AutoPID Librairy
CaptainIgloo
AutoPID Librairy
Post by CaptainIgloo »
Hi all,
I would like use AutoPID Library (http://ryandowning.net/AutoPID/) in Z-uno project.(#include <AutoPID.h> in my .ino)
error in compiling :
Preprocessing file: C:\Users\3l33t\AppData\Local\Temp\arduino_build_733351\AutoPID.cpp with SDCPP...
Compiling C:\Users\3l33t\AppData\Local\Temp\arduino_build_733351\AutoPID_sdcpp_.cpp ...Unknown error:'class AutoPID' uCxx returned error code:-1
Have you solution ?
Best,
Captainigloo
CaptainIgloo
Re: AutoPID Librairy
No idea ?
The library requires adoption to work with Z-Uno. We will check it (it is pretty small)
CaptainIgloo
Little but strong ! Thanks @Poltos
rrozema
Post by rrozema »
I'm awaiting a port to Z-Uno too! Combined with OpenTerm library (which also needs to be ported) this makes an awesome way to create your own Z-Wave enabled thermostat.
Can you point us to the OpenTherm library that works ok in Arduino. This is indeed an important feature and we thought about it.
rrozema
Post by rrozema »
@poltos: I had already created a topic on that library. This was the library that doesn't compile on z-uno's 2.1.4 toolset. You replied yourself, that the header and cpp files needed to be copied into specific z-uno locations, plus that for missing functions detachInterrupt, attachInterrupt and digitalPinToInterrupt for a replacement should come available from 2.1.5. But also that micros() is not available at all yet. And finally yield that is also not supported yet for z-uno but could probably be tricked.
https://forum.z-wave.me/viewtopic.php?f ... 0917ee94dc
Yes, replied to that one few minutes after replying to this post. We are already looking on this topic to see if we can add most of you need.
