v.2.3.7 is out!
ronie
v.2.3.7 is out!
Post by ronie »
Dear Z-Way/RaZberry users, we are proud to announce a new release: v2.3.7!
In v2.3.7 we were focused on refactoring the look and feel of mobile app support. Also we've added italian and potuguese language support, a new section for wifi plugs added (TP-Link HS100, TP-Link HS110, EDIMAX SP1101, EDIMAX SP2101), did some fixes and enhancements in modules (Sonos, ScheduleScene, IfThen, LightScene, ...), made a bigger update of our postfixes, improved/fixed some connection or communication errors in z-way (speed of joining networks, Certification, Fixed problem with Security interview inside channels, ...) and finally add some more device descriptions (2000!).
Here is a short guidance about the new menus for wifi and mobile devices:
Both menus can be found under top right corner menu > Devices
Mobile device menus:
Use the row with the mobile phone icon to Add new or Manage your mobile devices
If you click on Add New a popp up will be opened where you can create a new QR code for your mobile device or use the buttons under the description to download our mobile app in Google's Play Store or Apple's App Store (Don't be confused about brands an logos, the software is the same. We'll try to release corrected ones as soon as possible.)
After clicking Create QR Code you will be prompted to enter your password for your account
and after clicking OK the QR code occurs with a green flight in label in the top right corner with the message that your input was successful
After you've successfully added your mobile device you will se two widgets for each of them (one is the scene trigger and the other one indicates if you mobile device has local or remote access) in your devices overview
Finally you can manage your mobile devicee under top right corner menu > Devices > Manage (in row with the mobile phone icon) to get to the already known configuration setup
Wifi device menus:
Use the row with the wifi plug icon to Add new or Manage your mobile devices
A click on Add New will guide you to a list with all currently supported wifi plugs
Click in the row of your choice with your prefered plug on the right icon to open it's configuration menu
after adding the plug successfully (IP of the plug is needed) they will occur in the devices overview as a binary switch
Use the Manage button in the wifi plug menu to call the list of your included wifi plugs. Use the right buttons to configure, en-/disable or remove them.
(All scrreenshots were made with DarkSHUI skin - You can find some more skins under Menu > Customize > Online skins ;) )
As usually, we keep full backward compatibiliy with previous releases, so you are safe to update.
For more information please have a look at the full change log (also available here: http://razberry.z-wave.me/z-way-server/ChangeLog)
We'll also try to release this update for all outstanding plattforms as soon as possible :)
We hope you'll enjoy v2.3.7 and we're excited to your feedback.
Big thank's for your support!
Best regards your
Z-Wave.Me Team
PS:
If somebody of you want's to learn more about how to built home automation modules or about our design features skins and icons, please checkout this link below:
https://developer.z-wave.me/?uri=help
https://developer.z-wave.me offers you also the possibility to upload your home automation apps and to share them with all other users.
Provo
Re: v.2.3.7 is out!
Post by Provo »
ronie wrote:
21 Mar 2018 11:58
I'm having issues with exactly that: https://forum.z-wave.me/viewtopic.php?f=3419&t=26243
It won't let me update a module.
micky1500
Re: v.2.3.7 is out!
Post by micky1500 »
Issues I reported under the "Re: v2.3.6 is out!" thread are still broken and have not been working since 2.3.5 '5 months'
Have they been forgotten in this 2.3.7 build ?
Job Queue doesn't show active jobs. Was working fine on 2.3.5
Route Map doesn't show any details. Older version of Route worked on 2.3.5
Poltos said 15/10/2017.. @micky1500: seems Route Map feature have a problem with RSSI values. We will check it and make a small patch to fix this.
Ronnie Said 26/10/2017.. @micky1500 Oh, yes there is a bug. Seems the JobQue is requested regularly but there is no or only a very delayed update ...
We've already found the reason and will fix it.
I know most of my posts are complaints :(
But it's not meant badly.
I have a lot of things that work too. I thank you guys for that.
ronie
Re: v.2.3.7 is out!
Post by ronie »
Hi micky1500,
Did you already cleaned your browsers cache?
Unfortunately this is a necessary procedure when working with AngularJS Framework in a UI.
BR
ronie
micky1500
Re: v.2.3.7 is out!
Post by micky1500 »
Yes I have Cleared Browser Cache.
Tried with Chrome and MS-Edge.
I have 50 Devices present.
Job Queue and Route Map(old version) worked fine back on 2.3.5
Micky
iblis
Re: v.2.3.7 is out!
Post by iblis »
So where can we download the final release? ;)
Cmax74
Re: v.2.3.7 is out!
Post by Cmax74 »
i cant see it ?
Raspi 3, Zwave.me 4.1.0.
sploff
Re: v.2.3.7 is out!
Post by sploff »
Have same problem and if i typ v.2.3.7 it starts but it result in a error.
Tried edge and chrome browsers and its same result.
v237 error.PNG (41.94 KiB) Viewed 43885 times
aLiEnHeAd
Re: v.2.3.7 is out!
Post by aLiEnHeAd »
latest version on https://oldrazberry.z-wave.me/z-way-server/?C=M;O=D is 2.3.7 rc8. is this the final version ?
and
downloads 2.3.6 :roll:
Z-Wave Support
Re: v.2.3.7 is out!
Post by Z-Wave Support »
The rollout was stopped. We found a critical bug.
KR
Z-Wave Support
Locked
