Did z-way factory reset my Philio PAN08?
Genius
Post by Genius » 28 Mar 2018 21:10
Hey there,
yesterday my Philio PAN08 Roller shutter controller failed, it failed already 3 months ago, where I just factory reseted the device by hand without looking for the reason it failed.
But this time I took a look in the log file and it seems that out of nowwhere z-way did a reset of the device or how should I interpret this:
[2018-03-27 07:24:21.205] [D] [zway] SETDATA devices.8.instances.0.commandClasses.90.data.reset = True
[2018-03-27 07:24:21.224] [core] Notification: error (connection): User reset to factory defaults Z-Wave device ID: 8
After this command the device stopped working, any idea whats wrong here?
Here's the log file for the interesting time:
https://www.dropbox.com/s/qp4mldq6ujj45 ... r.log?dl=0
Best Regards
Patrick
Re: Did z-way factory reset my Philio PAN08?
Post by PoltoS » 29 Mar 2018 05:23
This means that your device entered (usually by button combination) in factory reset mode and just before resetting itself it has informed Z-Way about that.
Z-Way is just making that note for you so you know it was resetted manually and should not be deleted as Failed from Z-Way.
Popp Wod
Post by Popp Wod » 29 Mar 2018 17:35
interesting, I use to have the same issues with these devices more or less regularly.
Unfortunately I do not know how to access the logfile.
But I recognised by exchanging the device against another one, that the issues might be related to the device location. So I identified my bathroom as a week spot. So the device that had the issues worked perfectly in the other location whereas the device that used to work fine failed in the bathroom.
So I actually think the issue might be related to the network strength/coverage somehow. Maybe including additional activators inbetween the suspicious PAN08 and the controller might help.
piet66
Post by piet66 » 01 Apr 2018 22:04
I had the same case with a Qubino Double Relay Switch some time ago. What I don't understand: why should the device do a reset on poor connection?
Raspbian GNU/Linux 9 (stretch)
Z-Way version v2.3.8 from 2018-10-10 00:47:52 +0300 (build 854d8c466afa676694043ff7a9d17febb3bb01d6)
Post by PoltoS » 02 Apr 2018 10:14
I think somebody clicked on it the special sequence.
piet66
Post by piet66 » 02 Apr 2018 11:58
That's completely impossible.
Device is mounted closed in the wall without any physical switch. It is only accessed via Z-Way.
