Fibaro Dimmer 2 (FDG)-212 Fully supported
Re: Fibaro Dimmer 2 (FDG)-212 Fully supported
Can we help some how?
For me I manage to connect my Dimmer 2 after bypassing the not completed interviews. I can set the dim level within the z-wave.me interface but it is buggy as hell (I guess it got to do with the dimmer feeding back when I start typing a number), you can see in this video what I mean:
https://dl.dropboxusercontent.com/u/828 ... immer2.mov
Have any one the same issue (of you who manage to connect the dimmer 2 to your Razberry?
Hi all,
I have just received a box containing 3 of these dimmers, now having read this thread wondering if I should just send them back unopened.
I intended to use:
- One with a local load, plus a second switch controlling a TKB socket via association
- One with a local load controlled both by the local switch but primarily by an association on an Aeon Labs motion sensor
- One headless (i.e no switch) with local load controlled exclusively by an association on the same motion sensor
The first of those is a new install, the other two are replacing original (I.e not model "2") Fibaro dimmers which I'm then repurposing elsewhere - figured I'd switch as the above are LED loads and I'll move the original dimmers to a new spot with Halogens that need Z-waveing.
To anyone that has tried the new "2" dimmers, do you think the above is feasible with the current state, or should I send them back? I'm somewhat limited due to 2 wire install.
Many thanks in advance for any input.
I intended to use:
Reading back through the thread, it seems like that might work, but only until the device is rebooted for some reason, at which point it will need to be associated again. Is that a fair summary?
Thanks again.
Thanks again.
Hi there!benis wrote:For me I manage to connect my Dimmer 2 after bypassing the not completed interviews. I can set the dim level within the z-wave.me interface but it is buggy as hell (I guess it got to do with the dimmer feeding back when I start typing a number), you can see in this video what I mean:
that is something, that I experience with every dimmer and every roller shutter 2, so it's not isolated problem with the dimmer. It happens on my smartphone, tablet, Windows PC (Firefox, Chrome) and Linux PC. So I guess it's fair to say, it's either a problem with the software or the devices.
No, it's not. My interview with the dimmer is still incomplete, yet I use it without any problems. Only the expert GUI keeps complaining that the interview is incomplete.uchuff wrote:Reading back through the thread, it seems like that might work, but only until the device is rebooted for some reason, at which point it will need to be associated again. Is that a fair summary?
Thanks again.
I'd buy it again, as it works, even with incomplete interview. The Aeon Labs dimmer was included perfectly, yet couldn't dim my LED lights.
Regards,
rws
just quick update related to my 5 month old post, that i'm going to test FDG 212 with Z-Stick 2E usb controller.
My setup is Z-Stick connected to one of the USB ports of razberry. I stopped z-wave-server and installed Domoticz. I associated dimmer with Z-Stick using Domoticz and it worked without any visible errors.
Pity we are talking already 5th month about partial support of FDG212 in z-wave controller and nothing has changed.
PoltoS any update to this issue.
Can make the dimmer work fine, but would like have it finish the interview.
Modules with firmware 3.3 still have issues.
the biggest issues is that i cant set assosiations, tried the tip from geirgp (viewtopic.php?f=3423&t=22454#p60056).
But didn´t help.
But didn´t help.
I have 2 Fibaro 2 dimmers. I could include them, although the interview never completed. Actually the dimmers have different missing interview points, but still I could use them just fine with Zway 2.2.1. I could completely set them up in the expert mode, associate and all.
I upgraded recently to 2.2.3 and both started to behave erratically. I downgraded to 2.2.1 and all was fine again.
In 2.2.3 I couldn't use the expert mode either for these 2 devices.
Although the new zway version semms to be a good upgrade, somehow it can't get along with the fibaro dimmers. I had no time to debug it, so I'm not sure who to blame, I'll just had to switch back to 2.2.1.
I think I managed to get the associations working ok with a couple of Fibaro Dimmer 2's.
There are a few different lights in our lounge/diner, one set was controlled by a traditional dimmer one end and the other by a traditional dimmer at the other end. I have replaced the traditional dimmers with Fibaro Dimmer 2's, each still controlling their local load with Switch 1, with Switch 2 on each associated with instance 0 on the other dimmer, that way I can now control both set of lights from either end of the room.
Early days but I hope this sticks.
