config.json unnecessarily large cause of old devices
piet66
Post by piet66 » 07 Feb 2019 13:11
In my config.json there is a very large number of physical and virtual devices which are not existing any more for long time.
It doesn't seem to have any negative effect. But I don't think it's good. The file is unnecessarily large.
Is there a possibility to clean it?
Raspbian GNU/Linux 9 (stretch)
ZMEERAZ 2016, SDK Version: 6.51.03, Serial API Version: 05.00
Z-Way version v3.0.0 from 2019-07-18 02:13:01 +0300 (build 146fa9b44605907737b17032131987cab573da1f)
Re: config.json unnecessarily large cause of old devices
Post by PoltoS » 11 Feb 2019 05:31
Normally when Z-Wave Binding module is removing Z-Wave Devices it cleans this info. But other modules do not. This is because we do not have any onRemove event. So currently it is not possible
piet66
Post by piet66 » 11 Feb 2019 12:13
In my config.json there are at the moment totally 650 devices mentioned in vdevInfo and in profiles, 249 of these devices are existing at the moment, 401 devices are no longer existing and could be removed.
Here a list of the old devices (incomplete):
You can see at the end, that there are even physical devices, which are no more existing.
Seems that removal doesn't work correctly.
If it's not possibly to remove the devices at once, would be useful to have a cyclic function for cleaning up.
List: 401 old devices in config.json, sorted by id
    "AdvancedThermostatDevice_Switch_116",
    "AdvancedThermostatDevice_Switch_54",
    "AdvancedThermostatDevice_Thermostat_116",
    "AdvancedThermostatDevice_Thermostat_54",
    "BatteryPolling_135",
    "ConditionSwitch_130",
    "ConditionSwitch_132",
    "ConditionSwitch_48",
    "ConditionSwitch_49",
    "ConditionSwitch_50",
    "ConditionSwitch_86",
    "Configurator_445",
    "DummyDevice_27",
    "DummyDevice_36",
    "EnhancedThermostatDevice_Switch_56",
    "EnhancedThermostatDevice_Thermostat_56",
    "ForecastIO_barometer_152",
    "ForecastIO_cloudCover_152",
    "ForecastIO_current_152",
    "ForecastIO_forecastHigh_152",
    "ForecastIO_forecastLow_152",
    "ForecastIO_forecast_152",
    "ForecastIO_humidity_152",
    "ForecastIO_solar_152",
    "ForecastIO_wind_152",
    "Multiline_147",
    "Multiline_156",
    "Multiline_157",
    "Multiline_158",
    "Multiline_159",
    "Multiline_160",
    "Multiline_189",
    "Multiline_194",
    "Multiline_209",
    "Multiline_213",
    "Multiline_216",
    "Multiline_219",
    "Multiline_247",
    "Multiline_249",
    "Multiline_271",
    "Multiline_355",
    "Multiline_67",
    "Multiline_68",
    "Multiline_69",
    "Multiline_94",
    "OpenWeatherDaylight_406",
    "OpenWeather_406",
    "Presence_night_34",
    "Presence_night_63",
    "Presence_presence_34",
