150.scaleString = Empty
[2013-08-26 09:17:23.084] SETDATA devices.3.instances.0.commandClasses.49.data.150.scaleString = ""
[2013-08-26 09:17:23.084] SETDATA devices.3.instances.0.commandClasses.49.data.212 = Empty
[2013-08-26 09:17:23.084] SETDATA devices.3.instances.0.commandClasses.49.data.212.sensorTypeString = Empty
[2013-08-26 09:17:23.085] SETDATA devices.3.instances.0.commandClasses.49.data.212.sensorTypeString = ""
[2013-08-26 09:17:23.085] SETDATA devices.3.instances.0.commandClasses.49.data.212.val = Empty
[2013-08-26 09:17:23.085] SETDATA devices.3.instances.0.commandClasses.49.data.212.val = 7.000000
[2013-08-26 09:17:23.085] SETDATA devices.3.instances.0.commandClasses.49.data.212.deviceScale = Empty
[2013-08-26 09:17:23.085] SETDATA devices.3.instances.0.commandClasses.49.data.212.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:23.086] SETDATA devices.3.instances.0.commandClasses.49.data.212.scale = Empty
[2013-08-26 09:17:23.086] SETDATA devices.3.instances.0.commandClasses.49.data.212.scale = 1 (0x00000001)
[2013-08-26 09:17:23.086] SETDATA devices.3.instances.0.commandClasses.49.data.212.scaleString = Empty
[2013-08-26 09:17:23.086] SETDATA devices.3.instances.0.commandClasses.49.data.212.scaleString = ""
[2013-08-26 09:17:23.087] SETDATA devices.3.instances.0.commandClasses.49.data.28 = Empty
[2013-08-26 09:17:23.087] SETDATA devices.3.instances.0.commandClasses.49.data.28.sensorTypeString = Empty
[2013-08-26 09:17:23.087] SETDATA devices.3.instances.0.commandClasses.49.data.28.sensorTypeString = ""
[2013-08-26 09:17:23.087] SETDATA devices.3.instances.0.commandClasses.49.data.28.val = Empty
[2013-08-26 09:17:23.088] SETDATA devices.3.instances.0.commandClasses.49.data.28.val = 15.800000
[2013-08-26 09:17:23.088] SETDATA devices.3.instances.0.commandClasses.49.data.28.deviceScale = Empty
[2013-08-26 09:17:23.088] SETDATA devices.3.instances.0.commandClasses.49.data.28.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.088] SETDATA devices.3.instances.0.commandClasses.49.data.28.scale = Empty
[2013-08-26 09:17:23.088] SETDATA devices.3.instances.0.commandClasses.49.data.28.scale = 0 (0x00000000)
[2013-08-26 09:17:23.089] SETDATA devices.3.instances.0.commandClasses.49.data.28.scaleString = Empty
[2013-08-26 09:17:23.089] SETDATA devices.3.instances.0.commandClasses.49.data.28.scaleString = ""
[2013-08-26 09:17:23.089] SETDATA devices.3.instances.0.commandClasses.49.data.112 = Empty
[2013-08-26 09:17:23.089] SETDATA devices.3.instances.0.commandClasses.49.data.112.sensorTypeString = Empty
[2013-08-26 09:17:23.090] SETDATA devices.3.instances.0.commandClasses.49.data.112.sensorTypeString = ""
[2013-08-26 09:17:23.090] SETDATA devices.3.instances.0.commandClasses.49.data.112.val = Empty
[2013-08-26 09:17:23.100] SETDATA devices.3.instances.0.commandClasses.49.data.112.val = 471.000000
[2013-08-26 09:17:23.101] SETDATA devices.3.instances.0.commandClasses.49.data.112.deviceScale = Empty
[2013-08-26 09:17:23.101] SETDATA devices.3.instances.0.commandClasses.49.data.112.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:23.101] SETDATA devices.3.instances.0.commandClasses.49.data.112.scale = Empty
[2013-08-26 09:17:23.101] SETDATA devices.3.instances.0.commandClasses.49.data.112.scale = 1 (0x00000001)
[2013-08-26 09:17:23.101] SETDATA devices.3.instances.0.commandClasses.49.data.112.scaleString = Empty
[2013-08-26 09:17:23.102] SETDATA devices.3.instances.0.commandClasses.49.data.112.scaleString = ""
[2013-08-26 09:17:23.102] SETDATA devices.3.instances.0.commandClasses.49.data.84 = Empty
[2013-08-26 09:17:23.102] SETDATA devices.3.instances.0.commandClasses.49.data.84.sensorTypeString = Empty
[2013-08-26 09:17:23.103] SETDATA devices.3.instances.0.commandClasses.49.data.84.sensorTypeString = ""
[2013-08-26 09:17:23.103] SETDATA devices.3.instances.0.commandClasses.49.data.84.val = Empty
[2013-08-26 09:17:23.103] SETDATA devices.3.instances.0.commandClasses.49.data.84.val = 1.000000
[2013-08-26 09:17:23.103] SETDATA devices.3.instances.0.commandClasses.49.data.84.deviceScale = Empty
[2013-08-26 09:17:23.103] SETDATA devices.3.instances.0.commandClasses.49.data.84.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:23.104] SETDATA devices.3.instances.0.commandClasses.49.data.84.scale = Empty
[2013-08-26 09:17:23.104] SETDATA devices.3.instances.0.commandClasses.49.data.84.scale = 1 (0x00000001)
[2013-08-26 09:17:23.104] SETDATA devices.3.instances.0.commandClasses.49.data.84.scaleString = Empty
[2013-08-26 09:17:23.104] SETDATA devices.3.instances.0.commandClasses.49.data.84.scaleString = ""
[2013-08-26 09:17:23.104] SETDATA devices.3.instances.0.commandClasses.49.data.134 = Empty
[2013-08-26 09:17:23.105] SETDATA devices.3.instances.0.commandClasses.49.data.134.sensorTypeString = Empty
[2013-08-26 09:17:23.105] SETDATA devices.3.instances.0.commandClasses.49.data.134.sensorTypeString = ""
[2013-08-26 09:17:23.105] SETDATA devices.3.instances.0.commandClasses.49.data.134.val = Empty
[2013-08-26 09:17:23.105] SETDATA devices.3.instances.0.commandClasses.49.data.134.val = 55.000000
[2013-08-26 09:17:23.106] SETDATA devices.3.instances.0.commandClasses.49.data.134.deviceScale = Empty
[2013-08-26 09:17:23.106] SETDATA devices.3.instances.0.commandClasses.49.data.134.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.106] SETDATA devices.3.instances.0.commandClasses.49.data.134.scale = Empty
[2013-08-26 09:17:23.106] SETDATA devices.3.instances.0.commandClasses.49.data.134.scale = 0 (0x00000000)
[2013-08-26 09:17:23.106] SETDATA devices.3.instances.0.commandClasses.49.data.134.scaleString = Empty
[2013-08-26 09:17:23.107] SETDATA devices.3.instances.0.commandClasses.49.data.134.scaleString = ""
[2013-08-26 09:17:23.107] SETDATA devices.3.instances.0.commandClasses.49.data.100 = Empty
[2013-08-26 09:17:23.107] SETDATA devices.3.instances.0.commandClasses.49.data.100.sensorTypeString = Empty
[2013-08-26 09:17:23.107] SETDATA devices.3.instances.0.commandClasses.49.data.100.sensorTypeString = ""
[2013-08-26 09:17:23.107] SETDATA devices.3.instances.0.commandClasses.49.data.100.val = Empty
[2013-08-26 09:17:23.108] SETDATA devices.3.instances.0.commandClasses.49.data.100.val = 18.100000
[2013-08-26 09:17:23.108] SETDATA devices.3.instances.0.commandClasses.49.data.100.deviceScale = Empty
[2013-08-26 09:17:23.108] SETDATA devices.3.instances.0.commandClasses.49.data.100.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.108] SETDATA devices.3.instances.0.commandClasses.49.data.100.scale = Empty
[2013-08-26 09:17:23.109] SETDATA devices.3.instances.0.commandClasses.49.data.100.scale = 0 (0x00000000)
[2013-08-26 09:17:23.109] SETDATA devices.3.instances.0.commandClasses.49.data.100.scaleString = Empty
[2013-08-26 09:17:23.109] SETDATA devices.3.instances.0.commandClasses.49.data.100.scaleString = ""
[2013-08-26 09:17:23.109] SETDATA devices.3.instances.0.commandClasses.49.data.12 = Empty
[2013-08-26 09:17:23.109] SETDATA devices.3.instances.0.commandClasses.49.data.12.sensorTypeString = Empty
[2013-08-26 09:17:23.110] SETDATA devices.3.instances.0.commandClasses.49.data.12.sensorTypeString = "Rain Rate"
[2013-08-26 09:17:23.120] SETDATA devices.3.instances.0.commandClasses.49.data.12.val = Empty
[2013-08-26 09:17:23.120] SETDATA devices.3.instances.0.commandClasses.49.data.12.val = 15.600000
[2013-08-26 09:17:23.121] SETDATA devices.3.instances.0.commandClasses.49.data.12.deviceScale = Empty
[2013-08-26 09:17:23.121] SETDATA devices.3.instances.0.commandClasses.49.data.12.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.121] SETDATA devices.3.instances.0.commandClasses.49.data.12.scale = Empty
[2013-08-26 09:17:23.121] SETDATA devices.3.instances.0.commandClasses.49.data.12.scale = 0 (0x00000000)
[2013-08-26 09:17:23.122] SETDATA devices.3.instances.0.commandClasses.49.data.12.scaleString = Empty
[2013-08-26 09:17:23.122] SETDATA devices.3.instances.0.commandClasses.49.data.12.scaleString = "mm/h"
[2013-08-26 09:17:23.122] SETDATA devices.3.instances.0.commandClasses.49.data.206 = Empty
[2013-08-26 09:17:23.122] SETDATA devices.3.instances.0.commandClasses.49.data.206.sensorTypeString = Empty
[2013-08-26 09:17:23.123] SETDATA devices.3.instances.0.commandClasses.49.data.206.sensorTypeString = ""
[2013-08-26 09:17:23.123] SETDATA devices.3.instances.0.commandClasses.49.data.206.val = Empty
[2013-08-26 09:17:23.123] SETDATA devices.3.instances.0.commandClasses.49.data.206.val = 23.000000
[2013-08-26 09:17:23.123] SETDATA devices.3.instances.0.commandClasses.49.data.206.deviceScale = Empty
[2013-08-26 09:17:23.123] SETDATA devices.3.instances.0.commandClasses.49.data.206.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.124] SETDATA devices.3.instances.0.commandClasses.49.data.206.scale = Empty
[2013-08-26 09:17:23.124] SETDATA devices.3.instances.0.commandClasses.49.data.206.scale = 0 (0x00000000)
[2013-08-26 09:17:23.124] SETDATA devices.3.instances.0.commandClasses.49.data.206.scaleString = Empty
[2013-08-26 09:17:23.124] SETDATA devices.3.instances.0.commandClasses.49.data.206.scaleString = ""
[2013-08-26 09:17:23.125] SETDATA devices.3.instances.0.commandClasses.49.data.18 = Empty
[2013-08-26 09:17:23.125] SETDATA devices.3.instances.0.commandClasses.49.data.18.sensorTypeString = Empty
[2013-08-26 09:17:23.125] SETDATA devices.3.instances.0.commandClasses.49.data.18.sensorTypeString = "Air Flow"
[2013-08-26 09:17:23.125] SETDATA devices.3.instances.0.commandClasses.49.data.18.val = Empty
[2013-08-26 09:17:23.125] SETDATA devices.3.instances.0.commandClasses.49.data.18.val = 44.000000
[2013-08-26 09:17:23.126] SETDATA devices.3.instances.0.commandClasses.49.data.18.deviceScale = Empty
[2013-08-26 09:17:23.126] SETDATA devices.3.instances.0.commandClasses.49.data.18.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.126] SETDATA devices.3.instances.0.commandClasses.49.data.18.scale = Empty
[2013-08-26 09:17:23.126] SETDATA devices.3.instances.0.commandClasses.49.data.18.scale = 0 (0x00000000)
[2013-08-26 09:17:23.127] SETDATA devices.3.instances.0.commandClasses.49.data.18.scaleString = Empty
[2013-08-26 09:17:23.127] SETDATA devices.3.instances.0.commandClasses.49.data.18.scaleString = "m3/h"
[2013-08-26 09:17:23.127] SETDATA devices.3.instances.0.commandClasses.49.data.178 = Empty
[2013-08-26 09:17:23.127] SETDATA devices.3.instances.0.commandClasses.49.data.178.sensorTypeString = Empty
[2013-08-26 09:17:23.127] SETDATA devices.3.instances.0.commandClasses.49.data.178.sensorTypeString = ""
[2013-08-26 09:17:23.128] SETDATA devices.3.instances.0.commandClasses.49.data.178.val = Empty
[2013-08-26 09:17:23.128] SETDATA devices.3.instances.0.commandClasses.49.data.178.val = 16.200001
[2013-08-26 09:17:23.128] SETDATA devices.3.instances.0.commandClasses.49.data.178.deviceScale = Empty
[2013-08-26 09:17:23.128] SETDATA devices.3.instances.0.commandClasses.49.data.178.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.129] SETDATA devices.3.instances.0.commandClasses.49.data.178.scale = Empty
[2013-08-26 09:17:23.129] SETDATA devices.3.instances.0.commandClasses.49.data.178.scale = 0 (0x00000000)
[2013-08-26 09:17:23.129] SETDATA devices.3.instances.0.commandClasses.49.data.178.scaleString = Empty
[2013-08-26 09:17:23.129] SETDATA devices.3.instances.0.commandClasses.49.data.178.scaleString = ""
[2013-08-26 09:17:23.129] SETDATA devices.3.instances.0.commandClasses.49.data.108 = Empty
[2013-08-26 09:17:23.130] SETDATA devices.3.instances.0.commandClasses.49.data.108.sensorTypeString = Empty
[2013-08-26 09:17:23.139] SETDATA devices.3.instances.0.commandClasses.49.data.108.sensorTypeString = ""
[2013-08-26 09:17:23.140] SETDATA devices.3.instances.0.commandClasses.49.data.108.val = Empty
[2013-08-26 09:17:23.140] SETDATA devices.3.instances.0.commandClasses.49.data.108.val = 2.000000
[2013-08-26 09:17:23.141] SETDATA devices.3.instances.0.commandClasses.49.data.108.deviceScale = Empty
[2013-08-26 09:17:23.141] SETDATA devices.3.instances.0.commandClasses.49.data.108.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:23.141] SETDATA devices.3.instances.0.commandClasses.49.data.108.scale = Empty
[2013-08-26 09:17:23.141] SETDATA devices.3.instances.0.commandClasses.49.data.108.scale = 1 (0x00000001)
[2013-08-26 09:17:23.142] SETDATA devices.3.instances.0.commandClasses.49.data.108.scaleString = Empty
[2013-08-26 09:17:23.142] SETDATA devices.3.instances.0.commandClasses.49.data.108.scaleString = ""
[2013-08-26 09:17:23.142] SETDATA devices.3.instances.0.commandClasses.49.data.70 = Empty
[2013-08-26 09:17:23.142] SETDATA devices.3.instances.0.commandClasses.49.data.70.sensorTypeString = Empty
[2013-08-26 09:17:23.143] SETDATA devices.3.instances.0.commandClasses.49.data.70.sensorTypeString = ""
[2013-08-26 09:17:23.143] SETDATA devices.3.instances.0.commandClasses.49.data.70.val = Empty
[2013-08-26 09:17:23.143] SETDATA devices.3.instances.0.commandClasses.49.data.70.val = 15.500000
[2013-08-26 09:17:23.143] SETDATA devices.3.instances.0.commandClasses.49.data.70.deviceScale = Empty
[2013-08-26 09:17:23.143] SETDATA devices.3.instances.0.commandClasses.49.data.70.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.144] SETDATA devices.3.instances.0.commandClasses.49.data.70.scale = Empty
[2013-08-26 09:17:23.144] SETDATA devices.3.instances.0.commandClasses.49.data.70.scale = 0 (0x00000000)
[2013-08-26 09:17:23.144] SETDATA devices.3.instances.0.commandClasses.49.data.70.scaleString = Empty
[2013-08-26 09:17:23.144] SETDATA devices.3.instances.0.commandClasses.49.data.70.scaleString = ""
[2013-08-26 09:17:23.144] SETDATA devices.3.instances.0.commandClasses.49.data.104 = Empty
[2013-08-26 09:17:23.145] SETDATA devices.3.instances.0.commandClasses.49.data.104.sensorTypeString = Empty
[2013-08-26 09:17:23.145] SETDATA devices.3.instances.0.commandClasses.49.data.104.sensorTypeString = ""
[2013-08-26 09:17:23.145] SETDATA devices.3.instances.0.commandClasses.49.data.104.val = Empty
[2013-08-26 09:17:23.145] SETDATA devices.3.instances.0.commandClasses.49.data.104.val = 14.900000
[2013-08-26 09:17:23.146] SETDATA devices.3.instances.0.commandClasses.49.data.104.deviceScale = Empty
[2013-08-26 09:17:23.146] SETDATA devices.3.instances.0.commandClasses.49.data.104.deviceScale = 0 (0x00000000)
[2013-08-26 09:17:23.146] SETDATA devices.3.instances.0.commandClasses.49.data.104.scale = Empty
[2013-08-26 09:17:23.146] SETDATA devices.3.instances.0.commandClasses.49.data.104.scale = 0 (0x00000000)
[2013-08-26 09:17:23.146] SETDATA devices.3.instances.0.commandClasses.49.data.104.scaleString = Empty
[2013-08-26 09:17:23.147] SETDATA devices.3.instances.0.commandClasses.49.data.104.scaleString = ""
[2013-08-26 09:17:23.147] SETDATA devices.3.instances.0.commandClasses.49.data.124 = Empty
[2013-08-26 09:17:23.147] SETDATA devices.3.instances.0.commandClasses.49.data.124.sensorTypeString = Empty
[2013-08-26 09:17:23.147] SETDATA devices.3.instances.0.commandClasses.49.data.124.sensorTypeString = ""
[2013-08-26 09:17:23.148] SETDATA devices.3.instances.0.commandClasses.49.data.124.val = Empty
[2013-08-26 09:17:23.148] SETDATA devices.3.instances.0.commandClasses.49.data.124.val = 1000.000000
[2013-08-26 09:17:23.148] SETDATA devices.3.instances.0.commandClasses.49.data.124.deviceScale = Empty
[2013-08-26 09:17:23.148] SETDATA devices.3.instances.0.commandClasses.49.data.124.deviceScale = 1 (0x00000001)
[2013-08-26 09:17:23.148] SETDATA devices.3.instances.0.commandClasses.49.data.124.scale = Empty
[2013-08-26 09:17:23.149] SETDATA devices.3.instances.0.commandClasses.49.data.124.scale = 1 (0x00000001)
[2013-08-26 09:17:23.149] SETDATA devices.3.instances.0.commandClasses.49.data.124.scaleString = Empty
[2013-08-26 09:17:23.149] SETDATA devices.3.instances.0.commandClasses.49.data.124.scaleString = ""
[2013-08-26 09:17:23.149] SETDATA devices.3.instances.0.commandClasses.112.data = Empty
[2013-08-26 09:17:23.159] SETDATA devices.3.instances.0.commandClasses.112.data.version = Empty
[2013-08-26 09:17:23.160] SETDATA devices.3.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.160] SETDATA devices.3.instances.0.commandClasses.112.data.security = Empty
[2013-08-26 09:17:23.160] SETDATA devices.3.instances.0.commandClasses.112.data.security = False
[2013-08-26 09:17:23.160] SETDATA devices.3.instances.0.commandClasses.112.data.interviewDone = Empty
[2013-08-26 09:17:23.161] SETDATA devices.3.instances.0.commandClasses.112.data.interviewCounter = Empty
