Незавершенное интервью для AlarmSensor СС
freeman
Post by freeman » 21 Feb 2017 15:27
Добрый день,
Имеется Fibaro Routing Binary Sensor, по какой-то причине интервью на AlarmSensor СС на двух инстансах не завершается. Я пробовал с попапа 'View Interview Result' сделать форс интервью для данного CC при этом глядя в лог, ниже результат
[2017-02-21 11:06:29.600] [I] [zway] Adding job: Alarm Sensor Supported Get
[2017-02-21 11:06:29.603] [D] [zway] SENDING (cb 0x77): ( 01 0D 00 13 05 06 60 0D 00 01 9C 03 25 77 43 )
[2017-02-21 11:06:29.605] [D] [zway] RECEIVED ACK
[2017-02-21 11:06:29.609] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-02-21 11:06:29.609] [D] [zway] SENT ACK
[2017-02-21 11:06:29.609] [D] [zway] Delivered to Z-Wave stack
[2017-02-21 11:06:29.633] [D] [zway] RECEIVED: ( 01 07 00 13 77 00 00 02 9E )
[2017-02-21 11:06:29.633] [D] [zway] SENT ACK
[2017-02-21 11:06:29.633] [I] [zway] Job 0x13 (Alarm Sensor Supported Get): Delivered
[2017-02-21 11:06:29.633] [D] [zway] SETDATA controller.data.outgoingPacket.delivered = True
[2017-02-21 11:06:29.633] [D] [zway] SETDATA controller.data.outgoingPacket.deliveryTime = 20 (0x00000014)
[2017-02-21 11:06:29.634] [D] [zway] SETDATA controller.data.outgoingPacket.packetLength = 9 (0x00000009)
[2017-02-21 11:06:29.634] [D] [zway] SETDATA controller.data.outgoingPacket = **********
[2017-02-21 11:06:29.634] [D] [zway] SendData Response with callback 0x77 received: received by recipient
[2017-02-21 11:06:29.634] [D] [zway] SETDATA devices.5.data.lastSend = 5307520 (0x0050fc80)
[2017-02-21 11:06:29.634] [D] [zway] Job 0x13 (Alarm Sensor Supported Get): success
[2017-02-21 11:06:29.634] [I] [zway] Removing job: Alarm Sensor Supported Get
/: None (12:40)
    supported: true (12:40)
    version: 1 (12:40)
    security: false (12:40)
    interviewDone: false (12:40)
    interviewCounter: 9 (12:40)
    alarmMap: 0 (12:40)
    alarms: None (12:40)
Вроде же успешно проходит, почему тогда состояние интервью не завершенное? Пробовал перезагружать z-way-server, не помогло.
Подскажите как добиться того, чтобы устройство завершило интервью? Сообщите, если нужна какая-нибудь дополнительная информация.
Re: Незавершенное интервью для AlarmSensor СС
Post by PoltoS » 27 Feb 2017 23:53
AlarmSensor V1 давно устарел, он толком никем уже не поддерживается. Устройство тупо не отвечает на "Supported Get" - тут ничего не сделать, кроме как пнуть его ногой.
freeman
Post by freeman » 09 Mar 2017 15:31
Пнуть ногой это в прямом или в переносном смысле? Не понимаю свои последующие действия )
Post by PoltoS » 10 Mar 2017 00:19
увы, в прямом ;)
Похоже, с самим устройством проблема. А что за устройство? Universal Sensor или какое? Fibaro до сих пор все успешно работали в Z-Way, хотя именно Alarm и Alarm Sensor Они криво имплементировали и в некоторых устройствах они не в полной степени работали (но это был доп. функционал).