    "Presence_presence_63",
    "Presence_vacation_34",
    "Presence_vacation_63",
    "ThermostatControl_Switch_54",
    "ThermostatControl_Switch_55",
    "ThermostatControl_Thermostat_54",
    "ThermostatControl_Thermostat_55",
    "ThermostatDevice_55",
    "TimerSwitch_133",
    "TimerSwitch_23",
    "TimerSwitch_310",
    "TimerSwitch_312",
    "TimerSwitch_51",
    "TimerSwitch_52",
    "WeatherUnderground_barometer_59",
    "WeatherUnderground_barometer_62",
    "WeatherUnderground_current_59",
    "WeatherUnderground_current_62",
    "WeatherUnderground_feelslike_62",
    "WeatherUnderground_forecastHigh_59",
    "WeatherUnderground_forecastHigh_62",
    "WeatherUnderground_forecastLow_59",
    "WeatherUnderground_forecastLow_62",
    "WeatherUnderground_forecastToday_62",
    "WeatherUnderground_forecast_59",
    "WeatherUnderground_forecast_62",
    "WeatherUnderground_humidity_59",
    "WeatherUnderground_humidity_62",
    "WeatherUnderground_solar_59",
    "WeatherUnderground_solar_62",
    "WeatherUnderground_uv_59",
    "WeatherUnderground_uv_62",
    "WeatherUnderground_wind_59",
    "WeatherUnderground_wind_62",
    "ZWayVDev_zway_10-0-113-4-2-A",
    "ZWayVDev_zway_10-0-113-4-6-A",
    "ZWayVDev_zway_10-0-113-6-Door-A",
    "ZWayVDev_zway_10-0-113-7-3-A",
    "ZWayVDev_zway_10-0-113-9-1-A",
    "ZWayVDev_zway_10-0-128",
    "ZWayVDev_zway_10-0-156-0-A",
    "ZWayVDev_zway_10-0-48-1",
    "ZWayVDev_zway_10-0-49-1",
    "ZWayVDev_zway_11-0-128",
    "ZWayVDev_zway_11-0-48-1",
    "ZWayVDev_zway_11-0-49-1",
    "ZWayVDev_zway_12-0-113-4-2-A",
    "ZWayVDev_zway_12-0-113-4-6-A",
    "ZWayVDev_zway_12-0-113-6-Door-A",
    "ZWayVDev_zway_12-0-113-7-3-A",
    "ZWayVDev_zway_12-0-113-9-1-A",
    "ZWayVDev_zway_12-0-128",
    "ZWayVDev_zway_12-0-156-0-A",
    "ZWayVDev_zway_12-0-48-1",
    "ZWayVDev_zway_12-0-49-1",
    "ZWayVDev_zway_14-0-37",
    "ZWayVDev_zway_14-0-49-1",
    "ZWayVDev_zway_14-0-50-0",
    "ZWayVDev_zway_14-0-50-2",
    "ZWayVDev_zway_14-1-37",
    "ZWayVDev_zway_14-1-50-0",
    "ZWayVDev_zway_14-1-50-2",
    "ZWayVDev_zway_14-2-37",
    "ZWayVDev_zway_14-2-50-0",
    "ZWayVDev_zway_14-2-50-2",
    "ZWayVDev_zway_14-3-49-1",
    "ZWayVDev_zway_15-0-113-6-Door-A",
    "ZWayVDev_zway_15-0-128",
    "ZWayVDev_zway_17-0-113-7-3-A",
    "ZWayVDev_zway_17-0-128",
    "ZWayVDev_zway_17-0-48-1",
    "ZWayVDev_zway_17-0-49-1",
    "ZWayVDev_zway_17-0-49-27",
    "ZWayVDev_zway_17-0-49-3",
    "ZWayVDev_zway_17-0-49-5",
    "ZWayVDev_zway_19-0-113-4-2-A",
    "ZWayVDev_zway_19-0-113-4-6-A",
    "ZWayVDev_zway_19-0-113-6-Door-A",
    "ZWayVDev_zway_19-0-113-7-3-A",
    "ZWayVDev_zway_19-0-113-9-1-A",
    "ZWayVDev_zway_19-0-128",
    "ZWayVDev_zway_19-0-49-1",
    "ZWayVDev_zway_21-0-128",