[2013-08-26 09:17:23.161] SETDATA devices.3.instances.0.commandClasses.112.data.interviewDone = False
[2013-08-26 09:17:23.161] SETDATA devices.3.instances.0.commandClasses.112.data.interviewCounter = 10 (0x0000000a)
[2013-08-26 09:17:23.161] SETDATA devices.3.instances.0.commandClasses.112.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.161] SETDATA devices.3.instances.0.commandClasses.112.data.security = False
[2013-08-26 09:17:23.162] SETDATA devices.3.instances.0.commandClasses.112.data.interviewDone = True
[2013-08-26 09:17:23.163] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:23.163] SETDATA devices.3.instances.0.commandClasses.112.data.interviewCounter = 9 (0x00000009)
[2013-08-26 09:17:23.163] SETDATA devices.3.instances.0.commandClasses.112.data.1 = Empty
[2013-08-26 09:17:23.163] SETDATA devices.3.instances.0.commandClasses.112.data.1.val = Empty
[2013-08-26 09:17:23.164] SETDATA devices.3.instances.0.commandClasses.112.data.1.size = Empty
[2013-08-26 09:17:23.164] SETDATA devices.3.instances.0.commandClasses.112.data.2 = Empty
[2013-08-26 09:17:23.164] SETDATA devices.3.instances.0.commandClasses.112.data.2.val = Empty
[2013-08-26 09:17:23.164] SETDATA devices.3.instances.0.commandClasses.112.data.2.val = 1 (0x00000001)
[2013-08-26 09:17:23.164] SETDATA devices.3.instances.0.commandClasses.112.data.2.size = Empty
[2013-08-26 09:17:23.165] SETDATA devices.3.instances.0.commandClasses.112.data.2.size = 1 (0x00000001)
[2013-08-26 09:17:23.165] SETDATA devices.3.instances.0.commandClasses.112.data.3 = Empty
[2013-08-26 09:17:23.165] SETDATA devices.3.instances.0.commandClasses.112.data.3.val = Empty
[2013-08-26 09:17:23.165] SETDATA devices.3.instances.0.commandClasses.112.data.3.val = 60 (0x0000003c)
[2013-08-26 09:17:23.166] SETDATA devices.3.instances.0.commandClasses.112.data.3.size = Empty
[2013-08-26 09:17:23.166] SETDATA devices.3.instances.0.commandClasses.112.data.3.size = 2 (0x00000002)
[2013-08-26 09:17:23.166] SETDATA devices.3.instances.0.commandClasses.112.data.4 = Empty
[2013-08-26 09:17:23.166] SETDATA devices.3.instances.0.commandClasses.112.data.4.val = Empty
[2013-08-26 09:17:23.166] SETDATA devices.3.instances.0.commandClasses.112.data.4.val = 1 (0x00000001)
[2013-08-26 09:17:23.167] SETDATA devices.3.instances.0.commandClasses.112.data.4.size = Empty
[2013-08-26 09:17:23.167] SETDATA devices.3.instances.0.commandClasses.112.data.4.size = 1 (0x00000001)
[2013-08-26 09:17:23.167] SETDATA devices.3.instances.0.commandClasses.112.data.101 = Empty
[2013-08-26 09:17:23.167] SETDATA devices.3.instances.0.commandClasses.112.data.101.val = Empty
[2013-08-26 09:17:23.167] SETDATA devices.3.instances.0.commandClasses.112.data.101.val = 225 (0x000000e1)
[2013-08-26 09:17:23.168] SETDATA devices.3.instances.0.commandClasses.112.data.101.size = Empty
[2013-08-26 09:17:23.168] SETDATA devices.3.instances.0.commandClasses.112.data.101.size = 4 (0x00000004)
[2013-08-26 09:17:23.168] SETDATA devices.3.instances.0.commandClasses.112.data.102 = Empty
[2013-08-26 09:17:23.168] SETDATA devices.3.instances.0.commandClasses.112.data.102.val = Empty
[2013-08-26 09:17:23.169] SETDATA devices.3.instances.0.commandClasses.112.data.102.val = 225 (0x000000e1)
[2013-08-26 09:17:23.179] SETDATA devices.3.instances.0.commandClasses.112.data.102.size = Empty
[2013-08-26 09:17:23.179] SETDATA devices.3.instances.0.commandClasses.112.data.102.size = 4 (0x00000004)
[2013-08-26 09:17:23.179] SETDATA devices.3.instances.0.commandClasses.112.data.103 = Empty
[2013-08-26 09:17:23.180] SETDATA devices.3.instances.0.commandClasses.112.data.103.val = Empty
[2013-08-26 09:17:23.180] SETDATA devices.3.instances.0.commandClasses.112.data.103.val = 225 (0x000000e1)
[2013-08-26 09:17:23.180] SETDATA devices.3.instances.0.commandClasses.112.data.103.size = Empty
[2013-08-26 09:17:23.180] SETDATA devices.3.instances.0.commandClasses.112.data.103.size = 4 (0x00000004)
[2013-08-26 09:17:23.181] SETDATA devices.3.instances.0.commandClasses.112.data.111 = Empty
[2013-08-26 09:17:23.181] SETDATA devices.3.instances.0.commandClasses.112.data.111.val = Empty
[2013-08-26 09:17:23.181] SETDATA devices.3.instances.0.commandClasses.112.data.111.val = 720 (0x000002d0)
[2013-08-26 09:17:23.181] SETDATA devices.3.instances.0.commandClasses.112.data.111.size = Empty
[2013-08-26 09:17:23.181] SETDATA devices.3.instances.0.commandClasses.112.data.111.size = 4 (0x00000004)
[2013-08-26 09:17:23.182] SETDATA devices.3.instances.0.commandClasses.112.data.112 = Empty
[2013-08-26 09:17:23.182] SETDATA devices.3.instances.0.commandClasses.112.data.112.val = Empty
[2013-08-26 09:17:23.182] SETDATA devices.3.instances.0.commandClasses.112.data.112.val = 720 (0x000002d0)
[2013-08-26 09:17:23.182] SETDATA devices.3.instances.0.commandClasses.112.data.112.size = Empty
[2013-08-26 09:17:23.183] SETDATA devices.3.instances.0.commandClasses.112.data.112.size = 4 (0x00000004)
[2013-08-26 09:17:23.183] SETDATA devices.3.instances.0.commandClasses.112.data.113 = Empty
[2013-08-26 09:17:23.183] SETDATA devices.3.instances.0.commandClasses.112.data.113.val = Empty
[2013-08-26 09:17:23.183] SETDATA devices.3.instances.0.commandClasses.112.data.113.val = 720 (0x000002d0)
[2013-08-26 09:17:23.183] SETDATA devices.3.instances.0.commandClasses.112.data.113.size = Empty
[2013-08-26 09:17:23.184] SETDATA devices.3.instances.0.commandClasses.112.data.113.size = 4 (0x00000004)
[2013-08-26 09:17:23.184] SETDATA devices.3.instances.0.commandClasses.112.data.5 = Empty
[2013-08-26 09:17:23.184] SETDATA devices.3.instances.0.commandClasses.112.data.5.val = Empty
[2013-08-26 09:17:23.184] SETDATA devices.3.instances.0.commandClasses.112.data.5.val = 1 (0x00000001)
[2013-08-26 09:17:23.184] SETDATA devices.3.instances.0.commandClasses.112.data.5.size = Empty
[2013-08-26 09:17:23.185] SETDATA devices.3.instances.0.commandClasses.112.data.5.size = 1 (0x00000001)
[2013-08-26 09:17:23.185] SETDATA devices.3.instances.0.commandClasses.112.data.10 = Empty
[2013-08-26 09:17:23.185] SETDATA devices.3.instances.0.commandClasses.112.data.10.val = Empty
[2013-08-26 09:17:23.185] SETDATA devices.3.instances.0.commandClasses.112.data.10.size = Empty
[2013-08-26 09:17:23.185] SETDATA devices.3.instances.0.commandClasses.112.data.11 = Empty
[2013-08-26 09:17:23.186] SETDATA devices.3.instances.0.commandClasses.112.data.11.val = Empty
[2013-08-26 09:17:23.186] SETDATA devices.3.instances.0.commandClasses.112.data.11.size = Empty
[2013-08-26 09:17:23.186] SETDATA devices.3.instances.0.commandClasses.112.data.12 = Empty
[2013-08-26 09:17:23.186] SETDATA devices.3.instances.0.commandClasses.112.data.12.val = Empty
[2013-08-26 09:17:23.187] SETDATA devices.3.instances.0.commandClasses.112.data.12.size = Empty
[2013-08-26 09:17:23.187] SETDATA devices.3.instances.0.commandClasses.112.data.13 = Empty
[2013-08-26 09:17:23.187] SETDATA devices.3.instances.0.commandClasses.112.data.13.val = Empty
[2013-08-26 09:17:23.187] SETDATA devices.3.instances.0.commandClasses.112.data.13.size = Empty
[2013-08-26 09:17:23.187] SETDATA devices.3.instances.0.commandClasses.112.data.14 = Empty
[2013-08-26 09:17:23.188] SETDATA devices.3.instances.0.commandClasses.112.data.14.val = Empty
[2013-08-26 09:17:23.188] SETDATA devices.3.instances.0.commandClasses.112.data.14.size = Empty
[2013-08-26 09:17:23.188] SETDATA devices.3.instances.0.commandClasses.112.data.15 = Empty
[2013-08-26 09:17:23.188] SETDATA devices.3.instances.0.commandClasses.112.data.15.val = Empty
[2013-08-26 09:17:23.189] SETDATA devices.3.instances.0.commandClasses.112.data.15.size = Empty
[2013-08-26 09:17:23.200] SETDATA devices.3.instances.0.commandClasses.114.data = Empty
[2013-08-26 09:17:23.200] SETDATA devices.3.instances.0.commandClasses.114.data.version = Empty
[2013-08-26 09:17:23.201] SETDATA devices.3.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.201] SETDATA devices.3.instances.0.commandClasses.114.data.security = Empty
[2013-08-26 09:17:23.201] SETDATA devices.3.instances.0.commandClasses.114.data.security = False
[2013-08-26 09:17:23.201] SETDATA devices.3.instances.0.commandClasses.114.data.interviewDone = Empty
[2013-08-26 09:17:23.201] SETDATA devices.3.instances.0.commandClasses.114.data.interviewCounter = Empty
[2013-08-26 09:17:23.202] SETDATA devices.3.instances.0.commandClasses.114.data.interviewDone = False
[2013-08-26 09:17:23.202] SETDATA devices.3.instances.0.commandClasses.114.data.interviewCounter = 10 (0x0000000a)
[2013-08-26 09:17:23.202] SETDATA devices.3.instances.0.commandClasses.114.data.vendorId = Empty
[2013-08-26 09:17:23.202] SETDATA devices.3.instances.0.commandClasses.114.data.vendor = Empty
[2013-08-26 09:17:23.202] SETDATA devices.3.instances.0.commandClasses.114.data.productId = Empty
[2013-08-26 09:17:23.202] SETDATA devices.3.instances.0.commandClasses.114.data.productType = Empty
[2013-08-26 09:17:23.203] SETDATA devices.3.instances.0.commandClasses.114.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.203] SETDATA devices.3.instances.0.commandClasses.114.data.security = False
[2013-08-26 09:17:23.203] SETDATA devices.3.instances.0.commandClasses.114.data.interviewDone = True
[2013-08-26 09:17:23.204] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:23.204] SETDATA devices.3.instances.0.commandClasses.114.data.interviewCounter = 8 (0x00000008)
[2013-08-26 09:17:23.205] SETDATA devices.3.instances.0.commandClasses.114.data.vendorId = 134 (0x00000086)
[2013-08-26 09:17:23.205] SETDATA devices.3.instances.0.commandClasses.114.data.vendor = "Aeon Labs"
[2013-08-26 09:17:23.205] SETDATA devices.3.instances.0.commandClasses.114.data.productId = 5 (0x00000005)
[2013-08-26 09:17:23.205] SETDATA devices.3.instances.0.commandClasses.114.data.productType = 2 (0x00000002)
[2013-08-26 09:17:23.206] SETDATA devices.3.instances.0.commandClasses.128.data = Empty
[2013-08-26 09:17:23.206] SETDATA devices.3.instances.0.commandClasses.128.data.version = Empty
[2013-08-26 09:17:23.206] SETDATA devices.3.instances.0.commandClasses.128.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.206] SETDATA devices.3.instances.0.commandClasses.128.data.security = Empty
[2013-08-26 09:17:23.206] SETDATA devices.3.instances.0.commandClasses.128.data.security = False
[2013-08-26 09:17:23.207] SETDATA devices.3.instances.0.commandClasses.128.data.interviewDone = Empty
[2013-08-26 09:17:23.207] SETDATA devices.3.instances.0.commandClasses.128.data.interviewCounter = Empty
[2013-08-26 09:17:23.207] SETDATA devices.3.instances.0.commandClasses.128.data.interviewDone = False
[2013-08-26 09:17:23.207] SETDATA devices.3.instances.0.commandClasses.128.data.interviewCounter = 10 (0x0000000a)
[2013-08-26 09:17:23.207] SETDATA devices.3.instances.0.commandClasses.128.data.lastChange = Empty
[2013-08-26 09:17:23.208] SETDATA devices.3.instances.0.commandClasses.128.data.history = Empty
[2013-08-26 09:17:23.208] SETDATA devices.3.instances.0.commandClasses.128.data.last = Empty
[2013-08-26 09:17:23.208] SETDATA devices.3.instances.0.commandClasses.128.data.last = 0 (0x00000000)
[2013-08-26 09:17:23.208] SETDATA devices.3.instances.0.commandClasses.128.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.208] SETDATA devices.3.instances.0.commandClasses.128.data.security = False
[2013-08-26 09:17:23.209] SETDATA devices.3.instances.0.commandClasses.128.data.interviewDone = True
[2013-08-26 09:17:23.209] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:23.220] SETDATA devices.3.instances.0.commandClasses.128.data.interviewCounter = 9 (0x00000009)
[2013-08-26 09:17:23.220] SETDATA devices.3.instances.0.commandClasses.128.data.lastChange = 1377452754 (0x521a42d2)
[2013-08-26 09:17:23.221] SETDATA devices.3.instances.0.commandClasses.128.data.history.46 = Empty
[2013-08-26 09:17:23.221] SETDATA devices.3.instances.0.commandClasses.128.data.history.46 = 1377452754 (0x521a42d2)
[2013-08-26 09:17:23.221] SETDATA devices.3.instances.0.commandClasses.128.data.history.31 = Empty
[2013-08-26 09:17:23.221] SETDATA devices.3.instances.0.commandClasses.128.data.history.31 = 1377457794 (0x521a5682)
[2013-08-26 09:17:23.222] SETDATA devices.3.instances.0.commandClasses.128.data.history.30 = Empty
[2013-08-26 09:17:23.222] SETDATA devices.3.instances.0.commandClasses.128.data.history.30 = 1377467874 (0x521a7de2)
[2013-08-26 09:17:23.222] SETDATA devices.3.instances.0.commandClasses.128.data.history.28 = Empty
[2013-08-26 09:17:23.222] SETDATA devices.3.instances.0.commandClasses.128.data.history.28 = 1377480834 (0x521ab082)
[2013-08-26 09:17:23.223] SETDATA devices.3.instances.0.commandClasses.128.data.history.29 = Empty
[2013-08-26 09:17:23.223] SETDATA devices.3.instances.0.commandClasses.128.data.history.29 = 1377481074 (0x521ab172)
[2013-08-26 09:17:23.223] SETDATA devices.3.instances.0.commandClasses.128.data.history.27 = Empty
[2013-08-26 09:17:23.223] SETDATA devices.3.instances.0.commandClasses.128.data.history.27 = 1377481554 (0x521ab352)
[2013-08-26 09:17:23.223] SETDATA devices.3.instances.0.commandClasses.128.data.history.26 = Empty
[2013-08-26 09:17:23.224] SETDATA devices.3.instances.0.commandClasses.128.data.history.26 = 1377476034 (0x521a9dc2)
[2013-08-26 09:17:23.224] SETDATA devices.3.instances.0.commandClasses.128.data.history.25 = Empty
[2013-08-26 09:17:23.224] SETDATA devices.3.instances.0.commandClasses.128.data.history.25 = 1377473634 (0x521a9462)
[2013-08-26 09:17:23.224] SETDATA devices.3.instances.0.commandClasses.128.data.last = 27 (0x0000001b)
[2013-08-26 09:17:23.225] SETDATA devices.3.instances.0.commandClasses.132.data = Empty
[2013-08-26 09:17:23.225] SETDATA devices.3.instances.0.commandClasses.132.data.version = Empty
[2013-08-26 09:17:23.225] SETDATA devices.3.instances.0.commandClasses.132.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.225] SETDATA devices.3.instances.0.commandClasses.132.data.security = Empty
[2013-08-26 09:17:23.225] SETDATA devices.3.instances.0.commandClasses.132.data.security = False
[2013-08-26 09:17:23.225] SETDATA devices.3.instances.0.commandClasses.132.data.interviewDone = Empty
[2013-08-26 09:17:23.226] SETDATA devices.3.instances.0.commandClasses.132.data.interviewCounter = Empty
[2013-08-26 09:17:23.226] SETDATA devices.3.instances.0.commandClasses.132.data.interviewDone = False
[2013-08-26 09:17:23.226] SETDATA devices.3.instances.0.commandClasses.132.data.interviewCounter = 10 (0x0000000a)
[2013-08-26 09:17:23.226] SETDATA devices.3.instances.0.commandClasses.132.data.interval = Empty
[2013-08-26 09:17:23.226] SETDATA devices.3.instances.0.commandClasses.132.data.nodeId = Empty
[2013-08-26 09:17:23.226] SETDATA devices.3.instances.0.commandClasses.132.data.min = Empty
[2013-08-26 09:17:23.227] SETDATA devices.3.instances.0.commandClasses.132.data.max = Empty
[2013-08-26 09:17:23.227] SETDATA devices.3.instances.0.commandClasses.132.data.default = Empty
[2013-08-26 09:17:23.227] SETDATA devices.3.instances.0.commandClasses.132.data.step = Empty
[2013-08-26 09:17:23.227] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = Empty
[2013-08-26 09:17:23.227] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = Empty
[2013-08-26 09:17:23.228] SETDATA devices.3.instances.0.commandClasses.132.data.interval = 0 (0x00000000)
[2013-08-26 09:17:23.228] SETDATA devices.3.instances.0.commandClasses.132.data.version = 2 (0x00000002)
[2013-08-26 09:17:23.228] SETDATA devices.3.instances.0.commandClasses.132.data.security = False
[2013-08-26 09:17:23.228] SETDATA devices.3.instances.0.commandClasses.132.data.interviewDone = True
[2013-08-26 09:17:23.229] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:23.230] SETDATA devices.3.instances.0.commandClasses.132.data.interviewCounter = 9 (0x00000009)
[2013-08-26 09:17:23.240] SETDATA devices.3.instances.0.commandClasses.132.data.interval = 240 (0x000000f0)
[2013-08-26 09:17:23.240] SETDATA devices.3.instances.0.commandClasses.132.data.nodeId = 24 (0x00000018)
[2013-08-26 09:17:23.241] SETDATA devices.3.instances.0.commandClasses.132.data.min = 240 (0x000000f0)
[2013-08-26 09:17:23.241] SETDATA devices.3.instances.0.commandClasses.132.data.max = 2678400 (0x0028de80)
[2013-08-26 09:17:23.241] SETDATA devices.3.instances.0.commandClasses.132.data.default = 0 (0x00000000)
[2013-08-26 09:17:23.241] SETDATA devices.3.instances.0.commandClasses.132.data.step = 240 (0x000000f0)
[2013-08-26 09:17:23.242] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377481312 (0x521ab260)
[2013-08-26 09:17:23.242] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377481312 (0x521ab260)
