michap wrote:Please use Arduino 1.6.5
Michael
Hi Michael,
unfortunately I faced with troubles again.
Installed Arduino 1.6.5 with z-wave 0.6.3.
Bootloader not uploads. Errors:
java.lang.NullPointerException
at cc.arduino.packages.uploaders.SerialUploader.burnBootloader(SerialUploader.java:306)
at processing.app.Editor$59.run(Editor.java:2578)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Uploading the sketch stops and stage of compilation:
usage: compiler.exe [-h] {size,build,prog,boot,erase,readnvm} ...
compiler.exe: error: unrecognized arguments: and Settings\Admin\Application Data\Arduino15\packages\Z-Uno\hardware\zw8051\0.6.3 and Settings\Admin\Application Data\Arduino15\packages\Z-Uno\tools\zuno_toolchain\00.02.10/zuno_toolchain/sdcc/bin/
C:\Documents возвратил 2
Ошибка компиляции.
