Debugger for Z-Way JavaScript
Re: Debugger for Z-Way JavaScript
Post by PoltoS » 29 Jun 2015 02:18
sudo netstat -natp
will show if 8183 is listened. Make sure your tunnel is set up correctly too. config.xml should contain 8183 in debug-port tag
Isaksson
Post by Isaksson » 29 Jun 2015 16:39
Hello.
Thanks for the support, it was the config.xml that did not have the debug-port.
pz1
Re: How I installed the node, npm & node-inspector on RPi
Post by pz1 » 29 Jul 2015 21:39
kambis wrote:I had to spend some hours to find out how to install the node-inspector on my RPi.
For others to have it faster done here how I did it:
I did try the Node installation as root following your well documented instruction.
The first part goes well, but the Inspector installation fails in a loop where it starts loading the node-tar again. After the third cycle I broke the loop with CTRL-C.
> utf-8-validate@1.1.0 install /opt/node/lib/node_modules/node-inspector/node_modules/ws/node_modules/utf-8-validate
> node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/0.10.26"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/node/lib/node_modules/node-inspector/node_modules/ws/node_modules/utf-8-validate/.node-gyp"
gyp http GET http://nodejs.org/dist/v0.10.26/node-v0.10.26.tar.gz
gyp http 200 http://nodejs.org/dist/v0.10.26/node-v0.10.26.tar.gz
Update 20150730:
Tried again with an alternative node.js install method found here, that should install the latest node.js. Also this one breaks on the node-inspector install.
pi@raspberry ~ $ wget http://node-arm.herokuapp.com/node_latest_armhf.deb
--2015-07-30 10:43:32--  http://node-arm.herokuapp.com/node_latest_armhf.deb
Resolving node-arm.herokuapp.com (node-arm.herokuapp.com)... 23.21.97.86
Connecting to node-arm.herokuapp.com (node-arm.herokuapp.com)|23.21.97.86|:80...        connected.
HTTP request sent, awaiting response... 200 OK
Length: 6728900 (6.4M) [application/x-debian-package]
Saving to: `node_latest_armhf.deb'
100%[======================================>] 6,728,900   1.88M/s   in 3.4s
2015-07-30 10:43:36 (1.88 MB/s) - `node_latest_armhf.deb' saved [6728900/6728900        ]
pi@raspberry ~ $ sudo dpkg -i node_latest_armhf.deb
Selecting previously unselected package node.
(Reading database ... 71697 files and directories currently installed.)
Unpacking node (from node_latest_armhf.deb) ...
Setting up node (0.12.6-1) ...
Processing triggers for man-db ...
pi@raspberry ~ $ node -v
v0.12.6
pi@raspberry ~ $ npm -v
2.11.2
pi@raspberry ~ $ sudo npm install -g node-inspector
^Cpi@raspberry ~ $
> v8-profiler@5.2.9 preinstall /usr/local/lib/node_modules/node-inspector/node_modules/v8-profiler
> v8-debug@0.5.0 preinstall /usr/local/lib/node_modules/node-inspector/node_modules/v8-debug
npm WARN optional dep failed, continuing default-browser-id@1.0.2
> utf-8-validate@1.1.0 install /usr/local/lib/node_modules/node-inspector/node_modules/ws/node_modules/utf-8-validate
> node-gyp rebuild
gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/0.12.6"
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/local/lib/node_modules/node-inspector/node_modules/ws/node_modules/utf-8-validate/.node-gyp"
make: Entering directory '/usr/local/lib/node_modules/node-inspector/node_modules/ws/node_modules/utf-8-validate/build'
  CXX(target) Release/obj.target/validation/src/validation.o
