Works well but unreliable
fehguy
Post by fehguy » 23 Jan 2018 08:47
Hi all,
I've been slowly expanding a z-wave deployment and now have over 50 devices connected to a razberry running on a Raspberry Pi 3. It works, mostly, but...
* Frequently devices just "go missing" on the console. They are not reachable until I re-include them.
* Restarting or having a power outage seems to really mess up the network. I'll get flickering lights and generally weird stuff.
I have replaced the hardware once and re-including everything brought temporary peace to the galaxy. But as stated above, it wasn't permanent.
Do others have this problem? What can be done to make this system more reliable? I can't imagine that mission-critical systems can rely on this. What if a device disappears when a heater is turned on? Will it just keep blowing hot air until someone comes to attend to it?
Z-Way software version 25.09.2017 v2.3.6
RaZberry2 Z-Wave Plus Daughter Card with 500-series chip
piet66
Re: Works well but unreliable
Post by piet66 » 23 Jan 2018 18:56
similar problems here.
Since some months after installing V2.3.6 I got several times 'dead' devices which I had to include again. At first I thought of defective devices, but in the meantime I suspect ZWay. I agree with you, the current software cannot be recommended for critical applications.
Raspbian GNU/Linux 9 (stretch)
ZMEERAZ 2016, SDK Version: 6.51.03, Serial API Version: 05.00
Z-Way version v3.0.0 from 2019-07-18 02:13:01 +0300 (build 146fa9b44605907737b17032131987cab573da1f)
fehguy
Post by fehguy » 23 Jan 2018 19:05
Surprisingly the v1.x software didn’t have this problem
aidem74
Post by aidem74 » 24 Jan 2018 00:35
Sadly I have the same problem with 60 devices and same version. I've asked for advice in this forum if anybody else have a solution on big system but no one answered. So I can't give you any advice. I 'm thinking of splitting my systems up in two or three networks. I already have the pi3+rzb2 for two nets just haven't got the time yet.
fehguy
Post by fehguy » 24 Jan 2018 04:00
Anyone switch to another piece of hardware? I'm not sure if the problem is the SW or hardware that is making this flaky. There are a bunch of zwave sticks out there, I can't imagine they are all this bad.
piet66
Post by piet66 » 24 Jan 2018 10:54
I have only 23 physical devices yet. So I don't think that dividing a network will help much.
bgr
Post by bgr » 27 Jan 2018 10:29
I am just getting started with this, but thinking already if I need reliability, range, and support for large number of devices, the Razberry and Z-Way is not the way to go. i'm getting under 10' in range on my Razberry and thinking I will need to solder on an antenna to reach my entire house. At the same time, browsing these forums and seeing user's frustrations makes me think I should start looking at a commercial solution like SmartThings. Does anyone have experience with other Z-wave hub products to compare and contrast to Razberry? I'm a home brew advocate, but with something like home control, a trusted, reliable solution is required.
Benny
Post by Benny » 30 Jan 2018 12:24
Ich switched to domoticz for same reasons. I have about 100 Devices and z-way is randomly stopped or has timeouts about 5 and more seconds...
Domoticz seems to working well, but I don't have the whole System running yet. So I can't say for sure it is a Hardware or Software issue...At this point I think this is a Software issue.
Eagle
Post by Eagle » 01 Feb 2018 13:22
of course in a forum, generally a place for solving problems, there a more negative than positive posts about reliability. I had my problems too at the beginning, but now im fully satisfied. I got around 50 devices now and my system is fully stable and reliable. Its running now for about 2 months without a single restart and its still very fast, respectivley not slowing down. There are some problems, especially right now with the webservice find.zwave, but i am convinced, that they will fix this too sooner or later.
I am using a UZB stick on a wd nas (2.3.6 beta)
Benny
Post by Benny » 18 Feb 2018 10:36
Most answers: I'm unhappy with my System. Your answer: I'm happy. But why? What didi you Do to solve the issues? Do you have automationed lights? That are my big problems, the timeouts when switching a light on. You won't recognized the timeouts when switching a shutter or a setpoint of Your Radiator...
