im on a pi3, razberry2 setup.
i have gotten it all to start up farily good, get the unable to load data message quite often while browsing the dashboard.
i cant add devices, and have tried several.
can i somehow start over and removing all the zwave.me stuff and try again?
Start all over
Re: Start all over
Please show logs. May be also provide remote access
Re: Start all over
where can i find the logs for this specific topic?
Re: Start all over
logs are at /var/log/z-way-server.log
To start all over, I think it is sufficient to remove or rename /opt/z-way-server/ and run again
Re: Start all over
im not so good at linux at all, how and where do i access the logs?
Re: Start all over
you could use WINSCP https://winscp.net/eng/download.php to connect to your RasPi and copy the logfile from /var/log/ to your windows system...
