Interview incomplete - Fibaro Universal Sensor FGBS-001
Spirit78
Re: Interview incomplete - Fibaro Universal Sensor FGBS-001
Post by Spirit78 » 20 Jan 2019 18:55
Hom is it done?
I try the link with my ip-adress but it doesn´t work. I guess I must type in the sensor number somewhere? But how?
I would like to try bruteforce too, though the interview stucks at 86%
enbemokel
Post by enbemokel » 21 Jan 2019 14:00
ip:8083/JS/Run/zway.devices"NNN".instances"III".AlarmSensor.data.interviewDone
Hi, yes, you should exchange the IP address in the biginning, with your real Ip address.
NNN must be exhaged with your device ID an the instance you have to try from 1 to 4. This worked for me.
Spirit78
Post by Spirit78 » 22 Jan 2019 01:23
Thanks! I will try tomorrow.
NNN, is it #14 for example? And its just to try I, II, III and IIII?
enbemokel
Post by enbemokel » 22 Jan 2019 16:51
Yes, NNN is 14 for example, I´m not sure if i try instances with 1 2 3 4 or I II III IV or IIII
But you will see it in the browser.
Also, the link was incomplete, you have to type in at the end = true
ip:8083/JS/Run/zway.devices"NNN".instances"III".AlarmSensor.data.interviewDone = true
Spirit78
Post by Spirit78 » 24 Jan 2019 23:47
Thank´s Now finally it worked for me too :)
Spirit78
Post by Spirit78 » 27 Jan 2019 01:10
Thats what I thougt too at last. But mine were working in previous versions so it got a little strange. But the link did it for me👍
Willem_K
Post by Willem_K » 14 Feb 2019 17:23
I tried the link above (double checked it) but I get "SyntaxError: Unexpected string".
http://192.168.1.200:8083/JS/Run/zway.d ... wDone=true
What am I doing wrong?
enbemokel
Post by enbemokel » 14 Feb 2019 17:44
http://ip:8083/JS/Run/zway.devices[NNN] ... wDone=true
I think because i changed the [ with " to explain it.
Willem_K
Post by Willem_K » 14 Feb 2019 20:28
Aha, that was the trick. That worked. The tab "configuration" however doesn't get populated unfortunately. It says "This device doesn't have the necessary service".
enbemokel
Post by enbemokel » 15 Feb 2019 12:54
Yes, you may configure it with the Expert Commands menu