[2013-08-26 09:17:23.242] SETDATA devices.3.instances.0.commandClasses.133.data = Empty
[2013-08-26 09:17:23.242] SETDATA devices.3.instances.0.commandClasses.133.data.version = Empty
[2013-08-26 09:17:23.243] SETDATA devices.3.instances.0.commandClasses.133.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.243] SETDATA devices.3.instances.0.commandClasses.133.data.security = Empty
[2013-08-26 09:17:23.243] SETDATA devices.3.instances.0.commandClasses.133.data.security = False
[2013-08-26 09:17:23.243] SETDATA devices.3.instances.0.commandClasses.133.data.interviewDone = Empty
[2013-08-26 09:17:23.243] SETDATA devices.3.instances.0.commandClasses.133.data.interviewCounter = Empty
[2013-08-26 09:17:23.243] SETDATA devices.3.instances.0.commandClasses.133.data.interviewDone = False
[2013-08-26 09:17:23.244] SETDATA devices.3.instances.0.commandClasses.133.data.interviewCounter = 10 (0x0000000a)
[2013-08-26 09:17:23.244] SETDATA devices.3.instances.0.commandClasses.133.data.groups = Empty
[2013-08-26 09:17:23.244] SETDATA devices.3.instances.0.commandClasses.133.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.244] SETDATA devices.3.instances.0.commandClasses.133.data.security = False
[2013-08-26 09:17:23.244] SETDATA devices.3.instances.0.commandClasses.133.data.interviewDone = True
[2013-08-26 09:17:23.245] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:23.246] SETDATA devices.3.instances.0.commandClasses.133.data.interviewCounter = 9 (0x00000009)
[2013-08-26 09:17:23.246] SETDATA devices.3.instances.0.commandClasses.133.data.groups = 1 (0x00000001)
[2013-08-26 09:17:23.246] SETDATA devices.3.instances.0.commandClasses.133.data.1 = Empty
[2013-08-26 09:17:23.247] SETDATA devices.3.instances.0.commandClasses.133.data.1.max = Empty
[2013-08-26 09:17:23.247] SETDATA devices.3.instances.0.commandClasses.133.data.1.max = 5 (0x00000005)
[2013-08-26 09:17:23.247] SETDATA devices.3.instances.0.commandClasses.133.data.1.nodes = Empty
[2013-08-26 09:17:23.247] SETDATA devices.3.instances.0.commandClasses.133.data.1.nodes = byte[1]
[2013-08-26 09:17:23.248] SETDATA devices.3.instances.0.commandClasses.133.data.1.nodesToFollow = Empty
[2013-08-26 09:17:23.248] SETDATA devices.3.instances.0.commandClasses.134.data = Empty
[2013-08-26 09:17:23.248] SETDATA devices.3.instances.0.commandClasses.134.data.version = Empty
[2013-08-26 09:17:23.248] SETDATA devices.3.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.248] SETDATA devices.3.instances.0.commandClasses.134.data.security = Empty
[2013-08-26 09:17:23.249] SETDATA devices.3.instances.0.commandClasses.134.data.security = False
[2013-08-26 09:17:23.249] SETDATA devices.3.instances.0.commandClasses.134.data.interviewDone = Empty
[2013-08-26 09:17:23.249] SETDATA devices.3.instances.0.commandClasses.134.data.interviewCounter = Empty
[2013-08-26 09:17:23.249] SETDATA devices.3.instances.0.commandClasses.134.data.interviewDone = False
[2013-08-26 09:17:23.249] SETDATA devices.3.instances.0.commandClasses.134.data.interviewCounter = 10 (0x0000000a)
[2013-08-26 09:17:23.249] SETDATA devices.3.instances.0.commandClasses.134.data.ZWLib = Empty
[2013-08-26 09:17:23.250] SETDATA devices.3.instances.0.commandClasses.134.data.ZWProtocolMajor = Empty
[2013-08-26 09:17:23.252] SETDATA devices.3.instances.0.commandClasses.134.data.ZWProtocolMinor = Empty
[2013-08-26 09:17:23.252] SETDATA devices.3.instances.0.commandClasses.134.data.SDK = Empty
[2013-08-26 09:17:23.252] SETDATA devices.3.instances.0.commandClasses.134.data.applicationMajor = Empty
[2013-08-26 09:17:23.257] SETDATA devices.3.instances.0.commandClasses.134.data.applicationMinor = Empty
[2013-08-26 09:17:23.257] SETDATA devices.3.instances.0.commandClasses.134.data.version = 1 (0x00000001)
[2013-08-26 09:17:23.262] SETDATA devices.3.instances.0.commandClasses.134.data.security = False
[2013-08-26 09:17:23.263] SETDATA devices.3.instances.0.commandClasses.134.data.interviewDone = True
[2013-08-26 09:17:23.264] SETDATA devices.3.data.keepAwake = False
[2013-08-26 09:17:23.264] SETDATA devices.3.instances.0.commandClasses.134.data.interviewCounter = 7 (0x00000007)
[2013-08-26 09:17:23.264] SETDATA devices.3.instances.0.commandClasses.134.data.ZWLib = 6 (0x00000006)
[2013-08-26 09:17:23.265] SETDATA devices.3.instances.0.commandClasses.134.data.ZWProtocolMajor = 3 (0x00000003)
[2013-08-26 09:17:23.265] SETDATA devices.3.instances.0.commandClasses.134.data.ZWProtocolMinor = 28 (0x0000001c)
[2013-08-26 09:17:23.265] SETDATA devices.3.instances.0.commandClasses.134.data.SDK = "5.03"
[2013-08-26 09:17:23.265] SETDATA devices.3.instances.0.commandClasses.134.data.applicationMajor = 1 (0x00000001)
[2013-08-26 09:17:23.265] SETDATA devices.3.instances.0.commandClasses.134.data.applicationMinor = 18 (0x00000012)
[2013-08-26 09:17:25.634] SETDATA devices.3.data.isFailed = False
[2013-08-26 09:17:26.449] SETDATA devices.3.data.basicType = 4 (0x00000004)
[2013-08-26 09:17:26.449] SETDATA devices.3.data.genericType = 32 (0x00000020)
[2013-08-26 09:17:26.449] SETDATA devices.3.data.specificType = 1 (0x00000001)
[2013-08-26 09:17:26.451] SETDATA devices.3.data.deviceTypeString = "Routing Binary Sensor"
[2013-08-26 09:17:26.451] SETDATA devices.3.data.isRouting = True
[2013-08-26 09:17:26.452] SETDATA devices.3.data.isListening = False
[2013-08-26 09:17:26.452] SETDATA devices.3.data.optional = True
[2013-08-26 09:17:26.452] SETDATA devices.3.data.sensor1000 = False
[2013-08-26 09:17:26.452] SETDATA devices.3.data.sensor250 = False
[2013-08-26 09:17:26.452] SETDATA devices.3.data.infoProtocolSpecific = 5413888 (0x00529c00)
[2013-08-26 09:17:27.533] SETDATA devices.3.data.neighbours = byte[13]
[2013-08-27 07:36:35.051] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:36:35.051] SETDATA devices.3.instances.0.commandClasses.128.data.history.15 = Empty
[2013-08-27 07:36:35.052] SETDATA devices.3.instances.0.commandClasses.128.data.history.15 = 1377588995 (0x521c5703)
[2013-08-27 07:36:35.052] SETDATA devices.3.instances.0.commandClasses.128.data.last = 15 (0x0000000f)
[2013-08-27 07:36:35.153] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:36:35.153] SETDATA devices.3.instances.0.commandClasses.128.data.history.15 = 1377588995 (0x521c5703)
[2013-08-27 07:36:35.153] SETDATA devices.3.instances.0.commandClasses.128.data.last = 15 (0x0000000f)
[2013-08-27 07:36:35.229] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:36:35.230] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 07:36:35.230] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 07:36:35.230] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 07:36:35.232] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 07:36:35.232] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 07:36:35.434] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:36:35.434] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 07:36:35.434] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 07:36:35.435] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 07:36:35.436] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 07:36:35.436] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 07:36:35.499] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:36:35.499] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 07:36:35.499] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 07:36:35.500] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 75.000000
[2013-08-27 07:36:35.501] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 07:36:35.501] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 07:36:35.685] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:36:35.685] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 07:36:35.685] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 07:36:35.685] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 75.000000
[2013-08-27 07:36:35.687] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 07:36:35.688] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 07:36:35.753] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:36:35.754] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 07:36:35.755] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 07:36:35.755] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 15.800000
[2013-08-27 07:36:35.757] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 07:36:35.758] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 07:36:35.831] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:36:35.831] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 07:36:35.833] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 07:36:35.833] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 15.800000
[2013-08-27 07:36:35.835] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 07:36:35.835] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 07:36:35.846] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:36:35.847] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377588995 (0x521c5703)
[2013-08-27 07:36:35.847] SETDATA devices.3.data.isAwake = True
[2013-08-27 07:36:35.847] SETDATA devices.3.data.lastSend = 21678 (0x000054ae)
[2013-08-27 07:36:35.848] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377588995 (0x521c5703)
[2013-08-27 07:36:35.958] SETDATA devices.3.data.lastSend = 21687 (0x000054b7)
[2013-08-27 07:36:35.958] SETDATA devices.3.data.isAwake = False
[2013-08-27 07:40:35.045] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:40:35.045] SETDATA devices.3.instances.0.commandClasses.128.data.history.18 = Empty
[2013-08-27 07:40:35.045] SETDATA devices.3.instances.0.commandClasses.128.data.history.18 = 1377589235 (0x521c57f3)
[2013-08-27 07:40:35.045] SETDATA devices.3.instances.0.commandClasses.128.data.last = 18 (0x00000012)
[2013-08-27 07:40:35.145] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:40:35.146] SETDATA devices.3.instances.0.commandClasses.128.data.history.18 = 1377589235 (0x521c57f3)
[2013-08-27 07:40:35.146] SETDATA devices.3.instances.0.commandClasses.128.data.last = 18 (0x00000012)
[2013-08-27 07:40:35.229] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:40:35.230] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 07:40:35.230] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 07:40:35.230] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 07:40:35.232] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 07:40:35.232] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 07:40:35.396] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:40:35.396] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 07:40:35.396] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 07:40:35.396] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 07:40:35.398] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 07:40:35.398] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 07:40:35.462] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:40:35.462] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 07:40:35.463] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 07:40:35.463] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 75.000000
[2013-08-27 07:40:35.465] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 07:40:35.466] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 07:40:35.636] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:40:35.636] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 07:40:35.637] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 07:40:35.637] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 75.000000
[2013-08-27 07:40:35.638] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 07:40:35.638] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 07:40:35.711] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:40:35.712] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 07:40:35.713] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 07:40:35.713] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 15.900000
[2013-08-27 07:40:35.715] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 07:40:35.715] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 07:40:35.799] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:40:35.799] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 07:40:35.800] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 07:40:35.800] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 15.900000
[2013-08-27 07:40:35.803] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 07:40:35.803] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 07:44:33.204] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:44:33.205] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377589473 (0x521c58e1)
[2013-08-27 07:44:33.205] SETDATA devices.3.data.isAwake = True
[2013-08-27 07:44:33.205] SETDATA devices.3.data.lastSend = 60535 (0x0000ec77)
[2013-08-27 07:44:33.206] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377589473 (0x521c58e1)
[2013-08-27 07:44:33.317] SETDATA devices.3.data.lastSend = 60544 (0x0000ec80)
[2013-08-27 07:44:33.318] SETDATA devices.3.data.isAwake = False
[2013-08-27 07:48:35.031] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:48:35.031] SETDATA devices.3.instances.0.commandClasses.128.data.history.19 = Empty
[2013-08-27 07:48:35.032] SETDATA devices.3.instances.0.commandClasses.128.data.history.19 = 1377589715 (0x521c59d3)
[2013-08-27 07:48:35.032] SETDATA devices.3.instances.0.commandClasses.128.data.last = 19 (0x00000013)
[2013-08-27 07:48:35.136] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:48:35.136] SETDATA devices.3.instances.0.commandClasses.128.data.history.19 = 1377589715 (0x521c59d3)
[2013-08-27 07:48:35.137] SETDATA devices.3.instances.0.commandClasses.128.data.last = 19 (0x00000013)
[2013-08-27 07:48:35.211] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:48:35.211] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 07:48:35.211] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 07:48:35.211] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 07:48:35.213] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 07:48:35.213] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 07:48:35.386] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:48:35.387] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 07:48:35.387] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 07:48:35.387] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 07:48:35.388] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 07:48:35.389] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 07:48:35.457] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:48:35.457] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 07:48:35.458] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 07:48:35.458] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 75.000000
[2013-08-27 07:48:35.459] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 07:48:35.460] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 07:48:35.622] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:48:35.622] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 07:48:35.622] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 07:48:35.622] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 75.000000
[2013-08-27 07:48:35.624] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 07:48:35.624] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 07:48:35.692] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:48:35.693] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 07:48:35.694] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 07:48:35.694] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 16.299999
[2013-08-27 07:48:35.695] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 07:48:35.695] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 07:48:35.791] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:48:35.791] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 07:48:35.792] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 07:48:35.792] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 16.299999
[2013-08-27 07:48:35.794] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 07:48:35.794] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 07:52:35.026] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:52:35.026] SETDATA devices.3.instances.0.commandClasses.128.data.history.20 = Empty
[2013-08-27 07:52:35.026] SETDATA devices.3.instances.0.commandClasses.128.data.history.20 = 1377589955 (0x521c5ac3)