  SOLINK_MODULE(target) Release/obj.target/validation.node
  COPY Release/validation.node
make: Leaving directory '/usr/local/lib/node_modules/node-inspector/node_modules/ws/node_modules/utf-8-validate/build'
npm WARN engine xmlbuilder@2.2.1: wanted: {"node":"0.8.x || 0.10.x"} (current: {"node":"0.12.6","npm":"2.11.2"})
> bufferutil@1.1.0 install /usr/local/lib/node_modules/node-inspector/node_modules/ws/node_modules/bufferutil
> node-gyp rebuild
gyp WARN EACCES attempting to reinstall using temporary dev dir "/usr/local/lib/node_modules/node-inspector/node_modules/ws/node_modules/bufferutil/.node-gyp"
^Cpi@raspberry ~ $
pi@raspberry ~ $
The first irregularity I observed both in the first and second attempt was the warning:
Problem with linux is that developers always tell you to ignore warnings, but this one seems serious enough to mention I guess :mrgreen:
Update 20150730-2: Installation on Windows 7 no fun either. After successful node installation, it also failed on the node-inspector install
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\pz>node -v
v0.12.7
C:\Users\pz>npm -v
2.11.3
C:\Users\pz>npm install -g node-inspector
> v8-profiler@5.2.9 preinstall C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\v8-profiler
> v8-debug@0.5.0 preinstall C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\v8-debug
> bufferutil@1.1.0 install C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\ws\node_modules\bufferutil
> node-gyp rebuild
C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\ws\node_modules\bufferutil>if not defined npm_config_node_gyp (node "D:\programfiles\node_modules\npm\bin\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node  rebuild )
configure error
gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.
gyp ERR! stack     at failNoPython (D:\programfiles\node_modules\npm\node_modules\node-gyp\lib\configure.js:114:14)
gyp ERR! stack     at D:\programfiles\node_modules\npm\node_modules\node-gyp\lib\configure.js:69:11
gyp ERR! stack     at FSReqWrap.oncomplete (evalmachine.<anonymous>:95:15)
gyp ERR! System Windows_NT 6.1.7601
gyp ERR! command "node" "D:\\programfiles\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
gyp ERR! cwd C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\ws\node_modules\bufferutil
gyp ERR! node -v v0.12.7
gyp ERR! node-gyp -v v2.0.1
gyp ERR! not ok
npm WARN engine xmlbuilder@2.2.1: wanted: {"node":"0.8.x || 0.10.x"} (current: {"node":"0.12.7","npm":"2.11.3"})
> utf-8-validate@1.1.0 install C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\ws\node_modules\utf-8-validate
> node-gyp rebuild
C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\ws\node_modules\utf-8-validate>if not defined npm_config_node_gyp (node "D:\programfiles\node_modules\npm\bin\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node  rebuild )
gyp ERR! configure error
gyp ERR! cwd C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\ws\node_modules\utf-8-validate
gyp ERR! not ok
npm WARN optional dep failed, continuing bufferutil@1.1.0
npm WARN optional dep failed, continuing utf-8-validate@1.1.0
> v8-profiler@5.2.9 install C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\v8-profiler
> node-pre-gyp install --fallback-to-build
[v8-profiler] Success: "C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\v8-profiler\build\profiler\v5.2.9\node-v14-win32-ia32\profiler.
