Before I buy - TKB Home thermostats
Anyone who has experience with TKB Thermostats in z-way? Just want to ask before I buy.
Re: Before I buy - TKB Home thermostats
Cant say anything for the tkb. But i got 2 mcohome mh7 v2 for my underfloor heating in the bathrooms, which work flawlessly! Might take them into your consideration
Does MCO thermostat show relay status?
No, it just shows 4 premade elements:
Heating On/Off switch, this does not show relay status
humidity
temperature
and set thermostat temperature
but, there is a CommandClass called ThermostatOperatingState, where relay status is saved. You could load a custom javascript and save this 1 or 0 to a dummy device.
humidity
temperature
- Mcohome.PNG (28.03 KiB) Viewed 14313 times
Thank you for your answer. Java is nothing for me. I might need relay status for a logical boiler control.
