After v2.3.7 the z-way installation package structure was changed for maintainance reasons from simple *.tgz into debian packages.
Also some newer libs are used now which are not supported by Wheezy (Debian 7). So this distribution won’t be supported anymore by default as before, which means an upgrade to Jessie (Debian 8) is necessary if you still want support for your Z-Way.
This instruction should help you to migrate your old system to the other.
Revert a faulty v2.3.8 upgrade - e.g. done on Wheezy
If you unfortunately tried to upgrade to v2.3.8 and your hub seems to be broken now then please follow these Receipe to roll the update back tov2.3.7:
Revert a Z-Way upgrade with help of the terminal
Make your box ready for v2.3.8
An upgrade from Wheezy to Jessie is necessary if you still want to use the latest Z-Way . It is recommented to do backups before (Smart Home UI > Menu > Management > Backup > Cloudbackup or Local Backup / Expert UI > Network > Control > Create Backup). Please follow the next instructions below to upgrade your system.
!!Attention!! This update can take up to 2 hours or more. Making a copy of your SD card before is recommented.
Follow these steps below to upgrade wheezy to jessie:
- Get up to date:
$ sudo apt-get update $ sudo apt-get upgrade $ sudo apt-get dist-upgrade - Verify nothing is wrong. Verify no errors are reported after each command. Fix as required (you’re on your own here!).
$ dpkg -C $ apt-mark showhold - Optionally upgrade the firmware.
$ sudo rpi-update - Prepare apt-get
Update the sources to apt-get. This replaces "wheezy" with "jessie" in the repository locations giving apt-get access to the new version’s binaries.Code: Select all
$ sudo sed -i 's/wheezy/jessie/g' /etc/apt/sources.list $ sudo sed -i 's/wheezy/jessie/g' /etc/apt/sources.list.d/*.list - Verify this caught them all. Run the following, expecting no output. If the command returns anything having previously run the sed commands above, it means more files may need tweaking. Run the sed command for each.
$ sudo grep -lnr wheezy /etc/apt - Do the Upgrade:
$ sudo apt-get update && sudo apt-get upgrade -y $ sudo apt-get dist-upgrade -y
some user prompts during the installation may occur (handle on your own choice):
popp hub 1 users can usally accept with yes or YCode: Select all
no ssh for root user: yes/no >>yes some services needs to be restarted: yes/no >> yes Configuration file '/etc/skel/.bashrc' ==> Modified (by you or by a script) since installation. ==> Package distributor has shipped an updated version. What would you like to do about it ? Your options are: Y or I : install the package maintainer's version N or O : keep your currently-installed version D : show the differences between the versions Z : start a shell to examine the situation The default action is to keep your current version. *** login.defs (Y/I/N/O/D/Z) [default=N] ? >> Y Configuration file '/etc/sysctl.conf' ==> Modified (by you or by a script) since installation. ==> Package distributor has shipped an updated version. What would you like to do about it ? Your options are: Y or I : install the package maintainer's version N or O : keep your currently-installed version D : show the differences between the versions Z : start a shell to examine the situation The default action is to keep your current version. *** login.defs (Y/I/N/O/D/Z) [default=N] ? >> Y Configuration file '/etc/login.defs' ==> Modified (by you or by a script) since installation. ==> Package distributor has shipped an updated version. What would you like to do about it ? Your options are: Y or I : install the package maintainer's version N or O : keep your currently-installed version D : show the differences between the versions Z : start a shell to examine the situation The default action is to keep your current version. *** login.defs (Y/I/N/O/D/Z) [default=N] ? >> Y Configuration file '/etc/xdg/openbox/LXDE/rc.xml' ==> Modified (by you or by a script) since installation. ==> Package distributor has shipped an updated version. What would you like to do about it ? Your options are: Y or I : install the package maintainer's version N or O : keep your currently-installed version D : show the differences between the versions Z : start a shell to examine the situation The default action is to keep your current version. *** rc.xml (Y/I/N/O/D/Z) [default=N] ? >> Y Configuration file '/etc/xdg/pcmanfm/LXDE/pcmanfm.conf' ==> Modified (by you or by a script) since installation. ==> Package distributor has shipped an updated version. What would you like to do about it ? Your options are: Y or I : install the package maintainer's version N or O : keep your currently-installed version D : show the differences between the versions Z : start a shell to examine the situation The default action is to keep your current version. *** pcmanfm.conf (Y/I/N/O/D/Z) [default=N] ? >> Y Configuration file '/etc/dphys-swapfile' ==> File on system created by you or by a script. ==> File also in package provided by package maintainer. What would you like to do about it ? Your options are: Y or I : install the package maintainer's version N or O : keep your currently-installed version D : show the differences between the versions Z : start a shell to examine the situation The default action is to keep your current version. *** dphys-swapfile (Y/I/N/O/D/Z) [default=N] ? >> Y Configuration file '/etc/nginx/sites-available/default' ==> Deleted (by you or by a script) since installation. ==> Package distributor has shipped an updated version. What would you like to do about it ? Your options are: Y or I : install the package maintainer's version N or O : keep your currently-installed version D : show the differences between the versions Z : start a shell to examine the situation The default action is to keep your current version. *** default (Y/I/N/O/D/Z) [default=N] ? >> Y Configuration file '/etc/lightdm/lightdm-gtk-greeter.conf' ==> Modified (by you or by a script) since installation. ==> Package distributor has shipped an updated version. What would you like to do about it ? Your options are: Y or I : install the package maintainer's version N or O : keep your currently-installed version D : show the differences between the versions Z : start a shell to examine the situation The default action is to keep your current version. *** lightdm-gtk-greeter.conf (Y/I/N/O/D/Z) [default=N] ? >> Y - Cleanup old outdated packages.
$ sudo apt-get autoremove -y && sudo apt-get autoclean - Verify with
the updated Firmware.
$ cat /etc/os-release - You’ve come this far, might as well get the latest firmware.
$ sudo rpi-update
Finally update z-way to latest POPP version (v2.3.8)
$ wget -q -O - http://z-way.z-wave.me/z-way/popp_rpi/v2.3.8-rcFINAL-internal/install | sudo bashCode: Select all
$ wget -q -O - http://z-way.z-wave.me/z-way/razberry/latest/install | sudo bashcheck the z-way-server log
$ tail -f /var/log/z-way-server.log // cancel with [Ctrl] + [C]http://[IP]:8083/smarthome/#/events
http://[IP]:8083/expert
that there are no Error Messages about Z-Way or Z-Way Binding (You will also recognize it because your Z-Wave devices aren't available)
Otherwise follow the steps in the Error Message. Serial port for UZB is /dev/ttyACM0 and for RaZberry /dev/ttyAMA0.
If the z-way binding is ok but the port has gone (null) > check the console log with the command above
Check if /boot/cmdline.txt is not empty and that the content is similar to the content below.
Simply open the nano editor and check the content:
$ sudo nano /boot/cmdline.txt
// content
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwaitIf you will be asked to store your changes type Yes and press enter. Also agree by pressing [Enter] if the file will be overwritten.
If a change was necessary, reboot the box
$ sudo rebootsupport(at)z-wave.eu (DE/EN)
razberry(at)z-wave.me (RU/EN/FR)
Or try to search our forums to find a suitable solution:
http://forum.z-wave.me/ (EN/RU/DE/FR/IT/CN)
http://zwave.de/forum/ (DE)
Anleitung in deutsch: Wie man von Wheezy nach Jessie migriert, um Z-Way v2.3.8 nutzen zu können