node" is installed via remote
> v8-debug@0.5.0 install C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\v8-debug
[v8-debug] Success: "C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\node_modules\v8-debug\build\debug\v0.5.0\node-v14-win32-ia32\debug.node" is installed via remote
C:\Users\pz\AppData\Roaming\npm\node-debug -> C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\bin\node-debug.js
C:\Users\pz\AppData\Roaming\npm\node-inspector -> C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector\bin\inspector.js
node-inspector@0.12.1 C:\Users\pz\AppData\Roaming\npm\node_modules\node-inspector
+-- path-is-absolute@1.0.0
+-- async@0.9.2
+-- debug@2.2.0 (ms@0.7.1)
+-- serve-favicon@2.3.0 (fresh@0.3.0, ms@0.7.1, parseurl@1.3.0, etag@1.7.0)
+-- semver@4.3.6
+-- strong-data-uri@1.0.1 (truncate@1.0.5)
+-- rc@1.1.0 (ini@1.3.4, strip-json-comments@0.1.3, deep-extend@0.2.11, minimist@1.1.2)
+-- which@1.1.1 (is-absolute@0.1.7)
+-- glob@5.0.14 (inherits@2.0.1, once@1.3.2, inflight@1.0.4, minimatch@2.0.10)
+-- yargs@3.15.0 (decamelize@1.0.0, camelcase@1.1.0, window-size@0.1.2, cliui@2.1.0)
+-- express@4.13.1 (fresh@0.3.0, escape-html@1.0.2, cookie@0.1.3, etag@1.7.0, merge-descriptors@1.0.0, utils-merge@1.0.0, array-flatten@1.1.0, parseurl@1.3.0, methods@1.1.1, cookie-signature@1.0.6, range-parser@1.0.2, path-to-regexp@0.1.6, vary@1.0.1, content-type@1.0.1, serve-static@1.10.0, content-disposition@0.5.0, depd@1.0.1, qs@4.0.0, on-finished@2.3.0, finalhandler@0.4.0, proxy-addr@1.0.8, send@0.13.0, accepts@1.2.11, type-is@1.6.5)
+-- ws@0.7.2 (options@0.0.6, ultron@1.0.2)
+-- biased-opener@0.2.6 (minimist@1.1.0, x-default-browser@0.3.0, browser-launcher2@0.4.5)
+-- v8-profiler@5.2.9 (nan@1.8.4, node-pre-gyp@0.6.9)
+-- v8-debug@0.5.0 (nan@1.8.4, node-pre-gyp@0.6.9)
C:\Users\pz>
NOTE: My Raspberry B has a fresh install on Rasbian release from May 2015\
Update 20150730-3
Tried the install on a fresh plain May 2015 Rasbian image. The installation of node-inspector failed following the same patteren.
Seems node-inspector is not compatible with this Rasbian release
Update 20150731
I found many users complaining about this problem on github. Seems it has something to do with npm or gyp. Someone reported the issue was fixed with node 0.12.4. I'll try to locate that version for Pi. On windows 7 I still had the error in v 0.12.7....
Update 20150731-2
I did find v 0.10.40 ( release 9th July 2015)build. That also ran in the node-gyp problem
pz1
Post by pz1 » 30 Jul 2015 15:48
PoltoS wrote:
sudo netstat -natp
Please update the description in the first post, because it is not mentioned there!
I quess this must be edited after every version update?
pz1
Post by pz1 » 31 Jul 2015 13:22
Isaksson wrote:Hello.
Could you tell me which Rasbian you are using? I can't get node-inspector installed
Isaksson
Post by Isaksson » 03 Aug 2015 10:29
Linux version 3.18.16-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #796 SMP PREEMPT Fri Jun 19 22:18:53 BST 2015
iam now going to install it on my developer pi.
pz1
Post by pz1 » 03 Aug 2015 11:25
Isaksson wrote:Linux version 3.18.16-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.8.3 20140303 (prerelease) (crosstool-NG linaro-1.13.1+bzr2650 - Linaro GCC 2014.03) ) #796 SMP PREEMPT Fri Jun 19 22:18:53 BST 2015
Apparantly I am on a different platform. My May 2015 standard Rasbian is on linux 3.18.11-v7+ and 3.18.11+ for Raspi2 and RaspiB respectively.
Isaksson
Post by Isaksson » 03 Aug 2015 22:01
I have now installed node-inspector on my developer machine.
One problem is that it seems that zway is not compatible with the new version of node-inspector 0.12.1 (not the error that you describe pz1 but it crashes when running).
So i did install the older version that i know is working.
npm install -g node-inspector@0.11.0
and now i have it up and running att thi machine also.
pz1, maybe you should try this command before you try to install node-inspector
npm set prefix ~/npm
pz1
Post by pz1 » 04 Aug 2015 13:44
Isaksson wrote:pz1, maybe you should try this command before you try to install node-inspector
Ended with the same problem:
Isaksson
Post by Isaksson » 04 Aug 2015 14:08
Are you using the standard account pi for this installation and also run the command npm install node-inspector without sudo?