[2013-08-27 07:52:35.027] SETDATA devices.3.instances.0.commandClasses.128.data.last = 20 (0x00000014)
[2013-08-27 07:52:35.218] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:52:35.218] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 07:52:35.219] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 07:52:35.219] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 07:52:35.220] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 07:52:35.220] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 07:52:35.381] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:52:35.381] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 07:52:35.382] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 07:52:35.382] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 07:52:35.383] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 07:52:35.383] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 07:52:35.450] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:52:35.450] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 07:52:35.451] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 07:52:35.451] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 75.000000
[2013-08-27 07:52:35.452] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 07:52:35.452] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 07:52:35.619] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:52:35.619] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 07:52:35.619] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 07:52:35.619] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 75.000000
[2013-08-27 07:52:35.620] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 07:52:35.621] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 07:52:35.689] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:52:35.689] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 07:52:35.690] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 07:52:35.690] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 16.700001
[2013-08-27 07:52:35.692] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 07:52:35.693] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 07:52:35.775] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:52:35.776] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 07:52:35.777] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 07:52:35.777] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 16.700001
[2013-08-27 07:52:35.779] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 07:52:35.779] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 07:52:35.794] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 07:52:35.794] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377589955 (0x521c5ac3)
[2013-08-27 07:52:35.795] SETDATA devices.3.data.isAwake = True
[2013-08-27 07:52:35.795] SETDATA devices.3.data.lastSend = 99899 (0x0001863b)
[2013-08-27 07:52:35.795] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377589955 (0x521c5ac3)
[2013-08-27 07:52:35.911] SETDATA devices.3.data.lastSend = 99908 (0x00018644)
[2013-08-27 07:52:35.911] SETDATA devices.3.data.isAwake = False
[2013-08-27 08:00:35.007] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:00:35.007] SETDATA devices.3.instances.0.commandClasses.128.data.history.19 = 1377590435 (0x521c5ca3)
[2013-08-27 08:00:35.007] SETDATA devices.3.instances.0.commandClasses.128.data.last = 19 (0x00000013)
[2013-08-27 08:00:35.112] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:00:35.112] SETDATA devices.3.instances.0.commandClasses.128.data.history.19 = 1377590435 (0x521c5ca3)
[2013-08-27 08:00:35.112] SETDATA devices.3.instances.0.commandClasses.128.data.last = 19 (0x00000013)
[2013-08-27 08:00:35.193] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:00:35.193] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:00:35.194] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:00:35.194] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:00:35.195] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:00:35.196] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:00:35.363] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:00:35.363] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:00:35.363] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:00:35.363] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:00:35.365] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:00:35.365] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:00:35.439] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:00:35.439] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:00:35.440] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:00:35.440] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 74.000000
[2013-08-27 08:00:35.441] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:00:35.442] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:00:35.597] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:00:35.597] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:00:35.598] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:00:35.598] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 74.000000
[2013-08-27 08:00:35.599] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:00:35.600] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:00:35.671] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:00:35.672] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:00:35.673] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:00:35.673] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 17.100000
[2013-08-27 08:00:35.674] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:00:35.674] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:00:35.764] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:00:35.764] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:00:35.765] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:00:35.766] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 17.100000
[2013-08-27 08:00:35.767] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:00:35.767] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:00:35.779] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:00:35.779] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377590435 (0x521c5ca3)
[2013-08-27 08:00:35.779] SETDATA devices.3.data.isAwake = True
[2013-08-27 08:00:35.780] SETDATA devices.3.data.lastSend = 139101 (0x00021f5d)
[2013-08-27 08:00:35.780] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377590435 (0x521c5ca3)
[2013-08-27 08:00:35.892] SETDATA devices.3.data.lastSend = 139110 (0x00021f66)
[2013-08-27 08:00:35.892] SETDATA devices.3.data.isAwake = False
[2013-08-27 08:04:34.999] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:04:34.999] SETDATA devices.3.instances.0.commandClasses.128.data.history.20 = 1377590674 (0x521c5d92)
[2013-08-27 08:04:34.999] SETDATA devices.3.instances.0.commandClasses.128.data.last = 20 (0x00000014)
[2013-08-27 08:04:35.107] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:04:35.107] SETDATA devices.3.instances.0.commandClasses.128.data.history.20 = 1377590675 (0x521c5d93)
[2013-08-27 08:04:35.107] SETDATA devices.3.instances.0.commandClasses.128.data.last = 20 (0x00000014)
[2013-08-27 08:04:35.179] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:04:35.179] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:04:35.179] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:04:35.180] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:04:35.181] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:04:35.182] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:04:35.349] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:04:35.349] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:04:35.349] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:04:35.349] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:04:35.351] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:04:35.351] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:04:35.428] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:04:35.428] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:04:35.429] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:04:35.429] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 73.000000
[2013-08-27 08:04:35.431] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:04:35.431] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:04:35.596] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:04:35.596] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:04:35.596] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:04:35.596] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 73.000000
[2013-08-27 08:04:35.598] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:04:35.598] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:04:35.668] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:04:35.668] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:04:35.669] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:04:35.669] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 17.299999
[2013-08-27 08:04:35.672] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:04:35.672] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:04:35.752] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:04:35.753] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:04:35.754] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:04:35.754] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 17.299999
[2013-08-27 08:04:35.755] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:04:35.756] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:06:54.948] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:06:54.948] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 08:06:55.050] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:06:55.051] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 08:07:54.213] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:07:54.213] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 08:07:54.302] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:07:54.303] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 08:08:34.154] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:08:34.154] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377590914 (0x521c5e82)
[2013-08-27 08:08:34.154] SETDATA devices.3.data.isAwake = True
[2013-08-27 08:08:34.155] SETDATA devices.3.data.lastSend = 178008 (0x0002b758)
[2013-08-27 08:08:34.155] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377590914 (0x521c5e82)
[2013-08-27 08:08:34.258] SETDATA devices.3.data.lastSend = 178017 (0x0002b761)
[2013-08-27 08:08:34.259] SETDATA devices.3.data.isAwake = False
[2013-08-27 08:11:45.466] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:11:45.467] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 08:11:45.575] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:11:45.575] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 08:12:35.989] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:12:35.989] SETDATA devices.3.instances.0.commandClasses.128.data.history.20 = 1377591155 (0x521c5f73)
[2013-08-27 08:12:35.989] SETDATA devices.3.instances.0.commandClasses.128.data.last = 20 (0x00000014)
[2013-08-27 08:12:36.093] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:12:36.093] SETDATA devices.3.instances.0.commandClasses.128.data.history.20 = 1377591156 (0x521c5f74)
[2013-08-27 08:12:36.093] SETDATA devices.3.instances.0.commandClasses.128.data.last = 20 (0x00000014)
[2013-08-27 08:12:36.166] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:12:36.167] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:12:36.167] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:12:36.167] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:12:36.168] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:12:36.169] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:12:36.338] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:12:36.339] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:12:36.339] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:12:36.339] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:12:36.340] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:12:36.341] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:12:36.412] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:12:36.412] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:12:36.412] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:12:36.412] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 72.000000
[2013-08-27 08:12:36.414] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:12:36.414] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:12:36.580] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:12:36.581] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:12:36.581] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:12:36.581] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 72.000000
[2013-08-27 08:12:36.582] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:12:36.584] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:12:36.647] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:12:36.647] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:12:36.648] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:12:36.649] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 18.100000
[2013-08-27 08:12:36.650] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:12:36.650] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:12:36.736] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:12:36.737] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:12:36.738] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:12:36.739] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 18.100000
[2013-08-27 08:12:36.740] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:12:36.740] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:12:45.191] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:12:45.192] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 08:12:45.300] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:12:45.300] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 08:15:44.658] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:15:44.658] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 08:15:44.771] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:15:44.771] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 08:16:39.484] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:16:39.485] SETDATA devices.3.instances.0.commandClasses.128.data.history.20 = 1377591399 (0x521c6067)
[2013-08-27 08:16:39.485] SETDATA devices.3.instances.0.commandClasses.128.data.last = 20 (0x00000014)
[2013-08-27 08:16:39.589] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:16:39.589] SETDATA devices.3.instances.0.commandClasses.128.data.history.20 = 1377591399 (0x521c6067)
[2013-08-27 08:16:39.590] SETDATA devices.3.instances.0.commandClasses.128.data.last = 20 (0x00000014)
[2013-08-27 08:16:39.665] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:16:39.665] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:16:39.666] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:16:39.666] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:16:39.668] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:16:39.668] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:16:39.838] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:16:39.838] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:16:39.839] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:16:39.839] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:16:39.840] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:16:39.840] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:16:39.901] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:16:39.902] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:16:39.902] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:16:39.902] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 72.000000
[2013-08-27 08:16:39.903] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:16:39.904] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:16:40.172] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:16:40.172] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:16:40.173] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:16:40.173] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 0.900000
