v2.2.4 is out
pz1
Re: v2.2.4 is out
Post by pz1 » 30 Oct 2016 11:31
pierre2302 wrote:I get the message "Value Was changed to 240 but not Stored in device yet."
This is a normal response if you changed something on a battery driven device. So in case this is a baattery device, it should normally be written to the device the next time it wakes up automatically. Once in a while I have pushed the button write to device in the configuration screen.
Check the presently configured wake up interval. If it is very long, you may consider to reinclude the device, and set the interval much shorter temporarily, while you are playing with other settings.
pierre2302
Re: v2.2.4 is out
Post by pierre2302 » 30 Oct 2016 15:43
Thank you for your reply
These are the Aeon Labs Multi Sensor modules 1.18, they are powered by the USB socket in the interview tab there that are marked active and Wakeup time is set to 0 by default.
I also noticed that I can not seem to change the configuration of modules powered by the mains. Always the default value, which returns (eg fibaro FGD211 V1.9)
micky1500
Re: v2.2.4 is out
Post by micky1500 » 31 Oct 2016 18:00
I don't think this worked well before 2.2.4
Try setting parameter's using "Expert commands" instead of "configuration" Tab
Then in expert commands, scroll down to the configuration option.
When you set it here, the green light comes on as it receives the new setting.
snip sensor.jpg (40.2 KiB) Viewed 21529 times
Raspi 3(Stretch), Zwave.me 3.0.0
klaasjoerg
Re: v2.2.4 is out
Post by klaasjoerg » 01 Nov 2016 00:38
I do basically have the same issue on some (but not all) devices. Unable to set certain values - just jumping back to the old value. So I used the "Expert commands" to set values the though way, but that worked. Little bit strange still...
pierre2302
Re: v2.2.4 is out
Post by pierre2302 » 02 Nov 2016 06:19
Indeed from the expert commands menu it works.
Thank you ;)
pz1
Re: v2.2.4 is out
Post by pz1 » 02 Nov 2016 13:13
@pierre
" Raspi 2 (RaZberry) / Raspi B (Razberry) " With OpenRemote Free 2.2.0_TTS-Email-Serial and Z-Way 2.2.1-rc6
ZWay 2.2.1-rc6 seems to be a bit out of date
pierre2302
Re: v2.2.4 is out
Post by pierre2302 » 02 Nov 2016 16:03
signature amended :D
It seems to me that the period of this version (2.2.1) has the configuration worked normally :?
pz1
Re: v2.2.4 is out
Post by pz1 » 02 Nov 2016 16:45
pierre2302 wrote:It seems to me that the period of this version (2.2.1) has the configuration worked normally :?
For that reason, I did use 2.2.1-rc3 as a fall back version until recently.
ridewithstyle
Re: v2.2.4 is out
Post by ridewithstyle » 04 Nov 2016 00:44
Hi there,
I upgraded to 2.2.4 last night and noticed some strange behaviour.
All my 3 Fibaro FGS-222 suddenly reported "interview failed" in expert gui and started to grey out in standard gui and all the switches disappeared. It is as if they don't have any functionality anymore. The device descriptor is set to "Fibaro FGS222".
I re-did all interviews, they finished with the following
Basic, Configuration, ManufacturerSpecific, PowerLevel, Association, Version
seems like there is a switch missing, any ideas?
Thanks and kind Regards,
rws
[update]this is how it looks right now
[update2]requesting a NIF doesn't bring back the switches though I do see the request being answered from the FGS222.
2016-11-04 08_44_08-Z-Wave_NIF_Queue .png (7.89 KiB) Viewed 21456 times
2016-11-04 08_17_45-Z-Wave Smart Home .png (15.94 KiB) Viewed 21456 times
2016-11-04 08_14_33-Z-Wave Expert UI .png (29.63 KiB) Viewed 21456 times
2016-11-04 07_52_52-Grey-Devices.png (2.51 KiB) Viewed 21457 times
ridewithstyle
Re: v2.2.4 is out
Post by ridewithstyle » 04 Nov 2016 11:03
Hi there,
veeery strange. After digging into the command classes and the device descriptor I tried forcing a new interview (like for the 10th time, I wanted to see the network queue wile forcing a new interview) and suddenly all my switches are back. Why now? What was different? I don't know, it's a mystery to me.
Mods, feel free to delete or split my posts into a separate thread if you want to.
regards, rws
