SHT21 HTU21
Gotty101
SHT21 HTU21
Post by Gotty101 »
Hi hopefully someone will be able tohelp me as im at a blank at the mo. Ive bought the following sensor (link below) and mine came with the HTU21 chip
https://www.ebay.com/itm/SHT21-HTU21-Di ... :rk:3:pf:0
Its got a built in voltage regulator so ive connected it to +5v and ground. Ive then connected SCL to pin 9 and SCA to pin 10. I then used the following library (https://learn.adafruit.com/adafruit-htu ... g-and-test) which compiles and uploads to to the zuno fine.
Only problem is i just get the following output
Temp: -46.85 C Humidity: -6.00 %
Which shows its not actually getting the right value as i would be rather cold. Ive even tried I2C pull ups on SCL and SDA pins to 3.3v and its still the same. So basically has anyone managed to use this chip with a Zuno?
Ive successfully got the BH1750 I2C light sensor and INA219 voltage current sensor working fine. This is just the last main sensor to try and i can move forward with my project.
Many thanks
Trev
Gotty101
Re: SHT21 HTU21
Post by Gotty101 »
Hi just update. I've tried another sensor in case I had a bad one, and also with the sensor on the i2c bus on it's own with the pull up resistors and without. No matter I just get the same result.
Re: SHT21 HTU21
Are you using some library like DHT11/22 or you are reading I2C? Please check the specs for your sensor
CHGWorker
Re: SHT21 HTU21
Post by CHGWorker »
Hi Trev,
i note from your post that you have managed to get the INA219 working in your z0uno. Could you kindly advise the code and where to get the library as the adafruit library does not seem to work with the z-uno.
Many Thanks