[2013-08-27 08:16:40.175] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:16:40.175] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:16:40.232] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:16:40.232] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:16:40.233] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:16:40.233] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 0.900000
[2013-08-27 08:16:40.235] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:16:40.235] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:16:40.246] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:16:40.247] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377591400 (0x521c6068)
[2013-08-27 08:16:40.247] SETDATA devices.3.data.isAwake = True
[2013-08-27 08:16:40.247] SETDATA devices.3.data.lastSend = 217536 (0x000351c0)
[2013-08-27 08:16:40.247] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377591400 (0x521c6068)
[2013-08-27 08:16:40.361] SETDATA devices.3.data.lastSend = 217545 (0x000351c9)
[2013-08-27 08:16:40.362] SETDATA devices.3.data.isAwake = False
[2013-08-27 08:17:35.186] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:17:35.187] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 08:17:35.300] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:17:35.300] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 08:17:58.046] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:17:58.047] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 08:17:58.147] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:17:58.147] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 08:18:57.193] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:18:57.193] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 08:18:57.284] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:18:57.285] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 08:24:39.978] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:24:39.978] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = Empty
[2013-08-27 08:24:39.978] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = 1377591879 (0x521c6247)
[2013-08-27 08:24:39.978] SETDATA devices.3.instances.0.commandClasses.128.data.last = 21 (0x00000015)
[2013-08-27 08:24:40.069] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:24:40.069] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = 1377591880 (0x521c6248)
[2013-08-27 08:24:40.069] SETDATA devices.3.instances.0.commandClasses.128.data.last = 21 (0x00000015)
[2013-08-27 08:24:40.149] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:24:40.149] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:24:40.149] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:24:40.150] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:24:40.152] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:24:40.152] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:24:40.320] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:24:40.320] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:24:40.321] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:24:40.321] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:24:40.323] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:24:40.323] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:24:40.394] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:24:40.394] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:24:40.394] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:24:40.394] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 70.000000
[2013-08-27 08:24:40.395] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:24:40.396] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:24:40.565] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:24:40.565] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:24:40.565] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:24:40.566] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 70.000000
[2013-08-27 08:24:40.567] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:24:40.567] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:24:40.630] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:24:40.630] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:24:40.631] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:24:40.631] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 18.799999
[2013-08-27 08:24:40.633] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:24:40.633] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:24:40.723] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:24:40.724] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:24:40.725] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:24:40.725] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 18.799999
[2013-08-27 08:24:40.726] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:24:40.727] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:24:40.742] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:24:40.742] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377591880 (0x521c6248)
[2013-08-27 08:24:40.743] SETDATA devices.3.data.isAwake = True
[2013-08-27 08:24:40.743] SETDATA devices.3.data.lastSend = 256367 (0x0003e96f)
[2013-08-27 08:24:40.743] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377591880 (0x521c6248)
[2013-08-27 08:24:40.850] SETDATA devices.3.data.lastSend = 256376 (0x0003e978)
[2013-08-27 08:24:40.850] SETDATA devices.3.data.isAwake = False
[2013-08-27 08:28:39.964] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:28:39.964] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = 1377592119 (0x521c6337)
[2013-08-27 08:28:39.964] SETDATA devices.3.instances.0.commandClasses.128.data.last = 21 (0x00000015)
[2013-08-27 08:28:40.060] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:28:40.060] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = 1377592120 (0x521c6338)
[2013-08-27 08:28:40.061] SETDATA devices.3.instances.0.commandClasses.128.data.last = 21 (0x00000015)
[2013-08-27 08:28:40.139] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:28:40.139] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:28:40.139] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:28:40.139] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:28:40.142] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:28:40.142] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:28:40.317] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:28:40.317] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:28:40.317] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:28:40.318] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:28:40.320] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:28:40.320] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:28:40.380] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:28:40.380] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:28:40.380] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:28:40.381] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 70.000000
[2013-08-27 08:28:40.382] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:28:40.382] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:28:40.559] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:28:40.559] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:28:40.559] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:28:40.559] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 70.000000
[2013-08-27 08:28:40.561] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:28:40.562] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:28:40.626] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:28:40.626] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:28:40.627] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:28:40.627] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 19.000000
[2013-08-27 08:28:40.629] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:28:40.629] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:28:40.713] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:28:40.713] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:28:40.714] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:28:40.714] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 19.000000
[2013-08-27 08:28:40.715] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:28:40.716] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:32:38.120] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:32:38.121] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377592358 (0x521c6426)
[2013-08-27 08:32:38.121] SETDATA devices.3.data.isAwake = True
[2013-08-27 08:32:38.121] SETDATA devices.3.data.lastSend = 295243 (0x0004814b)
[2013-08-27 08:32:38.121] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377592358 (0x521c6426)
[2013-08-27 08:32:38.237] SETDATA devices.3.data.lastSend = 295252 (0x00048154)
[2013-08-27 08:32:38.237] SETDATA devices.3.data.isAwake = False
[2013-08-27 08:36:39.945] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:36:39.945] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = 1377592599 (0x521c6517)
[2013-08-27 08:36:39.945] SETDATA devices.3.instances.0.commandClasses.128.data.last = 21 (0x00000015)
[2013-08-27 08:36:40.056] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:36:40.057] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = 1377592600 (0x521c6518)
[2013-08-27 08:36:40.057] SETDATA devices.3.instances.0.commandClasses.128.data.last = 21 (0x00000015)
[2013-08-27 08:36:40.135] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:36:40.136] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:36:40.137] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:36:40.137] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:36:40.138] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:36:40.138] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:36:40.307] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:36:40.307] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:36:40.307] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:36:40.307] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:36:40.309] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:36:40.309] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:36:40.368] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:36:40.368] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:36:40.368] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:36:40.368] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 68.000000
[2013-08-27 08:36:40.370] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:36:40.370] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:36:40.546] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:36:40.547] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:36:40.547] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:36:40.547] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 68.000000
[2013-08-27 08:36:40.549] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:36:40.549] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:36:40.609] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:36:40.609] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:36:40.610] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:36:40.611] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 19.299999
[2013-08-27 08:36:40.612] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:36:40.614] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:36:40.700] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:36:40.700] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:36:40.701] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:36:40.702] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 19.299999
[2013-08-27 08:36:40.703] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:36:40.703] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:40:39.941] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:40:39.941] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = 1377592839 (0x521c6607)
[2013-08-27 08:40:39.941] SETDATA devices.3.instances.0.commandClasses.128.data.last = 21 (0x00000015)
[2013-08-27 08:40:40.053] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:40:40.053] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = 1377592840 (0x521c6608)
[2013-08-27 08:40:40.053] SETDATA devices.3.instances.0.commandClasses.128.data.last = 21 (0x00000015)
[2013-08-27 08:40:40.132] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:40:40.133] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:40:40.133] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:40:40.133] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:40:40.134] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:40:40.135] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:40:40.306] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:40:40.307] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:40:40.307] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:40:40.307] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:40:40.308] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:40:40.309] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:40:40.374] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:40:40.375] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:40:40.375] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:40:40.375] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 68.000000
[2013-08-27 08:40:40.376] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:40:40.377] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:40:40.542] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:40:40.542] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:40:40.542] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:40:40.543] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 68.000000
[2013-08-27 08:40:40.545] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:40:40.545] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:40:40.607] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:40:40.607] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:40:40.610] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:40:40.610] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 19.400000
[2013-08-27 08:40:40.612] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:40:40.612] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:40:40.700] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:40:40.700] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:40:40.702] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:40:40.703] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 19.400000
[2013-08-27 08:40:40.704] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:40:40.705] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:40:40.729] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:40:40.729] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377592840 (0x521c6608)
[2013-08-27 08:40:40.730] SETDATA devices.3.data.isAwake = True
[2013-08-27 08:40:40.730] SETDATA devices.3.data.lastSend = 334613 (0x00051b15)
[2013-08-27 08:40:40.730] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377592840 (0x521c6608)
[2013-08-27 08:40:40.845] SETDATA devices.3.data.lastSend = 334622 (0x00051b1e)
[2013-08-27 08:40:40.846] SETDATA devices.3.data.isAwake = False
[2013-08-27 08:48:40.035] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:48:40.035] SETDATA devices.3.instances.0.commandClasses.128.data.lastChange = 1377593320 (0x521c67e8)
[2013-08-27 08:48:40.036] SETDATA devices.3.instances.0.commandClasses.128.data.history = Empty
[2013-08-27 08:48:40.036] SETDATA devices.3.instances.0.commandClasses.128.data.history.200 = Empty
[2013-08-27 08:48:40.036] SETDATA devices.3.instances.0.commandClasses.128.data.history.200 = 1377593320 (0x521c67e8)
[2013-08-27 08:48:40.036] SETDATA devices.3.instances.0.commandClasses.128.data.last = 200 (0x000000c8)
[2013-08-27 08:48:40.116] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:48:40.116] SETDATA devices.3.instances.0.commandClasses.49.data.182.deviceScale = 1 (0x00000001)
[2013-08-27 08:48:40.117] SETDATA devices.3.instances.0.commandClasses.49.data.182.scale = 1 (0x00000001)
[2013-08-27 08:48:40.117] SETDATA devices.3.instances.0.commandClasses.49.data.182.val = 1000.000000
[2013-08-27 08:48:40.118] SETDATA devices.3.instances.0.commandClasses.49.data.182.scaleString = ""
[2013-08-27 08:48:40.118] SETDATA devices.3.instances.0.commandClasses.49.data.182 = Empty