    "ZWayVDev_zway_21-0-49-1",
    "ZWayVDev_zway_24-0-37",
    "ZWayVDev_zway_24-0-49-1",
    "ZWayVDev_zway_24-0-50-0",
    "ZWayVDev_zway_24-0-50-2",
    "ZWayVDev_zway_24-1-37",
    "ZWayVDev_zway_24-1-50-0",
    "ZWayVDev_zway_24-1-50-2",
    "ZWayVDev_zway_24-2-37",
    "ZWayVDev_zway_24-2-50-0",
    "ZWayVDev_zway_24-2-50-2",
    "ZWayVDev_zway_24-3-49-1",
    "ZWayVDev_zway_26-0-113-7-3-A",
    "ZWayVDev_zway_29-2-49-1",
    "ZWayVDev_zway_30-0-37",
    "ZWayVDev_zway_30-0-49-1",
    "ZWayVDev_zway_30-0-50-0",
    "ZWayVDev_zway_30-0-50-2",
    "ZWayVDev_zway_30-1-37",
    "ZWayVDev_zway_30-1-50-0",
    "ZWayVDev_zway_30-1-50-2",
    "ZWayVDev_zway_30-2-37",
    "ZWayVDev_zway_30-2-50-0",
    "ZWayVDev_zway_30-2-50-2",
    "ZWayVDev_zway_30-3-49-1",
    "ZWayVDev_zway_36-0-37",
    "ZWayVDev_zway_36-0-49-1",
    "ZWayVDev_zway_36-0-50-0",
    "ZWayVDev_zway_36-0-50-2",
    "ZWayVDev_zway_36-1-37",
    "ZWayVDev_zway_36-1-50-0",
    "ZWayVDev_zway_36-1-50-2",
    "ZWayVDev_zway_36-2-37",
    "ZWayVDev_zway_36-2-50-0",
    "ZWayVDev_zway_36-2-50-2",
    "ZWayVDev_zway_36-3-49-1",
    "ZWayVDev_zway_4-0-113-6-Door-A",
    "ZWayVDev_zway_4-0-113-7-4-A",
    "ZWayVDev_zway_4-0-128",
    "ZWayVDev_zway_4-0-48-1",
    "ZWayVDev_zway_4-0-49-1",
    "ZWayVDev_zway_4-0-64",
    "ZWayVDev_zway_4-0-67-1",
    "ZWayVDev_zway_5-0-37",
    "ZWayVDev_zway_5-0-49-1",
    "ZWayVDev_zway_5-0-50-0",
    "ZWayVDev_zway_5-0-50-2",
    "ZWayVDev_zway_5-0-67-1",
    "ZWayVDev_zway_5-1-37",
    "ZWayVDev_zway_5-1-49-1",
    "ZWayVDev_zway_5-1-50-0",
    "ZWayVDev_zway_5-1-50-2",
    "ZWayVDev_zway_5-2-37",
    "ZWayVDev_zway_5-2-50-0",
    "ZWayVDev_zway_5-2-50-2",
    "ZWayVDev_zway_5-3-37",
    "ZWayVDev_zway_5-3-49-1",
    "ZWayVDev_zway_6-0-113-7-254-A",
    "ZWayVDev_zway_6-0-64",
    "ZWayVDev_zway_6-0-67-1",
    "ZWayVDev_zway_7-0-49-1",
    "ZWayVDev_zway_7-0-64",
    "ZWayVDev_zway_7-0-67-1",
    "ZWayVDev_zway_9-0-113-4-2-A",
    "ZWayVDev_zway_9-0-113-4-6-A",
    "ZWayVDev_zway_9-0-113-6-Door-A",
    "ZWayVDev_zway_9-0-113-7-3-A",
    "ZWayVDev_zway_9-0-113-9-1-A",
    "ZWayVDev_zway_9-0-128",
    "ZWayVDev_zway_9-0-156-0-A",
    "ZWayVDev_zway_9-0-48-1",
    "ZWayVDev_zway_9-0-49-1",
    "ZWayVDev_zway_9-0-49-27",
    "ZWayVDev_zway_9-0-49-3",
    "ZWayVDev_zway_9-0-49-5"
piet66
Post by piet66 » 12 Feb 2019 12:19
I removed all old devices.
config.json size has shrunk from 517,1 KiB to 244,0 KiB and start of z-way-server is much faster now.
tomshuette
Post by tomshuette » 17 Feb 2019 12:47
How removed ?
piet66
Post by piet66 » 17 Feb 2019 15:45
- Wrote a tool which stored an array of old device-ids to a file.
- Added some code to updateBackendConfig.js to read this file and remove all entries from config.json
- Restart
