There any way to Over the Air upgrade the Z-UNO sketch without pressing service button 3 times?
Thanks.
OTA Sketch Upgrade
Re: OTA Sketch Upgrade
I can use the parameter #20 in the sketch update? Because i try with several sketch and does not work and the triple click works.
I set the parameter and update in the zway.
"by setting any value to parameter #20 just before the process."
What does "just before the process " mean? 1 second?
In the zway i get this:
[2018-05-02 12:06:32.965] [zway] Job 0x13 (Firmware Update Metadata Request Get): Delivered
[2018-05-02 12:06:32.965] [D] [zway] SendData Response with callback 0x4c received: received by recipient
[2018-05-02 12:06:32.965] [D] [zway] SETDATA devices.6.data.lastSendInternal = **********
[2018-05-02 12:06:32.965] [D] [zway] Job 0x13 (Firmware Update Metadata Request Get): success
[2018-05-02 12:06:32.966] [zway] Waiting for job reply: Firmware Update Metadata Request Get
[2018-05-02 12:06:34.579] [D] [zway] Job 0x13: deleted from queue
[2018-05-02 12:06:34.680] [D] [zway] Job 0x13: deleted from queue
[2018-05-02 12:06:35.092] [W] [zway] Reply not received before timeout for job (Firmware Update Metadata Request Get)
What i am doing wrong?
Thanks.
Thanks.
Not a solution to your problem, but as a comment to OTA update of sketches:
I just put the question to Fibaro how to make use of the OTA mechanism in their Home Center 2 controller for us developers. Their response is that it is not possible because they only support OTA for their own products.
It is a strange approach if you ask me and it makes the HC2 a little less appealing as a target environment.
@donic46 : BTW: What Gateway you are using - with what relase?
Michael
Michael
Gateway: Raspberry Pi 3
Z-Way version: v2.3.7
Are you sure to use target #1 ? What version of Z-Uno bootloader?
Yes i choose target #1.
Z-Uno version: v2.1.3
Still checking it internally. We will get to you once he check it