[2013-08-27 08:48:40.289] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:48:40.355] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:48:40.691] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:48:40.692] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:48:40.693] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:48:40.694] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 19.900000
[2013-08-27 08:48:40.695] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:48:40.695] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:48:40.708] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:48:40.709] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377593320 (0x521c67e8)
[2013-08-27 08:48:40.709] SETDATA devices.3.data.isAwake = True
[2013-08-27 08:48:40.709] SETDATA devices.3.data.lastSend = 373774 (0x0005b40e)
[2013-08-27 08:48:40.709] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377593320 (0x521c67e8)
[2013-08-27 08:48:40.813] SETDATA devices.3.data.lastSend = 373783 (0x0005b417)
[2013-08-27 08:48:40.813] SETDATA devices.3.data.isAwake = False
[2013-08-27 08:52:39.923] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:52:39.924] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = Empty
[2013-08-27 08:52:39.924] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = 1377593559 (0x521c68d7)
[2013-08-27 08:52:39.924] SETDATA devices.3.instances.0.commandClasses.128.data.last = 21 (0x00000015)
[2013-08-27 08:52:40.029] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:52:40.029] SETDATA devices.3.instances.0.commandClasses.128.data.history.21 = 1377593560 (0x521c68d8)
[2013-08-27 08:52:40.030] SETDATA devices.3.instances.0.commandClasses.128.data.last = 21 (0x00000015)
[2013-08-27 08:52:40.111] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:52:40.111] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:52:40.111] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:52:40.111] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:52:40.113] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:52:40.113] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:52:40.280] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:52:40.280] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 08:52:40.280] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 08:52:40.280] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 08:52:40.282] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 08:52:40.283] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 08:52:40.354] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:52:40.354] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:52:40.354] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:52:40.354] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 67.000000
[2013-08-27 08:52:40.356] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:52:40.356] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:52:40.522] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:52:40.523] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 08:52:40.523] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 08:52:40.523] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 67.000000
[2013-08-27 08:52:40.524] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 08:52:40.525] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 08:52:40.593] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:52:40.593] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:52:40.594] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:52:40.595] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 20.000000
[2013-08-27 08:52:40.596] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:52:40.596] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:52:40.685] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:52:40.686] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 08:52:40.687] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 08:52:40.687] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 20.000000
[2013-08-27 08:52:40.688] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 08:52:40.689] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 08:56:38.090] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 08:56:38.091] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377593798 (0x521c69c6)
[2013-08-27 08:56:38.091] SETDATA devices.3.data.isAwake = True
[2013-08-27 08:56:38.091] SETDATA devices.3.data.lastSend = 412544 (0x00064b80)
[2013-08-27 08:56:38.092] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377593798 (0x521c69c6)
[2013-08-27 08:56:38.196] SETDATA devices.3.data.lastSend = 412553 (0x00064b89)
[2013-08-27 08:56:38.197] SETDATA devices.3.data.isAwake = False
[2013-08-27 09:00:39.920] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:00:39.921] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = Empty
[2013-08-27 09:00:39.921] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377594039 (0x521c6ab7)
[2013-08-27 09:00:39.921] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:00:40.028] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:00:40.028] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377594040 (0x521c6ab8)
[2013-08-27 09:00:40.028] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:00:40.105] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:00:40.105] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:00:40.105] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:00:40.105] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:00:40.107] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:00:40.107] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:00:40.270] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:00:40.270] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:00:40.271] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:00:40.271] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:00:40.272] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:00:40.272] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:00:40.341] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:00:40.341] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:00:40.342] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:00:40.342] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 66.000000
[2013-08-27 09:00:40.344] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:00:40.344] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:00:40.514] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:00:40.514] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:00:40.514] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:00:40.515] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 66.000000
[2013-08-27 09:00:40.516] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:00:40.516] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:00:40.581] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:00:40.581] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:00:40.582] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:00:40.583] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 20.400000
[2013-08-27 09:00:40.584] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:00:40.584] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:00:40.668] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:00:40.669] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:00:40.670] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:00:40.670] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 20.400000
[2013-08-27 09:00:40.672] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:00:40.672] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:04:39.908] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:04:39.908] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377594279 (0x521c6ba7)
[2013-08-27 09:04:39.908] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:04:40.021] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:04:40.021] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377594280 (0x521c6ba8)
[2013-08-27 09:04:40.021] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:04:40.100] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:04:40.100] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:04:40.100] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:04:40.100] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:04:40.102] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:04:40.102] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:04:40.270] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:04:40.271] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:04:40.271] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:04:40.271] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:04:40.272] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:04:40.273] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:04:40.341] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:04:40.341] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:04:40.341] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:04:40.341] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 65.000000
[2013-08-27 09:04:40.343] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:04:40.343] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:04:40.515] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:04:40.515] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:04:40.515] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:04:40.516] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 65.000000
[2013-08-27 09:04:40.517] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:04:40.518] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:04:40.584] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:04:40.584] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:04:40.585] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:04:40.585] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 20.400000
[2013-08-27 09:04:40.586] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:04:40.587] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:04:40.679] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:04:40.680] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:04:40.681] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:04:40.681] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 20.400000
[2013-08-27 09:04:40.683] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:04:40.683] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:04:40.694] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:04:40.695] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377594280 (0x521c6ba8)
[2013-08-27 09:04:40.695] SETDATA devices.3.data.isAwake = True
[2013-08-27 09:04:40.695] SETDATA devices.3.data.lastSend = 451937 (0x0006e561)
[2013-08-27 09:04:40.696] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377594280 (0x521c6ba8)
[2013-08-27 09:04:40.807] SETDATA devices.3.data.lastSend = 451946 (0x0006e56a)
[2013-08-27 09:04:40.808] SETDATA devices.3.data.isAwake = False
[2013-08-27 09:09:16.785] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:09:16.786] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 09:09:16.885] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:09:16.886] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 09:10:16.110] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:10:16.111] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 09:10:16.218] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:10:16.218] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 09:12:40.923] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:12:40.923] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377594760 (0x521c6d88)
[2013-08-27 09:12:40.923] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:12:41.086] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:12:41.086] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377594761 (0x521c6d89)
[2013-08-27 09:12:41.087] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:12:41.144] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:12:41.144] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:12:41.144] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:12:41.145] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:12:41.146] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:12:41.146] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:12:41.354] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:12:41.354] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:12:41.354] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:12:41.354] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:12:41.356] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:12:41.356] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:12:41.418] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:12:41.418] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:12:41.418] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:12:41.418] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 64.000000
[2013-08-27 09:12:41.420] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:12:41.420] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:12:41.539] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:12:41.540] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:12:41.540] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:12:41.540] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 64.000000
[2013-08-27 09:12:41.542] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:12:41.542] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:12:41.600] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:12:41.600] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:12:41.602] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:12:41.602] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 20.799999
[2013-08-27 09:12:41.603] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:12:41.603] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:12:41.910] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:12:41.910] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:12:41.912] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:12:41.912] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 20.799999
[2013-08-27 09:12:41.913] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:12:41.913] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:12:41.936] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:12:41.937] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377594761 (0x521c6d89)
[2013-08-27 09:12:41.937] SETDATA devices.3.data.isAwake = True
[2013-08-27 09:12:41.937] SETDATA devices.3.data.lastSend = 491201 (0x00077ec1)
[2013-08-27 09:12:41.937] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377594761 (0x521c6d89)
[2013-08-27 09:12:42.051] SETDATA devices.3.data.lastSend = 491210 (0x00077eca)
[2013-08-27 09:12:42.052] SETDATA devices.3.data.isAwake = False
[2013-08-27 09:16:40.896] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:16:40.897] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377595000 (0x521c6e78)
[2013-08-27 09:16:40.897] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:16:41.004] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:16:41.004] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377595001 (0x521c6e79)
[2013-08-27 09:16:41.004] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:16:41.074] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:16:41.074] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:16:41.074] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:16:41.074] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:16:41.076] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:16:41.076] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:16:41.249] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:16:41.249] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:16:41.249] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:16:41.249] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:16:41.251] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:16:41.252] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:16:41.313] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:16:41.313] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:16:41.314] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:16:41.314] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 63.000000
[2013-08-27 09:16:41.315] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:16:41.315] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:16:41.493] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:16:41.493] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:16:41.493] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:16:41.493] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 63.000000
[2013-08-27 09:16:41.495] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:16:41.495] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:16:41.561] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:16:41.561] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:16:41.563] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:16:41.563] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.100000
[2013-08-27 09:16:41.565] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:16:41.565] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:16:41.644] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:16:41.645] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:16:41.646] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:16:41.646] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.100000
[2013-08-27 09:16:41.647] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:16:41.647] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:16:49.699] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:16:49.699] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 09:16:49.802] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:16:49.803] SETDATA devices.3.instances.0.commandClasses.48.data.level = True
[2013-08-27 09:17:49.094] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:17:49.095] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 09:17:49.201] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:17:49.202] SETDATA devices.3.instances.0.commandClasses.48.data.level = False
[2013-08-27 09:20:40.050] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:20:40.051] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377595240 (0x521c6f68)
[2013-08-27 09:20:40.051] SETDATA devices.3.data.isAwake = True
[2013-08-27 09:20:40.051] SETDATA devices.3.data.lastSend = 530223 (0x0008172f)
[2013-08-27 09:20:40.051] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377595240 (0x521c6f68)
[2013-08-27 09:20:40.158] SETDATA devices.3.data.lastSend = 530232 (0x00081738)
[2013-08-27 09:20:40.158] SETDATA devices.3.data.isAwake = False
[2013-08-27 09:24:41.886] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:24:41.886] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377595481 (0x521c7059)
[2013-08-27 09:24:41.886] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:24:41.990] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:24:41.990] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377595481 (0x521c7059)
[2013-08-27 09:24:41.990] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:24:42.064] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:24:42.064] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:24:42.064] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:24:42.065] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:24:42.066] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:24:42.066] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:24:42.239] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:24:42.239] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:24:42.239] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:24:42.240] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:24:42.242] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:24:42.251] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:24:42.307] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:24:42.307] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:24:42.307] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:24:42.307] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 62.000000
[2013-08-27 09:24:42.309] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:24:42.309] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:24:42.472] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:24:42.472] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:24:42.472] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:24:42.473] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 62.000000
[2013-08-27 09:24:42.474] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:24:42.474] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:24:42.542] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:24:42.543] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:24:42.544] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:24:42.544] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.200001
[2013-08-27 09:24:42.546] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:24:42.546] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:24:42.635] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:24:42.636] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:24:42.637] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:24:42.637] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.200001
[2013-08-27 09:24:42.638] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:24:42.638] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:28:41.871] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:28:41.871] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377595721 (0x521c7149)
[2013-08-27 09:28:41.871] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:28:41.984] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:28:41.984] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377595721 (0x521c7149)
[2013-08-27 09:28:41.984] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:28:42.062] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:28:42.063] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:28:42.063] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:28:42.063] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:28:42.065] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:28:42.065] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:28:42.224] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:28:42.225] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:28:42.225] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:28:42.225] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:28:42.226] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:28:42.227] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:28:42.302] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:28:42.302] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:28:42.302] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:28:42.302] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 61.000000
[2013-08-27 09:28:42.304] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:28:42.304] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:28:42.474] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:28:42.474] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:28:42.474] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:28:42.474] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 61.000000
[2013-08-27 09:28:42.476] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:28:42.476] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:28:42.537] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:28:42.537] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:28:42.538] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:28:42.538] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.299999
[2013-08-27 09:28:42.539] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:28:42.540] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:28:42.629] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:28:42.629] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:28:42.630] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:28:42.630] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.299999
[2013-08-27 09:28:42.632] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:28:42.632] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:28:42.644] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:28:42.644] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377595722 (0x521c714a)
[2013-08-27 09:28:42.644] SETDATA devices.3.data.isAwake = True
[2013-08-27 09:28:42.644] SETDATA devices.3.data.lastSend = 569589 (0x0008b0f5)
[2013-08-27 09:28:42.645] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377595722 (0x521c714a)
[2013-08-27 09:28:42.751] SETDATA devices.3.data.lastSend = 569598 (0x0008b0fe)
[2013-08-27 09:28:42.751] SETDATA devices.3.data.isAwake = False
[2013-08-27 09:36:41.868] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:36:41.868] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377596201 (0x521c7329)
[2013-08-27 09:36:41.868] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:36:41.972] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:36:41.972] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377596201 (0x521c7329)
[2013-08-27 09:36:41.972] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:36:42.054] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:36:42.054] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:36:42.055] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:36:42.055] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:36:42.056] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:36:42.056] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:36:42.218] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:36:42.219] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:36:42.219] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:36:42.219] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:36:42.220] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:36:42.222] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:36:42.282] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:36:42.282] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:36:42.283] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:36:42.283] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 60.000000
[2013-08-27 09:36:42.284] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:36:42.284] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:36:42.464] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:36:42.465] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:36:42.465] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:36:42.465] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 60.000000
[2013-08-27 09:36:42.466] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:36:42.467] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:36:42.523] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:36:42.523] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:36:42.524] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:36:42.525] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.600000
[2013-08-27 09:36:42.526] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:36:42.526] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:36:42.615] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:36:42.615] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:36:42.616] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:36:42.616] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.600000
[2013-08-27 09:36:42.618] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:36:42.618] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:36:42.634] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:36:42.634] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377596202 (0x521c732a)
[2013-08-27 09:36:42.634] SETDATA devices.3.data.isAwake = True
[2013-08-27 09:36:42.634] SETDATA devices.3.data.lastSend = 608621 (0x0009496d)
[2013-08-27 09:36:42.635] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377596202 (0x521c732a)
[2013-08-27 09:36:42.747] SETDATA devices.3.data.lastSend = 608630 (0x00094976)
[2013-08-27 09:36:42.748] SETDATA devices.3.data.isAwake = False
[2013-08-27 09:40:41.864] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:40:41.865] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377596441 (0x521c7419)
[2013-08-27 09:40:41.865] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:40:41.965] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:40:41.965] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377596441 (0x521c7419)
[2013-08-27 09:40:41.965] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:40:42.045] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:40:42.045] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:40:42.045] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:40:42.046] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:40:42.047] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:40:42.047] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:40:42.210] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:40:42.210] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:40:42.210] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:40:42.210] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:40:42.212] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:40:42.212] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:40:42.277] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:40:42.277] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:40:42.277] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:40:42.277] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 59.000000
[2013-08-27 09:40:42.279] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:40:42.279] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:40:42.449] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:40:42.449] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:40:42.449] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:40:42.449] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 59.000000
[2013-08-27 09:40:42.451] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:40:42.451] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:40:42.523] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:40:42.523] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:40:42.524] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:40:42.524] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.799999
[2013-08-27 09:40:42.525] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:40:42.526] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:40:42.616] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:40:42.616] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:40:42.617] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:40:42.617] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.799999
[2013-08-27 09:40:42.620] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:40:42.620] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:44:40.017] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:44:40.018] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377596680 (0x521c7508)
[2013-08-27 09:44:40.018] SETDATA devices.3.data.isAwake = True
[2013-08-27 09:44:40.018] SETDATA devices.3.data.lastSend = 647534 (0x0009e16e)
[2013-08-27 09:44:40.019] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377596680 (0x521c7508)
[2013-08-27 09:44:40.127] SETDATA devices.3.data.lastSend = 647543 (0x0009e177)
[2013-08-27 09:44:40.128] SETDATA devices.3.data.isAwake = False
[2013-08-27 09:48:41.850] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:48:41.851] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377596921 (0x521c75f9)
[2013-08-27 09:48:41.851] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:48:41.946] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:48:41.946] SETDATA devices.3.instances.0.commandClasses.128.data.history.22 = 1377596921 (0x521c75f9)
[2013-08-27 09:48:41.946] SETDATA devices.3.instances.0.commandClasses.128.data.last = 22 (0x00000016)
[2013-08-27 09:48:42.035] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:48:42.036] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:48:42.036] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:48:42.036] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:48:42.037] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:48:42.038] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:48:42.203] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:48:42.203] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:48:42.203] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:48:42.203] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:48:42.205] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:48:42.205] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:48:42.281] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:48:42.281] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:48:42.281] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:48:42.281] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 59.000000
[2013-08-27 09:48:42.283] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:48:42.283] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:48:42.444] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:48:42.445] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:48:42.445] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:48:42.445] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 59.000000
[2013-08-27 09:48:42.446] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:48:42.447] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:48:42.512] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:48:42.512] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:48:42.513] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:48:42.513] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.900000
[2013-08-27 09:48:42.515] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:48:42.515] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:48:42.598] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:48:42.598] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:48:42.599] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:48:42.599] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 21.900000
[2013-08-27 09:48:42.601] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:48:42.601] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:52:41.837] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:52:41.837] SETDATA devices.3.instances.0.commandClasses.128.data.history.23 = Empty
[2013-08-27 09:52:41.837] SETDATA devices.3.instances.0.commandClasses.128.data.history.23 = 1377597161 (0x521c76e9)
[2013-08-27 09:52:41.837] SETDATA devices.3.instances.0.commandClasses.128.data.last = 23 (0x00000017)
[2013-08-27 09:52:42.032] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:52:42.032] SETDATA devices.3.instances.0.commandClasses.128.data.history.23 = 1377597162 (0x521c76ea)
[2013-08-27 09:52:42.033] SETDATA devices.3.instances.0.commandClasses.128.data.last = 23 (0x00000017)
[2013-08-27 09:52:42.113] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:52:42.114] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:52:42.114] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:52:42.114] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:52:42.115] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:52:42.116] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:52:42.328] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:52:42.328] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 09:52:42.329] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 09:52:42.329] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 09:52:42.330] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 09:52:42.331] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 09:52:42.385] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:52:42.386] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:52:42.386] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:52:42.386] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 59.000000
[2013-08-27 09:52:42.387] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:52:42.388] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:52:42.506] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:52:42.507] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 09:52:42.507] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 09:52:42.507] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 59.000000
[2013-08-27 09:52:42.509] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 09:52:42.509] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 09:52:42.566] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:52:42.567] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:52:42.568] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:52:42.568] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 22.200001
[2013-08-27 09:52:42.570] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:52:42.570] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:52:42.848] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:52:42.848] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 09:52:42.849] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 09:52:42.849] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 22.200001
[2013-08-27 09:52:42.851] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 09:52:42.851] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 09:52:42.885] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 09:52:42.885] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377597162 (0x521c76ea)
[2013-08-27 09:52:42.886] SETDATA devices.3.data.isAwake = True
[2013-08-27 09:52:42.886] SETDATA devices.3.data.lastSend = 686921 (0x000a7b49)
[2013-08-27 09:52:42.887] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377597162 (0x521c76ea)
[2013-08-27 09:52:42.999] SETDATA devices.3.data.lastSend = 686930 (0x000a7b52)
[2013-08-27 09:52:43.000] SETDATA devices.3.data.isAwake = False
[2013-08-27 10:00:41.828] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:00:41.829] SETDATA devices.3.instances.0.commandClasses.128.data.history.23 = 1377597641 (0x521c78c9)
[2013-08-27 10:00:41.829] SETDATA devices.3.instances.0.commandClasses.128.data.last = 23 (0x00000017)
[2013-08-27 10:00:41.931] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:00:41.931] SETDATA devices.3.instances.0.commandClasses.128.data.history.23 = 1377597641 (0x521c78c9)
[2013-08-27 10:00:41.931] SETDATA devices.3.instances.0.commandClasses.128.data.last = 23 (0x00000017)
[2013-08-27 10:00:42.013] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:00:42.013] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 10:00:42.013] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 10:00:42.013] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 10:00:42.016] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 10:00:42.016] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 10:00:42.180] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:00:42.180] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 10:00:42.182] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 10:00:42.182] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 10:00:42.184] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 10:00:42.184] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 10:00:42.257] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:00:42.257] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 10:00:42.257] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 10:00:42.257] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 57.000000
[2013-08-27 10:00:42.259] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 10:00:42.259] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 10:00:42.426] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:00:42.426] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 10:00:42.426] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 10:00:42.427] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 57.000000
[2013-08-27 10:00:42.428] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 10:00:42.428] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 10:00:42.496] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:00:42.497] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 10:00:42.499] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 10:00:42.499] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 22.600000
[2013-08-27 10:00:42.501] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 10:00:42.501] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 10:00:42.582] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:00:42.582] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 10:00:42.583] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 10:00:42.583] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 22.600000
[2013-08-27 10:00:42.585] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 10:00:42.585] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 10:00:42.602] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:00:42.602] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377597642 (0x521c78ca)
[2013-08-27 10:00:42.602] SETDATA devices.3.data.isAwake = True
[2013-08-27 10:00:42.603] SETDATA devices.3.data.lastSend = 725885 (0x000b137d)
[2013-08-27 10:00:42.603] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377597642 (0x521c78ca)
[2013-08-27 10:00:42.709] SETDATA devices.3.data.lastSend = 725894 (0x000b1386)
[2013-08-27 10:00:42.709] SETDATA devices.3.data.isAwake = False
[2013-08-27 10:04:41.823] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:04:41.823] SETDATA devices.3.instances.0.commandClasses.128.data.history.23 = 1377597881 (0x521c79b9)
[2013-08-27 10:04:41.823] SETDATA devices.3.instances.0.commandClasses.128.data.last = 23 (0x00000017)
[2013-08-27 10:04:41.923] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:04:41.924] SETDATA devices.3.instances.0.commandClasses.128.data.history.23 = 1377597881 (0x521c79b9)
[2013-08-27 10:04:41.924] SETDATA devices.3.instances.0.commandClasses.128.data.last = 23 (0x00000017)
[2013-08-27 10:04:42.005] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:04:42.006] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 10:04:42.007] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 10:04:42.007] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 10:04:42.009] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 10:04:42.009] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 10:04:42.172] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:04:42.173] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 10:04:42.173] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 10:04:42.173] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 10:04:42.174] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 10:04:42.175] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 10:04:42.254] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:04:42.255] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 10:04:42.255] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 10:04:42.255] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 56.000000
[2013-08-27 10:04:42.257] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 10:04:42.257] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 10:04:42.420] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:04:42.420] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 10:04:42.420] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 10:04:42.420] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 56.000000
[2013-08-27 10:04:42.422] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 10:04:42.422] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 10:04:42.485] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:04:42.485] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 10:04:42.486] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 10:04:42.487] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 22.700001
[2013-08-27 10:04:42.488] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 10:04:42.489] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 10:04:42.579] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:04:42.580] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 10:04:42.581] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 10:04:42.581] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 22.700001
[2013-08-27 10:04:42.583] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 10:04:42.583] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 10:08:39.987] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:08:39.988] SETDATA devices.3.instances.0.commandClasses.132.data.lastWakeup = 1377598119 (0x521c7aa7)
[2013-08-27 10:08:39.988] SETDATA devices.3.data.isAwake = True
[2013-08-27 10:08:39.988] SETDATA devices.3.data.lastSend = 764388 (0x000ba9e4)
[2013-08-27 10:08:39.989] SETDATA devices.3.instances.0.commandClasses.132.data.lastSleep = 1377598119 (0x521c7aa7)
[2013-08-27 10:08:40.094] SETDATA devices.3.data.lastSend = 764397 (0x000ba9ed)
[2013-08-27 10:08:40.095] SETDATA devices.3.data.isAwake = False
[2013-08-27 10:12:41.813] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:12:41.813] SETDATA devices.3.instances.0.commandClasses.128.data.history.23 = 1377598361 (0x521c7b99)
[2013-08-27 10:12:41.814] SETDATA devices.3.instances.0.commandClasses.128.data.last = 23 (0x00000017)
[2013-08-27 10:12:42.061] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:12:42.062] SETDATA devices.3.instances.0.commandClasses.128.data.history.23 = 1377598362 (0x521c7b9a)
[2013-08-27 10:12:42.062] SETDATA devices.3.instances.0.commandClasses.128.data.last = 23 (0x00000017)
[2013-08-27 10:12:42.147] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:12:42.147] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 10:12:42.147] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 10:12:42.147] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 10:12:42.149] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 10:12:42.149] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 10:12:42.332] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:12:42.332] SETDATA devices.3.instances.0.commandClasses.49.data.3.deviceScale = 1 (0x00000001)
[2013-08-27 10:12:42.333] SETDATA devices.3.instances.0.commandClasses.49.data.3.scale = 1 (0x00000001)
[2013-08-27 10:12:42.333] SETDATA devices.3.instances.0.commandClasses.49.data.3.val = 1000.000000
[2013-08-27 10:12:42.335] SETDATA devices.3.instances.0.commandClasses.49.data.3.scaleString = "Lux"
[2013-08-27 10:12:42.335] SETDATA devices.3.instances.0.commandClasses.49.data.3 = Empty
[2013-08-27 10:12:42.410] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:12:42.410] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 10:12:42.411] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 10:12:42.411] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 56.000000
[2013-08-27 10:12:42.413] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 10:12:42.413] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 10:12:42.504] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:12:42.506] SETDATA devices.3.instances.0.commandClasses.49.data.5.deviceScale = 0 (0x00000000)
[2013-08-27 10:12:42.506] SETDATA devices.3.instances.0.commandClasses.49.data.5.scale = 0 (0x00000000)
[2013-08-27 10:12:42.506] SETDATA devices.3.instances.0.commandClasses.49.data.5.val = 56.000000
[2013-08-27 10:12:42.507] SETDATA devices.3.instances.0.commandClasses.49.data.5.scaleString = "%"
[2013-08-27 10:12:42.508] SETDATA devices.3.instances.0.commandClasses.49.data.5 = Empty
[2013-08-27 10:12:42.566] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:12:42.566] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 10:12:42.567] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 10:12:42.568] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 22.600000
[2013-08-27 10:12:42.569] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 10:12:42.569] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 10:12:42.758] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
[2013-08-27 10:12:42.758] SETDATA devices.3.instances.0.commandClasses.49.data.1.deviceScale = 0 (0x00000000)
[2013-08-27 10:12:42.759] SETDATA devices.3.instances.0.commandClasses.49.data.1.scale = 0 (0x00000000)
[2013-08-27 10:12:42.759] SETDATA devices.3.instances.0.commandClasses.49.data.1.val = 22.600000
[2013-08-27 10:12:42.762] SETDATA devices.3.instances.0.commandClasses.49.data.1.scaleString = "°C"
[2013-08-27 10:12:42.762] SETDATA devices.3.instances.0.commandClasses.49.data.1 = Empty
[2013-08-27 10:16:41.805] SETDATA devices.3.data.lastReceived = 0 (0x00000000)
This is fixed in latest
This is fixed in latest version
